- Tranny: Problem never heard before, please advise!
- alt problems
- Paint Job
- I think its time to sell...
- VE Dipstick Question
- Side Mirrors?
- Washer fell in spark plug hole.
- sounds like I have a BOV!
- Fuel injector wiring
- front valve cover/head noise
- Spindle differences
- What can I say..ebay link
- steering wheel suckage
- found this on ebay.
- Failed Fuel Injectors
- Whining Noise from Front
- Sign of tranny going out?
- Need more power.
- 3rd gen Villager/Quest owners (ecu where)
- Just bought another Maxima
- Engine Coolant (antifreeze) Leak
- Clean injector plug terminals
- Heater core, where is it on these cars?
- My cure for hesitation
- new tires worth while selling maxima?
- Leaky ABS unit
- quick question about intake manifold
- AC controls stuck on heat!!!
- Wierd rattle. NEED HELP BAD!!!
- Replacing Control Arms and Minor Rust issue..pic*
- How much money is invested in your 3rd gen Max?
- One-piece BMW Halos and clear corners...pics update!
- Clear headlight film to protect wades???
- engine dress up kit???? anyone seen this??
- Edmunds TMV: Our car is worth...
- Drove with parking brake on
- Strange
- VG30E(T) Adjustable Cam Gears
- Too Hot to Work on Car!!!
- Stupid VE Dipstick Thread
- Those with aftermarket clutches! Enter.
- Replacing Control Arms and ST Sway Bars
- Fitting the 93/94 srs airbag wheel onto a 91 max?
- belt size for ASP udp?
- Do these chips really work?
- digi/anal gauges
- She's down....................................loooowwww :-)
- Sunroof shade problems. Help!
- Y-pipe problem
- VE cluster in my VG
- Justa warning to all of us: radiator hoses hazard!
- Valve cover gasket sealant
- Dust Cap?
- Todays photoshoot (56k beware)
- Air Bag Challenge...
- Sign of bad alternator??
- Help...92 maxi, Power lock problem
- Where are the VG sensors
- I know I dont post much but...
- turn signal indicator bulbs
- Some project pics (rust!) 56k no way!
- Axle Problem...
- Repost : heater/ac lights are dim at night-time
- rear suspension tower brace
- Acetone-duct tape residue removal
- Advice on possible purchase VE5
- Exhaust Studs Finally Replaced
- Foglight Question....
- Brake Master Cylinder Swap
- Auto Transmission fluid flush on a 93 GXE.
- Stiilen
- Spark Plugs G-Power
- Great New sources for Maxima Info...i think??
- cooler thermostat
- Bad dont know what happened yet!
- only running on 5 cyl
- oil pan replacement
- Made one window regulator out of two
- more exhaust bolt repair ???
- TB sensor question.
- Check engine and oil light lit up on dash, followed by a dead battery..in that order
- Fan Belt
- help, 92gxe to 89se
- So.....can anyone here in SoCal help me out?
- I Finally Did It. Installed e36 lights.
- Hard shift; worth fixing?
- How to get a new key cut for 92 SE?
- Injector additives
- found feature on accident
- New wheels for my '90 SE
- cabin air filter???
- Rear brakes - does piston need to be turned back in?
- Dashboard lights out
- Has anyone insalled a Quaif Differential on a 3rd gen?
- Factory alarm
- quick question here...
- That K&N really worth it?
- gauge needles stopped working....
- lopey idle
- VG TB water rerouting.
- Cleaned out engine bay
- #$&%@ foiled by the dealer parts guy - wrong seal
- Strange power locks issue
- Some pics of a recent project I have been working on (56k beware)
- Broken Pintle Cap
- Corner Light Rewire Keeps Blowing Fuse???
- Questions. And Answers that work.
- sway bar bushings
- It's finally here!!!!
- It's dead.....
- Just found this on my PC
- Crankshaft Position Sensor (VE) & VTCs
- How to get fuel injectors out of rail?
- i must say
- Help something bad
- Climate Control LED
- R12 vs r134 systems
- New front axles and now a vibration
- Door Panels
- 2 Quick Questions
- 1st Thread
- Wtf Was He Thinking!
- While I got my trany out, what should I look at?
- An Easy One !
- 240sx wheels...
- radiator?
- Sunroof vs no sunroof
- Antenna Prob.
- Making plans for VTC and Clutch install need help (long)
- Injector Stuck!?
- AC Compressor
- 93 maxima
- '94 DOHC in a '93?
- How to remove screws in fuel injector caps?
- Wont start and have run out of ideas
- Starter and maybe tranny problems???
- E36 light pictures?
- automatic a/c control
- LSD Problem?
- Blown Injectors (on both Maximas at the same time)
- Driver side door wiring question (trunk)
- VE5 tranny on a VG auto
- Car Cleanliness
- Window problem.
- OEM Spoiler Install
- bought a pair of lights Need Someones Help
- Bit The Dust!
- quick q
- 1993 Maxima Runs rough
- quick tranny question
- Replace Springs with Struts or no?
- Bad o2 sensor?
- WTF? Enkei RS6 + SMALL pothole at 25MPH
- Minor(?) rust..how to handle? (pic)
- Say hello to my aussie max
- My maxima gave me a pleasant surprise today.
- Replaced knock sensor and injector, now wat?
- Steering Wheel Removal?
- What's New
- Has anybody done this?
- Installed VE tails...looks "different"
- Best Aftermarket Speakers For Stock Bose???
- 3rd gen leather care?
- the million miles mark
- A/T additives?
- NE1 ship a Stillen Lip? How much? Folded?
- leaking ABS actuator.....
- Msd ignition, loud horn
- from 3rd Gen Maxima to BMW 3 series
- I replaced my window regulators!
- glad the inspector found this problem! (pics inside)
- failed state inspecition and not very happy...
- How to clean out hvac air ducts inside the cabin
- Short throw shifter
- Symptoms of bad springs?
- need a steering rack or rebuilt kit
- fuel injector test?
- Can Anyone help???
- Replacing VE water pump
- Chasing Down an Electrical Issue
- Help! Oil Light only on U turn.
- window problem
- Hi i need help
- sticking throttle body
- Strange buzzing from new exhaust
- Can I Jump Wire an Injector?
- Clutch question?
- Have you Adjusted your Koni Struts?
- Rear caliper and rotor capatability 90 to 94.
- i got owned by a caliper....(see inside for details)
- How many Green/Black/Silver Wires are there?
- Valve?
- abs light
- Tranny woes @ 149k, horror inside...
- How do you hook up Amp-Meter?
- Wat Color Would Look Best On Maxima?
- where can I find polyu bushings for fstb and rear stabilizer
- Fstb???
- Should I keep it?
- Delayed Shifting
- Anybody run the ST Struts on their 3rd gen?
- For all the mn people who wants a ve 5spd.
- FSTB for VE
- What would you do?
- someone EMAILED ME? lost ur email
- how can I tell if its LSD?
- Code 34 and 51
- yellow fogs??
- Rebuilding heads
- who is this
- bose speakers
- Eibach springs with stock struts?
- New in here with some doubts, looking for help!
- Replace auto climate control with manual one
- Intake Manifold Spacer
- Window regulator/power window motor?
- Steering wheel question
- Hey guys, back in town.
- Cam Angle Sensor Testing
- Does anyone have pics of....
- Any1 ever do a VG auto or 5sp to VE5 swap
- New Chrome Gauge Rings (Pics)
- Work in progress: Questions
- bad injector????
- $58 per lifter!?
- Paint/Bodywork prices
- Low Mileage VE, whats it worth?
- San Antonio, TX - Blue TURBO max with Stillen Kits and FMIC. On Nachodoches Rd. Who?
- All The Time Lit Speedo
- pioneer ipod adapter
- busted timing chain
- Digi climate control problems
- Well it's parked now.
- How do you remove the STEERING WHEEL?
- Disaster!!
- WHo here has made their gauges brighter?
- Step 1: Strip car
- Pics Eisenhower Meet 6/17/06
- Positive cable
- Noisy Brakes
- dead ve :(
- se gauges on Ebay
- another one down pic inside
- 149K-Time For JDM Swap
- Back on the road
- Time to say goodbye
- o2 Sensor, will this fit?
- bracket
- Funky noise
- Hmmm....very strange pictures
