PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 [91] 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Y-pipe n Pulleys
  2. Looking for a walk through
  3. fair price for conversion?
  4. y-pipe diameter
  5. Door making loud noises when opening
  6. Question About Viper alarm
  7. Quick question
  8. Ok guys, I need advice.. what would you do?
  9. Tragic boating accident
  10. Airbagged steering wheel removal
  11. Heater doesn't heat up!
  12. Maybe Nissan Should Have Required Premium for 3rd Gen
  13. Pop Charger Question...............
  14. Any foglight pics?
  15. Amp rack
  16. Not The Average E-36 Question
  17. loud sound
  18. Non-ABS = Sliding into a Blazer
  19. Keyless Entry Question
  20. overheating...tried to fix it but i dunno??
  21. Sounds like my door is going to fall off
  22. Condenser and drier.. which brand to buy..?
  23. Noise when turning left - help
  24. No more exhaust leak....
  25. Audio help?
  26. What is a good strut/spring combo for the front?
  27. EGR in 92 SE
  28. Seat belt light comes on.
  29. Yet another VTC question, a little different this time...
  30. Scratches painting
  31. Tube question
  32. Fan not turning on!
  33. shift and brake boot
  34. strut and rear disk conversion questoin
  35. Bumper Lights Question
  36. Anybody have this problem?
  37. Pics of what I did today....
  38. Offset and other questions (PLEASE HELP!!)
  39. 2 Problems =\
  40. What are the raidio dimensions?
  41. 92 SE hose size?
  42. polished valve cover/ intake manifold?
  43. Does anybody have a pic with Eibach pro springs?
  44. Resonance Frequency
  45. A.c. Question..................
  46. Is This True Or Not ? ? ?
  47. VE exhaust studs
  48. Upgrading Handling
  49. Fuel Gauge
  50. turbo manifolds
  51. Greased Lightning Auto treatment question
  52. Sprint n Kyb gr2
  53. Odd problem
  54. which rims looks better
  55. platinum tint
  56. I need a reality check!!!
  57. Just replaced fuel filter, wondering how many more MPG I will get................
  58. VG ticking pla Help
  59. RearView Mirror - Hot Sh*t!
  60. air/fuel gauge install???
  61. thermal research and design mufflers
  62. Worth polishing the stock GXE rims?
  63. Updates On My Car....
  64. VG30E GXE Maxima Radiator Hose Replacement & Coolant Flush
  65. 5speed conversion on 3rd gen
  66. security lock-out help!!
  67. Did I Leave Anything Out ? ? ?
  68. subs
  69. Foglights
  70. Stereo Buzzzz!!!
  71. Can't get an ignition coil out
  72. Buying a 1994 Maxima...potential problems?
  73. Stupid headlight problem---kind of long--
  74. first mods???
  75. VTC assemblies and Mobil 1?
  76. will 4th gen struts fit 3rd gen?
  77. 91 maxima question...
  78. 91 se Valve Cover Removal
  79. a sad day in WV...
  80. What should I pay?
  81. Maine
  82. window problems
  83. Fuel Return Line Repair
  84. Alarm/electrical issue
  85. recall????????
  86. Making tthe VG faster????/
  87. Clutch & Flywheel talk: Calling all VE 5sp owners..
  88. VG Auto - Advance Timing - Yay or Ney?
  89. tranny noise (VE 5sp)
  90. what causes the tranny to slip?
  91. remote starter??
  92. 6"x9" in rear deck
  93. Cruise control is not working ?
  94. Search Is Up! And Running Can I Do This?? Can I Do That Questions? Newies
  95. For those with ST Sway Bar Kit
  96. OEM Alarm Question
  97. Tell Me What You Guys Think
  98. Bigger TB for a VE?
  99. Need advice with AC problem Please help.
  100. Anyone need the stock bose speakers?
  101. seatbelt problem
  102. sea saw power loss?
  103. See if you can solve this one
  104. Mods - Semi-Easy and/or Semi-Cheap
  105. Trying to replace my antenna, not as easy as the write up says!!
  106. Window Problems
  107. Since most VE members dont check the group by forums, here you go...
  108. For those with 6.5's up front....
  109. Problem with gauges but don't know what
  110. timing belt
  111. Antenna Question..............
  112. a few Q
  113. VG30DE vs VG30D (E) are they interchangable?
  114. How many O2 Sensor on 92 GXE
  115. corner lens bulge
  116. lighting up the maxima sign in the middle of the trunk
  117. 3rd Gen PWNZ0Rs
  118. almost a ticket
  119. EPROM Question
  120. Tel me how
  121. Transmission
  122. Climate Control & Key code Questions I might be able to answer them!!!
  123. seatbelt chime
  124. Really Tallll Attenna
  125. Its so nice to add new mods - ASP UDP and ST sways
  126. How do I fix my antenna?
  127. cat back sources
  128. Question about tires and springs (Craig)
  129. NEED HELP???? All with smoked or UK corners
  130. What Will Help my Low end???
  131. Just got pictures up.
  132. Any one near Woodbury, Long Isand, NewYork
  133. Why car stalls
  134. variable intake question
  135. 3rd gen crew of nyc pics lots of them also HIDs
  136. 92 se ignition coils
  137. intake mod help
  138. MaximaLess is no longer MaximaLess
  139. buying a max
  140. 1991 Cam Profile
  141. 3rd gens in magazines
  142. Possible dead maxima! Any ideas...? Everything appreciated
  143. Just browsing the Stillen catalog...
  144. Anyone put a volt meter in their car??
  145. Fuel Filter Location
  146. Fog lite replacements
  147. tokico suspension installation???
  148. advice on buying another MAXIMA --!!!
  149. Easy/Cheap Mods
  150. Will a leak in the exhaust affect gas mileage?
  151. Car polishing
  152. maxima handling
  153. Question - Neon Lights
  154. A/C rentention valve------HELP-----------
  155. cheap stillen lilp on ebay
  156. Test drove a VE 5 speed...
  157. magazine appearances?
  158. technical question.....
  159. $20 million dollar question (to be paid on Tuesday)
  160. VQ30DE swap for VE30DE
  161. HARDCORE DIY'ers, quick question
  162. WANTED: Grille
  163. Performance, comfort switch
  164. well mother nature got mad at my maximas last night
  165. Power Steering Squeak
  166. Question regarding HID and BMW lights
  167. vb mod
  168. cold air intake silicon hose?
  169. Maxima GXE 93 info ???
  170. cam shafts from cattman
  171. stillen rear cross drilled rotors
  172. whats that black regulator
  173. 2 max's and same seatbelt prob.
  174. want better handling?
  175. bose
  176. where to buy front struts
  177. question about my speed limiter
  178. want opinon on new rotors and pads
  179. Tok/Sprint Suspension setup
  180. Bushings, alighnment or what??
  181. NE1 ever used engine treatment llike zMax
  182. valve body question?
  183. tire size for 18x8?
  184. Well Somebody Broke Into My Car
  185. '91 Maxima - Possible Torque Converter Problem
  186. 92 SE differential question
  187. Ignition Upgrade Questions
  188. BMW headlight Question
  189. 1/4 mile
  190. For those who have done or planning to do a 5spd conversion is it worth it???
  191. To those who have Eibach's... please read.
  192. busted sun shade
  193. Where is the Idle Speed Control Valve?
  194. Strange clutch action
  195. How much to replace Vacuum lines?
  196. What are our wattage on our headlights
  197. quick question
  198. Hey all you EE majors....which resistor do I need?
  199. VI voltage question
  200. someone please help
  201. Paint
  202. foglight question
  203. What do you use for cleaning the seats?
  204. Diagnostics and coil question... HELP!!
  205. Transaxle Stuck
  206. Need Info On CV Joint Replacement
  207. Where can I get good cheap reasonable price for 225-35-18
  208. 92 SE Tranny Swap
  209. spark plugs
  210. whats our wheel offset??
  211. Clear Out Rear Blinkers?
  212. gas
  213. maf adaptor
  214. gas leak
  215. headliner removal
  216. ??'s about putting VG together
  217. Strut length question....
  218. nrw pics
  219. Suspensionmax.com shocks n struts???
  220. embarassing question
  221. Pics of blue leds in gauge cluster!!!!
  222. New rims
  223. Upper strut tower
  224. 1st max
  225. lug nut sizes
  226. 93 SE Clutch hydraulic fluid leak?
  227. Has anyone replaced a camshaft oil seal?
  228. Where is tranny speed sensor specifically located???
  229. Looking for photos on strut replacement
  230. Turbo VG guyz
  231. Axle Hub Socket Size for `91?
  232. finally both door handles are roughed in (pics)
  233. Door stuck locked, electrical
  234. Does a new engine always need a new tranny
  235. Is it bad to...
  236. will 2003 bose hu work on 93 max w/ bose?
  237. Is my 92 GXE auto equipped with transmission filter?
  238. What affects the gas mileage?
  239. Had a scary problem last night
  240. Interior Question
  241. What is PVC valve and why should I change it
  242. automatic seatbelt problem
  243. Is there such a thing as over done rice? (pics)
  244. another tranny problem
  245. Sway bar bushings
  246. A few new pics...
  247. new vg engine for 250
  248. 5spd tranny question
  249. Smoke from exhaust and stalling
  250. What are the cables under the seat?
