PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Spongey Brakes even after bleeding
  2. Clock no display
  3. custom coilover setup
  4. built ve
  5. Door Panel Insert Design Suggestions
  6. 93 SE BOSE System problem
  7. power more power
  8. Help in installing antenna mast
  9. Camshaft seal or power steering pump?
  10. IN need of a little advise
  11. Axle nut removal details
  12. Replace Manifold(s)? . . .or OBX headers?
  13. Blue VG on craigslist
  14. MISFIRE only when AC is on
  15. VG Flywheel anyone???
  16. exhaust / muffler
  17. the most rarest
  18. cruise control
  19. SoCal Maxima is up and running
  20. Is it really worth it?
  21. Washer reservoir replacement question
  22. Door lock escutcheon
  23. Possesed Temp Guage
  24. Farewell Maxima !
  25. Car Wreck!!! Now windows wont roll up????
  26. Look at what I did
  27. Around the engine. . .
  28. Sun roof
  29. Weird clunking sound when braking (axle problem?)
  30. air conditioner
  31. loud squealing is pissin me off
  32. ASCD not engaging
  33. HUD conversion
  34. Rear Speaker Problem
  35. Blue HID Lights in stock setup?? 8mm plug wires??
  36. crankshaft questions
  37. dealer parts
  38. wheel stud question! some help??
  39. I broke my Max doing plugs and wires.. WTF? need help.
  40. help turn signal and hazard not blinking
  41. Better performance by removing good O2 sensor
  42. Cleaning VE engine bay
  43. In One Year
  44. Lower Control Arm Nut
  45. Engine Cutting Out, Not Starting
  46. stance???
  47. so who remembers me :)
  48. Hit and run three weeks ago
  49. More injector joy
  50. Knock sensor: male or female?
  51. Putting a '92 GXE on the road after sitting awhile Questions
  52. Steering flops around on every little bump
  53. Transmission identification?
  54. Rear Brake caliper troubles!!
  55. Wiring up a Sound System
  56. Vacuum leak near the firewall side of the engine???
  57. Oil change
  58. True Max(3rdgen) Enthusiast!!
  59. Seat back getting loose...what to do?
  60. going crazy
  61. Clutch issues.. Master/Slave cynlinder? FSM?
  62. where to get 16x8" wheels with a +35 offset?
  63. loved her so much I had to let her go
  64. to those with "cleared" tail lights
  65. Fuel needle problems
  66. Have to wiggle shifter after putting it into DRIVE for the car to move?
  67. Polyurethane bushing question
  68. vg to ve swap?
  69. 3rd gen Maxima Lower Control Arm Bushing Replacement Tutorial
  70. electrical question - keeping cornering lights on a few seconds after turn
  71. Cars back up
  72. Craigslist Find...Fidanza Flywheel
  73. New Struts/Springs and axle. Which is best?
  74. R12 Recharge...
  75. VG blowing white smoke
  76. Upgrading Fuel Injector Connectors
  77. i just got mind****ed
  78. carbon fibre centerpiece
  79. Another Difference Question: Lower Control Arms
  80. Difference between GXE and SE Front Bumper Covers?
  81. gauge cluster
  82. What part is this behind the engine leaking coolant?
  83. Damaged pass side front door lock??
  84. Door Insulation Leakage
  85. transmission mount
  86. Getting to body work opinions???
  87. r-12 to 134 problem
  88. Coilover Damper System for 3rd gens???
  89. power steering hose replacement bracket
  90. What now?
  91. Emergency VE help
  92. Starter problems
  93. Cluster Question...
  94. Questions about my vq35 Max
  95. any have FAST that can get me a part #?
  96. Odd question
  97. Trunk does not open
  98. For Those Of You with Loose Hoods
  99. My maxima and all parts been replaced. (pic heavy)
  100. BOMZ
  101. surging fix
  102. Injector-Pintle Caps
  103. Cluster n tail lights off
  104. G35 Center Caps No Fit
  105. Mixed Cluster
  106. Alternator Swap
  107. 3rd gen alarm?
  108. Is this an alignment problem or something more sever?
  109. HELP! IDLES WAY TOO HIGH!
  110. We Have Parted Ways
  111. Climate Control Swap...
  112. 92 ve 5spd tranny issue help
  113. Bose Speaker
  114. wierd whirring sound, into 2nd gear lurch
  115. quick vg question
  116. Back together
  117. I30 interior in a 3rd gen
  118. Car doesn't want to start
  119. Anyone need a VE Auto trans?
  120. Some VE parts questions...
  121. color change
  122. Back in a 3rd gen! VE5...
  123. Knuckle bolt (camber)
  124. 5th gen subwoofer
  125. short shifter?
  126. 3rd Gen Wheel Well Splash Shield Clip Upgrade
  127. Inner tires wasting.
  128. suspension advise
  129. Time to Upgrade My 6 Month Old CM Muffler!!
  130. Digital Instrument Cluster
  131. Aluminum Radiator
  132. In Drive with brakes and Still pulling
  133. Wheel Bearings...?
  134. VG vs VE and SE questions
  135. What Kind of Wheels should I get for My Max??
  136. new parts!
  137. 91 se parts car
  138. 89se vg30e to ve30de swap
  139. would not believe
  140. Couple of annying issues with the max!!
  141. 93/94 Green Dot Injectors mixed with Yellow Dot??
  142. Styling
  143. Crappy Trim
  144. 94 Max Pink/Green Dot Oval connector injectors needed.
  145. Semi-retiring the VE-5
  146. "89" Automatic Transmission help please!
  147. Interior Lighting Information
  148. Car hums at stop lights or in traffic?
  149. tps
  150. RC Engineering (Fuel injector cleaning)
  151. Upgrading to Optima Battery...
  152. Understanding offset
  153. Rear strut mounts
  154. window tints
  155. Finding an Automatic SE..
  156. extended studs??
  157. What an awesome day (enhanced sarcasm)
  158. Will VQ30DE injectors from a 95 work?
  159. Vacuum hoses
  160. Maxima's 1989 Intoduction of the 3rd Generation
  161. tps
  162. Anybody familiar with Stanzas?
  163. Sloppiness in steering...bushings?
  164. wanted to know
  165. Congrats Aaron for the article in Nissan Sports Mag
  166. rack and pinion and sway bar bushings
  167. I am back into a 3rd gen....:)
  168. Brake Mod
  169. windshield wipermotor and hose
  170. How Much to install a Rebuild Automatic Transissionin 94 Maxima GXE SOHC
  171. Some questions
  172. fuel leak... ugh!
  173. CV joint busted??
  174. The Rear Caliper
  175. factory freak idle..??
  176. Adjustment to Camber
  177. Sonar Suspension System
  178. First time for everything
  179. Driver's Side Power Seat Belt Malfunctioning!!??
  180. Anybody still have JN1EJ01P5NT102532?
  181. Master Cylinder or brake booster failure??
  182. Anybody Got The Eibach Pro Alignment Kit??
  183. fuel overflow or leak
  184. brake pads
  185. RTV on PCV valve threads?
  186. unknown relay?
  187. K&N drop in filter question
  188. check out this 86 maxima
  189. Cattman December Discount Sale in Group Deal
  190. bye guys!
  191. digital gauge cluster problems
  192. Fresh vent door cable
  193. Turning the wheel makes my rpm's drop?
  194. Door SEals, Weather stripping??
  195. How-to add parking lights to your front bumper
  196. Broken exhaust stud/drill out/helicoil experts step in (long)
  197. The VE Gets a New Home (Very Pic Heavy)
  198. Rear strut gland nut removal
  199. front calipers and rotors rusting?
  200. Synthetic Oil Vs. Conventional Oil Vs. Synthetic/Conventional Blend Oil.
  201. fuel tank capacity
  202. Random stalling during stops
  203. Rear oil seal retainer gasket?
  204. Scrap wood FTW
  205. temp guage moves at its own will..........
  206. Does this transmission mount look bad to you guys?
  207. good bye to third gens
  208. Window Motor
  209. Could the O2 sensor/O2 sensor wiring cause the fuel pump fuse to blow?
  210. what rims fit our car?
  211. A few issues, Please help....
  212. Aux in wiring
  213. Tutorial on installing lowering springs?
  214. "Restored" OEM wheel with Duplicolor wheel paint
  215. Ready to drop my motor in and I find this..
  216. Antenna Question
  217. Win a Sony Playstation 3 (PS3) or Gran Turismo 5
  218. Price quotation from les schwab
  219. Crunching on the Driver side
  220. Car Running Rough At Low RPM & CEL (Injectors?)
  221. 92 GXE won't start some times, won't turn over
  222. Check Out This Clean 93' SE With a VE
  223. Leather seats for my (almost) Base GXE
  224. 2004 maxima wheels
  225. AT shifter issue, need help
  226. So....
  227. Suspension refreshments
  228. Quick compilation of parts for my turbo setup
  229. Will RB25 injectors fit a VG30e?
  230. 93 just died on freeway, now wont start.
  231. cool car
  232. How am I supposed to remove the ignition cylinder?
  233. Sudden rough idle + sulfur smell?
  234. Lower radiator support replacement
  235. which rotors should i get?
  236. So my dash is possessed
  237. Anybody hook up an aftermarket fuel pressure regulator??
  238. Brake Pedal super Spongy after complete Bleeding - Need Help NOW!..please :)
  239. 425WHP Sleeping Road Warrior build thread
  240. Rear Brake caliper Problem??
  241. A/T fluid has bubbles on dipstick
  242. header and downpipe
  243. Coolan circulation problem
  244. engine shakes when i accelerate
  245. whose VG/VE are these?
  246. Cam upgrade in a VG30E
  247. Blast from the bodykit past
  248. New Climate Control
  249. Possible short? 89max
  250. Interchangable Parts
