- does aftermarket y-pipe cause hissing at higher RPMs?
- piezo question
- What now!!!!
- Round fogs
- Tires Flexing :(
- Failed emissions
- My 90 VG Idle's @ low rpm when engine is cold
- vacuum hose diagram....or pic
- I Hate Saturns
- since nobody else posted pics of the gauge pod here they are...
- Chilton site down! need code procedure..pretty please
- Pics of a crappy Maxima: Good for a few laughs if not a few tears..
- Oh GNOES!!!
- y-pipe fitment
- I am going to replace the fuel hose to the rail
- codes?
- Paint/body shop in S. Cali?
- The VE crank is cast right?
- problem with hose
- Need to locate the Modulator Valve!!!
- Check air bag system after 10 years??
- My Pics are up, Come on in!
- ran with gtech over 300hp@8psi!
- suspension upgrades
- Thermostat Changed heat still sucks! Help Plz
- Interior Lights (OLD)
- driverside window problem
- audio recordings of my car
- Best place to mount tweeter?
- bleeding coolant system
- muffler on a ve
- question to all that have done the E36 conversion
- Moans & Groans
- Headlight covers
- Phillips Vision Plus
- "new" grey tweed seat covers
- custom ve turbo..**pics**
- E36 conversion done in 2 hours
- Cat-back Exhaust
- turbo
- weird problem?!?
- aftermarket oil pressure guage
- need some info plz (people who did headlight conversion)
- clear corners
- Crazy instrument lights
- aero turbine muffler???
- Just got it from the tranny shop,
- Just got e36's
- Any one who got a JDM VG
- fluctauting idle when cold??
- VG30E- Are they all the same long block?
- in need of a 92 transmission!
- Matt's Product of the Week- reinforced RSB Links!!!
- Gauge Lighting Problem!!!
- ticking under acceleration?? valves? vtc's? HELP?
- Misunderstood
- Wheel Spacers
- new alternator?
- Heater Core is gone.........You're kiddin me!!!......
- Clock has a mind of its own.
- Heating probelm H E L P!
- VG30E supercharger
- Power window problem...not regulator
- any good car shipping company?
- 1990 Turbocharged
- Factory remote starter, trunk opener stop working
- Aftermarket gauge install
- Strut and Spring install.
- need clutch & tranny advice!!!
- Would these work for big brake setup?
- for those who don't have a muffler
- Need short stack intake
- Diagnosis: “Low compression on cylinder 1”
- strange water flowing sound
- Thinking of selling Max. how much should i ask?
- NGK wires dont fight tight enough :(
- High flow Cat and Muffler question, HELP
- need edvice please!!
- Keypad Problem
- Gas Leak from Top Front of Engine
- Manifold Studs: Question
- fuel rail/injector o ring leak- how much $
- Yeah
- H.I.D. compatability
- i found something cool, need advice
- Another e36 question...................Yeah I know.........
- Springs and Shocks
- JWT cams for VG30E
- Noise under the hood
- power steering hose and radiator
- Whats the best bang for my buck?
- missing antenna
- Stock Muffler
- intake problem
- Pwr Antenna Replacement Problems...
- Power steering pump filter?
- motor and trannie longevity and where to find rebuilds of both?
- Replacing CV Joint - Any Gotchas?
- time to replace my tranny?
- Very Very Cold -7 F
- Addco RSB owners
- Rear Speaker brackets.. Need 6.5 have 6x9
- Does Nissan Service Center Carry Screws?
- Where to get a SS tube for intake
- How much to replace the wing on a 91SE?
- manual tranny ?
- Disabling VTC's
- How much should I estimate?
- Highest wattage for e36 lights
- meeting for the LA autoshow 1/10 sat....
- I'm gonna go nuts
- some help here pleeze
- updated cardomain w/ pics
- Who has an Alpine head unit on their 93 max? problem with fitting.
- engine/exhaust mods
- I hate it when this happens
- Looking for a tranny
- Odometer not resetting
- *****Gauge Pod Pillar Update*****
- Ve + Cai + 18º = :)
- Used front bumper cover?
- how is your max in the snow ??
- How is the view at night with e36's?
- What grill is this?
- 92 SE injectors
- Rattling from engine when key turned to ON only
- fault injector (again). need to replace gaskets?
- How to remove digi climate control
- I saw 20"'s on a 91 MAXIMA
- Will this fit our car?
- BMW E36 conversion headlights
- matt's rstb reviewed once again
- exhaust system setup?
- Tach quit working
- fuel rail
- Another Grommet Question
- Throttle body cleaning (extended)
- Fuel smell inside car
- leather seats
- big problem
- Model car for you 3rd GENers...
- power/comfort switch question
- Starter motor & extreme cold..
- Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Appropriate tire pressure
- Help with car problem
- Ok its the 7th
- 1992 Maxima hesitation and lurching problems
- need pic of underside of car
- Defroster question.....
- JDM vs. JDM
- Thermostat Replacement
- Clutch problems
- No heat when ECON is on, blowing snow and engine smell through vents...help
- Sound of water moving
- is this a good deal? please help! (rims)
- sequential shifters
- Firewall Grommet Question - Where to run wiring through?
- Cold Weather Effect!??!
- HELP!!!! My Brakes are gone!
- Charging System Issues
- Got in an accident - the car won't start!!??
- Replacing Camshaft seals
- People with lightweight flywheels
- OMG Maximasechs! (PICS!)
- do our cars come with block heaters?
- I want better lights
- Crusing Speed II with PICS
- Ratteling from the rear pass. side!?!?
- amplifier board for 92 max
- Sylvania Silverstars
- HELP ME! I think I just broke my muffler!
- Blower stuck on high...
- Driver's Door Hinge Problem
- Transmission Question
- why reset the ecu? (exhaust)
- Window Help~!?
- VE auto tranny slipping in first gear
- doesnt wanna go over 3000 rpm ?
- Will it rub??????????????
- okay here goes
- won't go in reverse?
- Rear turn signals
- lowering the seats
- brake light!
- Buddy Club Suspension?
- new exaust
- Will the back seat from an 89 fit in a 92?
- VE Max is a hot commodity!
- tranny f*ing up only in second
- vg tranny swap
- Taking apart the fog lights....
- Some simple pics of the 13" Cobra bracket and caliper
- Tranny Problem
- Motor mounts
- Check engine light
- is it just me? or am i the only one with HUD??
- shes dead!
- Look at this MAX!!
- Is this intake for the ve?
- Door lock problems--also Help!!!
- need motor help
- KeyLess Entry Problem , please help stuck outside car
- Auto trans fluid
- Sunroof clip?
- Mechanic Needed in San Antonio
- 92 rear speaker installation
- New seat cushions for front seats?
- More about my starter, yeah I know calm down
- where can i get an UDP for VG?
- Throwout Bearing Differences?
- the right offset
- Seat Neons Project...Yes?YEEEEESSSSS!!
- anyone have bose 6x9 brackets they wanna get rid of?
- what 300zx brake master cylinder to use??
- a31 cefiro headlights
- Dual Exhaust
- Anybody With Valve Body Mods ??
- Info On Changing Brakes:pads And Rotors
- Power Steering Pump Leak
- Transmission Transplant...
- Thermostat question
- Max runs rich - O2 sensor?
- 89 and 90 rear speaker installation
- IACV and EGR Questions (Turbo guys read)
- Need help deciding on new front brake setup...
- whats the model of yellow optima battery for our car?
- HELP!!! I need detailed instructions and pics on how to put in a CAI in a vg .......?
- newbie here
- dual exhaust..to do or not?
- How to replace drivers mirror?
- couple new pics
- Sprint springs for $140....Worth it?????
- how do you tell if you have blown your engine?
- Operation Parts Car (pics)
- Where could I hook up neons?
- stock suspension/ safety question, pelase help!!
- Say... I found some leather...
- air/fuel meter
- 1991 Nissan Maxima Starting Problem
- What is the normal Cruising RPMs?
- a couple concerns????????
- Help locating headlight sensor
- Whos CAR???
- How to get sunroof to open
- E36 Headlights
- Tight vs. not-so-tight steering
- Replacing struts on a 94
- Evaluating High Mileage '92
