- 3rd and 2nd gen option comparison...
- heater core dilema
- UDP, pros and cons.
- weird noise..
- Help
- customizing tail lights
- nitrogen in tires-better gas mileage
- VE troubles
- Head gasket replacement
- Tire Wear
- tie rod question?
- Y-Pipe bolts?
- Manual trans question
- No signal lights normal?
- A/T Tranny Oil Change - THE blk hole in FSM
- Got in an accident- cheap place to get rear bumper?
- Power steering pump problem?
- i want to change my auto trans fluid but wheres the filter????
- Need Quick Help! Back Right Window Does Not Stay Up!!!
- another max in future??
- HOW DO YOU SET U Engine at TOP DEAD CENTER?
- Hey admin. What's the deal??
- Diagram please sombody help
- Don't be fooled with the VE30DE timing chain reliability.
- will a vg 5 spd fit a ve 5 spd engine?
- Some scumbag stole my car!!!
- Those with short throw shifters
- 94 GXE not Starting**Replace w/ O.E. Fuel Pump vs. Walbro Fuel Pump?
- what should i use to fix my broken exhaust pipe???
- Stillen Front Lip?
- VG owners: Gauging interest KALSC Turbo kit
- Installed UDP, first opinion.....
- What should I use to fill my motor mounts?
- This is it guys...
- Going to purchase a flywheel...some questions.
- New Pictures!
- New Pictures!
- '93 GXE might undergo a VE transplant
- She Just Dies
- Wiring advice needed.
- My maxima is hit its end
- How you ride that clutch....
- Should I have buyers remorse?
- Corner Lamps and Instrument Cluster Lights Out!
- Whining sound on idle
- Concerned About my Perfomance
- pic of 3rd gens on 18 or even 19's
- Bought another maxima, have some questions
- Yep shes gone
- can u mess up a auto trans by over filling the oil?
- JDM Engine Owners, hows it going?
- CV Joints
- In Over My Head, Perhaps!
- VTC's or something else?
- axles and lowering
- Dropped the engine-n-trans today...
- I got a set of Sumitomo SRIXON4 for $40, are they good?
- Timing belt changed
- Maxima go buh bye :sadwavey:
- Need to rig a kill switch. Suggestions?
- I think this mod I did to my 4th gen will work for you guys...
- kak kak kak!!!
- Steering pull
- Low fuel pressure
- 92VE Every Gear loses power dramatically
- Catalytic converter going out now!?
- iacv replaced
- LSD on VE 5psd.
- Coolant flush Q.
- RPMs drop slightly when the fans kick in - bad alt?
- BOSE system amp bypass?
- ebay strut bars
- car dies....pretty funny
- Fuses
- Tranny Cost Questions
- long time to crank and whining alt
- front stablilzer bar bushing gone out (pic)
- Missing Link
- Rims Rubbing (2nd problem of the day)
- Engine Fire!!!
- A$$hole hit my car and left.. need lil help
- 91 SE AT Worth Selling?
- Automatic Seatbelts+Power Windows stopped working..
- shifter bushing?
- Need Maxima Color Codes and Pictures
- mmmmm....new struts and arms
- Someone nab this car!
- Changed Vacum hoses and then got a bad idle!!! Please Help!
- Quick engine question
- transmission impossible
- couple tranny questions
- 3rd gen parts
- Growl...so replace....repair...hmmm...
- Please Help
- should i replace transmission or repair it?
- Full Cold Switch And Heater Solenoid
- did my dash tonight (titanium silver)
- I'm back
- lots of vg manifold stud replacement pics/ 56k, get some cereal
- GXE Electronic Suspension
- ECU Saver
- How much time for...
- SE & GXE Tiebars the same?
- Shop??
- do i need new window motors?
- show me pix of painted dash pieces or dash kits
- My First Maxima also a great deal IMO, what do you think..
- ***Off Topic Posting***
- Any idea why I get low idle sometimes at stop light
- my max wont haul a** anymore
- TDC question
- got my cardomain page up
- Horn quit working
- :sadwavey: Black Maxima
- aftermarket shifter knob for autos
- a question for you smart people
- Reliability of 3rd Gen Maximas
- Burning smell
- WTF is up ???
- springs
- Fuel Pump Controller... do our cars have one?
- Place Racing still doing business?
- What do you guys do when you need a bolt or nut replaced?
- Cryo treatment
- 300 ZX parts in our maxima
- nissan parts desk question
- save some cash?
- Fuel Pump Question
- Non USA Toyota YZZF2 Filter... *PICS 56K BEWARE!*
- Stanza maf adapter...
- Injector Removal
- Poll: Stock SE centercaps
- door sills shiny look
- Spedometer issue
- need help with a parts source
- Installing new rack and hose, do I need new pump?
- weird noise
- My brights are gone. Headlight switch part #?
- please help me get my max back on the road.
- tranny filter
- where can i buy a body kit online for my 91 max
- 1994 maxima FSM pdf files!
- Got a crack in one of the lights in back? Replace it!
- Auto Climate Control/HUD Install
- ECU wont power up sometimes...
- maxima parts car on ebay
- VE valve cover gasket
- trunk release
- Just got my oil leaks fixed, now there's a BIG problem (Kinda Long)
- missed you guys
- Error codes 21 and 33
- 2nd gen AT work with a 3rd gen VG?
- Done Something DUMB, but I don't know!
- Your 3rd gen ever leave you stranded?
- any 3rd gen videos?
- strut replacement options
- Alarm?
- One issue down, a few dozen more to go...
- Help!!! Need Part # info!
- 91 Maxima SE with 28k
- coilovers
- Are complete one way mirror tints illegal?
- any one knows web sites where i can buy parts for my max
- bent rim and stuck valve stem
- Electrical Problems, No ACC
- A/C bleed?
- power antenna makin noise
- odometer question, please help...
- Good Place to Find Used Max?
- 1992 in Auto Locator
- pulling codes?
- no hazard lights but turn signals work?
- PCV valves help
- Great Deal on a Max in NJ
- abs problem
- Wash car and now no lights!!
- Power Stearing Fluid Leaking
- stupid mistakes are costly
- Lower Control Arm Bushings
- how to lighten the max
- finally secured my sub box
- A cooling Q, and yes I searched...
- Timing Belt Change?
- How much did auto-to-manual swap cost you?
- new pix of rear lip (bad quality pix, sorry)
- tranny really getting bad
- Power steering hose leaking
- backward compatability?
- O2 Check Engine Light Issues.
- Looks like Im back :)
- Cefiro Question
- Bose Radio
- Hey all, thought I'd stop by and say hi!
- general info on Bose amps
- i need help removing driveshafts?
- cloudy headlights
- How does cruise control work?
- RPM drops to 200~400 at the light
- Shifting Problem...
- Check out my 200$ maxima se
- flush mounted bimmer lights, pics inside
- BRAKES?? Need Help
- Lost all pressure in my clutch
- On the pipe....
- Found some pictures(Now I need to find my car.)
- Strange sound coming from dash? Any thoughts?
- Front end noise, Ball Joint or CV?
- anyone heard from awsm66?
- Warpspeed Y-Pipe
- Speed sensors for different years
- How Far - with one gallon?
- radiator resavoir
- Hmm, MAF issues? '92 Maxi
- Possible or waste of time (lighting Q)
- Help with GXE alarm and trunk sensor.
- i need a new clutch
- Brake Job
- ACC Question
- Just Some Pics of Max
- CF hood?
- Rear wheel arches
- pathfinder bose hu question
- Adjusting rear discbrake help
- heater core
- Wiring problems?
- how can i tell if timeing belt snaped????
- Brembro blanks and increased performance...
- Help a friend, help a friend
- Rear drum seezed up...Help!
- low idle still
- Philadelphia dyno day
- Tempature gauge rises while idling
- E-brake
- Our 3rd gens are Famous!!!
- Hummmm an exhaust option???
- Cooling Issues
- Dropzone Lowering Springs
- flex band
- Did some work today.....
- replacing manifold studs today
- Struts 1990 maxima
- my car wont idle anymore?????????
- how to increase your fuel economy
- hinge pins
- Need help diagnosing problems
- Hey Yourself, saw you today
- VG Timing
- Good place to get fuel injector
- Intake Manifold Bolt Question
- transmission fluid qustion
