- Keepin the 3rd gen and bought a 1995 M3
- blew transmission
- maxima spoiler
- e36 conversion
- GXE to SE gauge cluster.
- grilles for maximas
- Auto Climate Control
- Harmonic distorttion exhaust
- So after 2.5+ years I finally got a factory Nissan Key
- VE runs rough.
- Surging Idle
- heater problems
- should i keep my max?
- my VE is so slow
- a couple questions on my new max.
- trim
- vtc
- 18" wheels
- Tachometer wire
- Fog Lamp Replacement
- Oh help me please!! Please help me please!!
- Flipout Key
- Help!!! My 93 VE30DE shakes when accelerating
- Front speaker mounts?
- Max stumbling upon acceleration
- New owner needs assistance...
- Gay manifold studs!!!
- Does anyone have the wiring diagram for the stock h/u
- How to properly bleed brakes with abs system????
- ABS pump leaking fluid
- General Maxima Question
- Vq30de
- How to check for intake leaks????
- HIGH idle in Neutral and Park
- Engine shutting off at certain rpms
- 94 Engine problems HELP!!!
- interference or non-interference?
- Ok I got a block heater now what?
- Best Brakes
- Air Filter Adapter
- Headlight Harness?
- How do i take the trim off my rear window?
- 226k mi on VE Compression results
- How hard is it to change thermastat on 94 Ve
- Front Vents?
- "Security" keeps flashing
- 300ZX Rims
- Car not starting because of shifter?
- HELP!! Gas Fumes........
- Speedometer not working
- Question about Spark plug wire order
- tranny resistor plug auto
- Very quick question - trans fluid?
- hit deer please help...
- exhaust hole question
- 92se lacks power
- 17x8.5
- Air/Heater Sounds
- Would These Headers Work-Increse My Perfomance
- Haynes or Chilton, which is better?
- Crank but no Start
- Tranny swap question
- Still a bad idle problem need help
- Just Got Car Fixed And Painted!!
- Still wont start(every time)
- speed sensor
- TRUNK RELEASE MAXIMA....need help ASAP
- Gas light, tank full. What can it mean?
- Auto Trans question(s)
- lookin for pics of that slammed orange 3rd gen with wrx lights
- Cai!!!
- fuel injector question
- What Kind Of Nissan Engines Will Fit In A 93 MAX GXE?
- Need Stiffer Steering
- Got broken into today
- Idle Problem
- Transmission Resistor
- inter cooler?????
- window goes up very slow
- VE injectors in a vg???
- speed sensor location
- 17x9 Mustang wheels ???
- New member... Buying a Black '90 SE Autp
- Noise sounds like lifters that are out of adjustment
- trying different tire sizes question...
- Why should i take off wheels for the winter?
- how much did it cost to lower your maxima?
- Cambers for eibach/tokico install?
- Keypad unlock code???
- Re:question:iat Sensor
- Transmission cooler/extending transmission life?
- Power window regulator Replacement
- gas smell in car (winter only)
- Question for those who have installed ES control arm bushings
- Any Good
- ve auto O/D on or off?
- changing VG Thermostat
- What state are most of your parts from?
- Wiring in ve guages to vg
- Manual swap q's
- TPS at fault?
- timing increase
- Adding ABS?
- recalibrated valve body
- (?) on shaving spoiler
- Another home fabricated Short Shifter
- How to change a windshield?Help pls....
- Mo problems fixed
- what motor do i have?
- prking lights/ fog lights
- CV Joint Boot?
- newbie intro with question about speedo and car in general
- 91 Maxima
- Can you adjust the antenna motor power?
- crazy tach
- Maxima/Audi wheel question
- vg30dett swap?
- Mechanic needed in Philly
- finally got pics of car
- my neverending problems
- Which side INTAKE MANIFOLD gasket? (pic)
- Need really good chrome paint!
- Transmission quit suddenly
- Auto tranny question
- best place for clear corner quality...
- door keypads broken
- Threw a rod, how much can I expect from junk yards?
- What good is CAI --FOR REAL?
- ecu wiring harness
- Climate control/blower motor?
- removing horn
- problem with giving it the gas
- Clutch question?
- how much should i expect to pay for some axles?
- When does ECM look at which sensors?
- help with sunroof
- Radio trim differences
- Speaking Of CAI
- ABS relay stuck ...?
- Tranny connector problem
- window going all the way up/down
- chirping noise near top engine...
- door panel problems
- Finally got my cardomain site up....
- what's wrong w/ this?!
- wierd pluggy thinger majiger
- How much would you pay for this?
- My max almost gave up the ghost!!!
- Getting mounting hardware for valve covers
- Performance Egine Questions
- VG Auto what time will I run you think?
- ebay listings.....
- How to put in Driver's Side Axle
- Questions about my Gen 3, Im a newb to the maxima's
- Yo mtcooksen, you gots 280hp now??
- e30 lights???
- need opinion with clutch
- Sprint Springs w/ Koni Struts
- 3rdGen Pickup ?????
- headlight switch
- RPM's acting up
- BOOST? or BUST?
- sluggish accel - heed help
- Problem with Max
- Has anybody put eye lids on their car?
- Knock Sensor Bad???
- Gauge Lights?
- need quick help with a spacer ?
- im stuck
- fuel injectors?
- Goofing around - Convertiblized Max
- weird el. problem....
- Front Axles???
- Fuse keeps blowing
- so long its been fun
- rip in cai boot
- Is this normal - No fuel pressure after sitting overnight?
- Please Help!
- Stainless braided clutch line pics
- Rattle at 115mph?
- Widest tire on a 17inch rim wihtout scrubbing
- Where to find UK corners
- Power antenna problems....
- Car dies at idle when cold?
- Improve brake pedal pressure?
- Car Won't Start!
- buzzing noise
- gunk in my cai
- knock sensor resistor
- maxima of golf
- Ex Manifold studs - manifold
- Brake bleeding order confusion
- just installed digital dash on 92 se 5sp
- Block heater
- problems with door locks...
- who said they got replacement bose amps 4 free?
- testing harness
- Trunk not opening
- Y pipe.
- Idle problem with ve
- auto > manual swap
- Hi-Beam issue
- Problems starting engine
- Need help, diagnosing random engine cut off
- car acting very strange today(long)
- Check engine
- Dead water temp. gauge... how do I change it?
- tranny help!!!!
- Angel Eyes
- Upgrades
- Charging issue
- best way to polish valve covers?
- How many of you have replaced you cats?
- Are JDM VE engines proven to be a tad more powerful than the american VE?
- Changing Fuel Injector...Experts..
- LED turn signal update
- Tail Light
- Grinding Under feet?
- New crank arm sensor...how much should this be?
- Clutch engagement
- found a site with a bunch of parts
- Head Unit for 2002 SE
- Lights
- 91 GXE for Sale -- AS IS
- 205/R15 Specs
- complete asthetic restoration (need parts)
- A few pics of me goofing off at the track...
- Guage Cluster Malfunction - Any Ideas?
- 200k - too many miles?
- Foglight Kits?
- AE Pedals & Shift Knob
- Question about alarms =) (and HI)
- O2 sensor problems
- need help with the rust recall (long)
- sunroof shade?
- installed heads-up display
- hi flow cats
- How to remove right axle?
- sohc vg30 turbo off a 84-89 300zx turbo on a gxe sohc?
- My VE's gone!!!!
- Turbo Maxima Project
- Id10t light
- interested in having another choice in the exhaust world?
- timing chain or belt?
- Help!!!! Vg?
- good find at Junkyard
- vent problems....is this common?
- Exhaust woe's
- If not lines on fuel rails, where is smell coming from?
- Daytime Running Lights
