- What connects to this vacuum port?
- ok updates...gas leak
- Tires Show uneven wear
- G35 Wheels on 3rd GEN MAX.
- question about coilovers
- Adjustable Fuel Pressure Regulator
- ST rear sway bars
- Stupid car stranded me - tips?
- WTH!!!??
- heater core going bad?????
- What I learned today..
- Fuel rail insulators missing?
- hood lift/strut support replacement ?
- Just my luck!
- question about suspension
- Is something wrong?
- Want to tighten up my handling...where to start?
- Pic Request. Please Help
- Spot the Maxima
- How can i tell if my max has antilock brakes and locking differential
- rear disc swap - quick question
- Off roading fun!
- removal?
- Blinker mod wiring
- 90VG To 92VE Conversion
- Fog Light Question
- Duralast Brake pads
- gas leak???
- Bored...testing 350z wheels...
- Windows rolling down
- Nooby door lock question.
- Can't find 3rd gen pics w 17" 350Z wheels. Anyone?
- Pre-5spd swap questions
- 3rd gen buyers in the ohio area.
- Finally got a deal. 1994
- 3rd Gen-HHO Fuel Cell Discussion
- Coming back to life...ASAP
- Changing PCV Valve
- New Cah
- Tranny light comes on only when...
- Refinishing Factory Wheels
- Where is the ECU
- Replacing injectors, manifold removal problems
- Problem shifting into reverse or drive.
- Dead battery only.....
- just a hypothetical question...
- Car won't start
- 93 se auto is wanting to die any help???
- Oil leak and other things
- Oil pan info?
- So whats this car worth?
- Pulled my codes
- So, I'm getting ready to pull the heads
- Project Lineup
- EVERYTHING MUST GO!!!
- If i wanted to fix compression.....
- Vg y-pipe fit on ve?
- Stripped Intake manifold bolts on VG engine
- Steering Column
- headlights?
- Groaning noise near/under backseats.
- What causes low idle?
- Injector problems?
- VLSD QUESTION
- Brake upgrades
- Camshaft position sensor out of range ??!
- ABS Sensors
- Anyones steering wheel wearing down?
- LED problems
- intresting max on cragislist
- Injector wharehouse (feed back needed)
- lucky clutch
- 5-spd tranny issue
- Brake pads?
- Can Driving With 1 Broken Injector Do Damage?
- My 3rd Gen New Zealand spec Maxima
- Where to get OEM key blank
- pwned o2 sensor..
- Help fast!
- Heater always on
- Heat
- thermostat?
- gas smell
- REAL cold air intake
- Please help ASAP
- So, I think I found my heater problem
- 1.25 lug nuts choices
- $725 For a used transmission replacement Job??
- RADIATOR FANS ALWAYS ON
- Failed Emissions...any thoughts...
- cup holder issues
- Tachometer works....sometimes
- e36 headlight conversion questions
- 1992 Maxima Convertible in Ohio
- VE30DE A/T starter brushes
- here we go again
- VE Knock Sensor Connection
- Parking brake fail
- 3rd Gen Photo Request
- 94 Idle Control Valve
- yeah. im sorta proud of myself.. lol
- New Shoes for the Babe
- I Just
- Where to get O2 sensor harness holder?
- Anyone Try 5W-40 in their GXE?
- Steering problem
- In park or Nuetrual Car Revs up to 3000Rmp's
- Brake options that will fit under a 16" wheel?
- 2 Questions: Crankshaft pulley + sunroof
- How do I know if I have a bad MAS?
- Anyone change the following?
- Heater control valve the culprit?????
- Well, I REALLY did it this time...
- Getting Closer!
- My Front Passenger Window is Controlled by a Ghost
- Over extended CV axle
- I F'd up! Help pleasee
- MDF Rings for 6.5" speakers in front door
- How-to - Trunk lock switch replacement
- Horn won't stop blowing
- Auto tranmission shifter
- Alignment needed after rear strut replacement?
- Hi! I'm back (sort of)
- Power Steering Rack Boot Replacement Question
- Transmission Issue Help Please. THX
- clicking noise
- 91 Maxima VG Jumped time
- clutch replacement
- Engine code 35 for 93 maxima
- TCU self test not working....
- ive got a problem
- Wings West style wing.
- Crank Angle Sensor Problem- Electrical Guru needed
- 92 GXE won't start :(
- Anyone Install an Electric Oil Pressure Gauge?
- Fog light modification
- F@(&!#g injectors again........
- Resolution
- tranny, clutch, or IPS?
- steering wheel contact grease?
- diagnosing suspension issue
- Updated my Cardomain. New turbo setup
- weird noise while driving...wheel bearing??
- Flucuating fuel Pressure!
- Coolant leaks on a cold start
- Low engine temperature
- door locks not working 89SE
- Okay. Getting sick of this (Door Locks)
- Bi-xenon vs. Hi/low(halogen) kit
- ABS Questions: Experienced Help, Please
- VE 5spd trans rebuild?
- Weird Sound ? Metal rattling kinda noise
- I give up
- heater smells BAD!
- Rear Defroster Question
- 3rd Gen VG MAF Sensors....
- misfiring/hesitation/bucking. UPDATE
- External Transmission Oil Cooler for VG30e engine?
- Reverse Lights Aren't Working
- Ebay Sellers of 3rd Gen Parts
- Bad starter!!!
- Blemco Part Extras Anybody..?
- 3rd gen a good beater?
- Help ! Leaking anti-freeze after timing belt
- Need Axles
- Windshield trim removal
- Will Marvel Mystery Oil Clog our Shoddy Injectors?
- Assessing Gas Tank Decay
- help diagnosing, whats draining battery when car sits..
- Temp Gauge
- NA VG30 makes over 220rwhp in Z31
- Who has JWT in their Maxima?
- Does the Cooling system need to be bled???
- cant pass smog
- MAF adapter for cone filters.
- Another VE for me
- Cleaned my IACV, now tranny shifting fast?
- Heater A/C Vent Selector
- what is a vg33e swap, really?
- Random missing
- Throw Out(Release) Bearing?
- 3rd gen STILLEN popcharger/intake question.
- Odd smell
- weird whirring sound
- brake line?
- Finally! The REAL fix for a bouncing tach
- My 3rd gen is coming alive again!!
- Is My 'New' Fuel Pump Dead Already?
- Anyone Attempted to Replace Their Wheel Studs?
- New R8 type of E36 headlight
- Any Way to Prevent Whatever it Is From Opening Driver Door with Key?
- Found an Auto climate finally...How to swap?
- water in spare tire compartment
- Bumper Reinforcement
- Anyone have 6th gen 17 inch wheels?
- Headlights give me problems
- Electrical short
- Craig Brace and other GeoCities pages
- Relay colors?????
- Stalling
- 91 Problem
- Rummble durring Acceleration after 5spd swap.
- Seafoam on a 3rd gen
- Have you had to change these????
- VG Crankshafts
- Engine hesitation
- AWD/RWD 3rd gen
- CEL came on and car started to stutter
- Window visors
- where to get front hubs
- Battery relocation
- 3rd Gen Wheel Choice
- What's the actual WHP of a VG/VE?
- Dang, VE 5 speeds all over for sale
- Infiniti I30 HID retrofit build
- Thread callout for the EGR tube off the exhaust manifold.
- Clutch pedal stuck on floor
- Will the VG30E Knock Sensor trigger the Engine Check Light?
- highbeam light stuck on?
- SE parts
- Anyone Running Wider Than 225s?
- Old Car
- front wheel hub
- Transmission Seals
- Front center fuel injector replacement
- 3rd Gen Sparco Seat Build
- manual climate control issue
- Will Hydraulic Brake System Work if I Remove ABS Wires
- How to swap to digital gauge?
- Driver side clunk during deceleration after 5spd swap.
- schematic electrical headlight hight adjustment
- To Seafoam or Not to Seafoam - Photos
- Intermittent Problem for a Year now...
- Is there a strtup proceedure with new VTC/Chains/Tensioners?
- Removing Speedometer Needle
- Fuel injector replacement write up w/pics
- New Type of Single DIN cupholder. Might work on Max.
- P/S Pump is Done
- Shaking Violently In Reverse
- VE timing chain info
- Did some work on my car today, suspension
- Where is the fuse for the cig lighter located?
- Headlight Removal
- Finished JDM swap (and VE 5 conversion) - now some issues
- Speed sensor issue
- My 92 SE Pearl White with 5 Speed Tranny Just Died
- custom garage door opener x3
- Is there a Nissan exhaust tip to fit
- cooling system issues
- New problem after fixing an old problem
