- tranny cooler
- bad vibratons ect....
- Sensitive Steering
- help me
- Wheel Question...
- problem with my alarm
- VG30DETT swap
- Antilock brake problems when cold
- Are you in need of more warmth/cooling?
- Loose Hose
- BAD Idle
- grounding kit
- How Short Can I Make the Stick?
- Gas Guage off, how to fix?
- 3rd gen
- OEM muffler
- Trunk lid opener
- Are the motor and tranny mounts the same?
- Window Reg question
- "Flip Flop" Trunk
- help mt tach is goin crazy
- Lack of Power
- 91 SE Heater problems??
- tranny poping out of gear at a stop?
- 186k Max.....tranny questions
- Will not Rev past 2000 rpm....
- 1991 SE 5 spd Tranny/ABS problems...
- shock/strut/ lowering spring reccomendations...
- Spoiler on GXE
- my car sits crooked...
- '89 maxima speedo,odo,and cruise problems
- Window Broken, stereo gone
- Fuel leak?
- catalyc converter
- Replaced MAF, now runs worse!
- NX 2000 bolt pattern
- Really bad gas mileage. I know I have bad fuel injectors but what about O2 sensors?
- Free X-Mas give away.....Chilton's Repair Manual
- VG engine noise problems...
- Whats wrong with my exhaust? Noise every time I hit a bump.
- Want a muffler or exhaust system that makes the VE sound like a 240sx!
- Wanted Advice...
- Smells like shoe-shine
- motor / tranny mount repair urethane ??
- engine question
- Trunk "Maxima" PLate Cover....
- Whats wrong with my idle?
- 5-spd swap question
- MAF sensor resistance?
- Thinking about a 93/94 SE 5Speed Low Miles, what should I look for? Problems?
- woot new rims
- Complete Replacement Bushing Set?
- What's custom in your car?
- tire help...
- another problem so soon!
- Center Console Gauge Cluster
- 4500 to 5000 rpm hesitation?
- Intermittent check engine light
- popping noise under car
- rear & emergency brakes
- TPS problem very weird very long
- tail light question
- 92 SE stall problem
- Newbie question
- Trouble with power door locks!!! Help
- Last Motor mount to replace
- Trying to install new temp control.. HELP!
- clicking ve
- buying new ve 5spd!
- How to instal Full Cold Air Intake System
- Whistiling
- advice on choosing 3rd gen
- Gauge Needle Trouble
- Auto Tranny???
- I Finally Got Some Pics
- Brake Fluid Leak
- Bose Head Unit died - what are my options?
- Winter overhaul
- Triple Pod Gauge Cluster
- Pics of the new Max
- 5th Gen Strut Bar fit my 93 VG?
- ABS actuator leak
- can someone please address the heating issue
- Rear left side window
- Bose speaker/amp removal..
- Premature Stereo Install Pics
- for my suspension gurus
- Starter Grinds
- HELP Front Passenger Door Stuck!!
- Squealing Maxima - Bad Alternator bearing ?
- Wood Wheel?
- Xmas Ideas?
- need parts for rear disc conversion
- seat belts
- Two new problems I got....
- loud clunk into drive
- Temp control & clock LCD on-off-on-off
- Just bought a wsp y-pipe.
- burnt headlight harness!!!
- Need Help with Extracting Fuel Injector
- Cruise control not working
- My car runs worse after cleaning EGR valve!?
- "Airbag killed a mechanic." Is the danger real?
- power steering problem
- Well, this is fun
- Drivers Front Wheel + Curb = Need advice thanks
- customize location of speakers
- Maxima already CAI?
- max performance
- Light weight subs, do they exist?
- battery terminal question
- Avoid Kauffman (long)
- interior water leak...
- Spindle Replacement
- Which Spark Plugs Are Good On the VG's?
- AACV??? (long stupid question)
- ECU Diagnostics
- ABS Brake system problem
- Panel button lights -93 J30 ???
- 02 Sensor, OEM (walker) or NTK?
- Had shop install stereo deck to solve dashboard light problem
- 93 SE Turbine clearcoat...
- need the FSM picture of the timing chains
- Oops... I screwed up, please help!
- Shifter bushing question...
- Ignition key light question
- spastic windshield wipers
- car revs up slow
- sunroof leak!!!!
- 1991 Maxima Brougham Edition
- 123 only
- starter...
- whos fault?? please respond
- CM brand or Race Brand lowering springs
- synthetic oil
- VG30E Oil filter and oil?
- Nissan service manual
- please help me got ellectrical probs
- Questions about lowering a maxima, Where to buy what to buy? RIsk? HELP!
- Loud Clicking Sound From My VG (HELP!!)
- Sunroof Help
- Pulsing lights & weight question
- torque steer???
- bumpy ride
- Stalling Issue
- Front end kit question ????
- Trunk Light Problem
- Shifter hard to get into drive...
- question on installing after-market alarm
- Wiring Speakers on the 92
- Low fuel light
- RE4F02A (Gen III Auto Transmission) FYI
- Idle Air Control Valve
- 92 Rear Speaker Install
- How to replace rear shocks, Pleae help ASAP
- Need Cheap replacement front speaker
- pics from VE swap, VTC rebuild, exhuast studs,knock sensor, etc
- Only 240 miles on a tank of gas
- put the speedo where it should be!
- VE Diagram
- Q On E36 Lights
- Water C ock Valve/Solenoid
- Anyplace to get a new/used airbag?
- Fuse hunt, bring some ammo...
- Heating/cooling system question(s)
- tail centerpiece
- I hate my doors
- How screwed am I?
- door locks
- Door locks don't work most of the time.
- veering when shifting
- Auto Transmission parts question
- What's up with this?
- Spring Isolators????
- Free 5-speed Conversion!
- 1992 VE failed smog test, any advice..tips?
- help my window switch!!!
- Tranny Questions
- Oil filter
- Rear Disc Brake Conversion Write Up
- I need constant acc. power
- thermostat issue
- Parts is NOT parts
- Green crap!
- clock for sale???
- 94 maxima running rough
- Question
- 90 max, no heat, good operating temp.
- Whirring?
- Heat Problems
- Clutch pedal freeplay
- Headlamp cleaner blade sync. Is there?
- exhaust time
- help, prep work VE 5SPD!
- Touring Spoiler
- clicking sound and more
- spark plug gap
- im dumb and hit a girl
- how to install pacesetter header
- Does anybody have a Techtom, Nprobe, or similar Consult type device in their VE?
- Upholstery Repair
- Transmission
- Question: Cause i'm dumb.
- nitrous
- Wont start(little tricky)
- What is wrong with my car?
- Tranny slipping, then fine?
- What is the optimal tire pressure?
- muffler upgrade
- Heater core only avail from dealer?!
- finally got 20's on!!!
- My max has officially rested...12-04-04 5:46PM
- what should I use to take oil/grime off the suspension bushings??
- Mockup of guage cluster
- Why do VE and VG's sound...
- Wisdome of the org needed
- My Slotted Rotors
- Ok, I need a new fuel injector
- Replacing body parts (help needed)
- 2 Problems...
- How can you check the MAF sensor?
- how come none of my questions get answerd
- anyone who's opened our manual transmission, please step in for 2 quick questions...
- Stereo was ripped out and stolen; dashboard does not light up anymore at night......
- BAD CAR PROBLEM!!! NEED HELP ASAP!! fuel presure reuglator?
- Timing belt
- defroster shaking
- Help, car stalling.
- keyed
- Bose speaker differences in plug size and color
- high engine temperature... my car is... great!
- 150k still able to mod?
- power light has mind of its own
- fuel injectors
- windshield defroster
- control arms...
- Junkyard maximas
- I Guess I`m Special.......
- tire question
- studdering and a weird noise
- Anal and cheap.
- door panels
- Replacing Head Unit (NO SOUND)
- Parts car, Alittle expensive though but considering
- torque converter lockup
- Powerband?
- What is this?
- Replacing Thermostat
- This would compliment my SE-R nicley...
- anyone have problems with courtesy parts?
