- performance specs
- Will R34 Skyline wheels fit?
- Throttle Position Sensor (TPS)
- Looking for an install template for a SOHC CAI...
- Oxygen sensor help
- About Lumens and Halogen
- bump stops and dust boots
- paint stripper safe for stillen kit
- car puttering in low rpm in drive
- Exhaust manifold stud theory
- custom headlight covers/ wade covers/ flush mounted.
- 90 Max...Looks like it's seen its last day
- Can I run the engine on just water w/o coolant?
- Thinking about selling 93 SE
- cefiro lights?? H I D's to use?
- Whaaaaaaaaaaaaaaaaat?
- WTB - Left Front Drivers Seat
- Life After the 3rd gen........
- Is this it?
- quick exhaust manifold ?
- LSD question
- Fog light covers for 3rd gen lights
- 93 Car Audio Help
- writeups for engine pull?
- Knock Sensor questions...
- Are 3rd gens 9004s or 9007s?
- where is the darn iacv
- Car doesn't seem to make power until about 3k RPMs, any ideas?
- Pitching and rolling help please
- Is this real or is it a scam for money?
- Sparkplugs... PFR5C-11 vs BKR5EGP
- air filter box
- General Mantenance Q's (Spark Plugs, O2 sensor, fuel filter)
- Alarm System ( again )
- Help Please?Cylinder Head Temp sensor???
- Ma
- door panel?
- SPEC Clutches
- where to get stage 2 clutch
- what clutch will fit?
- bose power problems possible short???
- vacum line?
- What ya think?
- gas milleage improvment?
- unlock button on the driver side problem
- Superbright reverse lights
- Removing Manual Climate Control
- Wheels and lugnuts
- Security Alarm Light...
- Exhaust manifold problem
- Questions about engine parts swaps
- Need parts!
- Today I got lucky...in an unlucky sorta way
- Jdm Vg
- need help or opinions...
- HELP! fidanza flywheel clutch cover the bolts
- Stranded at School (Electrical)
- amp question
- ABS Braking system
- $300 Vq30de?
- quick question on repainting -
- Electrical Problems - Wiring Gods Needed
- Exhaust
- Recommendations for seat covers?
- leather seats, need help
- Where to buy alternator / fuel pump
- Struts/Shocks & Springs
- VG30E Cams?
- Gas Stablizer/Booster Suggestion?
- Went to replace spark plugs... uh oh!
- BMW Lights
- The end of my Maxima
- Question for those with sunroofs
- My next project...
- clutch problem
- When replacing radiator hoses/thermostat?
- super bad gas mileage
- Catalytic Converter w/Air Tube
- knock sensor and harness replacement
- Another Interesting Fuel Problem on the Injectors
- Oil leaking on my 93 SE Maxima
- Stock Tire Size?
- door locks?window won't roll down?
- I got a VE5spd! I got a VE5spd!
- Got my new ride
- bumper removal
- changing lights
- Fstb
- innerglow
- Intrax springs: any performance value?
- New speakers, Sony CDX-F5700 CD Player
- I lost my foglights
- Air Conditioner Direction Output
- Power Window Switches
- Manual Climate Control Lights
- VTC noise in 93 maxima
- Sound system HELP!
- take a look at this...
- I need help big time.....
- Performance Chips
- Turn Signal Bulb
- Aha! Finally figured it out!
- anyone wanna take bets on my tranny problem?
- what is it, why is it running
- Still Wanted: Engine Parts Pics
- Hood shakin
- Quick temp question
- Headlight issue
- inside light problems
- Spring cuts
- timing belt and other replacements
- i figured you jdm vultures may want to jump on this
- Just bought an SE instrument cluster, How do I swap the odometers?
- fin flywheel and exedy stage 1 install
- anyone live in Quebec ?
- Stock Amplifier
- 5th Gen Muffler
- Timing Light.......
- Loud noise from rear side???
- If I spent $1000 in engine mods...(GXE)
- door trim can YOU get them off
- Engine Stalling Really Bad. Help !!!!!!!!
- sunroof
- Any reason to be picky about a battery?
- How To Change A Fuel Pump?
- Fuses
- Rubbing
- wtf this must be to good to be true
- Help with transmission removal
- Help With BLOSE Replacement
- smell
- A/T Switch Green Orange and Light Green?
- Window button lights?
- i am new and need major sound system help!
- oil pan seals....
- Ok......so lemme get this straight......
- Engine missing
- Speedo, ODO and CC dont work
- G35 Coupe rims on a '90 3rd gen?
- pictures of my maxi! no 56k!
- injector recall
- Internet wheels and tires
- Will it fit?
- 350z wheels on 3rd Gen??
- Underbody light kits
- STS Problems
- Worst locks ever
- Sparco Torino seats installed, plus fixed my sticking out muffler. PICS! 56k death.
- Intake
- RF high beam doesn't work?
- what is this
- Changed Your Struts? Rack?
- wanna blaze
- engine whine - VE
- Keyless entry
- A lake in my trunk
- should i buy these?
- Is $440 right for timing belt + water pump?
- ecu toast!!
- Tranny Problem?
- Auto transmission needs rebuild.
- Was this a good deal and................
- Security System
- rice burner?
- Do I need a better alternator?
- Strut Mounts & Boots??
- Is this Crank Pulley OK?
- Turbocharging VG
- where i can find the refilled oil for the rear cartriges
- Headlight switch
- Finally got pics of my new ride
- Its a sad day for the Max
- To Techron or not?
- Sea foam made my car sooo sluggish ???
- Question about engine swap
- Saying goodbye
- Keyless entry
- finally got her back together
- car won't start please help
- Brakes Pads
- tires looking funny
- coil overs for a third gen
- Newbie has Questions about headlights and grills
- Idle Issues
- Saturday is a big day for my 3rd gen
- some new pix
- Bose Stereo Trouble
- Xenon?
- Defrost?
- BOSE specs
- Door lock/car starting problem again
- intermitant dying.. any ideas?
- Alternator=Bad I found out the hard way
- How hard is it to change the water pump and timing belt?
- VE Maxima vs. Taurus SHO
- Optima Red Tops
- not regulator, not guide... ?
- Headlight gremlins 2
- seat belt warranty repair on a 1991?
- power seatbelt
- ES Motor and Tranny Mounts for 92-94 SE.
- no more rub
- Bored project #1 & 2
- strut suspension problem
- Newbie Timing Belt Question
- Fuel Warning Lamp Issue
- VIN# issues...my car from Canada?? -->
- How big is fuel tank?
- Thanks to all who helped
- Before I Buy.
- Cutting shifter...
- got 2 problems
- Radio Display out............fixable?
- headlight gremlins
- Resetting the ECU after exhaust install
- Super blinking turn signal
- Remove the rear bumper
- Y pipe
- After market HU and Speakers: Do you have to rewire?
- e36 lights
- Years for tail lights
- SAFC-II VE wiring
- Stillen kit knock off?
- wheel alignment after struct change
- paint
- Everything works (pretty much)
- Wheel bearing replacement
- Warpspeed, probably the worst purchase I ever made (long)
- Clutch Issues
- Wrecked max, now what?
- Tranny/Clutch Problem?
- high fan speed problem
- E36 Light Advice
- Bose Sysetm?
- anyone got picture ??
- its gone..
- dyno'd the POS today... with and without VTCs.. (56k warning)
- Axle ? (pics)
- 92 max SE timing belt??
- Lights on my HVAC unit don't work right.
- ball joint
- help on power lock
- upgrade guides
- can someone help me..
- car won't start, any ideas?
- Just installed my VG grounding kit
- Temp Sensor Problem?
- Just a lil update on the g35 muffler.
