- Idle adjustment procedure for '93 vg30 SOHC
- rear suspension
- question about Q45 T/B
- sold the max:(
- Fuel Pump recommendation
- Electrical problems...no start
- ABS problem
- Weird engine miss - vg
- power windows stopped working
- Max still has electrical issue
- oxygen sensor socket
- i think i finnally fixed it
- Torqe Specs - vg upper intake manifold
- A little 3rd gen 'Extra'...
- Sweet Smelling Exhaust? Oil Leak too?!?!
- any1 else has water in the radio?
- Can't seem to figure this one out... need advice
- Funny how things work out (warning... big picture)
- Suede interior write up...install tomorrow pics today
- Aftermarket Radio
- How can I fix this... (See Pic)
- changing oil pan gasket/directions
- 3rd gens rendered in 3d
- brake bleeding procedures?
- Need help on engine mounts R&R
- E36 curve/contour vs stock
- bad idel and take off still help fast!!!please
- Help! Can't shift into Park.
- Best Performance Upgrade
- So I was on ebay and found some interesting lil toys...
- 92max, car shakes betwen 0-40mph's, what do i do?
- Need help, car just die...
- Radiator Hose?
- Here's a new body kit v.awsm66
- Stage 1 of VG auto swap. question about a part
- Best place to buy a Fidanza Flywheel?
- 'pulsation' feeling.new exhaust
- Is this normal in the cold?
- Rip
- Car broken into... NEED 2 FRONT WINDOWS
- 3rd Gen Reunion - Tons of issues (damn the mother-in-law)
- Rear Disc Conversion (Pics Inside)
- 3rd Gen Auto Transmission: Whats your story?
- Brake problem again!
- help installing power steering hoses?
- torque number for ST front stabilizer bar
- crap! help help I cut my brake line
- Need gasket on my trannsmission RS5F50A
- Still Wrenching on the Brakes..
- vg30de ticking?
- how to refill a craftsman hydraulic jack?
- Random Pics of Max and New Fogs
- The Fidanza Flywheel I ordered that I never Got
- Spoiler on GXE
- HELP! Rear brake shoes stuck
- Want to do 5-speed swap but found VE Auto on CraigsList for CHEAP
- i think my clutch is on the way out
- Burnout Vid
- rear brake caliper rebuilt
- Power Steering Rack and Pinion
- expansion valve
- need some help on installing the (R) lower arm control
- Merry Xmas Eve+TY
- Bad front struts - what to replace with
- Any off the shelf 140A or larger alternators for the VG?
- EPROM chip worth the money?
- ECU (OBD I) consult cables...would this work??
- Hood Project!
- need a post for a vg auto to vg 5spd swap
- Timing: Distributor 12mm bolt not tighening
- Got a Z. Expressing Gratitude and Bidding Farewell...
- new wheels
- My Maxx is on its way!
- Throttle Body Bypass...
- Great news
- facelift possibility?
- Took a Drive Today...
- swapin steering wheel
- Will 18x9 with a +40mm offset Fit?
- Stupid y-pipe
- 2-Piston Brake Upgrade
- Lighting on Climate Control
- Who's dash digital clock still works?
- Coolant Temp Sensor
- Best year 89-94?
- No Power, Brake pedal to the floor?
- crank angle sensor
- Interior Lights
- Correct me if im wrong or miss something.
- Speed-O-Meter/VSS
- A/T Mistery, Please Help me!
- Anybody wearing Kumho Solus KH16 on their Max?
- Maximum offset..
- Trunk Lid Take 2 (Wrx tail) + bonus
- ecu codes
- VG Exhaust Upgrade
- hard to start rough idle/ check eng lite
- Have a charged battery but now it wont turnover
- Will new headers work...
- VSS wire info...
- installing transmission /killself
- Got some wheels from a org member on here, tell me what you think...
- Passed inspection...
- Hard cold starts?
- pics of my macco paint job after 1 month....
- maybe my egr?
- Original Wheels
- Painted Grille
- Interior roof removal
- MAX broken into, pics
- 5 speed manuel gearbox overhaul
- New exhaust and missing low end torque
- After New CV axle & injector Max is Back up!
- 92 auto tranny problem
- Trading in the Max :(
- Order of Clutches/Steels?
- Odometer, Shocks and TailLights
- now that the cold weather rolled in....
- Dual Stage Muffler
- Fuel Injectors?
- 92 auto tranny - revolution sensor
- Got bored ended up with retrofit.
- Stock b-pipe diameter
- RSB question
- Stalling when the motor is cold
- 17" chrome infiniti's? what you all think
- Sub direction/enclosures.
- I want to post a picture,but I don't know how? Step in here :-)
- Vg Manual transmission number
- Last word on Konis?
- Transmission out need help!
- metal fuel and brake lines help!!!
- Heat, No Heat
- Getting All Exhaust studs replaced but
- Timing Chain vs. Belt
- Headlight Bracket ?
- uh, HELP please..
- Vibration in reverse - any idea?
- Removing Transmission
- Auto tranny check plase help me!
- Well, I sold my max today and picked up this...
- Speaker Sizes?
- What 14" wheels fit?
- Common ABS leak?
- 3rd gen repair issues.
- Best price for Fuel Injectors!
- Maxima Down=CTS-V UP!!!
- Thoughts on Tokico HP Spring and Strut kit.
- What's Your Most Anal-Retentive Automotive Quirk?
- Parking lot light fell on my car!
- No Longer!
- whoah, what a difference.
- In-Cabin Lighting upgrades
- Engine Whine VG
- 95-98 240sx Steering Wheel in 3rd Gen
- VE Brake Rotor/Pad selection
- firewall water leak
- Stop with the multiple threads that cover the same subject!
- Power Black Leather
- sunroof drain exit point?
- can a timming belt affect peformance?
- Digital cluster and HUD
- oxygen sensor?
- Question on installing the Digital Dash in a 93 GXE
- Front Strut Bar?
- Can you interchange parts from a 93 Altima to a 90 Maxima?
- Help ! No fuel
- Nice VE-5 on ebay
- People who have rebuilt 93-94 Auto Trans? Chim in
- 3rd Gen may be the best Max Ever!
- How to remove governor from your Maxima...
- Euro headlight pics...INSTALLED!
- CV Axle assembly
- AT refill VG
- someone has some suede..............
- pot hole bent my rims!!!
- Bench Bleed Master cylinder
- Speaker PODS
- Finally pic of my max w/clear euro headlights
- new twist on a common problem....exhaust manifold
- 1993 Maxima.. Took Tranny Apart Questions?
- New Battery
- shudder when in reverse.
- question
- battery relocation
- intermittent power loss
- Electrical Woes...
- Does anybody likes Rats?
- Weird sound from engine-video
- Overheated....coolant leak....won't start...----->
- Yay another problem..
- Broken sway bar bracket?
- Does the VE really like intake(HAI or CAI)?
- just picked up a 90 SE
- Plastic Fog Light Lens Protectors?
- Vibrating When Braking
- What to do with old starter?
- Clunk
- Just donated and WOW I can search!!!
- relocate stereo 2" forward?
- Best prices for OEM
- Valve cover gaskets done last night BUT...SOL
- MP3 Player Cradle
- Turbo'd 3rd Gen
- what is wrong here?
- The dreaded recall....
- Anyone have ZENN Springs on their max....
- Maybe my EGR valve?
- Why are brakes still soft after bleeding?
- need deep tone muffler..
- Oh.... snap my master cylinder is leaking very bad
- $ distributor cap & rotor
- Got The Max Back From Paint Shop Tell Me What U Think(Pic 56k beware)
- Just received/installed new tires today
- How does VLSD work?
- Alternator output 15v and over, HELP!!
- brakes on a 3rd gen
- Pics of Clean and Sweet Engine Bays?
- Anyone here live in North Central Florida?
- Carbon fiber hoods?
- Another bose question
- 3rd generation coilovers?
- Seatbelt Question
- Exedy Clutch= OEM???
- Anybody with black interior pieces?
- Forced Cold Air Intake?!
- JDM Intake FTL
- Need pictures of dash at night!
- Yet Another Door Lock Problem
- Master Cylinder ran dry-how do I bleed?
- Idle air control valve?
- Exhaust too loud?
- worthwhile upgrade? Or just a gas guzzling waste of money
- Speakers acting weird...
- Turn signal/headlight switch stalk
- Any experience with axles from Raxles.com?
- So I hit a deer....
- what happened to this forum?? ive been gone a few months.
- Supercharger
- Bose Buzz
- Vg question
- Powder Coated my rear break calipers
- Synthetic oil? (non-maxima question)
- broken bolt in the main pin
- Power Steering Question
- Weird Relay Happenings
- 3rd Gen Wiper Arm Replacement
- 1993 Black VE for sale $500?
- Gas Consumption Revisited!
