PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. help-locks stopped working agine!
  2. performance headers/y pipe
  3. clickity clack from engine
  4. Rear suspension and blehmco upgrade finally done!!!!
  5. new intake and some questions
  6. Door Problems
  7. Shift selector removal?
  8. which gauge panel?
  9. weight reduction
  10. is this normal?
  11. Engine Restore
  12. Long Never ending problem. Any input would help
  13. Turbonator? anyone heard of? Does it work?
  14. Clay bar
  15. What' wrong with my brakes?
  16. posting pictures
  17. 3rd gen Seattle Meet: Saturday, Aug 6th
  18. Rust...
  19. Skyline Tails
  20. oil press gauge install
  21. those with HUDs, problems
  22. Removing Spray Paint
  23. exhaust wrap
  24. Does anyone remember....
  25. just a question
  26. TSB for rear Seatbealt Retractors
  27. Strange Power Window Problem
  28. Who has brake rotor/pad pricing like Automax?
  29. reman fuel inject
  30. Small questions on changing ATF?
  31. grant steering wheel
  32. Tranny Repair, need advice/opinion
  33. Power Antennae Not Extending Fully
  34. Fresh Paint Pics
  35. noise from front of car
  36. Cleaning Tinted windows....
  37. Is this a record or something?
  38. ebrake light stays on
  39. bleeding brakes/ss brake line install
  40. HELP!!!! theft wiring
  41. Need Help: Part num. or name for this hose?
  42. injectors and premium fuel
  43. Odometer stopped working!
  44. new alternator whines, why??
  45. help with temp gauge
  46. Tail light covers (Dual circles)
  47. Fuel Injector replacement questions
  48. hole in firewall
  49. Alternator leak current; how much?
  50. any1 try pathfinder navi in 3rd gen?
  51. window reg ques
  52. Windshield replacement ...
  53. power steering again
  54. Made my clock always fully illuminated
  55. fellow 3rd gens with 15" subs...
  56. More on Magnaflow...
  57. East Coasters - Poss. Large Hail
  58. Datalogging/OBDI Palm Question
  59. rims
  60. Power trunk release nonfunctional...
  61. Rims
  62. Parts Source?
  63. offset Q's
  64. vaccum canister?
  65. need measurements of exhaust cut-out in rear lip of stillen kit.
  66. Support bearing bracket
  67. need some suggestions
  68. noise from drivers side front wheel
  69. jdm ve swap completed but few problems
  70. Front pass seat arm rests, are there?
  71. Anyone have Fidanze Flywheel?
  72. another e36 convert thread
  73. How many max's do you have?
  74. Some help please (plexiglass related)
  75. Thinking about getting a 3rd Gen!!!
  76. Parting Away With My Max!!!
  77. power steering rack boot
  78. 3rd gen Wrenching Tricks of the Trade
  79. new brake pads porterfield's?
  80. Driver's side headlight is out
  81. Can you identify this Tranny?
  82. gauge cluster swap (GXE vs. SE)
  83. monza catback?
  84. Replaced both LCA with poly, did the PS hose
  85. noise
  86. Warpspeed not making 3rd gen exhaust???
  87. Possibly selling the Maxima...
  88. anyone ever try this on a 3rd gen? pics inside
  89. kinda sorta maxima related
  90. CV boot ???
  91. shift boots
  92. superchargered maximas
  93. Motor mounts interchangable?
  94. What exactly does the surge tank do?
  95. 2 questions
  96. Window regulator and motor question.
  97. ASCD wiring
  98. Shifter popping out of gear
  99. need help from the maxima enthusiats
  100. oil pressure guage
  101. Something is seriously wrong with my steering
  102. Autozones return policy on tools for changing 91 SE rball joint?
  103. power antenna
  104. Changed trans oil today
  105. Because so many of you want an A/F meter
  106. Does anyone know where ot get a very low mileage motor for a 91 4dsc auto
  107. Power steering lag
  108. Power door lock, alarm, remote
  109. Changing ball joints questions?
  110. inspection woes
  111. Tranny Change: For the Criminally Insane?
  112. Remove the center rear trunk pice...or not?
  113. Fsm
  114. General Injector Questions
  115. Almost everything is ok!
  116. Turbo Manifold options?
  117. Speedo not working
  118. seafoam
  119. HELP!!!! feels like wheel is going to fall off!!! (VE auto)
  120. been a while, just updating everyone...
  121. Anyone have sticking rear doors?
  122. Fuel injector pintle caps?
  123. Underhood Heat
  124. Suspension swap oddity?
  125. Exhaust manifold warpage?
  126. Exhaust stud hardware
  127. Power steering fluid leak????
  128. weird sounds
  129. How Many Amps Is Stock Alternator
  130. 1Grand to play with, what to buy???
  131. cefiro front end swap
  132. hole in the cat
  133. What is the condenser made of?
  134. Air Condition goodies update for u
  135. A/C question
  136. Brake Problems.
  137. finally updated my cardio site
  138. maxima clock
  139. I did a Jeff92se :)
  140. Been getting an odd noise from the front
  141. Big 3 Upgrade
  142. rpm's and acceleration.
  143. I pulled a Matt today
  144. new job = updated ride
  145. It's been forever
  146. omg look at the rims
  147. opinions on suspension
  148. high idle
  149. rear strut removal problemo
  150. trade in the works
  151. Quick question, potentially got scammed
  152. Do I really need to buy a 4th slave cylinder?
  153. Exhaust studs +++
  154. Attn Fidanza users......
  155. new tires
  156. Tire Pressure
  157. so sick of my crappy gas mileage
  158. Wiper Problem
  159. Ball joint OEM part no
  160. My road trip...
  161. Jacobs Pro-Street Ultral Team. Any Benifit?
  162. How much to get a decent paint job done?
  163. Removing Right Halfshaft - Need Help!
  164. Needs front end naked pics.
  165. Need some serious help pliz
  166. how fast would you go in your 3rd gen
  167. Keyless Entry install....worth the hassle?
  168. Visiting NJ/NY
  169. manual transmission mount
  170. I've had mine for 2 years
  171. Exhaust Studs - A Thanks
  172. Max Broke Down(Very Weird) - Please Help
  173. O2 Sensor difference
  174. Need Opinions...
  175. What Lowering Springs
  176. Outside Temperature Sensor
  177. Im I insane or....
  178. all lights dim, erratic idle, dead battery....help!
  179. Fuel injector diagnosis and replacement
  180. Door Panel question
  181. Bye Bye 1st gear
  182. Oil Leaking Problem
  183. Manual Transaxle Grind
  184. problem with belts maybe
  185. One Touch Sunroof Control?
  186. You ever had a "one of" problem that no one else seem to have problems with
  187. MAF Adaptor
  188. Stock Windshield Washers Have Low Pressure/Aim Low
  189. HID's
  190. Ground kit help
  191. How to realign steering wheel with wheels?
  192. another worthless thread
  193. Wiper not smooth
  194. Spark Plug Information
  195. 6th gen engine/tranny fitment
  196. Looking For A Stillen Body Kit
  197. automotive problem of the century
  198. Is SE and 5-speed indicated in VIN?
  199. My buttons...they be broke... :)
  200. New muffler
  201. 3rd Gen Grounding Kit?
  202. Fuel pump problem?? maybe
  203. Various intake Q's....
  204. anyone have warpspeed catback
  205. need help for a friend
  206. will synthetic oil smoke?
  207. MAF wire question
  208. Rear end droning
  209. Black Out Headlights And Tailights
  210. JWT ECU on a 91 SE 5spd
  211. Starting VG build, any sage advice?
  212. exhaust help
  213. Eurolite Headlights
  214. z31 engine question????
  215. coilover setup
  216. If you think you're having fuel injector problems.
  217. 5 speed swap first problem...
  218. Cobra Rims
  219. Mustang Wheels
  220. Brake pads and rotor replacement
  221. Trouble with window...
  222. Cat Back
  223. Possible problem with distributor?
  224. anti roll bar
  225. front suspension clunking
  226. clay bar loves my car *PICS*
  227. Update: starting problem
  228. Some 3rd gen autocross pics...
  229. put engine in. crank, no start
  230. What consists of a full tuneup
  231. Power Steering Pump
  232. For BadHonda Injector issues.
  233. valve cover seal washers
  234. Hookup power leather seats?
  235. Let us say goodbye... (56k=go drive a 4th gen)
  236. Input Shaft Bearings
  237. Maxima maintnence episode V: SE wing strikes back
  238. Maxima Maintnence episode III : revenge of the stalling VE.....
  239. buying another car/carfax request
  240. Seized rear brake: caliper or e-brake?
  241. Clogged Injector Leaks on Mornings
  242. Speaker/headlight Problem
  243. bose amp wires
  244. stock exhaust
  245. running 16.0s :(
  246. Condenser replacement
  247. Do they make Angel Eyes for 3rd Gens?
  248. Doing timing belt, what parts do I need?
  249. anyone know if these ar 16 or 17s
  250. gear shifter very loose all of a sudden
