PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Very Emotional Day for me.
  2. shift linkage help
  3. Replacing fuel pump
  4. Charging System Prob?
  5. Passanger Side Grinding when breaking
  6. help with y-pipe studs
  7. Heater Not working?
  8. VG Air Box Question !!
  9. Is it safe to clean injectors with CarbCleaner?
  10. Relay?¿
  11. Prices for a VE
  12. Need a cat....not the meowing kind
  13. Best sounding muffler ever #199
  14. Wierd clutch
  15. where on earth is this hose connected to
  16. Green Dot vs. Yellow dot injectors for 1993 and 1994 VG30E
  17. Half Shaft Part number for VE
  18. Front right wheel wobbling need help
  19. what size tires for 18'' wheels
  20. need help with my BOSE
  21. please help!!!!!!!!!!!!!!!!!!!!!!!!!!!
  22. non driven VG running rough
  23. toyota filter #
  24. rear strut cartridge
  25. weird heater problem
  26. volk wheels?
  27. Best sot to run Power cable
  28. Gas Smell Is Gone....... BUT.....
  29. Bose Whining
  30. Update! (pics)
  31. hard to start when it rains (odd)
  32. short throw shifter
  33. looking for thoughts on how to spice up interior (classy that is)
  34. JWT ECU and Knock Sensor thread split
  35. VE30DE build details
  36. Power Steering pressure hose replacement
  37. Engine/ Tranny Mounts
  38. Pics!
  39. doing some surgery soon
  40. Exhaust Manifold Studs.....anywhere to gettem other than dealer?
  41. Front bumper cover removal
  42. Somethings broken here
  43. Best clear corners, recommendatons?
  44. FSTB Question
  45. spare mirror?
  46. help with ignition.
  47. Stop Lamp failure, please help
  48. Quick help needed in cd player installation
  49. How can I be sure my Max is being cooled properly?
  50. manual tranny fluid change
  51. Stereo HELP!!!
  52. No, really, I do have a catback...somewhere...
  53. **3rd gen owners, put yourself on the map**
  54. New Rims *pics*
  55. Need swap help info
  56. No blinkers....what happened? step in...
  57. What is whining in my max? Help!
  58. Car is acting wierd
  59. A Q about Painting
  60. 600$ 154000 mile loaded 3rd gen maxima is it worth it !!help!!
  61. cracked/broken injector plugs
  62. Making More Light
  63. hard to start problem
  64. UH OH! What Have I Done Now?
  65. My 92' GXE Pics
  66. SS clutch line for VG stick
  67. Where to get studs???
  68. My car's still on the lift!!
  69. How much to shave off VG heads to get 10:1 Compression?
  70. jdm vg30et install
  71. still having troubles with ve
  72. steering rack replacement check list
  73. advice on tradeing from vg to a ve max
  74. if speed is wrong what about RPMs?
  75. Are there any aftmkt spoilers that fit the stock holes?
  76. Battery trouble?
  77. Intake idea...CAI
  78. Finally took pics of the max
  79. Lighting Problem (Headlights and Foglights)
  80. Car got broken into....
  81. Max and 5 speed swap are almost done!
  82. 1st and 2nd gear, toast.....
  83. ABS leak
  84. therealgoon9, happy birthday :)
  85. Max doesnt start????
  86. PCV location (1993).
  87. Are wheel bearings a big problem on our cars?
  88. Some help trouble shooting steering problem
  89. weird sound...
  90. Totalled the max. Bye, maybe...
  91. Trans Problem
  92. Bad radiator..or bigger problem?
  93. Cant seem to pin point vibration........
  94. starting problem
  95. Clock and Stereo wont turn off
  96. Oil Leek??
  97. reverse glow gauges
  98. How do you hold the crank pulley still to loosten the bolt?
  99. The winterizing thread...:-)
  100. 10" or 12" Sub
  101. Low pressure hoses r12 and r134
  102. legal legal legal
  103. Getting new Half Shafts.
  104. just did a carfax
  105. thought you guys would like this *pics*
  106. Hit a Median...........
  107. Knock Sensor
  108. High Idle Help Please!
  109. Carbon fiber hood vs stock hood
  110. Headlight problem
  111. ...and I knew I was in trouble when my exhaust passed me...
  112. tuning fork effect...belts?
  113. Gas smell from the tank cover
  114. To those who have done the 5-speed swap...
  115. Probe GT Wheels
  116. Power Steering normal or acting up?
  117. Input on 3 Gen as a beater
  118. Have a broke valve. What else can I do to the heads while they're off?
  119. Power Locks.
  120. Fstb
  121. New Battery, All Lites On, ....No Start!!!!!
  122. sway bar end links
  123. Replacing t-belt Saturday
  124. Waiting for "I-Bent-My-Key-Day"
  125. Vin Check Please
  126. Changing exhaust manifold gasket.....advice?
  127. Tracks to the right...
  128. Powering aftermarket accessories sort of long
  129. heater core continued.....
  130. Exhaust Leak on Y Pipe
  131. need a carfax ran
  132. Lowered Alignment
  133. in the matter of master & slave cylinders
  134. By Popular Demand!!! PICS!!!!
  135. cold/heat slider problem
  136. What do you do after all the bolt-ons?
  137. replacing passenger side axle
  138. Does high grade fuel & advanced timing need colder plugs?
  139. ATF level
  140. Performance increase question....I know you're tired of these...
  141. replaceing lower balljoints
  142. Trunk lid
  143. is this bad??? *pics*
  144. Discovered Something Leakin Need Help (PICS!)
  145. another man's problems
  146. The Stillen Front Lip, and Fog Lights
  147. ode to a manual trans
  148. fridays genocide
  149. power seat problem
  150. Puff of smoke and exhaust smell in the morning
  151. part request, heater control unit
  152. Need stock exhaust:
  153. VTC Clack!!!!
  154. Worried about smoke
  155. Mustang wheels on a Max?
  156. Exhaust Manifold Leak.....What to do?
  157. wierd shutter while driving
  158. plates between tranny and engine
  159. Move on to 6th Gen Maxima
  160. Rubbing Problem
  161. need help installing car alarm
  162. starting problems
  163. More pics from my crashed max
  164. "fill-in car"
  165. shock problem
  166. Did tranny honey help your automatic?
  167. Rear KYB struts fluid
  168. wanted : dyno sheet.
  169. intermitent power problem...VE
  170. Trouble With Auto Shop!!!need Help Pliz!
  171. Maxima bit the dust at the right time
  172. temperature problem
  173. Hoisting a complete VE on a pallet.
  174. IS WARSPEED Y-pipe SAME for VE and VG?
  175. not sure If I had the compresssion stroke or not what would happen
  176. Video of my ex-89 SE accelerating....
  177. GL-4 gear oil [where to get it?]
  178. No Red valve covers here, MrGone :)
  179. quick psi air pressure question
  180. custom fenders?
  181. Let's meet this Friday-Minneapolis,MN
  182. How do you make a home made CAI?
  183. Which is ebay CAI for VG+where to get o2 sensor?
  184. do i need my Power Steering cooler
  185. 89 questions
  186. Rollin'!!
  187. What Kind of engine
  188. What happened to this place?
  189. Another custom grille with pics
  190. 89 SE trunklid
  191. tranny slipping
  192. Intake Question
  193. Another Recall Issue
  194. Suspension/Front-End Problems
  195. Brake mushy mushy
  196. Signals
  197. is this good?
  198. Its about time!!!
  199. well, it finally happened
  200. Tried rebuilding the front calipers
  201. Anyone make their own Angel eyes???
  202. Need ASAP help for Oil Leak
  203. Pressure Release from Gas Cap
  204. Rusted Oil Pan
  205. clutch problem
  206. I KNEW I smelled gas
  207. Anyone selling their Warpspeed Y-Pipe?
  208. Hep! popping noise from 94 GXE
  209. Changed the injectors this weekend
  210. Poor performance (not spark related)
  211. Idea for easy IACV cleaning???
  212. noise/idle
  213. ps2 in glovebox, power invertor, wiring help
  214. Making some progress on my trunk....
  215. Max got INJURED.....quarter panel....pics
  216. My future project
  217. Cps
  218. A few Questions
  219. Pics of Max with New Dig Cam
  220. Need some opinions
  221. intermitent wiper problem
  222. Sold the Max Today
  223. Proper Reverse EL Gauge Installation on an '89 Max
  224. A Q on Fidanza Flywheel
  225. throttle response loss
  226. Clutch bracket broken? Slave cylinder? Need clutch help
  227. Pic's
  228. Help: Maxima stock alarm
  229. help with g35 rims
  230. Changing CV joint. HELP
  231. Gauges
  232. 3rd and 4th Gen STS options...........
  233. advice on engine mounts?
  234. Intermittent missing on VG
  235. oil pan gasket help
  236. Power Window Repair?
  237. Is it safe to use Fuel injector cleaner?
  238. !Spark! VG30E Accel Coil Conversion, Very Easy and Clean
  239. Burning water
  240. How to reduce wheel hop?
  241. Quick Questions
  242. Grounding Kit
  243. I saw this in the RSS News scroller on VQpower.com
  244. 2 Questions
  245. Clutch Recommendations.
  246. Body kits & Hoods
  247. Uncertainty about Flywheels...
  248. im i gonna have to replace my water pump??
  249. gear oil from bellhousing?
  250. 3rd and 2nd gen option comparison...
