- Location of the Idle Adjustment Screw on a 1992 Nissan🤔Maxima
- door closes wont open
- Cps
- 94 Max dohc manual trans
- Wheels and Tires
- What's up guys! anyone recognize this turbo 3rd gen?
- Kansas City 1990 Maxima for sale prestin condition
- I think my transmission is going out, it’s leaking trans fluid
- 1992 Nissan Maxima SE Not Cranking / Not Starting
- Headlight sometimes not working
- Speedo problem
- Identify this Wiring Harness
- Roll call!
- Engine swap
- Manual de Servicio
- Speedo problem???
- No start
- hi everyone! :)
- auto climate control no display...sometimes
- 1994 GXE Parts Clearout
- Flashing CEL
- Coilovers for USDM 3rd Gens
- Coilovers/Lowering
- Digital dash repair?
- Maxima 1989 - Failure to accelerate
- Looking for a digital cluster + questions
- Sagging door hinge repair
- 94 max se driver side cv axel
- Cylinder 2 misfire
- 93 gxe transmission issues
- 1989 Armrest
- Looking for headers, Exhaust Y-pipe and ECU recommendations for a 1990 MAXIMA SE
- Project Log - White 93 Maxima SE
- 1992 Maxima - Climate control display and Bose radio questions
- Wheels???
- 1994 GXE Parts for Sale
- 94se
- trans swap help
- 1993 Nissan Máxima V6 Camshaft sensor location?
- What could it be? Transmission
- Exhaust
- 1989 GXE Transmission help
- Stereo Replacement (BOSE)
- This is what happpens...
- Need help - not revving past 2000 RPMs
- HKB Bosskit ON-102
- Tino's 1989 Nissan Maxima(Post, and Updates)
- Replacing valve seals on the engine
- Seeking 1989 GXE/SE
- 1992 Maxima Brougham - Digital Display cluster
- SF Racing Coils, do they fit USDM?
- bushing for my 5 speed shifter
- I bought a white VE-5 for $700
- 1991 Maxima Power Windows not Working
- Con Rod Bolts
- Rough idle
- Does the vg33 really bolt up to vg30 transaxles?
- sloppy auto trans gear selection issue
- Shocks
- Bogging Maxima
- Aftermarket keyless entry install documentation
- driver window switch trim
- Parking brake cable for 5-speed SE
- 94 VE30DE Fuel gauge not working since fuel pump swap.
- ABS Wheel speed sensor options in 2023?
- 3rd gen CAS trigger wheel pattern details
- VE Oil Dipstick Length
- 1990 nissan maxima steering wobble
- anyone has a passenger side pillar trim
- Manuals & Parts Any Interest?
- Gas smell
- VE Engine with GXE instrument cluster
- 1990 nissan maxima roof drain
- Door code????
- Any OGs still around!?
- Time to consider. . . 93 GXE
- Water leak - need help knowing what to replace
- 1993 VE auto part out in LI NY 11801
- camshaft and crankshaft sensors; where are they? VG30E
- 89 nissan maxima gxe crank no spark. HELP!
- 1989 MAXIMA, on Hemmings for sale, who does this belong to(?!)
- Climate control for 1990 Nissan maxima
- Headlight problem
- Speedo problem
- Clean Looking 93
- 1990 Maxima No Crank, No Start
- 3rd Gen CoilOvers - YELLOWSPEED coming!!
- 500whp maxima help
- speedometer intermittently non-functional
- Blow-by gas hose discontinued
- Locating obsoleted parts
- Maxima Failed to sell
- New to the family
- How much to ask for '90 SE 5sp sunroof black leather that needs work
- My 1993
- Cross memeber bushings
- Asking for a favor - bolt check/size mix up - rear suspension
- IN 1992 Maxima SE 5spd For Sale/ Not Parting
- What is this seal (?) behind both of my inner tie rods and why is it there?
- Place racing cold air intake VG30
- Dome light and clock not working
- Cruise Control
- My 3rd gen needs some love!
- Random hanging hose...
- Air Bag light
- 3rd Gen Parts
- Rims
- What's the best intake?
- In search for Idle air control valve
- Idle air control valve SPECIFIC HOSE NEEDED
- fuel pump assembly
- Maxima Water pump install
- VE engine rear crank bushing
- I Think it's time to say goodbye
- Speed sensor pinions
- Wheel size
- Test light goes out when pulled the ignition fuse under hood,also the engine cont fus
- 3rd Gen Fog Lights
- 3rd gen digital cluster
- 89 Max Transmission Strangeness
- Scan tool plug????
- 5spd swap 92 GXE
- 5spd swap 92 GXE
- Power valve VE engine
- How to confirm that VTC is working?
- 90 max see automatic,? Yes your all correct .new ?
- 90 max se automatic,?
- brake pedal goes to the floor
- Finally a coilover for 3rd gen that match J30 plus reference
- Center cal avail?
- Maxima at Le Mans with Datsun 240z
- AC gets warm on highest setting
- New ve30de silicone hoses
- my 93 Project VE
- Just picked up a J30
- Pilot Bushing/bearing
- No start after replacing timing belt
- First car 89 Maxima --it's complicated
- VE axles
- Hello fellow Maxima owners:) my crank pulley is shot:/
- 3rd generation 5-speed for sale
- Clear polycarbonate headlight covers
- French maxima adventure
- VE Chain ticking
- Windshield Wiper Install
- Rear Brake lines
- 92 SE For Sale
- Looking for 1991 Maxima SE ABS Delete Procedure
- BRAND NEW Fiber Images Gloss Carbon hood
- Solenoid on the Water ****
- '94 with dead cylinder
- swap transmission?
- Front Driver side Transmission Mount Bracket M/T
- 1989 Maxima
- head bolt replacement
- 1993 VE30DE starting issue
- Battery drains even without key in ignition
- Overheating questions.
- Maxima problem!
- Maxima problem!
- 3rd Gen Auto Door Locks hainted
- St suspension asb installation problems. Anybody help?????
- Buscando una caja de cambios para mi j30, porfavor ayuda
- Parts Help for transmission Vehicle Speed Sensor for 5-speed Manual?
- Clean ve for sale maybe someone here wants it
- 94 Nissan Maxima coilovers, need help
- Odometer Gearing Fix
- IACV Problems
- More VE problems
- Disconnect water to TB and IAC
- 91 vg30 AXLE removal
- My new 92 ve5
- Shifter bushing
- Rear Strut Replacement
- New owner of a 92 VE5, problems already!
- Ran over debris, now transmission doesn't work
- 93 SE VE30DE starting issues
- My grandmothers maxima
- Looking for Euro Spec Corner Lights
- Floor Mat Clips
- Dash lights not working all of a sudden
- Anti-Theft alarm randomly after driving
- Anyone looking for ASP UDP new for VE30DE
- Megan Racing OE-RS / Stillen front lip
- Anyone have good luck with cheap ebay injectors?
- Digital dash fuel pump/sending unit?
- Need a passenger door lock actuator? There’s one left.
- Reminiscing My Pops Old Max
- Upgrading suspension
- Who's Max is this?
- My new 93 VE30DE SE
- Flex Plate.
- Faulty or Failing MAF Sensor? Intersting observation
- Brake and caliper job
- What poor running conditions can "Code 13 engine temp circuit" be linked to?
- replacing radio and bypassing rear amps for 1994 gxe
- Alternator
- Looking for a black leather driver seat for 89
- Interpreting fuel pressure & vacuum test results
- 3rd gen floor mats
- Who rebuilds digi dashes/has 1 for sale??
- My New ve30de SE. Looking for parts
- Third gen maxima bug bit me yet again. My project 94 SE
- 1989 maxima SE for sale or part out
- IAC idle air control valve
- vtc's or kit 13072-97E00
- Power Steering Fluid
- Engine Assembly for Sale
- Parts still readily available?
- 1994 Nissan Maxima chasis
- Anyone have a Bose headunit?
- 90 GXE (code 55) intermittently won’t start/quits running
- 1991 Nissan Maxima parts-where to buy?
- driver side rear engine mount bracket
- 1990 Maxima VG30E
- Studder
- Front speaker adapter
- Digital cluster repair
- VE30DE Timing Chain Tensioner Symptoms
- New Speedometer
- 91 3rd gen maxima wheel hubs
- Transmission broken
- 1991 Nissan Maxima-ECM no power, no codes
- Automatic third Gen trans stoped working
- Compatible part?
- VSS Test Using Osciliscope
- Let me introduce my 3rd gen. Fantasma
- 1989 Rack and pinion
- Transmission problem
- How should I lift my 3rd gen?
- Speedometer stopped working.
- 5spd tranny rebuild question
- Broken rail under driver's seat
- Vibration ?
- Vibration ?
- Knock sensors
- Driver door off alignment.
- 90 Max SE Fuel Tank Relief Hose
- SUSPENSION HELP!! Nissan Maxima se 1992
- I have a broken fog light on my 92 Nissan Maxima!!
- Ve30de oil filter
- Can't find springs for my 4th gen
- Nissan Maxima Se VE30DE rough idle
- 4DSC decals here
- 1994 Transmission Fluid Leak
- napa distributors
- Help transmission maxima 1991
- Shifting is stiff
- Z31 Rebuild. VG30ET guru's needed
- 91 SE Any Interest Part II?
