PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 [100] 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. overheating help stat!
  2. heater/overheating
  3. Problem: clutch pedal bracket
  4. WTB: SE taillights
  5. Yet another VE Stalling/Idle problem
  6. sprint springs
  7. This is one sweet car...
  8. shes dying!!! i need help
  9. What Have You Topped Out At?
  10. My Wheel Well Fell Off!!!
  11. Engine wont start HELP!!!!!
  12. Installation of new ignition coils and plugs
  13. Does climate control work on 3rd gen?
  14. Is it worth replacing...
  15. Timing belt broke. YAY!!!
  16. Security system affecting startup???
  17. Grounding VTCs...
  18. Need Help!!!
  19. Good Deal?
  20. would dis fit in a 3th gen
  21. got my car back........it still hesheshesitates!
  22. CAI for 3rd gen. / problems with TPR CAI
  23. Would this work?
  24. How to tell diff between......
  25. Door Lights Always On
  26. sprint springs with kyb struts 1990 max 18 rims
  27. Transmission Fluid
  28. 93 GXE engine problem
  29. Mileage on a 1992 Maxima GXE
  30. How do you know if your knock sensor is bad or going bad?
  31. who has an engine block they want to sell me
  32. how do you replace fog bulbs?
  33. Suspension Components
  34. Good source for suspension parts?
  35. Engine noise/ wine ( with radio off)
  36. Tossa Mechanics
  37. Tranny advice?
  38. Bottom Line about VTC's!
  39. Changed my spark plugs - car running real rough...
  40. Got my car back from the body shop today...
  41. Carbon Fiber
  42. Question on radio wiring
  43. 3rd Gen, Good first car investment?
  44. leather seats
  45. taking the A/C belt off...
  46. Attn: Max Owners Need Advice
  47. How to redout your tail light
  48. vacuum gauge
  49. ngk wires
  50. i need definate answers (suspension related)
  51. i though my maxima career was going to be over today
  52. antenna problems again
  53. paint prep
  54. headliner replacement
  55. Needed, carbonfiber hood,drivers side fender, blinker, and headlight,and a se grill p
  56. Special Tool(s) for Control Arm &or ball joint, CV joint
  57. Australians with maximas
  58. 94-97 Accord Spoiler Question.
  59. Power/Comfort Button
  60. .Org support please....
  61. My 89 won't start/ has no spark
  62. I think I found a replacement for Jagworks
  63. carbon fiber door pieces
  64. finally got some pics
  65. what bars are in a suspension technique sway bar set?
  66. How do I replace manual shift knob?
  67. Cold Axles = Strange Noise
  68. What's Your Tint Like?
  69. Who in Boston had that gold Max/chrome rims?
  70. eibach springs
  71. What Do I do???????
  72. Power Lock Problems
  73. Where is Power Supply to Digi Dash
  74. My New max - '92 SE 5 Speed!
  75. Digital Dash - ECU/ECM (quick question guys any and all answers are appreciated)
  76. Y-Pipe
  77. rear tail lights
  78. got my new max (pics)
  79. The buzzer-like noise & engine-stalling before engine warmed up
  80. molded stillen body kit?
  81. flywheel swap
  82. auto and 5-speed motor mounts
  83. VTC engage disengage confusion cleared up.
  84. Need exterior paint color suggestions
  85. Automatic transmission problem.
  86. After market front bumper
  87. 4th gen owner inquiring about 3rd gen Max
  88. clutch question
  89. Does anyone have...
  90. Simple and cheap???
  91. Turbo?
  92. Walbro Connector!!!!!
  93. 90 Maxima Transmission help and manual search
  94. engine problems when wet
  95. Proof of "Electric Turbo" Scam: In case you actually considered one.
  96. Bosch or NGK?
  97. Q about driving with no OIL
  98. Water pump replacement was easy on my VE
  99. Removing door..
  100. Motm
  101. Adapter for Bose front speakers in '89?
  102. Car cutting of problem....PLEASE HELP!
  103. life of a tire
  104. Question on Angel Eyes
  105. tranny question... im a newbie.....
  106. hey guys with E36 conv....
  107. Fabric alarm module location
  108. Rear Bumper Cover Removal
  109. "Y" pipe rattle problem found
  110. K&N question...............?
  111. Thanks for help.
  112. Installing 99 Bose HU, think I have it figured out
  113. Rough Idle when ingine is warm..What in the hell could it be?
  114. Speedometer & Odometer problem on '90 SE
  115. Help with shift lever lock-out on '90 auto
  116. 14 mpg!?!?! This car sucks!
  117. Help w/ Alarm problem
  118. How Easy Is It to Install....
  119. new master brake cylinder and dimming clock
  120. I can't understand my idle
  121. Does anyone know anything about AT Italia -->
  122. idler pully.... hissssing???? wtf
  123. Exhaust Problems
  124. Ebay Prices
  125. 93 max FSM
  126. Strange Sound while turning...
  127. magnaflow dealers
  128. Need some help...
  129. VE30 Rebuild
  130. Need help with finding tie rod end bushing/grommet
  131. Moderator
  132. Bags or Performance?
  133. Any ORIGINAL Owners Out There?
  134. New DVD Pictures!
  135. Rear end problems, need advice.
  136. Venom PCM
  137. Survey: B&M Trick Shift fluid
  138. 94 SE O2 Sensor
  139. Drove off a curb
  140. Rear Defrost
  141. Whats this?
  142. JWT ECU $$...is this right?!
  143. Gas mileage & Broken exhaust studs
  144. how to remove crowl panel?
  145. Best Octane To Use In VG30 Max?
  146. Battery and Brake light, Alternator
  147. Exhaust Stud Replacement? where?
  148. Variable Valve Timing, 1992, someone please tell me about it!
  149. I WANT 240 hp
  150. Fuel Filler Recall Update (I just cant win)
  151. Instrument Cluster from a '92
  152. Single disc player for 3rd gen
  153. Maximum Tuning VB mod problems.
  154. O/T: did your forum color just change...
  155. What IS coming out of the muffler?
  156. Stock Bose/Sony CD player
  157. water pump not so bad w/ help
  158. Bad ECU :(
  159. 6th Gen, 3rd Gen
  160. 2 Days In The Shop!! (recall)
  161. intake tubing
  162. Safety/accident stories? auto shoulder belt?
  163. ECU Setting
  164. re: oil burning smell
  165. 6th Gen Maxima
  166. Stereo Problems!
  167. Tranmission or ????
  168. maxima despair
  169. maxima despair
  170. 0-60 times?!
  171. unsteady idle after system install....
  172. Anyone replace tie rod ends?
  173. White 3rd gen in super street
  174. Intrax or ST's in the from, Eibachs in the back??
  175. Normal RPMs??
  176. Idle rough when warm
  177. Question about cryo treatment
  178. odd engine noise, suggestions?
  179. Dumbest thing u did in the snow in your max?
  180. High Idle
  181. my 3rd gen has a crazy-irratic idle in gear
  182. Aftermarket Steering wheels
  183. Cylinder Head Temp. Sensor DEAD!!! HELP!!!!!!!!
  184. Cost to rethread Engine Coolant bolt hole.....
  185. Hot & Cold air selector is stuck.
  186. struts and stuff
  187. Gruggling or water sound from dash
  188. Fuel Injectors - Black or Blue?
  189. If You Have a '90 GXE
  190. How much does the 5-speed tranny weigh?
  191. 92 Maxima Heater Issues
  192. weight differences
  193. high vs low idle
  194. monroe sensa-trac struts/shocks
  195. are e36 same as e38
  196. Would 5 spoke look better than 6 spoke?
  197. Need adapter to fit 2 din Bose HU in my 91
  198. Hey I know you guys must know what to do!!!
  199. Hey I know you guys must know what to do
  200. R.I.P. Jagworks
  201. What to buy?
  202. Tempermental Keypad
  203. Idle control screw??
  204. Funky Heater!!!
  205. Seatbelts
  206. Power Steering
  207. Poll: important decision
  208. Using stock rotors with 300zx calipers
  209. Problem with Keypad/Security System ?
  210. Does Anyone's Heather Totally Suck??
  211. New Pics
  212. Battery Options
  213. Mounts
  214. Rear and front speaker install...
  215. butterfly knife key
  216. Help! Broken antenna mast!
  217. pace setter short throw shifter???
  218. Automatic Tranny Survey
  219. car sluggish; slow trans. fluid leak (i think) or is it bc of the cold?
  220. Water pump replacement..............Check this out for me..........
  221. fuse keeps going out
  222. Thermostat on 91 Max?
  223. Degreaseing
  224. idiling
  225. shaking
  226. Weap Hole Blues
  227. adj suspension
  228. Shocks
  229. R-33 tail lights
  230. Dash-Switches bulb replacement
  231. What's the best degree to set the timing to?
  232. I need pwr Antenna
  233. gxe cup holders
  234. Misfiring and window not going up
  235. LCD Display for MP3/computer in trunk
  236. Transmission, Replacement Questions
  237. Replaced Master cyl and ABS pump still spongey
  238. soon to get a new maxima got Q's
  239. Bose radio suggestions
  240. Bosch O2 sensor: compatibility issues???
  241. VIN lookup
  242. Need info, think I have a floating valve
  243. intake maf adapter
  244. Great Deal On Bmw Ellipsoid W/ Halo!
  245. Anyone have Pics of a Maroon SE with Black int
  246. Do 1993 SE's have airbags?
  247. Greddy Exhaust and y pipe
  248. 300 zx shifter
  249. How can I fit a CAI in a VG?
  250. axles qustion
