- jwt ecu install. help?!?!
- leather seats
- Green Mark, Yellow Mark??
- I picked up the car today
- Shifter Clunking Noise
- Got The Cup-Holder...
- 89 ball joint replacement
- for all you techies and want to know hows
- quick question about a 93 maxima DOHC
- 93 nissan maxima blower problem.....
- Positive Battery Cable
- VTC noises ... must they be fixed?
- burnt smell
- 240 SX K&N adapter
- Ecu
- Knock sensor and O2 sensor
- new max, new problems
- 3rd Gen radiators
- Blehmco ground kit?
- Some advice and a question
- Frozen e brake
- searching for good alarm
- Auto Climate Control
- VI system
- removing engine 91 4DSC
- Y-pipe for a VG?
- 5 speed conversion questions
- So I drove a VG today
- ECU Pin/Wire diagram?
- sorry, more things i would like to know. MODS,MILES,SHOWCAR!!!
- Climate Control not working, please help
- port and polish heads
- for my 5000th post I give you
- Please help: Where or who is the guy that was giving away rear passenger seats?
- Stillen Short Throw Shifter too HOT!!
- speedometer dont work still
- Need a couple socket sizes
- lightened pulleys
- msd ignition
- in-dash dvd
- 3rd gen parts
- more money. more problems!!!
- Keyless Entry Recommendations?
- auto shifter locking up
- window really slow!!!!
- Paint Codes
- Engine Idle - Gas smell (91 Max)
- '89 Digital Dash
- max has no bounce!
- I'm new, nice place you have here.
- electrickTrunkPop in 89-91se in addition2stk
- Shifter mount
- suspension decision!!!!
- se spoiler
- OE thermostat
- stainless clutch line replacement... no idea
- "my neverending problems" finally fixed
- More trouble for my 92se
- battery terminals
- tubing?
- old suspension thread
- The Bose Amp repair thread
- Idle jumping 92GXE
- brembo brake kit
- e36 headlight w/angel eyes
- bulbs
- Injector stuck wide open help!?
- 9004->9007 conversion
- gauge console
- Looks like I have the only UR DOHC UDP in the World! lol
- Black Trim
- 1990 5speed max
- 89' parking lamps question
- I wanna know how to upgrade my maxima GXE
- Radio fun...
- hella fog lights
- what are these streaks on my pressure plate? (pic)
- Install Driver lights?
- Alignment after springs/struts
- anything wrong with remanufactured clutch parts?
- 1994 Maxima
- suspension question
- window roll up!!!
- window regulator
- Oil Pan Bent In
- Front Axle Replacement
- Speakers: Diamond Audio (will these fit?)
- will theese rims fit on my max? quick yes or no
- carbon fiber sunroof and trunk
- roof rack on maxima?
- Warpspeed vs. Place Racing
- VE noise
- camschaft question
- Need Advice
- help on knock sensor
- Rusted out brake/fuel lines
- gauge lights
- cv boot..
- engine swap
- Engine Swap Idea
- spark plug wires
- E36s installed, check it out!!
- Help! I'm Misfiring!
- Big brake Kits?
- 92 max shuting off while driving,5sp dohc ( help)
- 92 SE Not Running (MAF Problem or ?)
- Need help with KYB GR2s! (rear)
- Max '93 - Door locks security code
- 1991 Maxima radio flame out
- Coilovers
- O2 Sensor....?????
- Fuel Injectors
- Engine Swap...
- VE timming chain issue after VTC rebuild, Need some help guys
- Idle control valve and intake couplers on VE?
- car shakes like crazy
- need quick advice on cracking tranny open
- antenna problem
- hey guys maxima door problem
- Removing The Taillight Housing
- Temperature Gauge Fluctuation
- 5 speed conversion question (need your 2 cents input)
- a cylinder down
- No reverse lights help!!
- Brake & Battery Lights Both ON + Rough Idle
- Maxima Running Real Bad
- heating issues
- VG - Lightened Flywheel
- Were can I get my Max Painted?
- Rims
- 92'vlsd,5-sp in my 91 non vlsd 5-sp???
- big driveabilty problems
- Where Can I Get The Best Deal On A Turn Signal Combination Flasher Relay?
- YAY! It's that time for heat problems...
- WHERE IS THE "FAST IDLE CONTROL VALVE" OR "IDLE AIR CONTROL" LOCATED ON A VG30E
- timing issue
- valve cover gaskets cont.
- Why is my car slow?
- 1990 se auto tranny
- why is my car fast?
- no AM reception..wierd
- body kits
- Odometer one more time
- question for you 90 gxe guys,
- Back Seat
- My Max Hit
- How to remove front bumper and lights?
- Transmission modification
- dim gauge cluster lights! HELP PLZ
- !help! My Maxima Doesn't Idle Up When I Use A/c, Headlights, Accessorsries,ect.
- !help! Turn Signals Not Working, Front-back-dash Arrows
- Lighting Chart
- Fixing your dead clock - take 6
- SE Spoiler on a GXE trunk...
- Recommended OBDI diagnostic equipment?
- VE or VG?
- Problems wit maxpowers idle
- brake light swap
- Installation of FOG light help!!
- Auto Transmission Help!!
- stillen brake lights!
- preffered clutch in the ORG.
- need help!
- need some help with my 5 speed
- howdy
- howdy
- Engine Oil Leak/Burning up?
- Fuel Delivery problems? Pls Help.
- interior upgrades..
- Manifold stud repair/shortcut?
- Using vin to check for ABS (vin decoder?)
- Altima MAF adapter
- Please Help With My Ve!!
- Need write up on bmw headlight wiring
- No power Radio,trunklight,steplights,glovebox
- ticking sound not on a ve
- ABS Problem
- whistling noise
- Post pics of your body kits
- VE30DE has to go, what to replace with?
- Keyless entry/alarm compatability question
- corner light bulb size?
- Gas Smell and Clicking Noise
- Slow Oil Leak?
- Extreme Rattling HELP.
- JWT ECU and gas problems
- Head up display
- pacesetter headers update
- break-in for new cars
- What front axles do I need???
- fixed gas smell in car, but now a new problem starting. i love problems
- Arrgh I'm stuck (i Think)
- grounded vtc car sucks
- Replacing injector. Have couple questions.
- I blew something...
- What is this? Light Bar?
- dash, tail, parking lights not working.
- overdrive problems
- moisture in head lights
- Fuel filter replacement
- Speaker question
- Quick questin...
- How do you remove the plastic on the B pillar?
- Will 2k wheels fit
- A/C Heat Blowing Vents
- I'm getting code 51 and 32 at the same time
- Need ideas for Fixing a 90' Maxima SE
- Finally pic vg turbo
- '91 Sunroof Leak; Where to find replacement seal?
- AC/lighter Power Outlet Doesn't WOrk
- VG Tranny Question
- Getting an extra VE!
- just bought 4th gen seats
- Car is finally done....
- guage lights please look!!!
- The Mind Boggles...
- 93 SE for sale?
- gxe brake upgrades
- Motor Mounts
- 3RD & 4TH GEN COMPATIBILITY
- Help a Gross Polluter
- big *** spoiler
- I "winterized" my Max today
- Sweet sounding advice.
- VE30DE doesn't start (HELP!!!)
- Wiper Refills to replace Bosch's
- Power Window Help "PLEASE"
- crank pulley trouble!
- Sorry
- Eibach Pro-Alignment Kit
- 93 DOHC 3.0litre, timing issue
- VG30de perofrmance
- Bedding rear brakes?
- Ve30de Turbo
- I am looking for a good mechanic in Minnesota...
- Have to replace the brakes + Rotors - what to get?
- engine rebuild questions
- 95-96 Bose HU
- Need Help With New Speakers
- intake manifold question
- Abs....
- resetting computeri
- 1989 Maxima Heater Core
- Squirelly steering
- Bolt pattern?
- AT gone bust... =(
- speaker grills
- Tranny flush?????
- I just bought a Maxima!
