PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 [108] 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. how to fix small dent on driver's door
  2. Please help me
  3. ? Y pipe
  4. not pealing out
  5. Almost rear ended today
  6. List of wanted mods..very..very bored
  7. Brake lights not working!
  8. ATTN Maxima Owners! Opinions wanted!
  9. still missing!!!!
  10. Bye
  11. marine oil???
  12. auto max question
  13. Where to change timing belts
  14. I just cannot break into the 14's. And i'm getting mad!! need help
  15. AC, gauges, tailights, corner lights NOT WORKING
  16. Cold-air cooling the throttle body
  17. help!?!?!
  18. tricking the ecm: a solution to the "engine heat soak" problem?
  19. BOSE fuse
  20. something weird to check on
  21. Odometer wire location??
  22. Looking for Leather Seats
  23. Noise coming from my car
  24. Where to find a new antenna?
  25. Fuel Economy
  26. Need a VIN Check on CarFax Please
  27. Dead maxima... need some pointers and help
  28. Brakes...
  29. Polished Rims
  30. Hesitation at first, now it won't even start
  31. What muffler to use?
  32. Headlight Wattage ??
  33. Warp Speed Performance Y-pipe wait.
  34. help....abs valve unit
  35. 100,000
  36. $64,000 Question...
  37. OT: Nismo1989 / Geoff
  38. Nissan Parts
  39. digital instrument panel will not light up
  40. Installed Euro Reverse Indiglo Guages Today...Photos
  41. *<Want to replace 1993 Max SE Engine>*
  42. engine misfire?
  43. Fixed My Bumper and Antenna
  44. what sould i do
  45. noise from the wheel?!??!?
  46. Mud Guards
  47. Struts
  48. pwr window
  49. Nissan Engines
  50. Gas Tank Started Leaking
  51. VG30DETT 285 hp Twin Turbo engine
  52. Headlight Problems
  53. Some questions
  54. tint question
  55. Clutch Problem!!!!
  56. Pics Of Hidden Armrest Cupholder
  57. Found ABS problem
  58. Window Problem's Again
  59. Problem With my ABS! Help
  60. Transmission slipping problem
  61. anyone ever do a 4th gen sterring wheel conv.
  62. cooling system air bleed valve ???
  63. Door problem
  64. More then Interesting www.tilleyfoundation.com
  65. carbon fiber hood???
  66. wireing diagram for a the dual radiator fans?
  67. SCCA Pro Rally
  68. Compression tester question for VE and maybe VGs
  69. Got Carbon Fiber?
  70. lowering problem
  71. Tranny Click
  72. Is my tranny acting up???
  73. Intermittent Engine Stall--Help!
  74. Carbon fiber hoods are on their way!
  75. cai?? POP?? combo??
  76. cv joint or drive axel?? Clicking on turns
  77. cupholder
  78. Spring/shock install
  79. axle and bearing gone... please advice
  80. where are Bose amplifier for rear speakers
  81. Inspection
  82. New Muffler is TOO Loud
  83. anyone w/ an extra corner light wire harness?
  84. good engine for my gxe
  85. vg engine running lean help
  86. Westheimer
  87. Fuel Pressure Gauge
  88. pictures that work of my max
  89. pics of my 91 se wit 18s
  90. just ordered my ACT should be here wednesday...
  91. pic of my max
  92. and here, we have a monkey with four....
  93. Finally got engine running BUT!
  94. HKS Style Filter???
  95. Valve adjustment specs
  96. Problem that started after install of intake
  97. Help with springs and shocks...
  98. Anyone receiving their CF hoods?
  99. fuel injectors!!??!!??!
  100. Its got its share of problems (new guy)
  101. Lookin to become a 3rd Gen owner
  102. Love the tires.
  103. Spring Install
  104. Tranny code question.... ??
  105. Question about CAI install
  106. Finally have a tranny cooler
  107. White smoke?
  108. wiring codes for stereo
  109. Seems like my car already has a sort of CAI?
  110. Need Help With A Meltdown Problem
  111. 17's or 18's?
  112. Sold the maxima
  113. Cash fer a Max
  114. comfort/power shift button doesn't work
  115. Possible newer max for me soon (I hope)
  116. confused
  117. fuel filter question 300zx & maxima
  118. clear corner problem
  119. is it possible to do this?
  120. Just got some 18's
  121. help on installing intake
  122. reprogramming the security pad
  123. auto tranny slippage question
  124. Where to buy fuel injectors?
  125. temp guage also wacky
  126. ABS Problem
  127. 3rd Gen exclusive performance electronics
  128. You see what's wrong with this
  129. Bose amp repair (new user)
  130. Gear ratios
  131. Wacky Temp Guage
  132. ignition coils
  133. Tachometer speed chart for broken speedo
  134. Strut bar
  135. re : clear corners
  136. website
  137. teach me some stuff
  138. Brakelight covers or tint?
  139. Annoying rattle from the front...
  140. Timming a VE that has had its CAS removed
  141. newbie questions. sorry
  142. engine swap
  143. Engine Swap
  144. Dumb Qusetions that I need to Ask
  145. differences in the doors for the maxima
  146. Those of you W/ PR CAI......
  147. Tranny Change on my 94 SE Max
  148. Putt Putt 3rd Gen?
  149. wheel offset
  150. Any good/bad experiences with Engine Importers?
  151. What controls the warning light?
  152. Wanted 93 Maxima Bose Speaker+Amps
  153. I have this squeaking and grinding noise
  154. electrical problem
  155. Look what I recieved!
  156. please help im new
  157. Help with Knock sensor
  158. Rear turn signal housing question...
  159. Horn Trouble
  160. Question on tranny swap
  161. what does offset mean ?
  162. important, 18 inch question
  163. Squeal From Speakers Or Deck
  164. lowering springs and struts
  165. overpriced?
  166. Good Mechanic in Louisville?
  167. Rear spoiler disintegrating
  168. UDP and AC
  169. Fuel injector harness repair/replace??
  170. Might be getting 18" wheels.....
  171. I want a Maxima as a 2nd car, but what's up with the broken trannies?>
  172. succesfully changed my control arms today
  173. Goodbye all my good 'ol 3rd genners
  174. Tranny trouble
  175. Carbon Fiber Hood Thread
  176. alternator problems help!
  177. Hey Guys, new to the forum, with a troubleshooting question.
  178. Headlight warning chime intermittant how to fix?
  179. Ethanol
  180. Cam noises?
  181. trouble codes
  182. Why don't we ever get in on Group Deals!
  183. Grounding VTC's
  184. something in the trunk????
  185. That's not right
  186. 93 and 92 bose match ??? pls answer
  187. 1992 Maxima won't crank
  188. removal of stock deck
  189. rims from my eclipse to my max???
  190. Place Racing Cold Air Intake
  191. Spoiler or wing?
  192. Save Money on car parts
  193. sturt bar?
  194. Mod q's
  195. VG33et...
  196. Humming sound while stopping before Traffic lights
  197. Whining Engine--Can't take it anymore (92 GXE)
  198. Going to the junkyard tomorrow . . . anyone need parts?
  199. Performance Chip Q's
  200. I have searched... new problem never discussed before
  201. Fixed VTC noise issue...
  202. De-Bosed my max
  203. Maximas crashed by NationWide
  204. Choking? Skipping? Jumping? what is it??
  205. shox.com stuff
  206. Alarm Problem
  207. fuel injectors
  208. damn what a crappy day...
  209. Intake manifold
  210. Help! Electrical system problem...a bad one
  211. high pitch engine sound under accelaration
  212. testing vtc from ecm
  213. Need Engine & Opinions
  214. Changed engine mount (front)
  215. Weird problem
  216. engine stalls at idle, sputters between 1500 and 3500 rpm... plse help
  217. Varad L.e.d.
  218. suffolk ny piece out 90gxe
  219. Basic tune up???
  220. Vtc
  221. 3rd Gen Sighting in Chicago
  222. Tinting tailights?
  223. Another NOS Question
  224. need someone to look under their car for me ASAP -->
  225. few questions on power
  226. Parts car in for sale forum..
  227. Greasy interior windows
  228. ridin on 2 wheel stud
  229. sprint drop question
  230. stock alarms saves...system/rims/car AGAIN
  231. Finally the Greddy exhaust is in and being put in
  232. Finally fixed my dead speed sensor!!
  233. Now that I am selling....
  234. suspension q, help asap please
  235. Fuel Flooding
  236. maximum HP possible from N/A 3rd Gen
  237. CV Joints
  238. 1990 wiring question
  239. rear seal
  240. Hey everyone, new to the board
  241. My webpage done!
  242. Wheel Stud?
  243. Window Jammed/ Just Replaced the Regulator
  244. correct NGK spark plug for a 94 SE
  245. interior
  246. HIGH PITCH SOUND on Stereo.. T.T
  247. My max is slowly dying
  248. New Pads and Rotors
  249. '94 gxe owners manual
  250. Help!!!! Window Wont Come Back Up!!
