PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Distributor Rotor Bolt
  2. happy new year
  3. this ever happen to you
  4. LSD or non-LSD???
  5. VG3OE knock sensor
  6. maxima won't start when it's been raining
  7. gauging out a possible trade or sell
  8. heating problem
  9. 1992 Maxima engine whine (tried searching)
  10. Wrong MAF?
  11. obx headers and y pipe
  12. New ECU? No FI pulse on one cylinder.
  13. Any Canadian 3rd gen members?
  14. Vg knock sensor
  15. Timing Issue: 1994 Nissan Maxima GXE SOHC
  16. 93 maxima exhaust manifold
  17. 1992 Maxima SE dies randomly
  18. ecu problem
  19. New struts going in....fast!
  20. Engine running bad...need help diagnosis
  21. 91 Maxima SE - Bad Thermostat?
  22. 3rd Gen Coil Spring Advice (NOT THE COIL OVERS!!!)
  23. 94 maxima need surge tank and canister hose diagram or pics
  24. My 94 GXE
  25. A long 3Gen history coming to an end.
  26. ve tranny sale
  27. Engine knock
  28. my maxima
  29. Rebuilding my turbo 3rd gen with big goals.
  30. rear seatbelt location
  31. shudder in reverse
  32. how do i get accepted on Facebook?
  33. video of my 92 se
  34. mirror ground wire
  35. 1990 Door Lock not working?
  36. 3rd Gen FSM?
  37. A little help on FI sub harness wiring?!?
  38. struts
  39. Replacing The Oil Pan Gasket
  40. Another "Car barely starting" thread
  41. obx hearders problems
  42. thermostat housing problem
  43. which relay?
  44. New owner of 92 Nissan Maxima
  45. Long cranking before starting
  46. transgo or valve body upgrade opinions
  47. possible to get bbk anymore?
  48. Electric door locks.
  49. 3 fixes: Shaking, sputtering, and noisy pulleys.
  50. wtf swap tranny still same problem
  51. Clutch Pedal no resistance, does not disengage clutch
  52. A little help!
  53. help plz
  54. Trying out 4th gen temperature sensor
  55. Abs error code %
  56. Newbie replacing VG30E
  57. yup it runs..
  58. Changing steering wheel
  59. where can i find transmission parts
  60. need help with identify transmission
  61. 1990 Maxima cruise control not working
  62. newbie of the day
  63. Manual transmission grinding noise???
  64. 3rd gen Addco rear sway bar
  65. I changed my Maxima injectors for another kind. (Chevrolet Astra)
  66. Lowering Springs availability
  67. found transmission leak help
  68. 93 se revival - 87'octane use and oil on my plugs
  69. 94 maxima SOLD :(
  70. Windshield and trim removal
  71. Digimax VG auto to VG manual 5 speed
  72. Oil recommendation for 1993 Maxima.
  73. What car are these for?
  74. 92 gxe electrical help
  75. Nice Max at the junkyard...
  76. WTB 3rd gen fuel filler neck
  77. Rebuilding Engine or Buy used?
  78. Keypad Replacement Time
  79. i really dont post enough,lol
  80. Burgundy Dash
  81. Expansion valve
  82. Is there a facebook group For maxima fans?
  83. 1992 Maxima SE / (4) four fuel pumps since 2005
  84. 1991 VG broken exhaust studs
  85. 3rd gen fuel filler door spring
  86. What does it mean when my SE power light flashes when it turns on?
  87. 1990 trans slipping from 1st to 2nd
  88. Help! Intermittent start
  89. 94 Maxima Water Pump Pulley
  90. 90 Maxima Transmission quit working
  91. 91 Maxima Cruse Control Troubleshooting
  92. Just Bought 91 Maxima - Have Questions About Stereo
  93. 94 Transmission Problem?
  94. trunk reflector
  95. Leather seats, please help
  96. Maxima fuel pressure
  97. Exhaust
  98. Is it time to change my plugs
  99. turning signal fuse keeps blowing out!!!!
  100. Oh yea its that time
  101. ve turbo manifold
  102. Where do this wire belongs
  103. noob question...
  104. valve cover torque spec
  105. Aftermarket radio and amp problem
  106. 92 GSE no more
  107. A follow-up to AC settings thread
  108. turbo for sale ?
  109. Looking for GXE downpipes
  110. VE30DE - Cam/Crank angle sensor or Power Transistor
  111. Vacuum lines pop (video)
  112. Vacuum lines pop (video)
  113. AC settings
  114. ve tranny ?
  115. 1992 Nissan Maxima GXE (what's this part?)
  116. transmission rebuild ?
  117. IACV idle air control valve differences
  118. PaceSetter Headers
  119. Engine RPM going up and down with AC ON
  120. what do you guys think
  121. Lowering springs
  122. water pump help
  123. Engine swap
  124. 92 max se audio problem
  125. Master cylinder plug
  126. Ground behind rear seat back
  127. been almost a year since my max blew
  128. video of problem with shifter. help
  129. The good dirt... reman. injectors and a life well lived
  130. Rad hoses
  131. want to share a video of my ve
  132. Need Advice on a Loss of Electrical Issue
  133. turbo manifold ve
  134. obx headers installed help
  135. Best Free Mod
  136. Should I strip the interior?
  137. blehmco parts
  138. Throwback Thursday
  139. Looking for a VG30E oil pan
  140. Motor temperature
  141. very bad hesitation need help
  142. Thinking of selling the 92se ve auto
  143. small update (pics)
  144. Help identifying part under hood
  145. Need se info
  146. VE 5-speed for sale on CL
  147. radiator support rusted
  148. Owner's Manual?
  149. Engine Swapping and other shenanigans ?
  150. a/c recharge
  151. Radio doesn't work on on cold startups until a click is heard.
  152. not leaving, but branching off... pics inside :D
  153. New Owner- NEED HELP-
  154. Missing some conections Help!
  155. Discovered an interesting vacuum leak
  156. Ha HA! Seafoam fixed injector
  157. 1993 maxima rough idle bad gas milage
  158. Would it be o.k to use a 94 wiring harness on a 92?
  159. Is it true that
  160. MOOG or RAYBESTOS Tie rod ends
  161. Need Suggestions!
  162. just bought ve engine
  163. help please
  164. a little update
  165. So...
  166. dust boot
  167. Okay, two things...
  168. Audio question about a double din pioneer unit in a 3rd gen
  169. 93 GXE Wiring issue!
  170. How much time before replacign a timing belt reguardless of miles?
  171. Various Line questions with Pictures
  172. Obd1 to Obd2 adapter cable
  173. bose audio and sunroof question
  174. pic of my bmw headlight conversion
  175. before i change the alternator
  176. 91 maxima lowering springs help
  177. Por 15
  178. so pump up for my conversion
  179. Loose/sloppy steering
  180. Hesitation/Stalling issue
  181. 89 Maxima, update
  182. 92 max GSE road trip
  183. 89 maxima will run fine if I add injector cleaner but rough without it.
  184. Soon to be back in a max!
  185. Power stearing pump noise
  186. maxine my summer project
  187. Stalling Issues and wild fluctuations in RPM, help!!
  188. Transmission question
  189. For Sale
  190. My interior swap
  191. got in an accident
  192. Front Window Regulator Problem
  193. air conditioner / heater control - slides wore out on my 94
  194. So im happy how my car runs with new injestors
  195. Chain or belt
  196. Opinions on Eibach spacers
  197. Saying Goodbye 2 3rdgen!!
  198. my car updates
  199. slave cylinder smh
  200. rear sway bar replacement
  201. Auto trans part
  202. Heavy Fuel Smell Outside/Inside Car
  203. Need help with airbag
  204. emissions test - help reading numbers
  205. transmission
  206. Need help deciding on a Flywheel
  207. Heated Mirrors are sooooo 1992.
  208. tranny rebuilt
  209. Need help with cleaning injectors
  210. OEM filter vs aftermarket
  211. Bought another 3rd gen GXE today but.............
  212. Map light led mod
  213. Questions about Cold air intake for the 3rd gen VG
  214. bad driver side axle
  215. Could this be?
  216. Why did my car stop? :(
  217. Need help with injector
  218. 1994 maxima instrument cluster-odometer
  219. Fuel lines!
  220. good pair of slotted rotors
  221. do these rims fit?
  222. Think the steering rack went bad
  223. Low charge(voltage) causing misfire/stalling...
  224. Clutch Master Cylinder Swap Questions
  225. Looking for picture of CPS to compare for aligning mine for timing.
  226. Sold my Max, Thank Ya'll for the Help!
  227. Done with the VE engine
  228. Why does my car sometimes run on 5 Cylinders?
  229. A little help
  230. ve rear right motor mount help
  231. bmw headlight conversion
  232. Clutch Pedal Assembly: Weld Broke!?
  233. 3rd gen VG30E engine and engine bay pics.
  234. custom mud flaps
  235. Driver side headlight comes on by itself and/or won't turn off
  236. VTC Solenoid ground
  237. Just how tight should the screws be on the valve covers?
  238. Annoying factory alarm..
  239. Getting a VQ30DE vs VE VTC Clack
  240. Bose Amp Repair
  241. JWT s1 and s2 cams for the 3rd gen vg30e
  242. looking for any interest in shinjiduo ground wire kits for the 3rd gen se and gxe's??
  243. The Digimax is here...........
  244. bushing kit
  245. Why?
  246. Just bought a 92 se 5 speed
  247. Emotional about decision to keep or sell it
  248. Engine swap question
  249. under drive pully
  250. my FIFTH and FINAL 3rd Gen
