- So who has 240SX wheels??
- soooo cold- story
- Strange problems regarding my '94 Maxima
- VE and VG Automatic Transmissions interchangeable?
- Multimeter....Help
- intrax springs vs. eibach pro-kit
- Possibly Selling a 94 SE
- back seat Armrest
- If i only had money! what a steal
- Broken bushing on shift linkage.
- Climate control led display is dim
- may start may not start help please.
- The calm before the storm....
- Fuel Injector Replacement
- wierd startup issue
- My car stinks :-(
- starting trouble from the old gxe
- Right side (non-Bose) audio doesnt work
- Steam from Engine...
- Fiberglass and the fun it can be
- FSM on CD?
- KYB GR-2 installation help
- Instrument panel not lighting
- '92 Maxima fuel injectors...
- Control Arms
- turbo for a VG
- mph in each gear
- Does 230 Miles On One Tank In A 93 GXE Sound Right?
- 94Maxima Shift Knob Installation
- Power Balance Test......Not Good...Help Please
- strut options
- Recommended source for interior parts?
- PICS of my VE Turbo kit
- where can I get a 4DSC decal?
- i hate my drop
- replacing instrument cluster
- spokane area
- octane
- Rims
- Trunk Swap
- Putting it back on the road(for real, this time)
- Bose Audio from 4th gen in a 3rd Gen
- flip flop trunk
- pulley hell (removing)
- My First Visual Mod of 2005 will be......
- ebay adapter&filters
- It's very cold over here in Washington, hoses begin to crack
- ABS Problem
- Broken odometer - trying my luck again
- Maxima.org...
- OEM antenna
- Speaking Of Exhaust
- Air Breather
- Pics finnaly
- Cold Weather = Poor Fuel economy
- Has anybody seen this Max???
- should I rebuild the engine(VE)?
- GPS/AM/FM/cell "shark" type antenna
- 300 zx steering wheel
- fog lights
- Question for those who have done it
- early GXE tails and why they suck
- I beat the system....
- rear quarter body repair
- 1992 Nissan Maxima GXE....yes, I'm a n00b...
- heat takes seemingly too long to get warm
- Few questions...
- Flowmasters?
- Light smoker...
- did i realy blow a head gasket
- ps Short Throw Shifter anygood?... low price
- Trunk Light
- lower control arm
- Starter Replacing time...
- Cat converter
- Whos dash lights went out after stereo stolen???
- help me pleaze
- another one bites the dust
- horn problems
- i'm smelling gas man
- Oil Filter Fell OFF!!
- ATF or PSF
- Quick Question Before I Head To The Dealer
- minor exterior apperance q's
- My door locks are screwed up
- would this fit
- newb question
- Maxima Fuel Injector
- bose cd player?
- differential?
- ECU Access
- New to forums and need help
- foul odor...and gas
- New to Forum
- how do u install
- how do u install
- interchangeable seat question
- good deal?
- Omg
- Anybody broken a rear sway bar mounting bracket?
- Anyone with a WSP B pipe and aftermarket sway bar?
- powersteering Humm
- Altima springs for a sporty suspension on my 93?
- Still fighting door and trunk locks
- Car Keeps trying to stall
- Headlights Conversion HELP
- Repost (stereo Prob)
- New Style Y-pipe from WSP, needs Modification before install
- alarm issue how?
- car wont go in reverse very easy.
- 2004 Review: Your Maxima :)
- key release
- Weight of a 3rd gen?
- New maxima owner need manual
- what should i do
- Transmission Engagement, 93 GXE
- wanting to change the sterring wheel
- door won't open
- What is the Map Light Part #
- Fuel Pump
- Boosting
- 300zx exhaust manifold question
- body kit not compatible?
- Starting problem maybe transmission??
- My Head Gasket Repair Pics.....
- Pulleys
- Yellow rear tails.
- PCV Valve Location???
- Pictures of my maxima! Muahaha
- GXE performance mods
- fresh suspension got some ?'s
- Boost
- in-line permanent fuel pressure guage. yes/no
- Will my Cats Survive This?
- Speedo Stuck at 130 (89 Maxima)
- engine temp & gas mileage
- Electrical Help PLZ
- where to get new grill
- key code?
- Wont start
- Polyurathane Motor Mounts Here!
- CAI or New Muffler
- underdrive pulleys and warpspeed exhaust
- I hate drunk drivers
- Interior Lights Don't Work!!!
- Car Drives Stange While Stereo Is Turned Up
- i guess this is it
- A/C Sight
- Steering Rack Replacement
- j30 sticky tappet
- Electric turbo?
- winshield wipers dead!
- Homelink
- car randomly studders
- Car Spasms
- Possible headlight conversion?
- Maxima has been sitting.....
- Loss of 1st & 2nd gears.
- what do the letters in maxima stand for-2-u
- Plate between engine and tranny....
- chip
- HELP! I NEED a CD player!
- So i guess i pissed someone off
- Suspension Problem...Please Help!
- I'm in!! Bought a '93 SE!
- piece of junk
- Coolant Bleed?
- broken speedometer
- Those fixed their VG studs. CLICK HERE
- Why is error code 21 showing up? Only dealer can fix?
- what the F
- lower idle
- license plate bulb
- 5 speed trans fluid
- Strange door lock problem
- DIY axle replacement.
- Question for CraigB
- Where to get or make a high flow cat?
- Window tinting
- Just curious.....why are aftermarket springs bad with stock struts?
- spark plugs
- Vaccuum Diagrams Needed......
- Interesting GXE
- Anybody Got a Damn Match..........
- Front Rotors..
- Water leak in trunk
- sob bellhouse cover (oil pan issue)
- Slight engine stumble.
- Neeed a shaving idea.
- LED dash light help
- 1992 Maxima sudden loss of power, hesitation
- Bose strikes again
- Door and Trunk keys question
- Real quick gauge bezel question
- water noise
- Dash Kits from custommaxima.com
- High Idle...
- I hate being Grounded!!
- Turbo on a VG?
- 89 SE is gone
- oil pressure switch
- urgent need help
- Autostart
- fast knock sensor harness ques
- What parts do I need for aftermarket stereo?
- Fuel pressure question..........
- Car won't star could you please help
- 300zx brake master cylinder
- y pipe
- ABS Actuator Assembly Leaking
- Control arm bushing??
- old issue, we all have it
- gas and brake lines rusted through!!
- Master Kit...
- Another VTC ticking question
- shave it how????
- steering wheel adapters
- body kit anyone?
- how hard is the e 36 conversion
- im an idiot
- do they make a header
- what all can i do to my max
- insulation..
- knocking noise from behind glovebox.
- Stillen Kit
- Map Light Bulb?
- engine noise
- Steering wheel, she's come undone!
- Trip Odomoter wont reset to zero
- How do i disable the stock alarm?
- more tranny swap issues
- Maybe this is a dumb question...
- I need some help please........
- Springs/Shocks
- Doing A 5spd Conversion on 94 SE
- Calibrating the Fuel gauge.
- rattiling noise
- Oh My GOd!!!!!!!! look what i saw in another forum
- Fuel injector plug - corroded
- Bent my hood at the track today
- 2k2 muffler
- Need A Little Help, Car won't start
- question on relays
- Where can I buy bulbs for 3rd gen switches?
- vg camshafts
- Ticking that isn't my manifold studs?
- cold air intake question
- n00b signing in for duty, fellows.
- Ve or vg
- n00b port & polish
