PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. How many of you...
  2. A/T leak - pls help - see pics
  3. Overheating Issue
  4. Drive computer?
  5. Very bizarre Fuel Pump problem
  6. How do I remove the door molding?
  7. parts car is gone, new project in it's place
  8. Position Switch
  9. Torque specs.
  10. VG and VE hubs??
  11. Need help asap auto trans rebuild
  12. Transmission Mount inquiry
  13. Spacers sizing
  14. OEM thermostat too big
  15. rear manifold heat shield
  16. Does anybody remember Craig's corner/blinker mod?
  17. tuned up 92 GXE -- still idling rough
  18. Stillen FSTB and intake spacers?
  19. Timing Belt Noise
  20. Installed Aussie corners
  21. Eibach Springs
  22. Super Rare Grille???
  23. Jeffy style CAI
  24. Dam, Dam, Dammmmmmmmm!!!!!!!!!!!
  25. How to bypass Knock Sensor I've searched
  26. Weird A/c problem...
  27. Adjusting the Clutch Pedal - what happened?
  28. Rear BBK (big brake kit) brakets that use Z31 rear rotor available...
  29. TPS replacement: advice pls
  30. VSS mod?
  31. Doing condensor..
  32. throw out bearing or input shaft?
  33. Pros and Cons of the Poly filled Mounts
  34. Battery drain/usage w/no alternator
  35. What to replace on New/Used AUTO trans...
  36. Front END problems???
  37. Radio Broke
  38. Water Pump Took A Dump
  39. Car got broken into again...
  40. Fixing Broken Mirrors
  41. Lowering Springs
  42. r12 or r134?
  43. Firecracker/dynamite smell??
  44. using 4th gen 5 speed in 3rd gen
  45. Sunroof adjustment?
  46. need basic tune up advice
  47. Puller
  48. Stud Removal?
  49. Tranny issues
  50. YES! another 5 speed swap thread
  51. Heater core bypass
  52. ECU Numbers
  53. Broken heater core end from firewall
  54. Help! Drivers Side Headlight on all the time!
  55. 1992 NISSAN MAXIMA GXE Rebuild Kit?
  56. cams.
  57. Does y pipe need to be removed to replace front VG exhaust studs?
  58. VG30E Fuel injectors
  59. Turbo kit in my maxima?
  60. Spark plug wires
  61. Greddy + Addco = don't mix
  62. Radiator Fans
  63. Advice on front wheel bearing replacement
  64. REAR DOOR SPEAKERS
  65. Loss of Power in the Rain
  66. interior lighting question
  67. Can't get passenger axle out!!!!
  68. VG30E or VE30DE?
  69. How do I transport my snowboard?! lol
  70. 1989 Nissan maxima early model IAT sensor? yes or no?
  71. Anybody actually weighed their car?
  72. quick question here, does anyone know where the haedlight fuse is?
  73. Complete AC recharge
  74. Burning Brake Pad Grease
  75. Injector plugs
  76. Electrical Grease on injector plugs?
  77. MAF & Injector ?
  78. front drive axles for 89'GXE
  79. Right Hand Low Beam Problem
  80. VG Intake thoughts
  81. Rear View Camera Question
  82. 9004 bulb Headlights
  83. Spark plug wires resistance
  84. Rattling noise when accelerating:Months of trouble shooting
  85. limited slip question
  86. Stock Wheels
  87. Piston Velocity
  88. im back!!
  89. HELP!! Engine shakes violently at 1500rpm only?
  90. Blower motor noise?
  91. idle problem when a/c is on
  92. Interior lighting mod question.
  93. Tokico no longer producing HB3068 - Front Left Strut Assembly
  94. The Exhaust Pipe
  95. Keyless entry
  96. Radiator???
  97. m@d tyt3 m0dz, y0!!111one
  98. injector o-rings?
  99. I NEED HELP! AIRBAG & Batt. lights on...
  100. SO HAPPY!! :D
  101. Would a bad CTS stop car from starting?
  102. For the hell of it.
  103. Put over 1000 miles on Maxima this weedend!!!!!
  104. Rear main seal oil leak and fire!
  105. 92 VE power issue
  106. Anybody ever heard of Parts Geek
  107. The Problem SAGA Continues for my old 3rd gen...
  108. Something happened to the trunk lid
  109. BIG HUGE HEAVY THING
  110. Help with fornt passanger wheel bearing replace??
  111. Mixing Fuel injectors???
  112. Weird noise has got me worrying
  113. Squeaky Brakes
  114. 89 Maxima spedometer and brake problems.
  115. Auto Climate Control...EZCHILL helpneeded
  116. Clutch Disengage Issue "Go you stupid car"
  117. Sonar Suspension II
  118. How to adjust your front Koni struts without removing them
  119. Right side vibration?
  120. Aftermarket spoiler options
  121. How Do You Use Auto Cruise Control?
  122. Metal Brake Line Size
  123. S13 silvia power folding mirror question
  124. Where Is the starter located
  125. How to operate the keypad on your doors
  126. Whats the function of the red color tabbed key?
  127. CHTS deifferences
  128. Car Willnot Start - AntiTheft Engaged???
  129. Anyone tried AC Delco struts?
  130. Is it normal for car to run rough after injector installation?
  131. Pic request: 5-speed on eibachs
  132. should I?
  133. Sunroof glass adjustment
  134. oh no dead max help guys help
  135. Has anybody swapped/removed door panel inserts?
  136. Running Rough VE
  137. Ordered my new clutch
  138. The Conversion
  139. Planning a VE restoration
  140. Car struggled to start. Ideas?
  141. VE30DE, VQ30DE ADVANTAGES
  142. Need help ASAP! Key stuck in Ignition.
  143. Suspension Info
  144. Parts from Frontier that fit...
  145. engine problem
  146. Intake fixes, boost power?
  147. Split Boot Replacement for Outer CV Boot
  148. Car wont start :(
  149. Need help: cannot pull back knob
  150. Knock sensor question
  151. My 1993 SE WORK IN PROGRESS
  152. knock sensor
  153. custom CNC'd camber/caster plates top and bottom mount.
  154. Driver side Axle removal?
  155. Maybe Im stupid
  156. Door trim/Mirror removal
  157. Small motor turning on.
  158. Window tint
  159. Rear parallel link bushings
  160. Wheel Bearing and Axle seals?
  161. My first maxima and my first car got damaged this morning!
  162. Are 2nd and 3rd Gen Belt Idler Pulleys the Same
  163. 91 MAX totaled
  164. P/S problem
  165. Starting Problem??
  166. New wheel and tire fitment
  167. Brake improvements
  168. Anyone watch "COPS" tonight?
  169. VE accident :-(
  170. Does the P/S system on 3rd gens overheat?
  171. whats wrong with my car...please help!
  172. Buyin a used car?
  173. cylinder/tube in trunk
  174. KONI no longer producing front strut inserts
  175. 5 years - 5 days
  176. painted 05 Maxima 17" wheels
  177. Stillen kit with mesh style wheels... pics?
  178. any way of knowing milage
  179. Max iS back on the Road with a new problem!
  180. Looking at a 94 SE Auto Max...need some advice
  181. VE Head Bolts
  182. what would happen if I disconnected my battery for a while?
  183. new battery options advice please
  184. tranny problem need help
  185. Mobil 1 synthetic
  186. e36 write up
  187. just changed plugs :)
  188. What parts fit?
  189. A little update.
  190. Corbeau Baby
  191. I am back in the 3rd gen family
  192. Jut got my alignment and...
  193. To kill 2 birds with one stone!
  194. Nissan Maxima Digital Dash and HUD Swap Tutorial
  195. Welp There goes my Water Pump..
  196. Installed JWT ECU Finally!
  197. Auto climate, Blower Hi Relay
  198. Hud position
  199. Swapping ECUs
  200. pull-a-part tomorrow!!
  201. Who is this w/ VG-T for sale in AZ?
  202. Testing Oil
  203. long time no see, POWER STEERING issue
  204. 93 Max overhaul..the plan
  205. Dash Lights
  206. double whammy question.
  207. paging Jeremy Jabaay
  208. Is something wrong with my transmission?
  209. Intake Tubing and a rpm bounce Q
  210. Thanks for everything people......
  211. ITBs On a VG30e?
  212. $1500 to spend
  213. Replacing y-pipe
  214. Need some help with this problem!
  215. engine upgrades?
  216. Anybody remember Craig's seatbelt light fix?
  217. se cluster help
  218. Not Riding Dirty Anymore!
  219. rolling back km on a cluster
  220. Timing belt marks question
  221. Friend needs VE help
  222. How much fuel injection hose to use?
  223. Different front pads with drums?
  224. fuel question
  225. motor oil
  226. Did a run on the Dyno!!!
  227. torque converter lock up?
  228. fuel leakage turns into other problems?
  229. loud noise from engine on the freeway
  230. Check light upon acceleration
  231. Spring Maintanence: Oil Filter Comparison Study -
  232. Z32 NA wheels too high offset for 3rd gen?
  233. car whiplash
  234. wrecked my maxima
  235. misfiring? kind of odd thing today
  236. 92 maxima wiper problems
  237. Keypad suddenly does not respond
  238. New Car Y'aLL! (OG's wur you at?)
  239. video question about my speakers
  240. CLUSTER, SUNROOF AND REAR DEFROST NOT WORKING
  241. Update after removing heads
  242. Power steering ?
  243. Can someone tell me what the purpose of this part is
  244. 1989 nissan maxima injector problem
  245. New AFPR Installed!!!!!
  246. something new yet again with my GXE
  247. See if you can help me with this miss...
  248. Stop the Squeaking!!!
  249. New muffler time! Help me choose
  250. rim refinish opinion
