PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Corner Light Rewire #3
  2. Drivers side halfshaft installation SUCCESS! Woot
  3. Weird problem, help!!
  4. New diagnostics tool
  5. Gauges
  6. horsepower gain????
  7. Having trouble pulling the halfshaft out...
  8. Will these fit my car???
  9. Quite Exhaust
  10. any thing wrong with stock???
  11. am fed up right about now
  12. tranny prob.plz read this thread and help.
  13. Question re dash backlights..
  14. no beeps when locking the car
  15. first time at the track
  16. My next ride
  17. TPS malfuntioning?? Help!
  18. Posible?
  19. Leaking ABS
  20. Speedometer acting strange
  21. 1990 SE timing belt change?
  22. UPDATE: Finally got my spoiler installed + sum goodies...
  23. first tune up on my own please help me do this right
  24. 3rd/2nd gen VG30E differences? and a question.
  25. Knocking/Ticking, but goes away after long drive
  26. 91 And 92 Se
  27. '92 SE clutch inop
  28. Turbo a 94 Maxima SE?????
  29. Lowering
  30. Bad gas mileage after servicing the car
  31. need diagram for 92 max se ECU
  32. ABS light on and making rubbing sound? HELP
  33. SE in Colorado
  34. how much to get windows tinted?
  35. Re-Attaching the side molding on doors
  36. control arm bushings
  37. A caveat regarding the manifold studs article on 4dsc.com
  38. Relation between ABS sensor and EBrake?
  39. 1989 Maxima Lower Control Arm Bushings
  40. ECU and TCU
  41. New Engine?
  42. are there any cai for the vg
  43. Parting out 91 GXE
  44. How realiable are Maximas?
  45. VTC Rewire
  46. Remanufactured auto trans for $895
  47. brakes....ugggghhhhhhhh
  48. 92 GXE injectors - can't be reman'd?
  49. Matt's Product of the Day: Engine Ground Strap Kit for VEs
  50. Bolt Question
  51. Bypass hose?
  52. Exhaust leak noise when first starting out
  53. blown fuel pump fuse
  54. Electric Supercharger
  55. Replacing Distributor Cap & Rotor....
  56. Clutch Pedal Click
  57. THrottle body
  58. Fuel Injectors Harness
  59. Heater does not work, HELP!
  60. combinging warpspeed and jwt ?!?!
  61. overheating
  62. Intake for 3rd Gen?
  63. Trip to the track and still no 13's!!??
  64. Power Cut off
  65. Looking for a air flow meter
  66. Automatic Transmission
  67. rear camber adjustment for 3rd gens
  68. Water pump removal problem 93SE 5sp.
  69. you guys with ebay/autozone cone filters
  70. clicking when shifting
  71. another alternator question
  72. 92se-wierd noises & more...
  73. Fog lamps
  74. @#$&^ Timing Belt Sprocket
  75. Tranny issues
  76. Valve Cover Trouble
  77. Timing adjustment
  78. Running High Temps after Water Pump/Therm
  79. installed new alt now rpm gauge jumps up and down a lot
  80. anyone need console lid (arm rest) refinished?
  81. mirrored signal lights...
  82. getting rid or drums in the back??
  83. Just got a new max What should I do to it ? shooting for mid 15's!
  84. WOW.... Long time, no see ppl
  85. what should i do first???
  86. Looking for Mechanic in Phila
  87. In The Market For Bigger Brakes, Need Suggestions
  88. suspension techniques swaybars!
  89. NOPI and Isabel
  90. Why does my Greddy not fit????
  91. Help!!!!!
  92. engine/trransmission
  93. Nice 3rd gen for sale check it out
  94. replacing 92 GXE injectors - a few questions
  95. Weapon-R / Dragon-R Intake Filter
  96. Megan Racing exhaust...
  97. Does this really work?
  98. Update on addco rsb
  99. Alternator
  100. starter help
  101. Gettin some work done tomorrow....
  102. oil pan leak
  103. Front Crankshaft Seal Replacement
  104. Folding downs seats, taking orders
  105. Poor mileage
  106. ve CAI ? sorry
  107. Trouble getting into 3rd?
  108. 0-60
  109. Check out this break light sticker.
  110. master cylinder????
  111. Novice needs exhaust help (Warpspeed? etc.)
  112. Key for a 1992 Nissan Maxima.
  113. New Mods Added, And little Problem with My max
  114. Keyless Entry
  115. Car and steering wheel shake!!
  116. odometer/speedometer question
  117. Anybody here replaced their steering rack?
  118. Manual Tranny Question...
  119. need a computer for the max ASAP
  120. exedy clutch
  121. LSD available with A/T?
  122. www.car-part.com
  123. Codes? Sorry noob question..
  124. Just had rear exhaust manifold replaced...
  125. Another newbie question for the Knowledgeable
  126. Help I Am New
  127. Suspension
  128. Help! TV / DVD wont turn on?
  129. Warpspeed Setup Questions
  130. Electrical Problem
  131. wanna get fuel system cleaned...what to do?
  132. Help Rough Idle Problems
  133. miracle stud fix?
  134. Nissan Maxima SOHC Front Strut Brace
  135. emergency!!!
  136. I may have located some poly suspension bushings and bumpstops
  137. Need a pic of oem pws hose at top?!
  138. How to swap my odometer
  139. What Do You Recommend Me.........
  140. i hear a knocking noise form the engine!!
  141. bosch platnium 4
  142. ticking sound....v.t.c.???
  143. I need help choosing, from someone who knows.
  144. Heat doens't get hot on 94 GXE
  145. shift_money hole....
  146. Priority Repairs
  147. ABS Sensor
  148. Raidator hose (what is is called)
  149. Spark Plugs
  150. What is this white buzzing box under my dash?
  151. one of my exhasut manifold studs are broke???
  152. 300zx TT injectors
  153. Power locks and keypad
  154. paint
  155. Door Inserts...
  156. What color Zone at Nopi
  157. Low idle miss
  158. Window actuators?
  159. 1990 Transaxle/CV joints
  160. Kilometres or Miles
  161. Need New Bushings! Help!
  162. Car skips or stumbles @ 65 mph
  163. What kind of Oil in 94 Max gxe? Simple Help
  164. Hawk brake pads???
  165. NGK Platinum Spark Plugs with NGK Wire Set
  166. Engine and Tranny advise
  167. Had whole exhaust installed but have sound
  168. Its gone and its never comeing back
  169. window regulator
  170. HELP! ALL New Exhaust - Magnaflow is Deafening!
  171. Timing belt on 89SE
  172. autozone power steering hose-wrong #
  173. Need New Bushings!!!
  174. Central Florida Maximas (moderators, please dont delete)
  175. Bad, or dirty fuel injector
  176. lowering springs
  177. Lost blinkers......
  178. Seat belt alarm/relay location needs disconection
  179. Downshifting in An Auto
  180. I Need Help Swapping Engine!!!!!!!!!!!!
  181. Its good to have freinds with 3rd gens
  182. Automatic transmission
  183. 92 GXE replacing fuel injectors
  184. 3rd brake light
  185. Who has a cold air intake in their car?
  186. JDM Engine for 92 SE
  187. strange noise coming from engine
  188. Help, A/C electrical problem. Who can figure this out?
  189. How to turn on signature for forum ??
  190. Why Thermostat so $$$$$$
  191. First mods for 89 SE?
  192. Is it worthwhile to replace transmission
  193. Pics of my new gunmetal wheels on car!
  194. ATTN: tranny experts(long)
  195. Conversion: Tailight 92SE -> 90SE
  196. Angel eyes
  197. Power Ant. Wire?
  198. site update with *new pics*
  199. Hmm..
  200. 92 Tranny problems
  201. vg valve springs
  202. Electronic climate control backlights..
  203. White/blue light illegal??
  204. silverstars vs. xtravisions
  205. Subwoofers and electronics
  206. cilmate Air
  207. Fianlly got done with all fluids change, one qestion tho...
  208. Tranny Fixed Itself??
  209. My rear discs use different sized pads? WTF?
  210. Anyone else out there got a Brougham?
  211. Starting problems
  212. computer reset?
  213. Bye bye '88, HELLO '92
  214. Noise coming from wheels......
  215. i need help asap!!!!!!!!
  216. Check out my custom trunk.. Pics!
  217. poping noise coming from front end when hard right turn
  218. Best 3rd gen - LOOKS ONLY
  219. How to change wheel studs??????? HEEELLLPPPPPP
  220. squealing stops when brakes are applied
  221. Thinking about filling motor mounts
  222. nissanmatic fluid...
  223. Ignition cylinder
  224. Smell gas when key is cycled
  225. Mysterious noises coming from the front suspension?
  226. Courtesy Nissan Web Site
  227. problems starting
  228. finally got my max back!!!!!!!
  229. Shave rotors
  230. Advanced Timing
  231. i'm leavin...but i'll be back!!!
  232. Turbo & intercooler
  233. Carrier Bearing on a 91GLE
  234. Hey what sup guys ...just a little opinion
  235. Tranny issues
  236. Emergency!!!! Tranny advice needed!
  237. Hey, im new here!
  238. Timing Belt Replacement VG30E SOHC
  239. Question re. Tail lights
  240. Power steering making noise?
  241. the boosted max gets stuck in 2nd again!
  242. NISSAN 15208-55Y00 Oil Filter
  243. Stupid friend broke passanger door! need help :(
  244. who's going to the NOPI nats?
  245. Rear-end repair
  246. for those wanting to take their side moldings off
  247. What should I do with my tranny
  248. Bearing Noise? NO FAQ on this.
  249. how to raise idle 92 gxe
  250. engine control module '89
