- Brake & Battery Light Illuminating sporadically
- Today's project - custom auxiliary input
- Here We Go Again!@%&*(_+<>?!
- Help with a VG
- M/T Experts, Step Inside
- Bought Injectors of ebay need help
- VG30E Oil Filter Relocation Idea
- Replacing rack and pinion boot..
- Auto Trans - Not "down-shifting"???
- wink mirror quesion
- No startup after Heater Core Installation??
- Nitto Tire on Facebook, LIKE to win tires
- Shift Lock Problem
- Quick question about steering knuckle:
- I f^*#ed my car up!!! Now I gotta get rid of it.....
- Can I replace 6 greendot inj. with yellow dots?
- My Clutch Gone ???
- major brake failure. need help!
- Maxima-less driver
- another heater won't blow cold thread
- wELL
- Fuel tank filler line leaking?
- Replacing badge on intake?
- My laptop mount just made.
- New tie rod ends alignment twice still pulls right help!!
- Grille
- VE PS Pump
- AWD Maxima convertible
- thx for all the help, time to say bye to my 3rd gen
- Nismo pumpkin!!! :D
- Anybody heard of these lowering springs???
- IACV Interchangeability...
- Help, heelllpppp...not really.
- Front passenger side window
- Radiator Fan !!REPLACEMENT!!
- Do these symptoms indicate a blown head gasket?
- If you had to buy aftermarket injectors which would you buy?
- Transmission shifting at the wrong time
- Nissan tape over chrome on SE's - how to remove???
- Anybody recognize these wheels?
- infiniti J30 front brakes
- EZ spoiler hole fix
- Sour Patch Kids Commercial
- rebuilding an alternator
- Fuel injector sub-harness
- Mod spotted on nico forums
- is this a real gtr or bs
- Small project for the day
- speedometer is off
- Can you guys find my old 92 VE5?
- CLutch Problem
- Need Frame Measurements
- broken crankshaft bearing
- independent fogs :P
- Torque steering
- to anyone still trying to find AlexV
- need some help picking stuff out.
- IN CAR pic back of VE30DE upper manifold
- Put Your Tit Bits In Here
- where to get??
- Serious Oil Leak!!
- Yellow or green injectors interchangeable?
- Lamin-x installed on Aussie corners
- trip permit
- Anyone run dual mufflers?
- LOL i just had to show you guys:
- Steering Problems: Weird Groaning Sounds
- Used Or New
- what do you guys think?
- owned by heater core
- Fuel Mileage
- After lots of $ to restore 3rd gen, what Insurance?
- Engine bay connectors/plugs - where to get?
- Those flippin screws in the radio bracket
- Rolled over!
- Repairing OEM spoiler
- Who's Interested in a 3rd Gen Cattman 2.5" Catback?
- Ebay LCA
- Help with sputting of 90max
- Good junkyard find
- A few issues with my 3rd gen
- one-touch sunroof mod?
- antenna
- FITMENT QUESTION
- need help please
- Lets date myself. Looking for pics with CF hood, trunk or otherwise a black out
- The Latest and Greatest
- Pre-Engine Swap Questions (not to a VE)
- What is a good FUEL FILTER to get?
- Hello everybody.
- Matt's Restoration/Rebuild Thread
- Help ID'ing these parts.
- Has anyone tried fixing their dash?
- Operation Repo...
- question
- VG, Engine of the Day!
- Active sound system not real active
- Farwell to my last Maxima...
- Opinion: Should I jump on a local JY VE5 to swap over to my GXE?
- Bose relay location 93SE
- Rear Deck Subwoofer Setup
- Throw out bearing install. Need Help
- Quick Update
- VG Turbo question
- Time to replace the alternator - which should i get?
- Doing a transmission flush tomorrow. How do you flush the torque converter?
- Why Do I
- Anybody know how to replace the weather stripping on the 3rd gen sunroof?
- Why can I not bleed my VE?
- Getting back my max
- My steering wheel wobbles at low speed...whats wrong now?
- Anyone put HID's in their 3rd gen?
- Having Issues Wit My Starter!!!
- Stutter upon acceleration...help please
- Clickety clack, clickety clack, crunch
- Diagnostic Test...
- need info on extended wheel studs for spacers
- Fuel Pump Question?
- turbo dyno sheets
- Why is my Max idling like this?
- Identify this VE engine noise (video)
- Thanks for all the fish.
- Thinking About Installing Pillar Gauges/Pods.
- '92 SE! Battery and Brake Lights Flash Intermittently
- 10-14 ohm for fuel injectors OK, BUT...
- cat-back straight pipes?
- Long, slender middle muffler=resonator? Anyone removed it?
- Can You Tell?
- Injector replacement / Engine miss
- Electric trunk opener, "slow"?
- Strong GAS smell!!
- Radio question
- Custom Exhaust Installed Today!!!
- 3rd Gen rear wheel drive swap.
- ECU Grounding.
- ac suddenly blowing hot - compressor not cutting on
- so my radio stopped working but cig lighter too?
- A/T Shift knob
- Please help me...need to get my car running asap
- brake lights wont turn off
- VLSD Conversion
- Failed emissions high HC
- brake resevoir cap
- Front Speaker Amps
- What Would Cause My Fule Pump Fuse 2 Blow Out?!
- NGK Platinum plugs?
- My Automatic.., 1993 Nissan Maxima. 160hp or 190hp?!
- Mishimoto radiators
- Anyone know this guy?
- Trasmission noise. How long does it have left?
- 3rd GEN CHATROOM?
- rear end question
- Rear Window Spoiler
- Weird Noise comming from passenger side of car??
- Stwodahorty..rest in peace..
- Ohm test on injectors, A good spread? (Char. NC)
- Idle
- Odd 5-speed Problem
- Anyone else running Nistune here?
- What's this noise sound like to you? Tranny? (w/Video)
- Antenna Modification
- lowering springs problem!!
- Front engine mount removal??
- Help needed with 91 SE
- Lowering kit, rust, rims. Anyone ever lower there max???
- Color Code of Original Maxima Paint?
- Bose radio wont play
- Exhaust Stud Drill Bits
- VIN check
- squeek/screech when making a right turn?
- VQ30 Y-pipe Gasket
- camber bolt question
- 1989 engine pull
- Boy This ain't no Rant...it's a Celebration
- Pipe
- 3rd gen on film
- pwr steering pump question?
- Wheel Stud problem
- Pics of 3rd gens with xenon side skirts?
- power steering pump...
- I have to do something with my Max (pontential partout)
- Bomz Air Intake - What do you think?
- Dart Izumi style exhaust
- Ksport springs installed!
- O2 sensor and crank position sensor problems!!
- SOUTHEAST PEEPS!
- Guys whats the problem??
- quick wheel question
- UPDATES!!! DYNO RUN!! turbo!!
- need urgent help!!!
- Brake Line Mud Guard On or Off
- Maxima Plans. Need help, Wanted Items!
- Front Control Arm Bushing
- Turbo bad set up?
- First Time Changing Transmission Fluid
- Seafoam VS BG 44K
- problems...ect.
- Car Maintenance Tips
- A/c question
- Window tint?
- just a rant...
- Dayton
- caliper rebuilding
- whats the best engine & fuel treatment?
- Rear Rotor loose
- Temp Problem....
- aftermarket tach wiring info
- boost.. yes, turbo.. no
- StrUT MOUNT REPLACEMENT?
- Car Radio - FM Stopped working? Low Sound?
- Need some ideas...
- Suspension
- Cleaning around the spark plugs
- Car stalling/shutting off while driving
- Spark PLug fouled
- Do it yourself heat shield for cool air intake
- Need help! **URGENT**
- noob talk
- Digital Dashboard Swap to Analog
- any of you guys heard of this?
- Parts giveaway (local pickup only)
- Affordable Injectors?
- Random Maxima Pics
- 3rd Gen Maxima Roadtest
- Anyone with an 89-91 FSM (AC questions)
- My Continuing Maxima Story! (too long)
- Relay location and trim question
- Car Cut off while driving; not turning over. I'm completly lost. Help
- Budget brake upgrade
- amber 1157 bulb upgrade?
- 89 Maxima engine project.
- Speed sensor not working?????
- The End of Life
- 3rd gen dont start. has power * quick help needed*
- Just a little brake upgrade
- Oil leak can not be SOLVED!
- Who's done the e36 BMW head light swap
- there goes my tranny
- Headliner Cleaning after Coke Explosion
- 4th Gen Suspension components on 3rd Gen
- Generally this isn't good..
- very odd looking 3rd gen
- suggestions on conefilter adapter
- BELTS...
- cracked radiator
- Maxima wont start!
- VG to VE swap?
- universal cat converter
- Weird Engine Issues.
