PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. lowest springs?
  2. CAI suggestions since WSP is out for who knws how long...
  3. It's been a while but...I'm back!
  4. How is the shifting on 3rd gen max
  5. How should our idle feel?
  6. radiator flush
  7. Engine mounts... question for those who have done it
  8. Max and the Circuit Mystery
  9. Can someone tell me whats wrong
  10. Odd Vibrations
  11. Door Panels
  12. Rough shifting after rebuild...
  13. can this be true
  14. ABS problems
  15. Looking for a good used trunk 92
  16. Engine installation Q - where does this bracket belong?
  17. so i broke a starter....
  18. Painting Plastic - Anyone done it before?
  19. Gains from Warpspeed Y pipe
  20. need your help gearheads....
  21. Fuel injector removal
  22. Display Caps Part Number?
  23. caliper seals question
  24. Suggestions to replace Bose head unit
  25. I have a question?
  26. Good old "Lock Timer box"
  27. VTC problem and certain years
  28. Jim Wolf chip question???
  29. Attn: Those who's had Eibach and Intrax on their car, why did you switch?
  30. i did it guys warpspeed and G-Reddy
  31. Automatic Transmission
  32. stallin
  33. Seat Compatibility
  34. VERY good looking 3rd gen spotted
  35. 92 GXE rough idle and running
  36. For those with aftermarket antenas
  37. EGT placement
  38. body kits...
  39. new pics of grill and muffler and bezel
  40. Describe Your Exhaust System
  41. wheres the trany fill plug on a pre 92 5spd
  42. RWD conversion?
  43. Window regulator question
  44. throw out bearing?
  45. Anyone looking to install 13" Cobra rotors, take a looksee
  46. VG Turbo ( For all the VG peeps)
  47. Rear main Seal
  48. side moldings
  49. Thinking about buying a 94 max what color is the best???
  50. Grill Swap
  51. Just Joined
  52. Hope you guys find this interesting
  53. Doors wont lock with key...
  54. Midsection Trunk Lid...
  55. advanced VTC question
  56. Who has an oil pressure gauge on their VE?
  57. black smoke please help
  58. 300ZX engine swap to 5 speed SE?
  59. Automatic VS. 5 Speed SE
  60. is this 92se worth it???
  61. VE Turbo
  62. rear sway bar
  63. Caliper overheating?
  64. 3rd gen cruisin or racing? (GXE vs. SE)
  65. 93 Gxe First Mod
  66. question about CAI
  67. how hard to get the tach working????
  68. Sprints or Eibach the question!!!!
  69. Anyone know a good shop for my max in the Boston area?
  70. pics of my car damage in the accident and new pics of new 92 se 5spd pearl white my o
  71. Anyone used this clutch?
  72. power door locks
  73. Updated Cardomain site
  74. slave cylinder
  75. hey wsup guys..... i got a question....audio related i guess
  76. Questions on 3rd Gens
  77. 5 spd tranny question????
  78. t50h Torx screw and screw driver
  79. right signal lights are not working
  80. some of you guys might get a laugh out of this
  81. My VE dyno for those who dont check Gen. forum..
  82. I don't even no where to begin
  83. Need 89-94 Maxima pics for Cattman ad/website
  84. blah. finally got around to updating my cardomain page...
  85. Brakes and engine stall
  86. Radiator Leak
  87. steering wheel
  88. AC dying?
  89. best Haynes manual for a 92SE auto
  90. Sludge in Coolant Overflow Reservoir
  91. Strange a.b.s. noise
  92. 3rd Gen turbo kit available for YOU!
  93. can't remove center nut on strut
  94. 5spd is almost ready to go. Hope to drive tommarrow.
  95. Opinion Needed!
  96. Custom Kit?!???!?
  97. Uh oh....help!
  98. Finally Some Pics Of The Car In One Piece
  99. Need help with a few things with my 93 Max...
  100. Input on some noises I'm hearing
  101. poly urthane motor mounts
  102. New Shift Boot
  103. Bose audio...
  104. NGK G Power vs Laser Platinum Plugs
  105. Need Opinions from sprint owners.
  106. poor fuel economy
  107. Anyone know where to get hinges?
  108. window buttons not working properly
  109. check on my first max (rate please)
  110. Alarm goes off opening truck w/ key
  111. how many of us have rust spots
  112. How long for .Org stickers??
  113. .......29, 32, 35, 44 .........???
  114. rotor and brakes
  115. Broke or Not???
  116. An often overlooked emergency equipment
  117. Lift Points?
  118. abs or posy??
  119. Fair price for a rack and pinion install? Shop wants $650
  120. Alternator noise showing up on LCD, any ideas?
  121. abs brake problem
  122. polarg corner bulbs
  123. H&R coils
  124. Training wheels almost fit on my max and look sweet
  125. Changed the battery, now my blinkers don't work...WTF?
  126. got my e36 headlights installed!!!!!
  127. Fuel Pump...
  128. brake squeal, how long til i must change the pads?
  129. Subwoofer install pics
  130. Mis-matched Struts
  131. Garrett M24 A/R.48 Intake
  132. New wheels suggestions???
  133. rebuilt tranny question
  134. odometer/speedometer question
  135. cams
  136. The box
  137. Check This Out!!
  138. plese help with engine rebuild
  139. engine rebuild
  140. Maxima Electronic Alarm System. Doorpad. HELP
  141. another (stupid) knock sensor question
  142. trunk does not open by pressing the button
  143. Warning ...Paeco not as good as we thought
  144. corner bulb question
  145. Ok, so i'm a newbie...
  146. Does $759.- sound right to replace a Knock Sensor?
  147. headlight problem, need help!!!
  148. Errors from self-diagnostics
  149. Japanese parts for Maxima
  150. TT Injectors
  151. 92 maxima headlight problem
  152. warped rotors???
  153. what is wrong with my Maxiam?
  154. power lock
  155. Lowering the rear only
  156. Brake pedal normal / low / normal
  157. Roof Racks
  158. Clear Corners, just a quick question
  159. Am I getting ripped off?
  160. knock sensor
  161. suspension setup question
  162. Yes another newbie post
  163. Euro tails for a 3rd gen max
  164. ungrounded VTC's
  165. Tps
  166. Pace Setter Headers
  167. Check out this A31 Cefiro R34-style front lip
  168. brake light problems
  169. bought the VE with 72k
  170. Caster angle off after Eibach Drop
  171. I ordered new tires today
  172. Bye bye 3rd gen =(
  173. I am now the proud owner of a..
  174. I made a 3rd gen maxima for a video game!
  175. Got My Strut Bar Today But I Cant Get The Damn Strut Tower Bolts Off
  176. Changing over the A/C
  177. 92 SE Power Lock, Power Trunk Release Problems
  178. 92 Ve 5 speed 70k
  179. Tranny slipping
  180. any 3rd gen with 18' SSR's?
  181. 300zx rims
  182. which lights fit guys
  183. Any good info about Maaco paint jobs??
  184. I Need Your Help! Plz Read!
  185. quick amp question
  186. Gas Smell in car- Even After New Fuel Lines
  187. car stalling/ problems linked to water?
  188. Search down...How to remove/replace speed sensor???
  189. which year 300zx breaks fit us 3rd gens
  190. Stillen Rear Valance
  191. not starting
  192. bypass nutral safty switch for 5spd swap
  193. A/C belt seems too big (UDP install problems)
  194. 92 SE power locks not working
  195. shaking at low rpms
  196. Speaker Pods for 3rd Gen
  197. 3rd gen community... i've been thinking lately about a new car...
  198. Black exterior and Black Leather Interior ownz all
  199. Commuting
  200. just pontificating...
  201. Noise from front - help - wheel bearings?
  202. Hesitation on 92SE
  203. Rear lights will not turn off, or HUD lights
  204. Two secrets to good gas mileage
  205. Window switches go up but not down?
  206. Any 3rd gen with Racing Hart C5s?
  207. 89 Digital Dashboard
  208. 5 Speed Transmision
  209. Parting with my 1990 max
  210. Climate control back lighting....
  211. Shaking at high speeds
  212. Engine noise
  213. starting seems tedious?
  214. Steel Wool
  215. Analyze This plz
  216. Help with exhaust questions
  217. Tranny rebuild issue- 3rd gear
  218. Replacing condenser?
  219. need help buying a 93
  220. how many miles per 1/2 tank of gas
  221. Exhaust
  222. Air conditioning compressor problem :edit by Jeff92se:
  223. constant battery drain
  224. Need help finding.........
  225. Running with no oil !! What damage??
  226. Newbie Questions...
  227. High beams--Help anybody
  228. Fiberglass Field of Dreams (Wordy, but please check it out)
  229. gauging interest for CF hoods
  230. warpspeed y pipe with the g-reddy cat-bak how should i install them
  231. post-exhaust stud replacement:gaskets smoking?
  232. I need BIg Help i lost my only Key
  233. Wrong Plugs
  234. fuel gauge needle dropped
  235. Any tips for bolting up the bottom part of the a 5spd?
  236. Buying a 1990 Maxima
  237. VG33E, in a Maxima?!
  238. Nissan publications
  239. Parting with my Max
  240. lookin at a different max
  241. would 65w/45w headlight bulbs melt the harness?
  242. keyless entry and alarm question
  243. sputtering ???
  244. warpspeed y pipe vs cattman y pipe
  245. i broke my power switch what to do now
  246. auto tranny...
  247. saw this car.... omg i wish i bought it
  248. NZ aerial replacement
  249. VG quarter mile time
  250. intake
