- and the swap saga continues......
- high rpm when idle on ve
- Another KS question, should be easy
- Please Help
- 3rd gen in snow and ice
- Disabling factory alarm...with broken driver's side lock
- Master Cylinder Pic Request
- 4th gen seats in a 3rd gen
- Testing New Camera, tell me what you guys think..
- Aftermarket Alarm Problem
- HEEEEEEELP tranny drain pug!!!
- On the topic of vacuum lines...
- Transmission Fluid
- brake help
- Code for VE LSD 5sp tranny
- best place to buy new VE axles
- what to replace when changing a tranny
- Carquest offically SUCKS A$$!!!
- VE Power Steering Pump
- 3rg gear in a vg 5peed
- Need help on vacuum lines...
- winter
- VE Axle Replacement
- replaced rear struts, now they go clunk
- Platinum Plugs for the VE
- Help With distributor rotor
- VE to VG HELP!!!
- Something's draining the batt. (its not the alt)
- 93 Max SE 5 SPD 150K miles needs 4 new struts.
- Leaking coolant...but from where?!
- Replaced Axles and now....
- Stock Tire Recomendations for 92 SE
- Brake Pad Recommendations??
- New Max Tommorow. Super deal
- Need diagram of IACV and Throttle Body vacuum lines
- help, noise?
- Happy Thanksgiving to all my 3-gen bros.
- wheel hub question
- ve cai pics are up :-)
- VG running rough Help
- Confused max:
- Oem Number for IACV..DOHC motor/Manual Trans
- Free carfax, hurry while it last.
- Question about our Stock alarm
- VE Electrical expert?
- What other Maxima rims fit a 3rd gen?
- Over torqued tie rod ends
- To anyone who has replaced their IACV on a VE Motor
- weird problem
- VE Shudders/dies at any speed
- VG porn
- Woohoo! the rear end is pulled! part Deux
- max running rough
- Heater and Running problem
- Okay Weird VTC Issue....
- possible T-belt misalignment?
- check out what I'm rolling with (this takes me back :D)
- phillips hi visibility bulbs
- my power locks dont work
- Goodbye Maxine
- window regulator install
- Digital re-set?
- Many many questions...
- Dash LIght Death....
- So I buffed/waxed my car for the first time
- Trans goes again
- VG Maximas, replace your distributor rotor
- what years had the egr temp senor
- KYB Rear Struts Too Long?
- Should I replace the struts on my beater maxima?
- hood adjustment
- 5-speed update
- Fuel Pump Replacement
- Rear Center Reflector
- As long as I'm there pt1.
- Fuel Light
- how the HELL do you take out the fuel injector?????
- Spark plug wire diagram
- 92 gxe worth it????
- Digital Dash
- INstalling a transmission cooler?
- Price estimate
- Electronic Speedometer???
- Hey 3rd genners... Good DEAL
- Fuel Pump Issue/Relay Location
- Knock Sensor replace
- Damn Axel Bushing!!!!
- Best way to DIY allignment
- HELP with gas mileage
- I found a great deal on struts...
- Vibration increased in D/R and brakes applied
- Railroad Tracks!!!! =( =( =(
- 98 rims on a 90
- Headlights for a 3rd gen
- engine choices, ideas
- For anyone who cares...Pix of my sled are up.
- Need new door, couple questions...
- Anyone Have a Pic of IACV/EGR valve/PCV valve?
- trouble starting when warm?
- whine and gas smell- connected?
- Anyone have a discount code for CE??
- Loss of Power
- Big freeking hose w banjo fitting??????
- My 92 got hit! ::PICS::
- thumping nosie coming from the wheels???
- hydroplaning is no fun.....need new bumper skin
- Problems with idling?
- (PAGING internet auto martor whoever can help)oil leaking on bushing
- New Redlinemax Y-Pipe
- Manual Experts Please
- put car in reverse and shifter didnt stop until it hit the console ;X
- VERY annoying scraping noise coming from the rear...
- 5-speed conversion
- problems with car after letting it sit for a while
- Way to get $$ for bad axles?
- Body Kits
- Is it possible to use VE30de injecotrs in a VG30de?
- Front 3 cylinders not working...
- Any recommendations for a place to work on a car for those without garages?
- Running like crap!!!
- Getting Amazing Gas Mileage
- my max is working on 5 cyl
- Headlight problems
- Exhaust, etc....
- Speedometer issues!
- pics of tvs
- steering seams to pull
- bad alt?¿
- 'Clunk' noise over speed bump.
- Tranny still leaking!
- 3rd gen paint codes by color and year
- My new $1 DD
- Do i have a bad mafs?
- squeaking
- Gotta love the military (and their auto shops)
- Problem with Tie Rod End replacement
- Engine not happy
- Is it okay to buy fuel injectors that have slight damage to the pintle caps?
- ve out vq in?
- Bleeding Brakes?
- Startings Max after sitting
- taking 8 hour drive soon......suggestions on what to have in case of anything bad
- jetta wheels on a max
- * People Have No Respect *
- keyless entry
- foglamps
- A/C Temp. Slider
- aftermarket center console
- Help with STS install
- Terminal Velocity of Sunroof Deflector...
- right headlight won't turn on
- Another wierd VTC problem
- whats a good price to get a 93 blue 5 speed se for
- Are there any trip computers out there for our cars?
- 5speed grinding in second
- Exhaust Manifold
- Welders inside please...I had enough engine shake...
- Best prices for lowering springs?
- Help replacing vent window
- My weekend project
- New VE A/T - Some questions
- no F'in way this is for real
- Maximas and EBay?
- ayone have info on how to repair bose amps?
- cloudy E36 headlights
- What sets off the factory alarm?
- Rear seat cushion clips
- Parallel link bushings...
- How difficult is it to replace?
- Replacing Knock sensor POLL
- Ground for amp
- its back running and wow! 16psi
- water pump pully (tbelt job)
- Troubleshooting sudden gas mileage drop off
- CAI K&N Part Number and Place to buy
- So my speedometer...
- Found the problem
- back from Iraq and ready to get pumpin on my max (pics)
- Update...
- having trouble replacing axles
- Stall
- To anyone that has purchased an STS lately
- Exhaust Stud removal....
- battery up!!!
- post engine wash problems
- Is there a writeup on replacing gauge lights?
- Which is the best air filter to use?
- Goofy problem - climate control display gone dark
- Just installed Clutch masters stage 1 and fidanza
- radiator help
- Homemade Short/Short Throw Shifter
- Opinions wanted... G35 coupe Muffler
- question about heating
- ATTN: ALL MEMBERS - I SUCK AT TEH MODDING
- Which oil filter to use for oil change?
- VE performance problem.....
- 93 se VS. 95Acura legend
- Fuel Gage is reading 1/4 less than it should!!?? HELP!
- Why can I move my rear pass wheel in and out>?
- Tire Size Question
- quick length question!
- Wind shield wiper water tank leaking
- Rear Drum converstion?????
- Ideas to get exhaust off?
- How much capacity of antifreeze for 92 gxe maxima? Urgent as working on it now..
- Busse Woods, IL All Nissan meeting, anyone going?
- I cant find my computer?
- VG to VE (VTC fix)
- New toy M3 mirrors
- Lexus GS/IS series licsense plate lights.....future mod maybe?
- calendar pics
- How do you stop clear coat peeling?!!
- bumper is painted (pics inside before/after)
- temp went to High and smoke
- Real quick rear brake ???
- car is stalling on idle or driving
- ebay CAI, MAFS problem?
- Look what i found
- need some advice painting bumper
- Estimate for repairs, ouch.
- Are Dynomax mufflers any good?
- gold package on 3rd gen
- Wiper Piviot Point
- Thought it was plugs, boy was I wrong!!!
- Bbbbbaby - it's cold inside!
- boneyard goodies
- headlight help pleeeeeeeeease
- Euro/JDM or foreign maxima pic thread anyone have any pics. I do
- Valve rattling in a vg question. also gas grade question too.
- the mailman brought me some goodies
- '93 Max Versus '93 Camaro z28
- People with 5spoke rims sign in
- Cant install FSTB on right side tower..hose blockin way
- Rear Main Seal Automatic Transmission
- A question on painting...
- Input shaft bearing
- Me wantz a WAI
- Manifold Stud Question - Y-pipe
- hard to shift gears in my manual, why?
- In the garage on laptop trying to fix wipers, please help
- vg headers? who makes them? ANy one have them, any word good or bad?
- Max not starting AGAIN!
- Weird problem with car windows!!
- Knocking is gone
- 91 max wont go over 75mph
- Sputtering and vibrations
- '96 power, heated seats in my '89
- Fuel rail?
- Who's maxima is this on this board (its black) look inside
