- Sputtering/hesitation related to worn VTC Sprocket/Springs?
- Need timing belt replace! Lisle IL.
- Thank you and Goodbye...
- Rear strut removal questions....
- Would this cause a starting issue?
- Getting ready to pull motor - want to resolve last minute issues
- Search Function Settings
- 3rd gen turbo build
- Interior trim (roof) removal?
- Finally after a yr, some pics of my Maxima
- Rear Strut Piston Rod Nut
- Would like some insight
- OK New Injector In & This is What Happened
- need opinions
- wind noise on highway...strange
- Any1 ever installed U O Underdrive Pulley?
- Can The Leakdown Test for VG30E Work With Upper Plenum Off?
- VE and VG manifolds
- OH OH
- Driving without power steering/breaks
- BTDC How To Be Exact
- How do you drain the fuel tank?
- is this injector too damaged to use? pic
- i think im sure now!!!!!
- battery starting to go bad?
- GXE KEYLESS ENTRY TOUCH PAD PROBLEM!
- Any Ideas How To Remove The Tiny Injector Screws?
- Fouling on Bottom of Dead Injector
- Michael's (AWSM66) latest Maxima work pics
- HELP!!!!!!!!!!!!!!!!!
- motor mount bushing
- Strut help please?
- So, I was bored AGAIN...
- Welp....I riced it out...
- Photos of 93 J30 Maxima Suspension Parts
- Can I Inspect The Rear Caliper Without Bleeding?
- Disabled fuel pump - still getting fuel?
- so confused... injector colors
- PIcs of G35 rims?
- crack wire insulation repair
- I hit a deer
- No VE ignition timing "sight"?
- Anybody replaced front windshield?
- Broke timming belt I think What kind of damage is done
- Cleaning
- problems after engine wash
- Do I Remove the Oil Seal From the OEM Gland Nut for Rear Strut?
- Look what i FINALLY test fitted...
- misfire from h3ll part 2(videos)
- misfire from h3ll like poof poof poof!!!!!!!!!
- Spot the mod V Greeny2
- VIDEO: My Electric Exhaust Cutout First Run
- the problems keep rolling in
- tick noise while rolling
- RUSTY Coolent??
- I need soem advise for a better 1/4mile run
- Interior sunroof cover alternatives?
- my 92 got a bit owned
- Timing: Me vs FSM
- Is this a common oil leak?
- coilovers Finally?
- What to check to fix exhaust smell after injector replacement?
- color not matching
- E-Brake Issues
- Good quality fuel injectors
- Don't Know How You Guys Got Those Clips Off
- Has anyone Ever looked into This
- ignition help
- Grounding VTC
- Can ABS Be Dangerous?
- auto shift knobs
- Battery keeps dying, why!?
- After years of searching...
- car dying while running
- Who to setting timing
- Trunk?????????
- Revolution sensor error
- Dash Lights Intermittent
- MAXUS 09 WHO'S GOING??
- slow cranking
- Location of scanner connector
- Aftermarket Gauge Face Installation Write-Up
- So, I Need Your Opinion...(Power Windows)
- Want Smoked Headlight Covers For Your 3rd Gen?
- new axle, new control arm. Now vibration under fast acceleration
- Putting on White Face gauge and i think i broke someting. HELP!!!!!
- Multiple ECU Codes?
- maxima wrecked :(
- How do you deal with people with no insurance
- recomended brake pads?
- Runs Rough Only During Rain Or Snow
- High Temp Paint didn't Do Crap for My VG Muffler Assy
- Suspension Questions
- Paint
- Passing Smog
- Correct 1993 VG Injector Green or Yellow Dot
- Battery area rust
- 3rd Generation Rear Struts??
- Lucky to be alive
- turd gen teh pwnzor!!!
- installing axle...
- Using Speed Bleeders
- Knocking sound
- ED Kombat Body Kit
- What is causing this squeeling noise? [in the engine]
- having trouble getting tie rod to steering knuckle ball joint off
- Can this '91 be saved?? (pics)
- My 94 maxima Videos coming soon
- Clicking under e-brake?
- two different ve30de motors, i have both lots of pics
- CEL Again! Codes 34 & 51 Help!
- power steering hose leaking
- How exactly does out security passcode system work?
- Tires Studs
- Spot the mod
- HELP! Installed Pathfinder/ VG30ET injectors - not starting!
- Best way to pull the block and tranny?
- anyone in seattle area looking for ve 5spd?
- Keep blowing engine control fuse.
- Battery Connectors / Fuseable Link
- Adding a little Down Under style...
- Fuel Tank Vent hose
- Ball Joint... Stuck
- Installing Driver Side CV Axle
- Adding new switches
- (Aftermarket) Alarms and keypads
- Breath In and Breath Out!!!!
- Play in Front Axles - Jiggling Sound Down Low
- wiring diagram on a radio for a 91 maxima
- Need brake help!
- Fuse looks good; what the - is wrong with my radio?
- Auto hesitant to shift into second..
- California Spec ECU?
- Maxima VE vs T-BIRD SC
- tire size
- VG Rear Brake Conversion
- Rear caliper problem
- TACH Erratic
- odometer
- Bose question, please help
- Blown head gasket
- Moving on...
- Two audio questions
- stock 1992 ve highschool kid build thread..follow me from the start, (pictures)
- 1994 VG Check Engine Light On
- my GXE plus some questions
- Intake/Throttle Body
- battery problems, again.
- my car pulls to one side and nobody knows why
- Besides AMSOIL, tranny fluid
- Headlights
- junk yard sensor connectors. how do i pull out wires, pics
- Thinking about paintING my car...
- Junk Yard Trip
- TORQUE CONVERTOR/ tranny REMOVAL
- speedometer not working properly
- your input on your interior color
- Door question
- bolt pattern
- Replacing injector
- Rear sawy bar help!!
- Well I think im gonna sell my ride... anyone interested in my headlights?
- Would you buy these? (2 '92 maximas)
- speaker amp?
- The Great 3rd Gen Video Thread
- engine misfire moves from one cylinder to the next wtf
- ASP VG crankshaft pulley how to?
- Loud whistle after injector replacement?
- Iacv-AAC Valve Gasket question.
- How the hucking fell do you actually pull the injector out of the rail?
- GI: NWP VG Phenolic Spacer Group Buy
- Polyurethane Control Arm Bushings
- Fuel Level Guage Malfunction
- Stalling and rough running while idling or at low speed
- Could 5 of my 6 injectors be bad?
- (Another) Turbo 3rd Gen
- MANUAL SWAP IS DONE!!!!!
- The Maxima Has A Little Brother...
- VG30 Rebuild.
- Swapping brake lights
- Starter fuse
- replacing an injector any tips
- Air-Bag light constant on
- Teh VE hawtness has been revived!
- changed radiator, air not so hot when freezing out
- Injectors OEM or Remanufactured?
- Engine Misfire
- Injector problems??
- Replacing fuel injectors
- keys keys keys
- goodridge ss lines
- Progressively cranking slower
- Overdrive. re-evaluating?
- Headlight Retrofit Help
- Build Thread: turd gen...
- Need help on LED
- Help! hard running
- Noise at Brake pedal release
- VE auto driver axle, help which one fits my car...
- Misfiring
- Engine Temperatures?
- Project: AWD MAXIMA
- VE Injector rail O-ring size?
- Clicking noise behing the dash
- Places to mount amps in the trunk?
- Modifying Rear seats to fold.
- Where can I find a alternator that will "last?"
- Testing auto trans. line pressure
- Power Windows and Windshield washer not working
- rough idle when cold hard start
- axle mount, auto>manual, is it needed?
- Photoshop 3rd GEN...
- VE Starter Problem
- handbrake down...
- '93 SE auto trans. bolt up to a '90 gxe?
- Runs great! until... ('90GXE auto tranny help)
- timing cover
- coolant leak near pulleys
- ve intake plenum off...safe to clean?
- low-end misfire
- Led tail suggestions
- You know what I just realized?
- Interesting issue
- help me choose color for 3rd gen...
- Trunk swap with pics and questions
- Brakes!
- Brake & Battery light are both on.
- pilot bearing and my 1992 transmission input shaft?
- Don't know if anyone saw this
- Exhaust Systems...
- Pic of a rear trunk spoiler...
- Best spot to drill a hole in the firewall?
- another 3rd gen pet peeve
- Question
- Trouble Replacing Light
- Whats your Max's weight? And how can we reduce it.
- How 'Bout a Contest?
- brand new vtc from dealer, anyone use before?
- loose or broken wipers
- front strut ?
- intake manifold gasket ?
- perfect wheel fit?
- Single gauge pillar pod that fits?
- omg my wheels!!!
- oil pan gasket, one piece or multi piece?
- My Summer Project Just Fell Into My Lap
- Rear Radius Rod Bracket (Closer to Front)
- which one of you is this?
- The Maxima has a new playmate
- 4th gen fuel rails
