PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Tire Wear
  2. VG pics
  3. Stock Waterpump Belt Pics
  4. Exhaust advice!
  5. Exhaust Problem: irratic idle, and dies when "hot"?
  6. Extremely annoying interior sound!!!
  7. Tip of the week
  8. Betcha want my goodies...but u can't have them!
  9. Another dead Maxima
  10. can't search, 5 speed m/c template
  11. tach
  12. Master Cylinder
  13. Stock Air Intake Pics?
  14. New MAF
  15. New wheels :-)
  16. Help? After-market CD doesn't activate antenna
  17. New exhaust causing poor gas mileage??
  18. Looking for Transmission.......
  19. Please help with body repair options...
  20. Some new toys...pic!
  21. glue around transmission fill plug
  22. Buying a control arm
  23. Dash Light issue
  24. bmw exhaust
  25. that website
  26. how many quarts of GL-4 gear oil in a 1990?
  27. Winshield leak
  28. 06 g35 forged wheels on the the third gen
  29. Ebay Exhaust System? Will it fit?
  30. Really Bad Idle Help Please!!!
  31. How much drop?
  32. whirring sound
  33. It's Alive!! (New ECU!)
  34. Dashboard Lights
  35. headlight prob
  36. cheap auto body parts
  37. please help me save time
  38. Guess whats wrong with my Maxima?
  39. Just got the stillen kit what to do before installation?
  40. Valve cover gaskets
  41. BRA for the car
  42. Transmission jerks when putting to drive after changing injectos
  43. Replaced injectors on VE but still getting shaking/ rough feel
  44. Maxima Rims
  45. passenger window switch
  46. question about buying a 93 with a loan
  47. Short in tail light
  48. Replacing rear window..need help
  49. ve timing check
  50. Power Steering hose
  51. Fog lamps question
  52. Sunroof acting up
  53. Short Throw Clutch
  54. iPod interface question...
  55. Simple Fix for rusted out stock spoiler
  56. Goodbye to my '89 SE
  57. door lock handle
  58. need serious help!
  59. Phantom Fuel Check Valve
  60. stupid brake question
  61. rack question
  62. i need so feedback .
  63. Weird issues after injector install?
  64. Remote keyless entry?
  65. WATER PUMP TENSIONER? vg30et?
  66. Injector retaining screws?
  67. Coolant flow through throttle body?
  68. Who likes my knob? *PIC*
  69. Got my Timing Belt replaced By the STEALERSHIP!
  70. Quick question regarding VE intake manifold removal. *PIC*
  71. 1992 GXE engine??
  72. MAF regrounding?
  73. strut stabilizer to control arm mount
  74. Some Rare and Hilarious Pics
  75. o2 sensor upgrade?
  76. Alternator Prob
  77. ? some help ? timing ?
  78. e36 lights
  79. Is this an alternator problem?
  80. Opinion Needed
  81. What kind of seats is this?
  82. Gabriel Shock absorbers?
  83. is this worth buying?
  84. Quick Control Arm Quest.
  85. Engine a keeper?
  86. help-Blower won't stop blowing!
  87. Swapping ECU?
  88. Possible to switch GXE steering wheel with SE?
  89. what are the prices for a VE motor?
  90. Cylinder Heads
  91. Air conditioning in my 1992 SE
  92. New Bimmer!
  93. car shaking a lot
  94. Broken Dipstick
  95. Will a 300ZX shifter (A/T) fit in an A/T '89 GXE?
  96. exshaust question
  97. Exhaust Manifold and Studs
  98. what do you guys think? chicago guys i need ur help.
  99. speaker brackets
  100. think im buyin my 3rd gen back
  101. vg head light help
  102. wtf is up with my lights??
  103. New mods.
  104. She did it!!!!
  105. Camber Adjustment?
  106. Injector R&R / Intermittent dead cylinder
  107. starting issue???
  108. hey Cliff Clavin...
  109. Plastic housing on E36 HDLights need replacement?
  110. 3rd Gen caravan for 6/17/06
  111. Fitting a 300ZX steering wheel?
  112. Coolant boiling...Fans not coming on...need input
  113. 300zx shift knob in 3rd gen?
  114. ECU reset
  115. input shaft bearing inner ring
  116. Unorthodox Ruins Motors??
  117. Maxima VE engine radiator cap pressure????
  118. Is winter weather a problem for CAI?
  119. VE Valve Springs
  120. Tire size too small?
  121. Rim/Tire Sizes
  122. Clunk on front driver side
  123. Wheel painting help?
  124. Maxima AFM
  125. Intake advice
  126. Need Help with Suspension
  127. Noise From Rear Of Car
  128. Windshield wipers and other prob
  129. ABS Wheel Speed Sensor
  130. remote keyless replacement
  131. Duplicolor to match Nissan sapphire blue?
  132. Rough Idle
  133. Need wisdom from the org...tranny probs
  134. how to check the sensors...
  135. look at this pic/ whats wrong with it
  136. what happens when ks goes bad?
  137. still learning site.
  138. curse of the intake manifold gaskets
  139. I need to change my lower control arm bushings
  140. Front Bumper Damage
  141. front valve cover SNAFU !!
  142. Tranny Mount
  143. Check Engine Light...
  144. WIll this really work?
  145. Torque for knock sensor
  146. flywheel
  147. C.l.r.
  148. Death To The Mass Air !!!!!
  149. Only 3rd reppin at meet.............
  150. time to change my plugs
  151. Help? stuttering/misfire under acceleration/load
  152. Can The BKR5EIX-11 Be Used In VG30E?
  153. Camber Kits???
  154. Hardwiring Indiglow gauges?
  155. Heater doesnt work
  156. Door Pods Finished **PICS**
  157. Front valve cover !!
  158. piaa led lights
  159. ABS Code 10 question
  160. Simple Question
  161. Axle or bearing issue??
  162. PCV Inline Filter
  163. Inner Tie Rod removal
  164. passenger window issues
  165. car cuts out
  166. was ripped off..
  167. Anyone interested in fabbed vg33e bracket?
  168. New family member :-)
  169. Maf?
  170. ATF in Engine to Carbon Clean?
  171. outer tie rod ends
  172. Who outbid me!?
  173. tps ?
  174. Suspension problem? Right rear sitting lower
  175. I Got Hit Today !!!!!
  176. Saying good bye, another max RIP
  177. Erratic RPM
  178. Quick question since search is not working...4th Gen Seats?
  179. Weird Power Windows Problem
  180. Speedo Issues
  181. Oil Pan Screw & Crush Washer
  182. Code 33
  183. What's it gonna cost me??
  184. New SFC design
  185. caliper probllem
  186. HELP Max won't start
  187. Max smokes too much!
  188. 3rd Gen FSM PDF File?
  189. So my muffler rotted off and i put on a...
  190. So my muffler rotted off and i put on a...
  191. Your Steering Wheel
  192. udp for ve
  193. Place Racing CAI
  194. How does it sound when you plug the resonator?
  195. removing a crankshaft pulley...
  196. My 92se's speedo is dead
  197. ve intake help
  198. NEED HELP ASAP: got air in the brake lines when changing master cylinder
  199. 94 se running like crap
  200. Gas Leak Question
  201. My tires are killing me...
  202. Distributor
  203. Interior Body panels
  204. The time has come.....
  205. struts n stuff
  206. rough idle in gear
  207. rough idle in gear
  208. Should the AC Lines be Frosty?
  209. Need new injection system
  210. blinking red battery light
  211. Control Arm changed overnight
  212. the correct PCV valve......
  213. what if I dont have paypal how do I donate
  214. brake pads
  215. ground strap for exhaust??
  216. accord intake for 3rd gen?
  217. FSM for 92 SE
  218. Broken sunroof :(
  219. vin check?thanks either way
  220. y-pipe flex sect.can plug cat. convt.
  221. New Hinges YAY
  222. trunk mechanism stuck
  223. Correct Torque Value On Rear Caliper Pin Bolt?
  224. replace outer tie rod ends?
  225. average ve numbers
  226. limited slip check same for a/t?
  227. VG30E intake question...
  228. Stripped manifold stud
  229. Low oil pressure
  230. Max not starting
  231. Gauge cluster
  232. Product Q's
  233. Engine Rebuild?
  234. auto tranny
  235. wtf
  236. Maxima Of the Month...
  237. this is a bit confusing
  238. this is a bit confusing
  239. What is a resonator?
  240. Tire sizes
  241. Rear Swaybar?
  242. Junking my '93 max as a parts car
  243. Transmission, Rebuild or not
  244. stupid question
  245. Questions About Summmer Mods.....
  246. Dashboard light problem sorry about asking again
  247. Power Vavle Not Working???
  248. Best way to change pintle caps on injectors.
  249. should I paint my calipers???
  250. This is for (InternetAutoMart)
