PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Question about Fuel Hose between Rails - Caps to hold on Injector O-rings
  2. having some trouble
  3. Better Brake Light Mod = melted assembly?
  4. Sugestions on Cold Air Intake
  5. Horrible Headlights
  6. What Is The Correct Torque For Fuel Injection Hose Clamps?
  7. Is it True That Injectors Rarely Need Full Replacement But Just Re-Build & Calibrated
  8. stock fog lights
  9. 160 or 190 Hp
  10. The max and I were busy today
  11. WTF? My Maxima is trippin.....
  12. Anybody have the 1993 FSM PDF?
  13. Styling the ORG stickers
  14. What Would Wait ... pin43
  15. Wet Fuel Rail - Possible Sources?
  16. Tranny Good! CEL gone! What's next?
  17. No Power to anything but starter and fuel pump.
  18. Pacesetter Catback
  19. To Sell, or Not to Sell
  20. Illumination switch
  21. Starting Problem '91
  22. How do I figure out which injector?
  23. Blinking Air Bag light
  24. help about clock
  25. misfiring vg
  26. Pink or Red Bosch Injectors - which one?
  27. Short Ram Intake Problem
  28. ABS humming
  29. Parking Brake Light
  30. where to get suspension bushing kit?
  31. How much is my '92
  32. might be selling the max next month
  33. How much to install springs?
  34. Cleaning MAF sensor (VE30DE)
  35. Muffler Questions
  36. car wont turn over at all, was fine this morning...
  37. VE- CPS o-ring??
  38. car acts like clogged fuel filter....
  39. RARE 1993 Maxima
  40. got burned with remfg injectors...best place to buy new?
  41. VG30E A/T transaxle leak?
  42. Line Pressure Drop resistor bypass with 5kOhms
  43. How Do I Replace The Windshield?
  44. Security system on maxima
  45. How Do I Replace Windshield Washer Reservoir & Pump?
  46. Headlight timer
  47. VE 5 speed and AT axle interchange .. help
  48. How to remove windows/windshield/doors...
  49. finally fixed, replaced injectors
  50. car alarm
  51. Pictures Needed, All Colors and Years of Maxima
  52. 94 maxima air vent removal??
  53. o2 sensor connector, red wire broke, ecu side...
  54. wheel spacers...do or don't
  55. Brand new transmission has arrived :)
  56. Trading my MAXIMA FOR A LEXUS
  57. Twin Cam 24 Valve V6 3000 Engine Stickers?
  58. Cool idea....side markers on when reverse is engaged
  59. Replaced timing belt today...it now whines.
  60. mildew smell when a/c is on
  61. hate to ask such a simple q...
  62. IS IT TIME TO SAY GOOD BYE?
  63. Headlight Lense
  64. Auto Dimming rearview mirror?
  65. How do I Replace The Battery Cables
  66. Radius Rod Bushings
  67. Did i order the right gasket? Fixin injectors
  68. No air coming out of the vents
  69. 1990 VG30 Headers
  70. What is this on rear suspension VE 5spd car pic attached
  71. Price Quote
  72. 94 Max in the shop - Stalling in D, R. $1k for repairs and still has the problem!
  73. Strut Problem!
  74. What is it?
  75. Diming Automatic Climate Control Unit (ACC)
  76. to the track this weekend
  77. Anyone think this is legit?
  78. help me my 3rd gen members to....
  79. Fuel Injector Wire Harness
  80. rattling noise (video)
  81. Source for "soft" screws that hold in injectors
  82. Insrument clusters and VTCs
  83. Some questions before I start to upgrade the fuel system
  84. car starts wierd...like low battery, but its not..
  85. Cheap Replacement Window Regulators
  86. Blue GXE gauges?
  87. Walkin' in the JY just earlier to-day, ba-by, What'd ya, what'd ya think I saw?
  88. tranny cooler
  89. Long time no see
  90. Rear Passenger Window
  91. Turn Headlights off with Ignition = Off
  92. Paint Chipping badly.
  93. Dead VGE Horses
  94. Easiest Quickest way to remove power steering pump belt
  95. Tach and Temp gauges not working
  96. Sounds like my max is missing but....
  97. Idle Pulley bent?
  98. KONI'S ANYONE.
  99. My Max on 17's...Finally!
  100. Got T-Boned today
  101. Royal Japan Imports/JDM??
  102. hissing sound
  103. Happy B-Day capedcadaver!!!
  104. Solve the mysterious sound coming from my engine (a pissed off cat?)
  105. http://forums.maxima.org/showthread.php?t=547175
  106. blindin HID
  107. Many Issues. High idling, smoke out tailpipe
  108. 3rd Gen VE Progress Pics and Timeline
  109. Maxima "SXE" apperance package, phase 2
  110. TPS Gone Bad?
  111. should i be concerned about....
  112. brake booster lines
  113. All Engine Temperature Sensors, VGE
  114. 92 VG Blue Dot Injectors
  115. Quick CV Boot Question
  116. ODOMETER NON FUNCTIONAL
  117. New noise after replacing oil pan.
  118. Im a n00b and my Max is missfiring video
  119. Clutch noise...
  120. tie rod jam nut
  121. did 3ed gens have adj suspension??
  122. Remanufactured engine
  123. Look what a shop did to my max
  124. Write-Up: squeaky clutch pedal giving you the blues?
  125. quick alternator question 92-94 se model
  126. It's Always Something...
  127. Tick Tick Noise
  128. Retractable Antenna Repairs
  129. Noises from front-passenger wheel compartment. HELP!
  130. No alignment b/c of ball joint
  131. Maxima Forums > *
  132. 93 injectors
  133. Speed Sensor Repair
  134. 1.25 or 1.5
  135. VE and VG oil pans the same?
  136. VLSD 5-Speed is Installed!
  137. GFs car rough idle loss of power rps stay stead at Idle?
  138. Lug Bolts
  139. injector/knock sensor replacement. still showing 34/51 codes. HELP PLEASE.
  140. capedcadaver's "missing" issue (split from marshall's thread)
  141. What vg30e had this?
  142. Groaning and vibrating while turning
  143. Interior dash lights and switches
  144. Extended Rear Wheel Studs
  145. About getting parts from the local dealer
  146. coolant bypass
  147. Exhaust Studs
  148. Window Tint or not?
  149. The acceleration/shifting problem
  150. Fuel Injector Cross reference?
  151. What is it about the Gen3?
  152. strange noise from speakers as I accelerate
  153. Need some parts...
  154. HVAC Controls At A Junkyard
  155. Injectors, very strange problem
  156. FI questions for the ve30de
  157. Its missing?
  158. rear disc swap done
  159. where is my PVC valve? 92 SE DOHC
  160. Guide Pin Trouble
  161. Caliper rebuild or replacement?
  162. What to do next?
  163. VE5 Swap.. Do you NEED to take out auto "pilot bushing"
  164. engine shimmy
  165. ve vq swap out
  166. Weird engine noise at speed
  167. timing belt...
  168. Odometer overspeeding
  169. Update on VE in 200sx?
  170. Wheel Bearing Replacement
  171. Proper Manual Shifting
  172. VG30E fuel injectors and distributor
  173. Windshield Washer Nozzle Adjustment
  174. Strut bolt spins with nut?
  175. Tail Light Letter Clearing/ Sanding
  176. ABS pump question
  177. Anyone have a clutch cylinder template for 5spd swap?
  178. opinions on rims
  179. Speedometer pinion question
  180. NO PPM Emmission failed 3rd time
  181. how to get to my fan switch for A/C?
  182. Mixing power steering fluids?
  183. Brake lights NOT working
  184. Interior LEDs
  185. Steering Rack Removal
  186. WOOHOOO!!!! A NEW electrical problem!!!
  187. Fail Safe Mode?
  188. Non-working Cruise control & constant honking horn
  189. What to do? (opinions please)
  190. No start
  191. Cross eyed max
  192. Distributer Question?
  193. vg drive and susp parts
  194. Windows down tunnel video v.GReddy
  195. Hey Look What i Did!!
  196. Parasitic Draw
  197. any success with R12- R134 AC kits?
  198. Rust
  199. Stock Anti-Theft System... A question.
  200. Window
  201. two random questions. optima battery, and engine sludge...
  202. Engine Out - Help.
  203. unique ebay item
  204. Steering rack question
  205. Smoke and no temperature reading
  206. high pitch noise coming from water pump area...
  207. Missing hoses
  208. not good, wont start :(
  209. Max is back on the road after sitting for 6 months
  210. vtc grounding issue
  211. rear window spoiler?
  212. Transmission Control Unit
  213. Any Washington, Oregon People Seen This?
  214. was converted to leather/power seat but...
  215. Getting distributor off
  216. MAF Plug?
  217. Is it bad that.......
  218. Sunroof leak
  219. rough idle, my plans.. anything else i should do?
  220. TPS corroded harness...rewire and solder?
  221. Still Love My '91
  222. Dash lights are non-opperational...
  223. Pathfinder Clutch kit/flywheel?
  224. Problem with Heater
  225. vg compatible
  226. hey..uh...
  227. releasing fuel pressure, car stays running....HELP
  228. Do I need a magnetic socket to remove spark plugs?
  229. missing or chuging at low RPMs
  230. Replacing rocker cover gaskets. what else should I do?
  231. in search of a bad o-ring
  232. 91 Maxima SE in the shop
  233. Rear window defroster
  234. 91 SE Rear parking brake cable
  235. Throw out bearing installation
  236. 94 VG30E Tranny??
  237. some bad news...
  238. radiator plastic tank cracked. Where do I get a new one?
  239. Any ideas about wheel noise on freeway?
  240. Suspension Suggestions?
  241. Door locks stopped working
  242. KYB + lower springs = FTL
  243. Car shaking like not getting enough feul
  244. Video of a car jumping, looks like a 3rd gen?
  245. brake system help!
  246. ventilation fuel hose leaking
  247. Passenger CV Axle Carrier Bracket Removal
  248. Need to find starter relay.
  249. Front wheels coming of the ground?
  250. Clunk noise when I hit the brakes...
