- Cruise light blinking
- Blower motor stays on
- Thinking of buying a 3rd Gen
- Plasti dip on a 3rd gen, whole car - pictures
- Fuel Injectors
- led cluster
- Picked these up for the digimax GXE........
- rear swaybar links
- Charging car battery at home?
- What type of muffler to get?
- transmission studs on bell housing
- clear turn signal lights for sale at classified section
- where to buy heads for 94 maxima gxe
- CEL Code 33 - Oxygen sensor
- 92 troubles
- 1994 vs 2012 Maxima
- Stillen kit has arrived..........
- No reading on thermostat
- Key stuck in Ignition
- Power Lock Switch & Driver Window Help
- please help me my car is leaking lots of oil!!
- Brake Fluid leak
- Rack pinion steering
- ASCD issues
- Looking for 1994 NISSAN MAXIMA GXE Repair Manual
- Maxima Quick Release
- keys locked in car...keypad ect...
- Paint on stillen kit...
- My Maxima is Sold 2
- Engine block coolant drain plug?
- Bleeding cooling system
- Wheel choice
- where can I find a water **** solenoid?
- Correct Injector Part Question - 1993 SOHC
- No heat: Cured
- 94 GXE heater core
- No start on hot motor
- 1989 SE Performance Info Request
- Gas Smell or Leak after Injector Install
- Strange clunking
- 1993 nissan maxima Electrical problem?
- Removal of a 3rd gen maxima cluster
- what size tire i need
- Doing my timing belt at 145k
- 1994 maxima engine
- Hello everyone, new to the forum here
- Light blue smoke/acting odd?
- I need your opinions picking out an exhaust
- Whistling noise when accelerating?
- 3rd Gen the car that started it all?
- Stillen kit
- GXE with SE fogs
- Crash Boom Bah -
- how can I remove this bolt
- "Y" Pipe Comparison
- How to change fuel injectors
- how to open my front cylinder head?
- Need pictures of door lock PCB. (Locks dont work)
- dupli color
- Help with Vacuum conn - VG30E Intake Manifold
- 94 VE30DE issue when at temp
- Phantom Supercharger
- Vehicle Speed Sensor CEL Code 14
- Retrofit heated mirrors onto an SE?
- KSPORT LOWERING SPRINGS with Monroe shocks
- My Maxima is sold :-(
- cigarette lighter blew and power light coming on
- Flushing brakes?
- hid projector/e36 hi-beam hybrid
- Anyone know who is selling 89 Max SE in JAX FL?
- Dyno'd my turbo VE today
- Battery issue?
- Swap for JDM Engine
- 3rd resurrection?
- I need all your opinions on my maxima!!?
- Can you guys help me out???!!! opinions
- Brake line clogged!?!
- New bakes,new problems
- New TPS
- 1989 Nissan Maxima: can see arcing off spark plug wires all over
- Help
- 94 maxima auto transmission not going to third(loses engine power)
- Inner Tie Rod Boot
- why the car wont go into park
- New very used Maxi
- Dying when car getting to normal Running Temp
- Rough Idle-Hesitation When I Accelerate
- need a answer
- My poor Maxima!!
- vg5 keeps blowing eng cont fuse....
- help please
- 94 axima will not jump start, sometimes
- God I miss having a 3rd gen!
- Rough Idle, White Smoke
- over head cam or cams
- ECU Diagonistics Question
- would it be a good idea to buy a 93 max with the possibility of having no reverse?
- Where to find ECU-1991 Maxima
- THird Gen Maxima audio and Gauge cluster light questions
- Ve30de swap question
- where can i get an aftermarket mishmoto radiator?
- Is there anyway to restore Oxygen Sensors?
- Radiator Leak
- A/T MAXIMA not shifting gears today
- whats wrong
- Car runs rough only at night.
- i cant post pics how can i post up pics
- how clean is your interior
- Car shuts off frequently during driving
- Chatter Under Acceleration
- Where to find O2 sensors
- Replaced MAF-Still Have Problems
- Best NEW Injectors? I've had it with refurbs
- 1991 VG5 for sale
- why do you love your maxima
- the beast runs again
- bose speakers
- Unplug mass air intake sensor-car then idles smoothly
- whats up with threads being closed why
- Electrical issue. Need help ASAP!!!!
- Radiator Fans not working but come on if A/C is turned on
- lets talk about tail light bulbs and plates
- If your 3rd gen has a Rain Leak,not heater core
- warning to all maxima owner re post
- Any ideas on VQ30DE-K swap for a VE30DE?
- warning to all maxima owners
- Injector problems
- parting out 1993
- i REALLY NEED HELP. SAFETY CONCERN
- Automatic Windows
- Negative Camber?
- Active Sound system rear pre-amp?
- Pitted Coolant Pipe
- Need help Identifying What Goes here?
- valve cover gasket question
- lets talk miles
- RS5F50A transmission.
- Bought 94gxe yest.,power steering hose broke today
- When I start my car engine starts missing
- head light fuse
- 2 year update - Maxima love
- Clutch issues???
- story of my maxima and me(long story)
- R-12 to R-134a A/C Swap
- 1990 Maxima Tail lights dim, shut off, and sporadic
- intercooler
- Took my 3rd gen to a Datsun show...
- 1994 maxima, fuse blows on brake lights
- Selling blue tokico, springs, ve y pipe
- Air Conditioner Mildew Smell
- VG w/ VE 5spd Trans bearing noise mystery
- vg30et?
- Transmission removal...
- ok,so.....input shaft bearing/seal...
- Blew up my VG finally
- my parking lights don't work
- Master Power Window Switch Removal
- 20-50w ?
- 89 5 speed
- Noobie with Rear Power Window Problem
- 1994 transmission problem
- Ve transmission
- Need quick help Stillen kit owners
- Timing Belt Sliding
- Clutch Suggestions?
- Rebuilt motor
- Charcoal canister
- Water Pump Pulley Bolt Size
- 92 ve30de misfire
- So fresh and so green...green (smog results)
- q45 radio in a 3rd gen.
- stuttering acceleration and hard shift to second
- Need injectors but which ones?
- mystery hose
- Battery/engine fire put a hole in my A/C line
- TB Coolant/Hardline Delete?
- There are still a few out there worth having...
- Problems with moonroof
- VG Head Bolt Torque Sequence
- Wrong injectors installed?
- not your average crank no start concern very weird PLEASE SOMEBODY HELP
- Just pick up my front tokico
- So sad
- Help im stuck
- Manual Climate Control Teardown and LED Swap
- chip my car for more hp?
- My 3rd gen return from the dead 93ve 5spd.
- Homemade LED 3rd Brake Light
- Power steering problem video
- SOHC Motor Mounts
- Noise, gear grinding? in drive
- New blue windshield
- Manual Transmission Leak
- Ve ?
- Are these real? And a good deal?
- Having starting trouble
- Please Help i can't get my wiper motor off!!!
- Xenon 3rd Gen Maxima Urethane Kit - Stillen Clearance
- Plasti dipped hood!
- Shift lever only moves from park to reverse
- Anybody left who knows anything about these a/c systems?
- VG30E - pulley/belt vs. alternator ... noob
- Which is the best one?
- Finally
- Looks like the end is here..........sad...
- Oil leaking from 'ivt control sensor.' Can't find part number!
- Stop Stop Stop
- ECU got wet in storm!?$&@#!
- 93 automatic SE shifting issues, or just paranoia?
- Passenger side cornering light
- 1993 Maxima Shifting Problem
- Exhaust
- 93 Maxima problems
- Shocks n lower ?
- scottsdale pavilions
- My New Maxiam
- What is this electrical plug on my engine block?
- VE water pump leaking, yes or no?
- 91 vg30 injector issues
- Green springs
- ××××Shocks/Struts××××
- Digital climate control write-up? Craig's is long gone
- Tach Pegged
- Control Arm Bushing Bracket Bolt won't go back in.
- Brake light issue, turns off when headlight on
- Tranny problem
- Injector dot colors
- Euro clear headlights?
- Can i boost with this?
- ***Automatic Shifter/Everything But Drive Works***
- Front suspension issues
- exhaust manifold
- Interior Mods
- Rear Defogger Bairly Working...Need Help
- Is there a clip?
- Brake warning light on
- ++++3rd Gen Power Window Master Switch++++
- 1,3,5 Cyliner problems Please help...
- redundant topic bout suspension but....
- Clutch Slipping
- big diffrence
- O2 Sensor
- Do warspeed y pipes use gaskets?
- My latest 3rd gen
- Quick question
- Is it still around?
- Limp mode i think...
- sad day cuz my frontr lip crack in half. help
- Motor Mounts
- Replacing Rear Speakers in a SE
