- What 2 get with a grand 4 my Max???
- Would u keep it on or take it off? (video)
- Sunroof drain exit tube location?
- thinkin about trading my 90 max se.......
- Maxima Vs Porsche 944
- wtb fog lights and headlights
- TOB/ISB Noise - advise needed please
- Has anyone ever flush (not drain fill) their power steering fluid?
- VG 6AL ignition?
- Do any of you do your own oil changes?
- D2 Full Coilover System 4 3G Maxima!!
- Anybody hook up some heated mirrors?
- CPU DEAD!
- Front hub removal?
- I'm back. Scored a 90se with 65k!
- Dash lights operate with brakes???
- Getting car running again
- Maxima 94
- anyone looking for a SE?
- Anyone still have a Fidanza in their VE?
- 90 max se. 5 speed, 84 300zx 5 speed swapp everything?
- Hid
- 1990 maxima se, all stock, idea's for more power?...
- coil groundings
- Stolen Maxima Alert 1990
- Rear strut upper mount bushing......
- My Prototype box
- 3rd gen 5-speed swap help
- Any recent experience with the Monroe OESpectrum/Sensa-Tracs?
- Front hub VE
- Fun read on 3rd gens
- REQUEST
- My first car but a problem what is it?
- sputtering after warmed-up or hot
- Pic of ST RSB?
- Auto Trans Question's
- Little winter surgery on my Maxima
- What did I do wrong?
- Does it get worst if I keep on driving?
- What are ur plans for the 3rd Gen next year.
- 300000:)
- Problems I had while replacing knock sensor (VE)
- Been through Stickies, still need help.
- No codes From ECU
- How to: Reading and Clearing Diagnostic Trouble Codes
- looking for photos--
- shuts off when put in gear
- Crank but no start
- Question. 3rd gen bose to 4th gen bose harness
- Transmission question
- Transmission drain spring
- Battery Replacement Options
- Cracked IM solenoid?
- What do you guys think?
- ASP just repaired my UDP
- Exhaust Choices?
- Auto Transmission Died
- Rear Brakes Friction coefficient question
- Upper spring perch rubber?
- Annoying rattle from passenger side
- Help. Approximate power steering rack outer diameter
- Sway bar components question.
- Idler Pully Poof!
- anyone interested in 3rd gen bbk
- Who's sucessfully removed broken mani studs?
- Anybody have the OEM TOB part #?
- VG engine replacement??
- question. 93 SE PCV Valve Thread size
- Why am I still have shifting issues?
- A few quick questions
- Car shakes bad above 60mph
- Front seat belts question
- Paint to match dash?
- AC musty smell. Accumulator?
- Can't find the sunroof drain hoses to blow them out.
- HUGE Problem - Steering Rack Bolt Anchor Stripped
- Air Cleaner duct (16578-97E00) question
- Search function solution (Google Chrome only)
- Help. ECU Code Chart
- Help. Isolating Fuel systems problem
- Crankshaft pulley bolt size
- GXE auto trans to SE auto trans
- I wish I knew that before I did what I did.
- sharing pictures
- bought another 3rd gen
- 91 5 spd trans to transfer in a 94?
- Life of Power steering suction hose?
- Anyone run an aftermarket steering wheel?
- search function problem
- Where can I find a stillen lip/side skirts?
- Anyone know where to get third gen model cars??
- Bypass stock clarion amplifier?
- Car shuts off while driving without warning???
- Fuel Injectors
- where can i get engine mounts?
- fixing bent valves...
- Filter Question
- Thanks for everything and farewell.
- RPM jumpy when I brake.
- Front End Knocking
- How to tell if your oil pump is going out?
- Engine swap issues plz help
- cooling fans
- Stock cd player?
- wheel hub different?
- 100 more HP would be ideal for todays standard
- I need 2 working fuel injectors asap for my 90 max
- Inner Diameter of the Upper Radiator Hose
- couple seatbelt questions
- Anyone Change to Top Feed Injectors?
- Help. How will I pull codes from a 3rd gen?
- Performance Radiator For 1991 GXE?
- ECM different or same for all?
- Experiencing higher idle at times
- Noise
- Rattling/knock in engine (Video)
- Engine Cleanup?
- '92 SE - Damn Fuel Lines Again
- Sudden loss of power
- Headlight housing
- Trans Fluid
- Recommend What Last Minute Parts To Get Before Junkyard
- I washed my car today..
- loud beeping sound while driving
- Fluids question
- gxe starter issue
- Auto trans rebuild
- Sealant Stuff Used On Our Chassis Blasted Off
- What's The Most You've Towed Behind Your GXE
- How-to : light switch assembly salvage
- Help, help, help!
- High Idle Then Shuts Off in Gear
- Climate Control Issue?
- VE30DE issue - hesitation
- Vibration/Rapid thumping
- As of 2011 do you guys see many 3rd gens on the road anymore?
- Nissan OEM Metric Bolt Grades Conversion
- Anyone try the Dorman or ATP RH Exhaust Manifold for the GXE SOHC?
- Has anyone bench-tested a VTC with air?
- Aftermarket Hub Adapter Horn Wiring
- vg30 lower intake spacers
- '89 GXE Transmission issues
- Is a 1994 VG Green/Yellow Dot Injector fuel rail Compatible with 1992 GXE Computer?
- looking at '90 maxima; please educate me
- kinda bummed
- Replacing the bushings in my suspension.
- RS5F50V Drain Bolt
- Exhaust leak in the mesh flex...what to do?
- When do you shift?
- The time has come.
- filler neck hose and vent tube questions
- Where to attach stillen front lip
- Easier way to remove the oxygen sensor from plug?
- 93 maxima body kit
- my 93 SE lacks power(help)
- Idler pulley (AC) replacement help (noise after replacement)
- what gives?
- verify correct p/n for knock sensor sub-harness on VE?
- At a red light, it #*%@$^& DIED!
- Aftermarket Steering Wheel Hub
- front wheel hubs and bearings
- How to set the Tps?
- Engine light. Please read.
- A/C question
- (HELP)need to remove 93 max se top intake to replace rear injectors
- What car is my caliper from?
- Slow to fill with fuel
- List of car problems. Need help please. Thank you.
- Digital HVAC Face Plate Removal?
- Bose stereo head unit replacement question
- Throttle position sensor help
- I want those seats too!
- has anyone ever seen these
- Driving with that AC on, and water starts pouring out from the dash??
- I accidentally...
- 1 year later and still running!
- Next "BIG" 3rd gen Grounding Project:
- How to fix your sun damaged dash
- Original VE tire?
- Shaking and vibration at high speeds when on a curve?
- Photo (without comment)
- Can 1994 GXE Injectors be re-wired to work in a 1992 Brougham Chassis?
- Rear Quarter Panels
- Is this news to anybody else?
- Re-using Exhaust Manifold Gasket
- Can I By-pass the ABS Actuator?
- Looking for a part...
- Anyone w/ experience in B&G suspension?
- 92 GXE Radiator Fan Relay ?
- Burping the system
- Is it my throwout bearing or....
- How to use a miltimeter?
- Factory Alarm Reset on 92SE
- Speaker wire question?
- Engine Light On.....
- How much freon???
- aftermarket shift knob
- Question: How to install non-OEM fogs/driving?
- My Maxi!
- Looks like stock 15" sawblade wheel design robbed by Nissan:
- How heavy is your Max
- My Max
- just wanted to know
- Supercharge
- Should I advance my timing at 196k?
- Brake line question
- What to replace if I'm gonna take out the enginge?
- what is this thing?
- 2nd Gen Vs 3rd Gen Tranny
- Car is wrecked but driveable and fixable.
- Am i stuck in 3rd Gear?
- 93 SE exterior problems... any inexpensive remedy?
- Sway Bar help
- A/c condenser question help
- 3rd gen is going bye
- Engine fire
- ignition coil
- External ATX filter?
- Bad Rings!? :-0
- Sounds like my spring is clinking around, bad strut mount?
- power window switch - removeable from panel?
- here we go again
- Passenger high beam prob
- 300,000
- seat belt question!
- Orientation of Eibach Springs
- Z32 caliper leaking at the brake line
- Screeching and Goaning noise coming from front right
- where
- Parking brake sticking
- Rear manifold studs, does AT have to come off?
- Question (survey) on AC performance
- Free Camshaft Seal Install tool (VG)
- Is my oxygen sensor gone?
- Old rotor cause wheel shake
- How do I Know its time to replace my struts?
- go ahead
- What to pay for '92 VE5 w/153K white on tan
- Vg engine takes longer to start when hot outside??
- Mystery squealing
- Somethings draining my battery, and wallet :/
- Crazy Cooling System (Overheating)
- my custom hood
- Car won't start
- 93 SE problems/questions... help.
- air filter question
- long beep
- 93 SE Window regulator jam remedy
- key cylinders
- Blacked out corners
