PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Control Arm Bushings
  2. door panel
  3. Cruise Control not working?
  4. Auto tran. Shifter sticking...
  5. thud sound when accelerating or braking at low speeds
  6. I need advice about a noise
  7. looking at 94 gxe
  8. limp home mode
  9. How Do You Change The Abs Module?
  10. air conditioning poping/clicking
  11. I miss you guys :(
  12. My lights got me busted!!!!
  13. Updated my Homepage! Check out my E-36's installed.
  14. stupid question maybe....
  15. Check it out - new wheels!
  16. how to reset the ecu
  17. out of curiousty!!!
  18. whack temp gauge!!!
  19. manifold studs costly???
  20. speaker bracket advice
  21. How do you turbo a maxima??
  22. Fuel Injectors???
  23. Poly sway bar bushings
  24. Rear strut cartridge replacement (KYB)... have a question
  25. exhaust manifold????
  26. Climate control display
  27. SHIFT_New Tranny :) :) :) :)
  28. fog light bulb replacement
  29. Guys going to NOPI but havent registered please read
  30. Help an old friend out guys
  31. I go coo-coo for doo-doo puffs!
  32. injectors and coil
  33. will the shifter from a vg fit on a ve 5spd
  34. Opinions on tires
  35. Help w/ hella supertone horn install!!!
  36. Do you know anything about Nissan computers?
  37. Bucking and lurching--fixed!
  38. transmission swap possible?
  39. goo gone (is that what its called)
  40. auto tranny issue
  41. Cars almost done, well sort of....
  42. Going to the track soon, which way to run?
  43. SE Anniversary Edition
  44. Need help.....!
  45. would a 300 zx tranny fit a maxima
  46. sub frame connectors
  47. Anybody have any experience with...
  48. warpspeed vs placeracing
  49. will the g-reddy cat-bak fit the gxe
  50. any sound clips of a g-reddy cat-bak
  51. whats the most hp we can get
  52. look at these eyes....angel eyes
  53. small LEDs for dash switches
  54. Squirting Time!
  55. Buying used car 92-96 Toyota Camry vs 3rd Gen Max
  56. Resetting The ECU?
  57. breaks
  58. Stalling and jerking on 1991 model
  59. Stock Wing
  60. Sound/video clip of Fidanza revving?
  61. bose radio system
  62. Tech details for DIY CAI / Intake Designers + cheaper couplings
  63. Busted timing belt, my options?
  64. under drivey pulley won't budge!
  65. used maxima
  66. tapping
  67. Help with my rear rotors for my 90' Maxima :bawling:
  68. 90 SE Injector Resistance???????
  69. question about the 9006 and 9005 bulbs
  70. projecters for a 3rd gen ? ebay item
  71. 93 GXE, check engine on - fuel injector signal circuit fault
  72. Price for a 93 max with odometer fraud???
  73. grinding
  74. OE Cold Cranking Amps
  75. Sounds like meatal hitting-Sprint/addco install
  76. new axles??
  77. Problem!!!! Need help A SAP Please!!!!
  78. Reverse light switch....?
  79. Anyone in NY here selling clear corner lights and also bmw head lights
  80. Rear bumper replacement
  81. Has anyone purchased and installed this aftermarket wing.
  82. VIN Check URGENT!!!
  83. Loose brake rotor
  84. NISMO cylinder heads
  85. Which Fuse? Help Please!
  86. ftsb/AC hose question
  87. Question on 1991 Bose audio
  88. new interior paint pics for my ongoing project
  89. indiglo gauges!!!!!
  90. How to change temperature sensor harness
  91. I think my problem is my IACV, what do you guys think
  92. Question on rear spoiler....please
  93. R32 Skyline wheels on 3rd gen, cardomain
  94. Cost to Fix VTC
  95. Ignition Coils????
  96. Tranny Service
  97. question about hid xenon in fog lights
  98. Electrical gurus "Headlight ?' Not the typical ?"
  99. Spark Plug Change Help
  100. 93 max wire colors
  101. what mod should come first
  102. greddy cat-bak
  103. Standing outside the car, key in hand, yet still running....
  104. $400 a good price for this susp. setup??
  105. my tranny shifts a lil too hard
  106. Temperature Control
  107. dead battery, dead alternator or what?
  108. rear speaker bracket question
  109. front door panel removal
  110. Seatbelt Sensor Problem
  111. Is there any hope for my rims?
  112. VG vs. 2.5 Altima...how would VGs stand?
  113. Front end ?
  114. Catbacks between VG and VE interchangeable?
  115. Settle this once and for all. Poll POST what clutch set up you have and recoomend
  116. Is there a diffrent alternator and compressor for the SOHC and DOHC engine???
  117. Need some help on a stalling issue
  118. digital climate control
  119. rewiring corner lights
  120. engine warmup
  121. factory manual
  122. engine noise & sound clip... PLEASE listen
  123. New Technology Injectors?? Will They Work?
  124. ECU Green Light Blinking
  125. hyper ground wires
  126. Western Newyork (Buffalo) Anyone??
  127. Stupid sticker question...
  128. Preemptive Strike on Exhaust Studs
  129. Free to good (or bad) home: 93 GXE wheels
  130. Bulbs to hot???
  131. where to get seafoam???
  132. Exhaust and Cold Air Intake
  133. I hate SUV's part 784737432
  134. full catback or just a muffler for my GXE?
  135. Intermittent odometer
  136. 93 Maxima Se Radio Won't Work
  137. window roll up/down speed
  138. Plug Wires - a/m 8mm?
  139. sigs pics are not showing up for me
  140. Auto and Manual Trans Comparison Question
  141. A Couple Questions - Kinda Important
  142. Project Maxima: Skyline Tranny?
  143. auto trans shop in Dallas?
  144. anybody know what FICD relay is??
  145. Strange no start, stuck key problem
  146. Dropped the tranny :)
  147. Matt, Jeff, any other Fidanza Owners please help!
  148. Aftermarket fuel pump won't work?????
  149. 300m or 1/5 of mile
  150. Valeo clutch_Fidanza flywheel
  151. probs with engine cooling fan???
  152. What next?
  153. How difficult to replace Power Steering Fluid Reservior Hose
  154. 1991 Nissan Maxima SE (standard) Not Starting --- FUSE BLOWN (Help?)
  155. Broken transmission fixes itself!!! What happened??
  156. tranny self-diagnostics ??
  157. When is time to replace shocks
  158. Fuel Pressure or something else?
  159. skyline tails
  160. do we have split diagonal brake systems
  161. im moving but my speed says 0
  162. should my temp stay on normal
  163. Building Turbo Max Se
  164. Rotor Question
  165. screw on the ecu
  166. levoc auto shift knob w/ e-brake
  167. So, the installation of my Addco RSB wasn't as smooth as planned
  168. vacuum question
  169. 92se Ecu Part Number
  170. tranny slipping
  171. What steering wheels will fit?
  172. trunk fabric replacement
  173. super chargers
  174. Help!!!!!!
  175. Does anyone have their max painted...
  176. noticeable drop in Gas Mileage
  177. Can These Be Installed In A 3rd Max
  178. Front Passenger Suspension Clicking Noise!!!
  179. Size of Licence Plate Bulbs
  180. Pix of new 35% tint and black stocks........
  181. 5 sp swap.
  182. Some Questions
  183. Custom front speaker brackets. New ideas?
  184. Quick Tranny question
  185. Bought a GXE, miss my SE
  186. need help asap!
  187. Gear shift will not move
  188. Can I come to the meet in Natick, MA next week?
  189. Finished Rebuilding & Improving Suspension
  190. 18's Too Big??
  191. slyvania silverstars
  192. Umm Last time I checked, gear oil should never be in with the starter right?
  193. Fuel pump
  194. High Milage Contest
  195. Maxima Stalling
  196. My New Maxima, Pics Inside!!!!!
  197. ST SHOCKS STRUTS - Any good?
  198. U-Shaped hose
  199. Quick engine stall question
  200. Orlando
  201. wiring diagram 1989
  202. Online manual?(URGENT)
  203. battery question
  204. projecter and regular headlights?
  205. Won't start after overheating
  206. BMW E36 Write up
  207. good place or site to buy parts!!!!!
  208. How does the AC compressor work?
  209. About Loweing My Car. Will It Work?
  210. Injector prob,any help
  211. Letter to Service Department
  212. I need advice with this
  213. Hard as hell to find a 5-spd VE!!
  214. My $3,500 mod challenge....
  215. turbo update
  216. Before starting on changing to the WSP y-pipe....
  217. bad misfiring and high idle RPM....need some help
  218. brake pads
  219. motorized steering wheel
  220. aaaahhhhhh
  221. i lost my fuse picker
  222. Flowmaster Muffler Question...
  223. abs pump/actuator questions
  224. Steering
  225. never let your friend drive your car
  226. updated cardomain *new pix* sign guestbook
  227. ATF ? 94 Maxima Auto Tranny. What have you used? What works well?
  228. maxima airbags!!!
  229. Cost of A/C pulley
  230. abs pump/actuator
  231. update on my max, for those who care
  232. Why 134a makes the compressor louder......
  233. any online chilton/haynes manual for our maximas?
  234. Clicking/Raddle after 35MPH?
  235. head gasket question? need help
  236. Little blast from the past pic
  237. Question about Katzkin interiors....
  238. quest for euro tails begins
  239. How to remove the dynamic weight thing...
  240. What in the world is this part?
  241. Alignment specification gxe vs. se
  242. tranny question
  243. help!!!
  244. Toyota filter
  245. k & N air filter
  246. how many tickets for aftermarket bulbs (tails,headlights.cornerlights)
  247. 3rd gen t-shirt on ebay
  248. upgrade wiring harness
  249. Another 3rd gen goes under
  250. Possible dead alternator, other things to look for??
