- HELP! Best place to find a starter?
- Rear defroster button stuck
- Story of how you ended up with your 3rd gen
- Performance Loss, Any Suggestions...
- Tomarrow I start on fixing the broken exhaust studs, any tips.
- seatbelt chime
- Fuel Injectors Recall or service bulletin for '89
- 4th gen engine swap???
- 9007 vs. 9004 pics
- Need Some Vacuum Hoses
- mutated with rust
- new suspension
- Need electronic starter system diagram
- Exhaust
- where is it coming from...?!?
- ACC wanna-be ON
- Auto Shop
- What could this be??
- Maxima worth buying???
- ez outs, good or bad?
- Vibration issue solved
- no 2nd, OD or reverse?
- Eibach Pro Kit
- What color is my oxygen sensor wire on my ecu?
- big problem...
- keyless entry failure
- new to the board.
- quick fog bulb replacement..
- clunking noise
- What does a Knock senser code 34 mean?
- doors misaligned?
- power antenna
- transmission change
- Best way to lower my car?
- exhaust leak identification
- What to do about a cup holder?
- Audio problem
- My car smokes, any help?
- gas mileage
- What clutch to get?
- 5 speed transmission question
- PS Pressure host replacement
- Windshield wipers dont work! please help
- I'm A Total Fricken Retard/idiot
- Anyone on 19's?
- STS turbocharger
- Keypad Door Locking
- Has anyone used Maaco?
- Do I have a GXE or SE?
- 92GXE with antifreeze leak
- 1993 Maxima SE spd, is it worth it?
- Is it worth buying??
- good deal?
- cold air intake
- Couple Blemco things installed (pics), not much more to go!
- '91 Maxima won't move at all
- Roo Bars
- Grinding noise from rear.. Need to re-use strut fluid when installing new Struts??
- Urethane parts, how many?
- Best Aftermarket Suspension/ Custom Coilovers?
- Drive axel seating
- custom intake manifold idea
- my car needs an exorcism. "electrical"
- 4th gen head unit??
- when replacing rear main seal?
- clutch pedal goes to the floor!!
- Limited Slip Differential???
- Rear defroster not defrosting.........
- interesting fuel rail findings
- vaccume hose size and speed bleeder size
- shock/strut question
- help plz, problem after the snow
- It's So Hard to Say Goodbye...
- fat *** electrical problem, need help fast
- Fuel Pressure Riser?
- Help, can't reattach ball joint
- Model 3rd gen?
- 5 speed swap COMPLETE.. BUT!
- No Heat!
- pics of broken cross member
- what are the sizes of speakers in a 92 se?
- Door won't unlock with key in cold weather
- Power Window Problem
- can't lock rear door...
- Can I Use 215/50/15 Tires On My 93 GXE
- My VG Tranny Doesnt Shift Out of 3rd Gear Sometimes
- Any Suggestions For this???
- starting trouble
- Snowed-In 3rd gens sign in!
- Which tires to get for our stock rims?
- will not start.. HELP!
- Door keypad is failing...options??
- Im Back!
- Transmission Compatibility
- Interference Engine?
- Feasibility
- Bypassing bose?
- What do you think??
- Fuel Rail Fuel Lines
- Who needed VIN info?
- anyone have pics of brown leather interior?
- Battery Drain When Off
- Any one else in the north east?
- My new max [modding continues]
- anyone else ever encounter this with the rear calipers?
- Sorry VGers
- alternator question
- oil pressure light, friction sound on startup
- installing cv joint
- i made a solid shifter mount
- The old gas leak
- Coolant a little frothy
- 91 Nissan maxima MAF HELP
- du-oh! rear struts
- Just starting to fix
- Engine cold start problem
- compatibility between accessories
- Got a new Maxima...problems popping out like crazy...
- Toughhhh problem
- carpet wet inside car
- shift lock not releasing
- remote start manual
- factory tint...
- bad thermostat?
- Changing a timing belt....
- Custom MAF Adapter
- Thanks to super fishy administrator
- Master cylinder going..??
- No heat on 93 GXE
- DRRRive Moving on.
- How do we remove the ecu?
- Thinkin of getting Nissan to install a sunroof
- Projecter e36 headlights!!!
- I Need An Opinion On This
- 91 maxima exhaust problems
- Pics Of My 93 GXE Max Wat You Think?
- oem alarm system bypass
- fuse box
- Thermostat
- Pics Of My Pistons
- Injectors Question
- anyone w/ CARFAX....need vin # checked please
- Clutch Master Cylinder
- sun roof son of a |31tch
- So I finaly installed radio right
- High mounted brake light melting
- Got Clutch?
- The Bendix Blues, Starter Problems
- Spark Plug Fuzed - Help!!!
- Need help with strange sound
- maxima meet in ontario,ca
- 92 LR Caliper for GXE
- Disc Brake Swap on GXE Completed
- stuck odometer
- caught doing "about 90"
- chrome door sills
- Keyless entry seems to be out / Anti-Theft- 89 Maxima
- Brake Question
- car modification confusion
- engine swap..
- After market body panels
- Key in Door
- HVAC Control Swap?
- relay location help
- What will give me the power I had when I first got the car
- Price expected for P & P job
- how to fix a damn BOSE head unit....?
- Weird Noise at Start-Up
- 3rd gen stuff to sell?
- 1990 Maxima SE Alternator
- Valve cover gasket
- Torque specs...
- need some help fixing my friend's car...tech guys help me out.
- Ebay Air filters
- Top Speed Adventure
- How do I reset keyless entry on my 94 gxe?
- Pulled my CV joint apart....
- Body work
- Who owns 3 maximas...I do
- 1994 interior grey colour
- 92 vs 94 seat cloth design
- light problem
- Armorall on Plastic...
- Maxima Reliability?
- not looking good
- spongy brakes.....think it's the master cylinder
- Heater trouble
- Maxima oil cooler question
- Tail Lamps/Corner lights...
- thowout bearing and clutch mc specs?
- Need in dash screen help
- Oxygen Sensors
- 91 SE for Sale.
- Can't open my trunk??
- chrome door handles
- dash kits or paint
- E36 Projectors?
- Burning rubber smell though heat vents
- Replacing clutch soon, what else to replace?
- spedometer issues
- A couple of questions.....
- black smoke
- Weak spark
- Need A MP3/CD Stereo Need Help Picking
- Electrical Problem
- HELP!!! Broke parking brake tightening nut
- Wheels and Tires
- Wheel Buying Question
- Thinking of smoking front turn signals on my white max
- door panels
- Clutch pedal spacer?
- Rack and Pinnon
- Any soundclips or sound descriptions of magnaflow 14815 muffler and ebay cai?
- Do those Z32/Cobra BBK hub-centric rings really work on the 3rd gen?
- Whirring Noise on 5 speed trans
- Flooded car
- need a new bumper
- You Might be a ricer if...
- Speaker questions
- installed z32 drivers seat
- Tranny problem
- Winter wheels and Snow Tires mounted today
- Security Light On, Car Won’t Start
- Im coming back!
- Jeff...and others you`all were right.....
- Engine Hesitation
- Anybody have MM evo5s on their 3rd gen max?
- I have a problem!!!!!!!!!!
- Cheapest place to buy Stillen body kit?
- Anybody have modded maximas that have some rust or plenty of dents/ scratches?
- H.i.d???????
- door lock problems (con't.)
- Y-Pipe Stud came out with Nut
- Weird problem wit my 91 max gxe
- where are the #'s on my brass box??
- Just thermostat?
- Question on upgrading - wheels and springs-
- Accelerator pedal
- tranny temp and air/fuel ratio gauge
- Um....how do I get my grille off?
- 33 and 34
- suspension question
- Need Advice
- Car problems I haven't seen before...
- Just an idea ...
- 91' SE Gas Smell When Turning on Heater
- Help! I can't see!!
- Clear Coat or Single Stage?
- Battery and brake lamp
- Tune up question
