PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Best oil to use?
  2. Door Panel Key pad question
  3. Transmission is dead, some ?
  4. 1990 problems
  5. 50th anniversary max? uh... no
  6. 1992 Maxima looses power
  7. heater problem
  8. Which ignition coils?
  9. carbon fiber trim kit
  10. question about the power/comfort button
  11. Is this ok
  12. Antenna question.......?
  13. How come everyone says that Bose is crappy???
  14. Addco rsb squeek and it hits spare tire recess!?
  15. Diameter size of ST rear sway bar?
  16. Question on changing the gauge bulbs???
  17. Wipers quit working!
  18. Tune Up Headache
  19. So, I bought a 93 VE 5sp...
  20. Where to get custom plate frames/decals?
  21. cruise control cancel button
  22. 526,000 miles and counting....
  23. disable my stock alarm
  24. Where is the TPS located?
  25. Help With Maxima Adjustable Suspension
  26. Does Anyone Have 2k+ Rims?
  27. What are the specs for an 89 Maxima
  28. wierd noise when in reverse?
  29. greddy catback?
  30. Nylon in the tranny?
  31. Help! Somethings wrong with my Max
  32. Still a 3rd gen Owner...
  33. My car like to pass gas!!! Figure this one out.
  34. VG30E knock sensor location ?
  35. Headers what do i do?
  36. VG or VE
  37. rpm problem
  38. Free Carfax Today only! 2/23/03
  39. Check Engine Light
  40. curbing the max
  41. Those of you with touring spoliers...
  42. I still can not find the code any more sugestions?
  43. Mustang Brakes
  44. Altinator...if you ever had a Alt. prob. check this
  45. any good tires for the OEM wheels?
  46. homemake CAI
  47. Is my baby a waste of money?
  48. Newbie flush question
  49. how old is everyone on here??
  50. Broken back dash???
  51. Anyone Know Who's This is...?
  52. Strong fuel smell in exhaust of 94 VE
  53. Replaced injectors today...well attempted to...troubleshooting time...
  54. headlights
  55. 1990 Weird Problem Help !!!!!!!!!
  56. ASP UDP tightening
  57. need brake material info (searched)
  58. Catback options
  59. Ignition ?
  60. CAI ?'s
  61. stupid ? bout speakers
  62. Is bigger always better
  63. help me out ???
  64. Car Domain is Up...check out
  65. read ECU data in real-time??
  66. Where Do You Buy Gas?
  67. Knock Sensor replacement
  68. help me get the 3.0 auto quicker asap!!!!
  69. Seatbelt chime
  70. Springtech springs and struts?
  71. Windshield Washer Bottle / Way to small: Any Retrofits? /91 SE
  72. engine
  73. trying to diag. a small problem...your ideas?
  74. Keypad
  75. 5-modes ECU (VG30E)
  76. please help! ECU codes
  77. Uneducated Maxima Owner
  78. front bumper replacement...
  79. window regs fixed!
  80. Exhaust
  81. Need 3rd Gen DOHC to Prototype new CAI
  82. it just came off
  83. for anyone who needs a grill
  84. startup hesistation (long cause i like to type :)
  85. Rusted out Driving Lights / 91 SE :Replacements?
  86. Rear struts
  87. Wiper problems
  88. Today i got my heating back !!!
  89. Need help with hard shifting
  90. Clock intermintent???
  91. springs and struts
  92. stock wiring harness...
  93. engine revs dont match tach
  94. Is the Radiator support important?
  95. 911 in middle of timing belt please advise!?
  96. What's Wrong With My 92 GXE?!
  97. 3rd gen is best looking...
  98. Transimision diagnostic ??????S
  99. Preperation for 1700 mile trip!!!
  100. Help!!!! My car is hesitating and goes off
  101. eibach springs
  102. '92 SE auto vs. 99 SE 5-speed...
  103. power door lock wiring?
  104. turbo on a ve30de
  105. This question goes out to you VG30E owners
  106. Help! - Need 1991 charging system schematic
  107. noises
  108. No code stall and hesitation.
  109. VE variable intake
  110. Idle Problems
  111. drivability problems
  112. horrible gas milage problem
  113. For those that like the evo 5 wheel
  114. hey dmontz!
  115. Happy B-Day to....
  116. purchasing a mig welder
  117. coil overs
  118. crank pully
  119. hi everyone
  120. aftermarket Radio problems
  121. Replaced the neutral start switch (PITA)
  122. Tranny Mount?
  123. knock sensor help desparately needed
  124. Alternator
  125. transmission problems
  126. Aerodynamic maxima? or TIME machine? what is it!
  127. Possible reasons for car running rich?
  128. Gas leakage from a hose on the top of the VG30E head
  129. Front Suspension Queastion
  130. What's a 300zx like?
  131. which combo is better?
  132. Question from an "old" maxima member
  133. Who says you cant fit 10" of speaker in the front doors
  134. Mesh Grill
  135. car is making a tick sound
  136. ??/??/?? tire q
  137. I have joined the Intrax ranks
  138. Someone spiked the Koolaid!
  139. Bose amp
  140. Stupid tranny dipstick
  141. I miss my car...
  142. Beware...The Car Cleaners
  143. removing rear seat
  144. Link between tick and running bad
  145. About to sell my 90 GXE and I need some parts
  146. FUEL GAUGE OR PUMP? need help
  147. need quick help, what do you all think?
  148. water pump
  149. 92-94 SE tails.
  150. fuel pump
  151. Check out my EBay auction for tons of 3rd gen parts
  152. Engine swap
  153. Window reg attacks again!
  154. Recycled Injectors?
  155. Cost of cruise control actuator?
  156. 92 SE Needs new clutch.........
  157. Found out vibration cause: Need some exhaust replacement advice guys
  158. Hermonic Balance pulley?
  159. reuse y pipe gaskets?
  160. what is that behind gas pedal?
  161. 4th Gen Frankencar Mid-Pipe works on the VE!!!!!!!
  162. Installing OEM Keyless Entry
  163. Back Seat
  164. Cruise control cancel switch (break pedal mounted)
  165. Head Lights
  166. steering wheel vibrates
  167. My automatic seatbelts (driver side)
  168. Gas Mileage & Heating
  169. I Think it's my Wire Harness...
  170. Here are the pictures i told i would post....
  171. steering wheel alignment
  172. Another Headlight Question...
  173. 5th Gen Mufflers
  174. Here's the seat problem in my '92:
  175. Corners...and H20?
  176. antenna wire
  177. Check this out, Custom Tails, Ebay
  178. Knock Sensor Bypass
  179. head unit not working....
  180. cost of light conversion
  181. Audio Install
  182. tires Q and i SEARCHED
  183. Having intermittent shift solenoid interlock issues
  184. Auto Climate Control
  185. Looking....
  186. While the motor is in the shop.
  187. new pics finally up
  188. Which rims?
  189. 92 GXE creeky front end
  190. injector problems caused by mechanic
  191. will '95 seats fit a '92?
  192. Does This sound like an exhaust stud gone? - - mp3
  193. New job
  194. Transmission problem : please HELP me decide
  195. Power steering fluid leaking
  196. VTC rebuild question
  197. burnt headlight plugs
  198. Decisions decisions....
  199. hesitation, then pull, please help!
  200. fixed VTCs...
  201. hurtin max
  202. Make Fun Of The Rookie!!!!!
  203. just got new sub and levoc shiftknob
  204. Headlights
  205. Master Cylinder vs. Fluid Level
  206. Help Please!!!! Bose Cd/cs Info
  207. fuel filter, seat belt, clock and dash lights
  208. Question Regarding the Fuel Injector Color Dot and its Location
  209. New pictures
  210. keyless entry
  211. shut down
  212. tips on adj the timing belt tensioner?
  213. keyless entry stopped working...
  214. shifter
  215. Car going in today (clutch repair)
  216. will this hold up in court??
  217. Searched already but another ? bout addco rsb
  218. Transmission Problems!!
  219. transmission problem!! Help please
  220. Nasty Sunroof Shade & clips/91 MaxSE
  221. Center Caps
  222. manifold
  223. 300z rims
  224. Whining noise is finally GONE
  225. Preventative Maintenance
  226. ? 4 VG owners with UR UDP is it worth it?
  227. slick 50
  228. VE Coil Packs
  229. VG30i or VG30e
  230. just ordered some redline d4 ATF...
  231. Been gone for a while but I'm back
  232. Help - 90 SE - heater blows warm- not hot!!
  233. Code 51??
  234. Spare Bose Parts
  235. need price advice
  236. weight
  237. all motor
  238. tranny q's
  239. idle speed adjusting screw
  240. temperature gauge problem.
  241. Engine vibration, part two
  242. 3 out of 4 windows have problems ! HELP!
  243. I Love My Max
  244. New to forum
  245. how to access and reset factory alarm
  246. Do worn axles make a clunking noise?
  247. sooo... coll.d..d..d.dd..
  248. Crazy security system! HELP!!
  249. eclipse intake on my maxima - pics
  250. Heater problems no more!
