PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Mods for a 92 DOHC Max
  2. Shift lock override? is there one?
  3. So where does this plug go?
  4. chrome or tuner rims?
  5. My baby wont go into 1st or 2nd gear
  6. Alternator question for 92 Maxima SE Auto
  7. Whatever happened to LED tails?
  8. DOHC Engine costs or help on current engine
  9. Should I Paint My Dash?
  10. Things I learned today
  11. fuel injection hose ok for tranny to radiator?
  12. Turbo VG Video
  13. engine mounts at>m
  14. Is This Mechanic Blowing Hot Air About Rear VG Caliper
  15. Burning Plastic Smell?
  16. VQ 5-spd trans compatible w/ 3rd gen?
  17. The Smells...
  18. weird electrical problem
  19. What is this gasket for?
  20. Similar Radio Mounting Brackets?
  21. Opinion on aftermarket speaker grills?
  22. Looking for a 3rd gen UDP.
  23. VG Coil Springs
  24. NEEDED - 5MT Transmission diagram
  25. 4th Gen injectors on 3rd gen Max
  26. Repairing Hail Dents w/ Ice
  27. Why no hot air?
  28. Bose Amp By-Pass
  29. New Maxima, what should i look for?
  30. GXE Trans Failure! ideas as to why?
  31. stain removal
  32. Rear wheel bearings exist?
  33. Wierd Hesitation this morning
  34. Maxima is getting a lot of needed TLC
  35. Different Steering Wheel?
  36. Radiator blew like Old Faithful! Want to avoid installing garbage. Help
  37. Boy do I feel stupid...how do you remove exhaust tip?
  38. Can i have Blue Speedo Meter?
  39. Cold Cranking Amps?
  40. Intermittent High Idle Problem
  41. trunk light
  42. Clutch replacement... IDK
  43. Need lil info
  44. Back Firing From The Intake?
  45. someone post a pic of their stock intake box velocity stack?
  46. MP3 iPod connection
  47. i smell gas but dont see it
  48. Rear Passenger Suspension Dropped Tonight - Repairs
  49. Easily remove Comfort Control?
  50. Heater hose routing?
  51. OEM brake lines or universal brake lines
  52. How'd He Manage This?
  53. Phenolic Intake Spacer Kit! Is it worth it?
  54. Moving to sinthetic oil
  55. clutch issues.
  56. more from carbibles
  57. Venom Injectors ??
  58. Oil Flushing ( Sludge Removal )
  59. Seat belt light coming on while driving?
  60. oil pressure question
  61. Look what followed me home.... (bandwagon thread)
  62. come to light and car dies, but will restart....
  63. Maxima musings
  64. Installed HU, no sound?
  65. 4DSC Decals are back in stock!
  66. Third Generation Maxima Needed for Winter 2009 issue!
  67. Hello Everyone
  68. Greeny's VE "Retired" 1-08-09 "The Green Mile":-(
  69. possibly buying black 93 ve 5spd
  70. IM and head porting question. has anyone done this?
  71. tranny on its way out?
  72. A Rat Ate On My Plug Wires
  73. Should I buy another one?
  74. ideas for lincense plate?
  75. Intake manifold cleaning and chasing the elusive hot engine "ping"
  76. #2,4,6 cylinders not working...engine swap....desperation
  77. Battery/Alternator/Charging problem
  78. Wow our headlights do suck....
  79. How many 3rd gens have been on the track?
  80. Addco rsb instructions
  81. Starting Car causes power loss?
  82. recall
  83. fuel leak
  84. need more hp and torq
  85. what is the best way to install UDP
  86. Are the Metal Type Upper & Lower Plenum Gaskets Re-Usable?
  87. Having trouble getting 91 GXE to get power
  88. corner lights/blinkers not working
  89. Trip reset busted help.
  90. Window Regulators
  91. speed sensor or cluster
  92. Reducing wheel hop
  93. Front windsheild frozen. (inside)
  94. Front Parking Light How to?
  95. urgent: Eibach alignment specs vs stock?
  96. porting exhaust manifolds
  97. no heat
  98. Clutch won't relase.
  99. Can the VG Cylinder Head Gasket be Accessed Like So:
  100. Horn stopped? and brotherly war question.
  101. OBX Headers
  102. Heater Core
  103. Problem with suspension
  104. Looking for VE UDP
  105. Round Tooth or Square Tooth Sprockets - 2 Varations of Timing Belt for VG?
  106. Max pulls to the right. Help!!!!
  107. External Tranny filter (good idea?)
  108. power fold mirrors
  109. rear bumper
  110. Max dead on the side of the road, any thoughts?
  111. cooling system
  112. Time to change the timing belt
  113. exhaust manifolds
  114. safe to use chains on lowered max?
  115. WYNN's V.I.C
  116. Please help uneven mixture between front and rear banks
  117. Equal Length Y-Pipe (w/vid)
  118. Trunk wont open HELP!!!
  119. Heating problems
  120. Just need 1 more for spacer kit
  121. Wiper troubles
  122. installing keypads?
  123. Hate those VG30E valve cover fasteners?
  124. Painted Upper Intake Manifold
  125. Timing Tensioner
  126. Third Gen headlight retro
  127. I'm saying good bye to my Max.
  128. foglight rewire
  129. just bought body kit
  130. Winter Here new turbo projects take off...
  131. engine help
  132. Wheel/tire fitment question
  133. Idle worsens...
  134. Oooops :-(
  135. ebay strut bars
  136. HTP Billet 3rd Gen MAF Adapter
  137. Fuel Pump malfunction??
  138. ASP Racing Crank Pulley
  139. ****_____Lights Issue_____****
  140. Crankshaft pulley TURNED
  141. Killer Maxima!
  142. Car Clacks like an old Diesel Mercedes
  143. VTC's went as i was driving.
  144. AC tensioner pulley help
  145. HELP! Mechanic maybe screwing me, tokico struts
  146. 92 VE Stalling out while driving??
  147. Heater Core
  148. VG30E Intake almost ready to Howl!
  149. VG38R?
  150. Odd Noise After Timing Belt Job
  151. grounding kit
  152. Problem wire in harness
  153. Writeup: 5.5gen (A33B) front BBK for your 3rd Gen
  154. Visual Mods: add your opinion
  155. Raising the compression ratio on VE?.
  156. 'retarded llama' sound from brake mcyl
  157. Happy Turkey Day!
  158. Aussie maxima..se or gxe?
  159. Will a windshield fit in the back?
  160. is it my window motor or regulator?
  161. 1992 FSM??
  162. Caped and Pearl's Speed-O-Meter thread...
  163. Is it Possible to Replace the Metal in Wheel Wells?
  164. Bad caliper or wheel bearing?
  165. For Those Who Have Installed Aftermarket Swaybars
  166. Stock housing projectors
  167. 3rd Gen w/a GTR Motor
  168. VE30 engine swap
  169. Feedback on my lowred GXE
  170. 94 motor into an 89
  171. Anyone live near Binghamton, NY?
  172. Question regarding VG30E
  173. Need to replace crankshaft pulley
  174. axle and dust boot ?
  175. transmission leaking BAD!!
  176. Chip?
  177. Vacuum lines and power valve
  178. will an '87 engine fit on a 3rd gen?
  179. Motor Swap Underway, Any Advice?????
  180. Max was hit - need advice
  181. Where to buy the fidanza flywheel for the low
  182. Fasten seat belts light
  183. Is it Safe to Completely Remove the AC Condenser
  184. Floor mode doesn't work right on a/c
  185. my old 91 maxima is sick
  186. Clicking / Putting / smoke from engine bay while accelerating and clunk when braking
  187. tranny mount
  188. want to rid of my ABS
  189. the electrics!
  190. Question about VG injector tips?
  191. 5 speed swap done but have a slight issue....
  192. Congrats to Jonmandude and Pearl93VE
  193. strut tower brace
  194. Clutch pedal adjustment?
  195. Throttle Problems?
  196. Doesnt go in park
  197. 5spd intermit no crank
  198. Sway bar dimensions and recommendations
  199. 91 Starting Difficulty
  200. Headlights or dash lights not working.
  201. 2 issues, please help
  202. Seat Weight?
  203. Time for new injector harness?
  204. 1990 Maxima running poorly.
  205. Control arms welded to frame ?
  206. Is There a Way to Remove the Floor Carpet Without Riping it Out?
  207. Seat Covers
  208. Was There a Separate Parts Catalog From FSM?
  209. Misc issues inside....come on in!
  210. replacing radiator, suggestions on brands?
  211. Can a Power Steering Pump be Re-built?
  212. Changed Hood Lift Supports
  213. Swapping radio and climate control
  214. Battery Dashboard Light on
  215. Trans go shift kit
  216. Maf sensor?
  217. NA VG power
  218. Are my motor mounts bad?
  219. Harder to slow down.
  220. power window go up very slow
  221. Changed the Plugs
  222. Rattling coming from A/C compressor
  223. Heater Core Replacement??
  224. Addicted to fixing cars???
  225. Dropped Car Won't Move. Transmission?! HELP
  226. Recommendations for struts/shocks
  227. Loud sqeeking noise....
  228. Wierd transmission issues
  229. stereo help
  230. Help! I need some tranny removal instructions.
  231. remote starter options, for manual tranny
  232. Front Strut Bellows Gone
  233. possible project car.
  234. Where did the Maxima lose it's height?
  235. striking rod yoke/seal problems
  236. Leaking Radiator Coolant
  237. HOW TO: Replace VG camshaft position sensor
  238. Whats the best way to drive an old A/T
  239. Now that im done with school................
  240. Engine misses when wet at idle
  241. Engine swap checklist
  242. Windshield Wiper timing
  243. VTC Clack/No Clack: A Video Comparison
  244. Oh no, not again
  245. BEST YEAR OF 3RD GEN MAXIMA
  246. damaged tierod threads: fix or replace
  247. My 24 Hours of Lemons debacle...
  248. Has Anyone Found The Weight Specs on Max Engine & Tranny?
  249. what this could be?
  250. Pictures of my max photoshopped for Konig Contest
