- Questions on testing injectors....
- painting body kit
- VE woes......
- Daytime Running Light Problem
- Anyone Have Pics With Intrax Springs With 18's
- Crazy Speedo Needle/91 Maxima SE
- How hard to change to heated seats on 3rd or 4th gen?
- Clean VE - pictures inside
- Strut Bearings and Camber Plates...
- i really appreciate the help the people of this org has givin me..
- where to get engine rebuild instructions on the net?
- It's Decision Time.......sell max for turbo car ?
- Speakers, continued
- diagnostics codes
- hesitating
- Electrical Problem
- bose problems. confusing ....
- seats
- Help? Car won't go into gear
- which injector to replace
- DAD racing seats
- Bosche +4 Spark Plugs
- Key code for 1989 Maxima GXE?
- Where and how much should NGK plug wires be?
- What could you do when changing a spark plug that would cause a injector to die?
- get rid of the undertone paint?
- VG knock sensor problems
- A/C control lights...
- injector help
- I'm finally a 14 sec Maxima!
- 90 Max Hard to Start
- When Do I know it's time for a new Radiator Hose?
- what to say
- Pics of my new rims on the car!!!!
- problem w/the vents
- 1990 Se Is Not Running Right I Need Help
- Brake Pads
- Brake distributor problem
- Anyone Replaced Front Engine Pipe
- Oval Dash ????
- Finally, no stall and hesitation!
- I finally got a Max!!!
- Anti-theft module wiring - yellow wire
- Indiglo Gauges (how hard)
- Who Has The Most HP?
- e36 lights w/ angel eyes
- congrats to craig
- Clear Corners
- Well I still have some really nasty hesitation since installing my Y pipe....
- F*ckin rare manifold :eek:
- Uh Oh...
- stuff coming out of the exhaust
- just a thought.
- spring/strut combo cheap
- e36 write up
- bad acceleration
- 1990 Se Not Running So Great Plz Help
- Ve Rebuild Kits
- Does a VE B-pipe fit on aVG
- Indiglo Gauges
- Stupid Power Antenna
- suspension questions: guru's needed.
- Speed sensor testing?
- HELP Missing out while driving
- L.E.D. for Driver's Window Switch
- How long does it take to check the timing?
- Anyone use the dent puller "as seen on Tv" at Wal mart?
- Could code 51 be caused by something in fuel tank?
- Question about offsets
- For those who do it yourself
- question about putting on different rims
- VE30 head swap
- Car stuttering -muffler? -frozen gas pipes?
- Best Brakes...
- did vtc grounding while motor was flushed
- Performance Issues
- Driver Seat Broke, Help!
- 5-SPD problems-WIERD SYMPTOMS
- I need an answer Immediately
- Clarion Amp Problem - Repair sought
- Please help me with procedure of replacing water pump!
- Speed sensor
- Yazaki, or mega spark(plug wires)?
- Strut brace
- deal on sprint springs
- Tint pricing
- Parts car
- I need Instructions for installion of CAI
- vibration
- bose head unit
- speakers
- when are the for sale forums gonna be up?
- Door lock ghost
- Could this be?!
- compression springs
- ECU Change-out Problems
- car won't start
- What is the Horsepower of the Stock '94 GXE???
- Pulley Wheel
- Tail lights and corners stay on after switched off
- performace tires
- Ignition Kill problem?!?
- anyone living in va
- New To Maximas Need Performance Help!!!!
- I lost part of my caliper today
- rear bumper question
- Anyone w/ Painted Interior?
- Someone with a FSM
- can't afford a greddy exhaust
- Incompatible Antenna
- Shock/Struts gone bad??
- Windshield washer pump installation help is needed...
- Digital Dash
- VG auto went back to the track. New Record!
- What's the best way?
- Intake gaskets
- Bleeding brakes
- Rear Speaker Amp Fix
- Trans... questions....
- engine wiring harness and vaccum hose kit??
- headlight delay
- what does the "fuel injector sensors" look like?
- How can you do a comprehensive paint touchup?
- Installing new suspension...
- Oil on spark plug........dammit
- keyless entry
- XM Radio
- Ve30de Interference Motor ??????
- Prices for lowering springs
- My car does not want to start in cold
- lowering springs
- coil overs
- How to determine if gas odor from fuel injector or fuel line?
- the smell of gas
- wich engine do i have
- Digital Dash not turning on
- No turn signals...
- Pop charger maintenance
- VE Auto got a little faster today --->
- Inside the Bose amp...
- Speakers
- Need help on a quick question....asap....!!!!
- Important Threads- Mods mabey make this a stickie to clear up the cluter above?
- intake noise....suggestions
- Who Has Bags/ Air Ride?
- Parting out 90 GXE-silver
- Real nasty hesitation since adding the Warpspeed Y.....
- Grill question
- VE30 DE teardown
- Is it illegal to...
- I really need some help!!! Please
- any Pics of the 3G /w CF hood?
- running rough and stumbling on acceleration
- Auto Tranny to Manual Tranny Swap
- Turbo 3rd Gens
- Clueless????
- Clear blinker lights - Question! Help!!!
- Did I get RIPPED????
- Just Got My Car Back ( Im Broke ) But Atleast My Cars Ok !!!!!!!
- stuck door latch
- Replacing suspension, need advice
- Transmission question
- Radio/ speaker/ antena - strange problem
- re: can anyone check a fuse for me?
- Wouldnt Start
- common problems to look for when buying?
- Short Shifter
- neeper megga 18s
- Hesitation
- speedometer 10mph fast
- Rim opinions
- All 4 doors are open automatically in the morning
- Replacing Fan and Motor
- sudden downshifting, "P" light blinks, repeats constantly
- cold weather and tranny
- dog gone
- VTC solinoid oil leak???
- Fuel Leak Lucky
- fog lights
- VG30 help
- My New Max Homepage :)
- trunk light
- Grinding sound when car starts
- injector puller
- My Max
- 3rd gen direct ignition?
- Two questions...
- Blown Fuse?
- Electrical / Rear Brake Lights Problems
- Buying Max have question
- Got my warpspeed Ypipe on this morning....
- need help
- leaks and noises
- Transmission swap
- test
- Blue VE 5-speed in NJ
- legal limit on va tint law?
- what do you think of my max?
- bought 35% gila tint install sometime soon
- 17s or 18s
- Hello Fellow MAXIMATEERS!!
- Pics of my Max
- blew the head gasket
- Simple Question? Kinda dumb question but simple
- Rear Speakers
- Been a long time hows everyone doin?
- Car Wash/Window Control Unit Horror Story (kind of long)
- Gas Smell In The Vg
- IM BACK !!!!!! (well.......kinda)
- Need opinion
- ford.... waaaay behind in technology
- Had changed both Lower Ball Joints, what next...
- rebuilding VTCs shortly
- Fuel pump replacement
- changing starter writeup?
- Sounds of My car: Bad Idle, noisy valvetrain, cool stock muffler sound too.
- VI on a VE
- pic of silverstars on low beams
- I searched and searched and.................
- Adjustable Links
- 20's on a maxima!!
- OMG!! A little help finding the idle adjustment screw on my stutterin 92se 5sp please
- Need Help!!!
- Opinions please....
- What is "synchro for reverse"?
- anyone tried hyperwhite lights?
- Erebuni kit
- One of those Suspension Questions.
- man i need Help
- front turn signal housing
- Pictures of some new things I bought for my car
- Leather Seats GD
- Cheapest rebuild kit for VE
- exhaust noise
- 2nd Element On Parking Light
- 1991 nissan maxima se audio wiring problem!
- solenoid pack part number
- the clutch
- '94 GXE: stuck seatbelt?
- Talk me out of a 5th Gen...
- Crank Angle Sensor
- ground vtcs during motor flush
- Paint question.
- Nissans Poor material choices
- Well kids, I'm moving on...
- eric93SE, any word on new VE UDP?
