PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. windshield wiper arm making alot of noise
  2. need help bad smell
  3. spark plugs in the VE
  4. What Made My Car Stop??
  5. Why does this kit look familiar?
  6. 3 most helpful aftermarket guaes
  7. Car wont turn off, need help.
  8. Need urgent help - AC blowing HOT air :(
  9. what's this thing?
  10. wiring question
  11. Car Trouble... Need Help please
  12. VG 5-Speed Swap - Worth It?
  13. knock sensor problems
  14. Timing chain
  15. Clear corner probs.
  16. Bumping up timing
  17. Digital Gauges
  18. Tranny
  19. Steering ratio adjustment
  20. I miss the 3rd gen days!
  21. a few questions
  22. What's this rubber on the shaft for?
  23. We goofed: Urgent help needed!
  24. keyless problems
  25. Brakes, bad steering job
  26. rear seats
  27. Have you guys seen this damn thing yet?
  28. AC Relay Problem? please help
  29. Is it security system?
  30. 4th gen tranny in 3rd gen
  31. For those with ACT clutches. Does it smell like burning?
  32. suspension and other bushings
  33. ECU - Where is it???
  34. magazine ads?
  35. BMW Lights...
  36. Roof inside jumps track
  37. ACT clutch did me in...
  38. how much would it cost to...
  39. neutral safety switch? please help
  40. Alternator Removal
  41. Installed the redlinegoods leather boots
  42. putting in lowering springs
  43. Idle Air Control Valve - AAC Valve leaking coolant
  44. 90 SE makin me crazy
  45. Dash Clock
  46. Timing belt changed. Some issues now. (Sorry, kinda long)
  47. custom install help
  48. Another Turbo VE to the ranks
  49. ABS dignostics information with explainations
  50. How do I find the compression *ratio*?
  51. Found another new toy for my 89
  52. speedometer problems...on an 89
  53. VE 5spd conversion
  54. Right corner light doesnt work
  55. ABS warning light on
  56. Power surging under heavy loads
  57. Electrical Problem
  58. Will a condensor from any 3rd gen fit?
  59. here is the update with pics of my 2k2 maxima muffler installed*(warning 56k people)*
  60. Catback system help needed now!!!
  61. Newbie Transmission/Flywheel Questions
  62. A/T shifting hard.......really hard
  63. lights that were on ebay (jeff was wrong once again)
  64. Spark plug side gapping, yay or nay?
  65. viscosity oil for ticking VTC's
  66. Window Trouble
  67. Intentionally negative camber for aggressive cornering
  68. what the... crazy maxima rear calipers
  69. on and off problem!
  70. charcoal grey paint and clear coat
  71. Why Do and Would You?
  72. Power steering fluid
  73. whats's this Variable Intake manifold used on the VE30DE 5spd all about?
  74. Can't get my timing just right!
  75. new pics with stillen lip installed
  76. scared...she's goin into the shop tomorrow
  77. update on control arm swap
  78. The Max is for sale!
  79. Tranny oil in and out in one pour
  80. Re-bored Throttle Body 4 Max $190
  81. Quick Strut Bar Question
  82. is this bad?
  83. Would these headlights work in our maxima's
  84. Heat Gauge Not Working
  85. Tranny Fluid Question!
  86. Power surge when accelerating
  87. update: over a year with tokico blues_opinions:
  88. uhhh
  89. My Maxima Saved my life!!!
  90. K&N cone installed
  91. odometer/trip odometer quit
  92. trying to identify trim level
  93. gauge not working
  94. 92 SE Project Car
  95. A higher numerical gear ratio
  96. jus wondering..........
  97. Fuel Pump
  98. Subaru wheels
  99. New window reg. problem...
  100. blue maxima doors and windows
  101. 2nd Genner Detailing Advice
  102. 3rd gen with a VQ30de-k
  103. Is there such thing as a replacement wireharness?
  104. Car Problems!!
  105. Removing window motors from regulators?
  106. Fuel Injector Identification
  107. JWT Cams on a VG
  108. shifter question
  109. over revved:(
  110. i need help with my 91 maxima!!!!!!!!
  111. Two-Tone Paint Job?
  112. VTC rebuild tools? oh and studs :)
  113. Electrical Problems...
  114. 1991 maxima sound system...
  115. m3 mirrors
  116. Looking at Spring Options.
  117. Who has installed a 2k muffler on a 3rd gen?
  118. Hid
  119. Smoking....
  120. MAF sensor problem
  121. grill swap
  122. 1989-1994 maxima dual fan help for 300zx
  123. WW kit por favor
  124. Moon Roof Removal
  125. Suspension differences between GXE and SE?
  126. Location of fog light switch
  127. AC not working
  128. '93 SE Door Locks no longer function
  129. Drivers Side Lock
  130. T/B tensioner adjusment
  131. The Right MAF Adapter
  132. Fuel injector circuit open???????????
  133. new used car
  134. Rear disc or drum?
  135. engine swap
  136. one cylinder not firing
  137. Sonar Suspension Failure (SS II)
  138. Sonar Suspension Failure (SS II)
  139. Radio advice
  140. Yet another CAI thread
  141. Driver axle problem...help :(
  142. Cruise control Governer
  143. Car won't start (Changed valve cover gasket)
  144. What else could it be ?
  145. parts
  146. 3rd Gen Maxima Cartoon
  147. Would anyone be interested in a built VG?
  148. ut oh... metal shavings cant be good
  149. sprint springs on stock struts...bad or ok??
  150. NO heat
  151. security system
  152. WTF Looks Weird
  153. turbo and 300z ecu question?
  154. Ait Loacation
  155. need some insight
  156. 1990 gxe with a vq in it with its dash
  157. diagnostic question
  158. Replacing lights behind AC/Heat controls
  159. just f**ked my third engine
  160. struts
  161. Tranny is dead, now what?
  162. Auto Tranny question....
  163. Shop has had my car for over a month!!!!!
  164. How to replace distributor for 92 VG
  165. 92 max parts car
  166. heater
  167. Need Motor or Heads
  168. another bmw question
  169. Loose wires!
  170. Help, rebuild question!
  171. Engine Overhaul or Replace Gaskets???
  172. speedometer needles
  173. VG30DE in 1989 maxima
  174. Brake Bleeder pressure?
  175. Knock sensor
  176. Qwerky AC
  177. rear brakes
  178. 91 SE Valve ?
  179. Eibach camber kits
  180. quarter panel fitment
  181. new struts and springs
  182. WTB: interior pieces
  183. Auto Climate control Display and TRans??
  184. Anti-Theft light not turning off
  185. How to turn off these lights...?
  186. Yet Another Bose Problem
  187. Maxima with 19s...
  188. a/c display also dim & dash lights gone
  189. So I took some pics.... (56k = links, so no biggy)
  190. Speedometer Problems
  191. What color should I paint my max?
  192. a/c display is very dim
  193. cattman question
  194. How do you pull the engine codes ?
  195. Locked Out
  196. Check Out The Hood!!!!
  197. ported throttle body
  198. Speaker Grille Project
  199. help replacing rear struts
  200. steering wheel
  201. Are VE's supposed to have an IACV gasket?
  202. car over heating
  203. for a prospective buyer, how reliable are these cars?
  204. 91 Maxima clutch change
  205. tranny diagrams
  206. steering knuckle and hub
  207. new parts
  208. Seatbelt warning chime
  209. Keyless Entry
  210. Water pump pulley removal. Help,pls!
  211. MAF adaptor for 93 SE maxima?
  212. VTC / exhaust cam gear swap
  213. PPL W/ Alpine HU
  214. Fuel Pump Problems
  215. Detonation sensor
  216. Engines
  217. Cedar Falls Mini-Meet
  218. Car Problems...Again
  219. Fuel Filter
  220. quick question how to tell tranny with lsd
  221. VG30E with VE pistons Question...
  222. MaxTuning's VB Mod ....NICE !!
  223. suspension question
  224. Broken Speedometer. speeding ticket. how do i fix?
  225. Carbon Fiber door pillars ready to go!
  226. Battery Relocation
  227. Bodykit
  228. Those with BMW lights. Have you been able to take out the lense?
  229. I want my keyless entry! HELP!
  230. 92-94se 145mph gauges in 89se?
  231. KYB strut install problem
  232. Need critques on 3d 3rd gen WIP! !56k!
  233. interior door lights
  234. NEED HELP! Major trunk issues.
  235. Car sputtering when started
  236. Feedback on A Mod to the Rear Trunk Plastic
  237. Window Off the Path
  238. broken shifter???
  239. transmisson fluid
  240. Engine Mount replacement?
  241. coolant leak!!!!
  242. reprograming ECU
  243. HELP! --mainfold problems on a 91SE
  244. cornet light installation problem
  245. Electric superchargers on a ve
  246. Cooling system question
  247. Something slippin...Bogs?
  248. Clutch Tranny Quandries
  249. speed sensor
  250. Where to get reliable rebuilt injectors?
