PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 [109] 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Check out my new Cardomain.com Page... More pics to come of BMW headlight swap etc.
  2. Replacing Engine with factory or replace crankshaft?
  3. Drain plug washer question
  4. Alternator problem?
  5. Rough acceleration in 1st gear. Hopes its not the Tranny!
  6. Brembo Rotors
  7. ST Springs and Koni's
  8. child saftey lock on shifter
  9. Auto to Manual, parts list?
  10. Attack of the Stock Maxima: Comparison pictures of my interior swap!
  11. replacing speakers...
  12. getting rims soon!
  13. To Sony or not to Sony ????????????
  14. vacuum tube on tranny?
  15. Brake light covers?
  16. Maxima 1992
  17. y pipe problem
  18. nitrous yes or no????
  19. Steering wheel still shakes after all this??
  20. BMW lights?
  21. bulbs for step light
  22. A/C blows hot after downshifting from OD
  23. 94 Max GXE Bulbs......
  24. brake failure @ low speed
  25. Automatic window rolldown
  26. Replacing speakers - 94 Maxima
  27. Fsm
  28. I finally have my car back
  29. New KYB strut porblem!
  30. More info on my belts coming off...Please help:-(
  31. both my belts fell off!
  32. ECU reset procedure
  33. audio problem
  34. Air Condition and Heater Isn't Working!!
  35. brakes?
  36. steering pull
  37. Suspension ??'s (Struts)
  38. Wheel Wieght
  39. Wiper Arms
  40. rev idiglo
  41. Problem when accelerating! Plz Help!!
  42. Strut Bar
  43. Best brake system upgrade?
  44. sunroof/power doors
  45. Max scared me bad last night.....
  46. Engine distance
  47. Convert 94 Maxima to DOHC
  48. I need help fast!
  49. suspension
  50. Rubber wing??
  51. Spring/shock question
  52. Check out a newbies Max!
  53. Idling speed problems
  54. 8/6 Update on CF hoods
  55. need pics of lowered please!
  56. PICS my max on polished IS300 rims
  57. Why the Short Life Span on the VE30DE
  58. Gas leak after filling up
  59. OK the CF hoods are arriving but wheres the pics!!!!
  60. Power steering leakage
  61. My Max!!!
  62. rear strut is knockin
  63. Preview of Aluminum 3rd Gen Gauge bezel
  64. bose amps...
  65. Parting out 1993 Maxima SE
  66. Where can i ...
  67. vtc and variable intake related?
  68. MEET in louisville, KY
  69. Clear lenses?
  70. problems with o2 sensor???
  71. strut question..please help immediately!!!!
  72. Interior cleaner...
  73. Injector install problem?
  74. New struts and the ABS bracket.
  75. Mr. Gone's Misfortune
  76. Starter
  77. WSP CAI or JWT Pop Charger...
  78. VE PCV Valve Location --- Designed by Masochist
  79. Timimg belt queastion
  80. FSTB problems..
  81. Ground points on a VE
  82. A\C stuff
  83. Stock shifter
  84. New front struts
  85. Lowering
  86. what to replace when installing new struts?
  87. Body Kit pics and summer reconstruction info
  88. Help..Do it yourself gone bad..again
  89. Fiberboard or Fiberglass for speaker mounts?
  90. ever had this kind of lighting problem?
  91. bmw lights... again
  92. weird problem after installing new right side half shaft 92SE
  93. carbon fiber hood
  94. Air filter intakes?
  95. Spray paint or bulbs for clear corners.......?
  96. hi needs help ...!!!
  97. Thinking about new graphics
  98. Anyone here think....
  99. saying goodbye / In NY
  100. OEM part numbers
  101. working on brakes.. got a question
  102. Jim Wolf Technologies Chip Kit ??
  103. My emergency brake is stuck!!!
  104. CD player wire problem
  105. Power loss and odometer problem
  106. 1990 Maxima SE and 1994 Maxima GXE interior
  107. Pcv Problems
  108. Cruise/Fog/Power mirror switches
  109. trading the max for a BMW?
  110. ok I got a problem, can you help?
  111. Sounds Like Double-Sided Tape Stuck To Tires????
  112. soft top max? nissan option?
  113. e36 + HID
  114. found new site!
  115. Strange sound
  116. Chevron fuel injector cleaner?
  117. What happened to my post???
  118. S/T Lowering Springs Q's
  119. wierd noise
  120. I was thinking Y struts and not shocks?
  121. top ounting 6X9's
  122. Confession
  123. top mounting 6X9's
  124. Any Help W/ A Clutch..??
  125. sold the 3rd gen
  126. 4DSC... only better
  127. More power??
  128. Reminder: Discussions of street races will NOT be tolerated.
  129. i dont know alot will these fit my 1990 & look right?
  130. needing some guidance!!!
  131. HELP! Where is the tranny drain plug!? 94 GXE
  132. Need Help After Accident..Please Look
  133. K&N Factory Oil Job....
  134. AC Horsepower Loss.....
  135. Need some opinionated help
  136. backseat problem
  137. another double clutch question
  138. Car Airfreshner
  139. Question about your thread pattern
  140. Ok to run on Bad VTC Solenoids??
  141. Revs fluctuating as car slows down...
  142. i want me a VE...
  143. can someone figure this one out
  144. Did I get a good deal here?
  145. luggage rack disease problem!!!!
  146. What did they do to this ax!
  147. photoshoped my max
  148. The thickness of new rotors (Brembo)
  149. attn new york city peeps
  150. self diagnostics for automatic transmission
  151. powdercoating
  152. Creaking door sound from engine???
  153. Guys I'm selling the Max
  154. Cone intake related to loss of power?
  155. PCV valve location
  156. Monster Flow vs. K&N
  157. A/C hit the wallet
  158. In need of a GOOD estimate
  159. Power/Comfort switch......
  160. starting probs on '94 GXE
  161. 91 Max vs. 89 Ford Probe?
  162. Exhaust manifold studs bad?
  163. Stealth Max
  164. door locks...
  165. !Help! Guage problem (electrical short)
  166. version 2 angel eyes
  167. Cup Holder fix
  168. Matt93SE - a ??? about your tranny rebuild (I searched!)
  169. Anybody have pics of my turbo?
  170. does anyone have konig tantrums on their 3rd generation
  171. Shocks, springs or coilovers......which ones?
  172. Exhaust leak.....
  173. Canadian Car????
  174. water in tank, I think
  175. Paint Job
  176. attempting first brake job this weekend...
  177. Ball joint loose, LCA bushings need replacing too?
  178. Need Transmission Rebuilt -What to expect
  179. hit light post (pics)
  180. GREEN 194/168 LED BULBS for dash????
  181. corners?
  182. R33 Tail Lights
  183. Peal&Seal + Maxima = Lexus/Tank
  184. how do you get shift knob off?
  185. warp speed service
  186. timing belt question
  187. Strong gas smell when hot
  188. Headlight Advice
  189. seat belt ringing
  190. Hi Everybody
  191. Parts Store
  192. uneven ride/drive
  193. fiber images
  194. Speed Sensor?
  195. How do I change power steering pressure hose?
  196. A/C Leaking question and odometer question
  197. New Member
  198. Place to get a new tranny and at what price?
  199. Front Left ABS Sensor..$$$$
  200. restoring rims
  201. BMW Headlights
  202. Radio Help
  203. Need help with transmission problem...
  204. Question on "base timing"
  205. Can cleaning your engine add horsepower? :)
  206. CEll phone holder
  207. Whoops! Need some easy help.
  208. Information about body kits.....?
  209. Lowering my Max.....?
  210. Buying kyb-gr2's any known deals going around??
  211. Help ME!!
  212. Burning a lot of gas
  213. Hello from New Zealand
  214. I finally drove my max after a month since buying it
  215. rebuild difficulty
  216. Mass Air Flow Sensor
  217. some 3rd gen parts for sale corners, bumpers, rims
  218. Power locks don't work
  219. intrax
  220. Fog Lights
  221. Best thing to do to VTC
  222. 02 Altima wheels on MAX, anyone have pics?
  223. engine problem
  224. Major Power Steering Fluid leak...
  225. Good Lord, I'm a moron!
  226. o2 sensor
  227. Search NOT working, door lock timer repair
  228. maxima basically done
  229. Brake help
  230. RE: VTC's, Happiest Man Alive!!!!
  231. Fogging Windshield
  232. i have dirt cheap winter rims for sale
  233. Error Code Trouble
  234. Check out this 3rd Gen
  235. wsp cai?
  236. Transmission dreams of mine...
  237. VG30DE compression/internals?
  238. What did the 91se retail for when new???
  239. Metal in horn
  240. Problem with heater/ac control unit???
  241. question
  242. Exhaust leaks
  243. Want to add dimming/fading interior light feature in my 4th gen....
  244. Its a Sad Sad day...........no more 3rd Gen
  245. My freind suprised me when he chirped 3rd with his VG!
  246. Ebay Maxima
  247. Trouble
  248. Bose CD player for 89 Max.?
  249. Sunroof shade: which groove do clips ride?
  250. 91 Maxima
