- My dedication to 3rd gens
- Random stalling
- quick q
- Anyone sold or bought a SE auto lately?
- What to look for?
- Fog Lights dont work
- what a difference a day makes
- Seatbelt Warranty
- Creame Colored Maxima Owners
- Project OCD Engine bay.
- self destructing brake light
- Auto seat belt not working
- Where's the airbag control module?
- Good bye crankshaft.
- Help with remote start
- random battery / abs light blinking
- Still have exhaust leak.
- taillight assembly... disassembly
- Fuseable Links
- AC/Heater Floor setting acting weird
- Rear MAXIMA centerpiece LED (pics)
- Weight Reduction for All GXE Owners
- Allen head size on intake plenum
- What needs to be removed to drop a tranny?
- Best way to clean around spark plugs
- phantom highbeam
- Freakin bearins are goin bad AGAIN
- My Fresh VE Swap (ALOT of Pics)
- Replacing Vacuum Hoses
- No fuel smell but it was leaking
- Some problems while trying to replace my ball joint
- abs
- Stumbling, injector problem?
- Maxi for sale
- Anyone want to rebuild my vtc's?
- VE question
- Clutch removal day
- MAX won't start
- Car makes a pop sometimes during acceleration..
- How do you bench bleed a master cylinder?
- grounded my VTC's......
- Alarm, Remote start install
- Pics of the new max 56k beware.
- 90 Max runs great when cold but rough once warmed up
- Vg INTAKES
- Battery relocation
- Oil Leak
- Ticking sound when i turn on the heater
- cheap superchargerd
- Weird clanking noise under hood
- did I get ripped off?
- Ebay suspension question
- grounding wire ques?
- Knock knock..
- 300zx exhaust manifold???
- question about front end shaking......
- L.E.D Install
- NEW MODS
- Proportional (brake) valve rusted?
- Both CV Boots torn - help
- help-remove the crankshaft pulley on 89 maxima
- Valve cover moddys
- Idle Bad when cold, Improves with warmup..
- Antenna Mast Replacement Videos. No more Asking!!
- Heater experts, drop some knowledge
- Windshield Wiper Linkage Q!
- Seat Belt warning chime and light
- Chime
- Which Battery
- 1990 Maxima SE running inconsistently
- VG tbelt sprockets
- Guess My New Mods..
- It's Official: Maxima is Parked for Winter
- Which wire is the power antenna trigger?
- Front Brake Pads need replacing
- new lca's
- Where can I get a metal maf adapter?
- Shifting notchy when engine on, but smooth when off?
- Fuel Injector additive
- Replacing struts (need advice)
- 93 Maxima GXE Fuel injectors
- Whats needed for 5-speed Swap?
- new alty and battery, but still fading lights??
- 3rd gen automatic Maxima does 12s in the 1/4 mile!
- YAY!..I'm keeping Blackmax :-)
- Just did rear disc swap on le GXE BUT....
- 92 SE isssues please help
- Fuel Pressure Regulator
- Warning to all 3rd gens out there!
- Broken/Dead Max, electrical?
- repair the door lock actuator
- Anyone knows ECU?
- cheapest place to buy crossed drilled rotors
- 94 Max GXE on the Blink - SOHC Auto
- Disconnecting torque converter
- Leaking brake line
- Went to the dyno today
- rear strut "clunks"
- 5k into my max, worth it?
- Turbo Charger for a '90 Maxima SE
- I'm Snow Upset
- How many/what kind of bulbs behing dash cluster?
- 300zx brakes size
- many oppurtunities need you guys to chime in
- Low Compression
- Few Questions?
- I know there's an audio forum, and I hate posting another speaker thread.....but.....
- Just wondering......
- Rear valve cover gasket
- Brake question
- "P" light comes on at start up...
- SOHC vs. DOHC
- Bad suspension bushing
- timing question.
- Removing the VG
- Got Me Some Fogz
- Synthetic MT fluid in the VE?
- Installed LEDs today...
- Installing an AMP in a 1993
- Odd Shift Interlock Prob
- Big break for the Max
- Gas tank
- Rusty
- Removing VG transmission
- Suspension
- Distributor Problem
- Fixing manifold studs...
- Driving a max with a bad injector
- Driver side halfshaft
- Bose Issues
- Tranny - Engine Mating Question
- My BOSE died!
- 4th gen injectors in a 3rd gen?
- Uh Oh! Another VTC thread!
- clock problem...again
- At last the tranny, clutch, and flywheel are off!!11!!!1
- extreme humidity causing FOUL smell
- Car stalling, please help with diagnosis
- Replacing steering wheel
- Weeping oil
- Brake calipers
- Axle Rusted stuck
- hood lift supports - where to buy
- 92 Manual trans locked up?
- Max Won't Start, Error Code 33
- ATLANTA MEET 2MORO!
- just picked up a 91 se
- NEED HELP with my MCC (manual climate control) PLZ HELP
- Computer boxes
- EZ out size for Manifold Studs
- Hey guys..need your support!
- clutch issues
- Tranny cooler received
- How To remove/rewire bose for aftermarket
- HD Radio
- Another Maxima!
- Best way to prep for sale
- O2 sensor question
- posted in the audio forums already but.....
- Two whole months of Maxima ownership!
- NEW EXHAUST VID!!! 2.5" all the way...
- I'm stupid and poor and need help.
- what do you think?
- (Code 33) But Not O2 Sensor?
- car starts, car doesn't start, and repeat...
- Another unidentified hose
- HID
- If Cars Could Talk, Do You Think Mine Would Thank Me?
- drivebelt replacement help
- Shock Sensor Add on..
- Pigtail connectors.
- Thinkin about sellin the VG...
- collection terminals
- Remote Starter Options
- Window and Climate Control problems.
- Heat...
- Max shaking and stalling
- mystery terminal
- Coolant Temperature Sensor
- questioning the y-pipe
- VG compression ratio
- Deatschwerks Injectors.
- More VE goodies!!!11!!!!1
- Aftermarket fog lights hook up!!
- Help with rough running / codes 21 33
- Bumped into an old friend at the junkyard
- repair the bose system on 89 maxima, bypass the amps
- New Nitrous goodies for teh VE!
- Who ended up with my VE??
- Wheel Stud Question
- valve train
- major major issues
- The max broke down today
- Cars Jacking point Bent?
- Need Head!!!
- Repair progress
- Replacement bulb type?
- Fluttering sound coming from engine - video
- Just did the LED swap
- VG30DETT swap
- Do the 91's come with cup holders?
- would this cause weird steering?
- High Speed Traveling
- I love to get high on raw gas fumes in my cabin. Anyone else?
- My first trip to a drag strip (video)
- Maxima Is Mine
- Short Shifter?
- What could this be?
- No one cares but I'm back
- How many 3rd gens is yours made of?
- changing battery
- exam this morning missed because car wouldn't start
- Corner/Turning Lamps
- Some electronics questions....stereo, alarm, lights, 5speed swap.
- righthand camshaft seal?
- 3rd/4th gen flywheel the same?
- ECM Trouble Codes
- cold start??
- catalytic converter ?
- working on shift_fast again today... half of it almost worked
- OoOooOOo!!... a pic thread!!!1! :-)
- Blinking Air Bag Light
- Exhaust Question
- HG repair attempt! - need advice!
- Dash Bulbs
- Blinking cruise light?
- WarpSpeed Y Pipe
- starter failure
- Heated Seats
- Instant power cut-off - and the fix
- Bleeding coolant
- 99 altenator bolt on to 92 VE?
- New Headlights
- WTF? v. broken ss brake lines?
- Engine stand bolts
- What's This Connector For?
- 2 Sexy Maximas
- Car Missing Slightly
- Headlight problem
- i'M aLL wIrEd uP!!11!!!!1!!
- OMG
- bought a twin cam motor and tranny
- Is this a tranny problem?
- Warning about the poly control arm bushings...
- 90 se having mild seizures
- small issue with headlights and interior lights...
- Glowing Gauges
- need input (no pun intended)
- Big(ger) Brake Swap
- [holy] sliding control arms [batman]
