PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Axle question
  2. Any VG owners running Nistune?
  3. E85 experiences
  4. Dash vent replacement?
  5. D2 RS Series Coilovers - Info on a Groupbuy deal - checking for intrest
  6. How Do Mechanics Pinpoint The Exact Source of an Exhaust Leak?
  7. Negative pulse door locks?
  8. led dash light help
  9. Took Some Pics Today!! 93 GXE SELLING SOON !!!!
  10. Difference between the VE30s?
  11. Taillights always on, why?
  12. Front Door Adjustment?
  13. What other make has your car been mistaken for?
  14. Power Locks
  15. brake line woes
  16. Grounds For Engine and Chasis
  17. What OEM 18" wheels are direct bolt on's for my '92 GXE?
  18. Moving to Texas
  19. Wiper fluid leak
  20. OMG Power Steering Going Again
  21. Where Can You Find A 3rd Gen. Maxima...
  22. My 92 GXE
  23. Center Console Armrest Lid
  24. When doing 5speed swap, has anyone swapped ECU's too?
  25. Lowering kit with springs/shocks, best price?
  26. My quirky VE :007:
  27. backfiring through exhaust
  28. I'm off to see the wizard: Goon
  29. Cold Air Intake
  30. 92 5sp VE Tranny
  31. Clutch choices
  32. Smell gas fumes when starting my car please help
  33. Testing injector o-rings
  34. Is it worth putting $1000+ into a $1500 car?
  35. VTC TEMPORARY FIX, PLUS QUICK QUESTIONS....
  36. Need help replacing Power Steering rack
  37. my dad just sold his 3rd gen
  38. Tokico Struts
  39. clear timing belt cover
  40. anyone ever removed the valve body?
  41. heater valve by firewall???
  42. Stillen aero kit
  43. Engine swap problems
  44. Conversion project? Open minded only
  45. Clutch Trouble
  46. Throttle Position Sensor ( TPS )
  47. Can someone decipher a part #?
  48. CMPS trouble
  49. New Bumpers Finally Painted and Installed
  50. Any tranny options for the VG Auto?
  51. Another 3rd gen bites the bullet
  52. Woodpecker behind glovebox
  53. Thinking about an Ebay intake??
  54. fall tune up !!
  55. accident= Sporting 17"s now
  56. Going out of my mind
  57. would i get pulled for these bulbs?
  58. Draining fuel
  59. WHAT DO U GUYS THINK OF THIS ???
  60. Jerking at 2000 RPM
  61. E36 headlight conversion bracket
  62. Quick ? about foglights
  63. Replacing hydraulic lifter on a VE
  64. Cleaning MAF sensor with CRC
  65. Hub is loose..
  66. Are the CAT-->Muffler Flanges Supposed to Bend When Torquing Them?
  67. MaximaLess Will remain Maximaless
  68. Any led tail'ed 3rd gens?
  69. what did you pay for 2.5"/3" exhaust?
  70. Fans are Keep Running..
  71. Tirerack
  72. I want an S2K antenna....
  73. increase your gas mileage
  74. the 89SE Superwhite lives
  75. Same Coolant Temp Sensor?
  76. High NOx Reading Fails Emissions Test - Max Running Lean?
  77. Goodies For Sale!
  78. Sonar Suspension replacment?
  79. new pics!
  80. Coolant Leak?
  81. Cruise control doesn't work?!?
  82. keyless entry question
  83. Swap 92 standard audio with Bose from 93
  84. Easy Bulb Finder
  85. Saw these, thought someone might want them
  86. VG30E Almost Complete!!!
  87. 4th gen front seats??
  88. Lowering Maxima
  89. nissan maxima intake adapter question!
  90. I miss my 3rd gen
  91. 89 to 94?
  92. trunk question
  93. Clutch problem help
  94. Seller's remorse
  95. Greddy Evo II exhaust
  96. Digital Speedo Meter Problems
  97. Starting/idle/sputtering problem
  98. Window visors
  99. q about blue relay on strut tower
  100. The 12 sec VE Auto dies
  101. Oil question
  102. Jittery Ignition Timing, already replaced many parts
  103. your suspension set ups
  104. JDM Engine Depot
  105. Parts source recommendation
  106. Thinking about looking at this
  107. 1991 - 5 MOD system GXE
  108. VG 3rd gen owners - get more power!
  109. Strange Drivetrain Sounds
  110. steering wheel click
  111. Ignition question
  112. Fuel pump and ECU Fans issues tied all together....
  113. HELP! Pop quiz: What gets wet on the passenger side causing a miss?
  114. Flex pipe
  115. Questions about 92 SE
  116. Aftermarket E-Brake Handle?
  117. What's the easiest way to rotate the ring gear (flywheel) by hand?
  118. Power Issues
  119. 3rd gen laptop tune/consult fabrication complete (video teaser)
  120. Reset digital touch entry ( GXE ONLY )
  121. Gas door doesnt open
  122. VG30E to VE30DE injector swap
  123. Max Goes Up in Smoke - Very Scary
  124. Ignition amplifiers
  125. She's back to life Thanks to the org & brakes question
  126. Fuel Injector replacement
  127. Which is more difficult? Rear seal or timingbelt.
  128. ECCS Relay question?
  129. Looking to rebuild my VE.
  130. brake pad springs
  131. Heres my maxima
  132. how...Tail Light
  133. Cam Position Sensor
  134. strange popping
  135. Project MaximaZ
  136. this is weird
  137. High Octane Fuel?
  138. Finally Selling the Max
  139. instrument panel removal
  140. VE restoration thread
  141. Bose speaker problem
  142. Has Anyone Been Able to Source the LH (Front) Exhaust Manifold New?
  143. k sport coilovers
  144. Transmission not engaging...
  145. time is getting near for my 3rd gen.
  146. rebuilding transmission
  147. Nissan Sport magazine!
  148. Missing Splash Shield by Crank? (Pictures!)
  149. Clutch Pedal Wont Rise After Pressing Down
  150. Loud humming after turn off
  151. spring questions
  152. Installed my 300ZX 88NA Wheels
  153. Public notice, goon9's parts for sale.(Temporary Sticky)
  154. Sounds of Water
  155. Wheel Alignment
  156. Torque Value Adjustments for Anti-Seize Lubricated Fasteners
  157. ash tray light
  158. Black 18" Kobe find
  159. Resistance of the Heated Mirrors?
  160. Cai spacer
  161. Fuel pump don't kick on. ECU Ground bad?
  162. Tommorow Need to Tow The Max But Remove Rear Stabilizer Bar - Safe to Tow?
  163. Fuel Injector - Buy from Nissan or Aftermarket?
  164. Critique my noise reduction idea
  165. Nissan Maxima Fuel Injector Change Tutorial
  166. Transmission not shifting!!!
  167. Do you still floor your 14-19yr old car?
  168. Check Engine Light
  169. Fuel Injectors Purchasing
  170. Leather Seats?
  171. What Should I Replace Next Guys? SEE LIST
  172. Worth $500?
  173. catalytic converter
  174. Rewiring AUDIO system
  175. HELP fuel Injectors
  176. ve exhaust sprockets on the intake side?
  177. Wheel opinions?
  178. sputtering
  179. For those familiar with 3rd gen 3.5 swaps....
  180. 3rd gen headlights from Ebay
  181. Strut time, again
  182. 91 GXE won't start
  183. Rear Calipers - When Do You Replace?
  184. Can i have Digital Speedo meter swap?
  185. Swowlinc is back!
  186. Speedo sender
  187. Need help with Frame question
  188. vg ve trannies
  189. question for exhaust
  190. VG UDP w/ only 2 rows?
  191. where can I get this suspension part?
  192. family or sports sedan?
  193. Approx 35 miles w/ gas light on????
  194. Removing rear brake assembly 94 GXE
  195. Need Help
  196. couple ?'s
  197. Electrical Woes HELP!!!!!!!
  198. Bosal 099-549 Catalytic Converter - Need your help guys
  199. Yay! VE power is back!
  200. engine or transmission issue
  201. Need Bushings
  202. Car won't start
  203. Heater core replacement
  204. Write Up For Digital Climate Control Self Diagnose.
  205. Just claybared my Max.
  206. Right rear brake
  207. Pleased to announce.
  208. How brakes fails?
  209. Suspicious wire...
  210. Got The 1993 SE, Now To Fix Things
  211. I was driving and...
  212. Engine Lifespan
  213. 94 maxima fuel injector
  214. How much brake fluid do I need?
  215. EGR Question
  216. Windows will not roll up??
  217. Aftermath of running Prestone Super Cleaner...
  218. E36 Headlight Write-Up
  219. another headlight upgrade option?♦♠
  220. Bose question, weird problem, diagnosis?
  221. 6 cly to 4 cly
  222. Write Up?
  223. ohNoes! Sunroof Problem.
  224. No start (Weird...)
  225. Axle Problem
  226. RIMS
  227. Colder A/C ...Maybe?
  228. Car And Driver August 1992 - Tripple Showdown - Four Door Throwdown
  229. spoiler options and suggestions please
  230. Intake Plenum leak.
  231. Electrical: where do all the power windows send their signal to?
  232. 3rd gen in movies?
  233. Erratic Idle & smoke = electrical problem?
  234. RE-SOLDERING A NEW OXYGEN SENSOR
  235. Time to say goodbye to the 93 maxima?
  236. What cures a hard shift from 1st to 2nd
  237. who the hell are all you people?
  238. 91 Max at 55mph and beyond
  239. SELL MY 92 GXE AND GET A 93 SE??????
  240. Moving The Rear Stabilizer Bar Out of Way To Install Muffler & Safety Issue
  241. MAF
  242. Electrical woes
  243. VE Water pump replacement questions
  244. motor swap???
  245. OBD1?
  246. Shorted system..forgot to disconnect battery while changing alternator..
  247. Crankshaft Position Sensor and TPS
  248. suspension and brake work HOPEFULLY this weekend
  249. VG30e head mods
  250. dead temp gauge?
