- Replacing my injectors
- Injector question
- Time to move on...
- Max won't start
- Dang, it is messed up
- CAI Question
- Injector Swap
- Choppy Idle
- Inspired by 2000 I30 commercial, add your B&W's!
- Z31 Rear Brake Conversion/Upgrade Write up
- Big Brake Question
- Intake plenum gasket
- How Is The Rear Spoiler Held On?
- no A/C!
- missfire ve issure found so....
- Has anyone un-automated their seatbelts?
- Automatic seat belt clip + wheel problems
- Towing Capacity
- mold (or mould) on leather seats
- Stockpile parts?
- i belive my alternator going.....
- WOOOHHOOO! Gots My New Injectors Today.
- Pintle cap
- replace rear window?
- I suck at the brake bleeding
- Epoxy/Adhesive for V6 3000 Logo?
- Whats your max weigh?
- corroded injector terminals.
- Broken Screw!?
- where can i find foglights?
- Winter Sound Mod
- Heated Mirrors
- Interchange parts?
- Electronic climate control lights?
- The Engine/Tranny swap Finished!
- power mirror failure
- Radio Harness Mess
- Disconnecting injector/spark plug
- Need help buying VE injectors..
- rough idle injectors????
- Some WIP Pics
- Going Forward - ONLY
- Just thought i say good bye
- Is this worn springs?
- Quick pics during winter storm
- Capedcadavers tranny swap blog..;-)
- So what is the best spark plug?
- WIRE HARNESS PROBLEM
- Will an auto ecu work in 5spd
- Intake plenum and cooling fluid
- Wiring Issues
- 94 SE CHECK ENGINE LIGHT ON/OFF
- Need a favor; need a pic in the engine bay
- Rear bearings
- What the heck does this gotto?
- Rust pics?
- VE SSSIM
- Intake manifold/injectors questions
- 3rd Gen. Favorite Mods Thread.
- After a long hibernation and the max has awaken
- wrong VTC wire
- DOHC/SOHC injector difference
- E-brake cables
- No global warming here...
- iTrader feedback
- Umm...Foamy Gear Oil?
- Brake Master Cyinder Question
- The official VE love thread.:007:
- Not having this belt (see thread)
- Battery light comes on - Alternator?
- 93 94 trans bolt patterns
- car problem
- Need help with seats!
- 94 SE VE30DE 5-SPEED
- MAXIMA NOT IN GEAR
- Anti-Theift no start
- Spoiler repairs
- rims?
- Factory Head Unit
- Alternative to SE center tail...
- Engine models that may fit the SE
- anyone need some PARTS??? its finally here
- Door locks quit!
- Maxima (J30)1989-1994 Parts list with #s
- True 3rd Gen Clear Corner - write up w/pics
- Inner/Outer Tierod Replacement (Writeup)
- Alternate Fuel
- 5th Gauge Cluster Light?
- koyo radiator
- Tokico blues + Eibach springs
- I updated my cardomain
- bleeding the coolant sys instructions
- 3rd gen ve 5spd for $200 worth it
- Correct Part?
- Getting alarm/remote start but first!!!.......
- rs50a tranny wont stuck in 1st or 2nd but shifter is in neutral???
- melted plug... wtf
- Digital Dash and HU on a VE?
- Motostorm Products
- Different throttle body on stock intake?
- Fuel injector resistance reading
- VE Valvetrain: Diagnosis help please
- big brake kit (un) install one problem
- Need advise on new struts for my 94 GXE
- 3rd Gen Driving Pics (lots of 'em)
- whats this max worth?
- Digital Dash Problems
- dohc Steering Rack
- deatschwerks phase 2 injectors
- SE owners, thoughts on window trim?
- Show your heritage
- New dilemma
- location of the wind shield wiper relay on 94 maxima gxe
- Car won't start (Clicking!!)
- Both Rear struts and springs are maybe done...
- The swap is complete but I need some ideas....
- New Fuel injectors ... Car will not start. Please Help.
- non airbag wiring to airbag wiring
- Lowered: intrax/tockico
- If you love your VG POST A PIC HERE!
- mmm...STATS!!!
- Wierd starter/battery problems.
- Axle picture request
- Update on cardomain. Pics of turbo build.
- Alarm System Issues...
- What do you think about this Big Job
- I passed!
- What is the Best Method For Polishing and maintaining Aluminum?
- Buy complete strut spring pkg?
- Crunching sound when slowing down with transmission
- '93 gxe sohc used injector availability
- Distributor not staying in time?
- Your most replaced part/s v. long time 3rd gen owners..:o
- PCM Interchangability
- Original Bulb???
- Hinge goo
- New Suspension
- CLUTCH
- Need your help identifying some engine bay parts
- Fuel problem / Fuse problem
- Rpm signal wire on Ecu?
- Who Here Has Taken A Front Seat Apart?
- Replacing Window Regulators
- OEM GXE Fog Light Wiring (who the heck has 56K these days?)
- Koni Strut Adjustment
- Rear strut replacement - 93 GXE
- Trunk leaking
- Well That didnt work!
- 92 VG Injectors: Difference between black body and blue
- VG30 Knock Sensor: Who is the OEM?
- Automatic maxima won't shift from park
- Yes! The VG Auto to VE5 swap is DONE.
- 3rd Gen Maxima Chase Scene
- Need high resolution VE engine bay pics and/or wiring and hosing diagram
- Strange symptoms, engine light on?
- LSD for VG?
- Coolant system will not stay bled!
- Is there a step by step to getting the heater working?
- third gen carbon fiber hoods
- Anyone put HID's in these headlights
- car wont start
- Happy New Year 3rd genners!!!
- Ebay SS clutch line, Legit?
- pcv valve?
- motor mount from hell
- Automatic trans preventative maintinance.
- Putting together a Maxima Calender!
- Remanufactured SE 5spd trannies
- for anyone with lethargic steering response...
- Nissan quality, still strong
- tail light fuse blows?? help
- Bump shifter
- Because 1280x1040px Isn't enough sometimes
- What really happened to dmontzsta's max
- Interior Swap
- loose strut nut
- Locked up 5 speed tranny
- need new springs for shifter
- Stillen Ground Effects Attachment to Bumper
- Question about a nut.
- fan blows, but no heat
- I crashed my car; sell or part out?
- engine barely start after new injectors replaced
- In Dash GPS where clock went
- Happy Merry Holimasikahs?
- metal top radiator, with holes from the factory?
- High performa exhuast sys.
- trans. oil change 94 SE
- new fuel injectors
- Bumper cover, OEM or cheapo?
- Need some help...
- Need Help - Can't remove driver's side CV halfshaft
- Learning how to solve my own problems?
- VE vtc's/vq35 vtc discussion..
- New Pretty Pictures And Videos of your Max Thread!
- I'm about to give up out of frustration
- ford 302 into 3rd gen
- Hungry Oil pan
- heater motor won't stop blowing in acc/on position
- Oh no it's cold and my car won't start.
- Floormats
- Maxima would not start
- Thumping sound when engine is cold
- Quick question
- Attn Chicagoland 3rd Gen Owners!
- Better TB coolant bypass method.
- Testing Injector resistance
- Clean your Throttle body!
- So you think you had rust problems...
- Bose Radio ???
- Steering issues..
- An interesting trip to work (electrical woes)
- GXE pulls to the right on acceleration
- Engine Problem or Tranny?
- Transmission failing...thinking about parting out the Max
- Hey, Cliff!
- I will be doing the whole exhaust system
- ECT Nissan VG OEM part numbers?
- power problem once again
- Need Help with 1994 SOHC
- Third gen is Decembers MOTM!!!
- FYI --> Blinking Air Bag light
- 5-Speed Swap Here I come
- Happy Bday MyGreenMax94 ** 56k Go get a bowl of cereal**
- My New Forum for balla mechanics!! :007:
- Idle fluctuation when brake applied
- *NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
- Front Bump Stops
- Busy weekend. (mods/repairs)
- Different Cranks in VG?
- saw on ebay wat yall think.......
- looking for thoughts on this problem
- Car stalling - Any ideas?
- just picked up a 90 se
- Has anyone tried?
- Soft top of doom...
- R.I.P 89' Max :'(
- Yes finally fixed!!
- quick VIN question
- 3rd Generation Forum Guidelines (Please Read Before Posting!)
- Alternator diode pack(where to purchase?)
- want anthor car dont know what to get
- I dont think this is good =\
- Brake Question
- nOOb question!!1!!
- Radiator
- What's the 4DSC?
- Some pictures of Max and CG2s max in the snow
- I screwed up, front tire bent....
- another exhaust problem
