- chrome 2000/01 muffler tips
- Ordered my Pacesetter STS today
- Skyline Taillights
- Electric supercharger ? Scam or not?
- more questions!
- Heavy tech stuff. I'm stuck and don't know where to go!!
- Time Guestimates
- Is it safe for a 2 in drop
- Air Bag Light Flashing...
- Need help on Door Lock timer!
- Fluid swishing sound thru Eng at Idle
- How, um... Aggressively do you drive your 3rd Gen? Curious for comparisons
- kind of strange: battery/alternator
- Rear 6x9 speaker brackets needed
- Call me lazy...Throttle Body Question!
- what's with the seat?
- Question about Air/fuel gauge install...
- De- Chrome
- dash calibration
- ? on clutch
- anyone know
- My new exhaust set-up is on and pics in my homepage
- Rear Middle Piece
- Side marker lights
- ABS Pump
- Warning Lights are on for no reason??
- Climate Control not working AT ALL
- Front Speaker Size
- How you take out the rear seat???
- ECU Question
- Replacing rear exhaust manifold studs....How hard??
- VTC's have healed thyselves !!
- manifold studs snapped
- fixed the window problem
- Tire Question
- For all you sluggish VE guys....
- %'s of 89-91 SE 5spds compared to the rest of the Maxs in the same year ?
- SE tailights diff from GXE ???
- Jim Wolf Cams
- GXE tranny
- Fluid high? or low?
- finally tried the wheels on
- Trying to bring Maxima back to life. Let me know if I am missing anything.
- Engine specs on 3rd gens and 93 R32 Skylines....
- maxima hestitating, what do y'all think?
- Words of wisdom: Engine install
- VE engine problems...please help!
- Minor things can really make a difference....
- windshield washer bottle?
- Heat Soak
- New Oxygen sensor sets off Check Engine light?
- Seems that 3rd gen is still the best!
- Seatbelt really ****ing me off...
- would 95-98 240Sx rims look good on a 3rd gen ?
- VE vs. VG UDPs
- acceleration problems
- Dyno Comparison for a 3rd Gen VE30DE
- Why a VE knock sensor goes bad
- "roadkill"
- need info on diff models
- Removing door bumpers?
- 93 se 5spd questions
- body work update
- baffles me
- Another accident!!
- Overheating without overheating
- anyone like to inhale gas???
- I think my VE is dying...
- VE 5-spd different from VG 5-spd?
- Was the tranny improved from the 91 to 92 GXE ?
- Is there any good aligment shop in NJ?
- stillen wing
- A little hesitation starting the car.
- 3rd gen steering wheels
- Oyxgen sensor wiring question
- Master Cylinder help?
- Trunk rattling
- Bodykit and Resonator....
- Whats a good PIAA fog for the Maxima??
- Computer Question?
- metal intake filters
- Pics of Max O/Ds CF hood, fuel pump install and turbo compressor..
- ANYONE WHO KNOWS ABOUT 3rd gen BOSE stuff
- Anyone has a write-up on rebuilding rear calipers
- How to reach old thermostat?
- Need $6000 now!
- magnaflow vs flowmaster vs dynomax which is best
- Brake Pads/Dust
- wheel opinions...(bored)
- Rotten Eggs
- Anyone need a carfax report?
- Bose System HELP !!
- just got new tires., now i need springs. I smoke crack everyday!
- Ve lifter problem. Roseken/Eric93 or anyone->
- Wont start
- Apexi N1 black?? should or not?
- Value?? Is it worth fixing?
- I am very confused about a 91 GXE
- Quick Warpspeed Performance question.....
- '94 maxima stalls at higway speed ??
- Busted exhaust stud
- Fresh pictures of BLUE TO THE MAX day pictures are here !!
- **Which Maxima To Buy**
- Bodykit Fitting
- New Pics rims, hud/dash, car show
- Bad night, 15.32@89.76mph
- Frustration abounds in my garage...
- Installing a 95+ Nissan stereo or CD changer into your 3rd gen
- Magnesium rocker covers - Australia only for the moment
- Fuel filler tube recall
- How do I install my fire extinguisher to the A-Pillar
- Where do I mod next
- Syncro problem?
- transmission problems? please help.
- Nissan Catalytic Converter $50 Billion Dollars
- Indiglo Gauge question (they're already installed and working ;))
- 1993 Maxima with enacurate speedometer
- fuel pump
- Best tire size for 17" rims?
- What is the best way to remove a GOOD exhaust manifold stud?
- tinted windows/ inspection
- What's the speaker sizes for the 3rd Gens (non-bose)?
- Help uncloggin sunroof drain hoses
- Has anybody used the weaponR ram air intake?
- Piccies of my maxima
- whats the best suspension?
- broke a spring!
- PIAA Fog Light Models???
- Why does everyone hate the VG ?
- my moaning max
- 1991 SE Max ???
- Heat Shield Y Pipe Rattle
- Please Help??????
- Whats the first suspension upgrade????
- James..urgent read..
- need help w/92 Bose system
- Need help with my sister's 91 GXE
- Anything else to use for custom CAI tubing then flex pipe?
- what to do with pictures?
- Engine running rough
- winter
- big max needs an engine
- Power loss from exhaust leaks?
- Anyone tried that B&M trick shift trans fluid?
- Touchup Paint that Matches Factory:Where to Get
- 92 Maxima SE Running Like a TOP!! FINALLY
- tranny question..........?
- UR pulley installation estimate
- Loose Hose On Back Of Motor???
- Replacing Window Regulator
- Bose Relay question
- carsound cat
- smells like clutch burning WTF!??
- cam gears
- steering wheel problem
- I need power seats
- Please confirm parts needed (broken exhuast stud)
- Custom cat back?
- Customized cold air intake
- Is there a known problem with 3d gen fuel pumps?
- I think its a 93
- will 19's fit?
- auot tranny vacuum hose
- Clutch pedel questions??...Kinda URGENT
- That odd cylinder in the back of the rear arm rest.
- Plastic Engine Guards
- after seeing this i feel stupid...
- Tires for 16in wheels
- 2-3 cutloose 89 maxima
- Miles on a Maxima
- Lowering Springs
- Head Unit wiring cut...
- Planning to get stock Skyline R33 wheels
- Update on my Max accident.
- I Got A Big Problem And Need Help Fast!!!
- Parts!
- replacing disc brakes with ABS
- BMW headlights
- My car starts up strangly, and BMW lights
- '89 SE nightmare: intermediate stalling at any given time
- MAXIMA rear emblem question
- Turbo on 3rd gen
- 3rd gen, so many questions on my mind !
- Pics of my LCD / GPS / MP3 setup
- Lots of new pics...
- how many quarts of ATF
- wheels
- My newest "Mod"
- Is it possible to use a different model knock sensor?
- 17" 350z rims
- Daytime running lights problem
- Startup story ... Happy Ending
- ARGG....Dyno results inside>>>
- ypipe or manifold studs?
- Heater question
- ? on Sparkplugs
- It's all James' fault
- Macco paintjob.....
- real wheel bearings
- Genie Turbo 3 inch Stainless steel muffler for maxima
- need measurement
- general 3rd GEN questions
- where to buy ve30de??
- Engine management systems
- 3rd gen sighting in a magazine
- Removed my A/C compressor belt....Now no heater or a/c working!! HELP!
- Is this car worth buying ....
- 92 Maxima SE think I have problem Solved
- *** Anyone removed their tailights here? ***
- Apexi World Sport Exhaust ?
- Reset ECU after advancing timing?
- VG auto ran a 14.588 Record????
- Pathfinder intake
- Should I remove the exhaust manifolds?
- Open My Hood!
- Wheel ?
- tire pressure (2)
- Hissing/Rattling noise
- fuel leaking out guestion,
- Pezking4
- A questoin for someone who knows
- Moderator type question
- replacing bulbs on rear
- I Really Need Help From An Experienced Member
- raxles.com quoted me
- ypipe question
- Any one know how to disable the ABS?
- nokya purple
- pic
- Fuel Tank
- 1992 Maxima SE dumping fuel
- First Time under the hood
- Engine sounds supercharged, wish it really was.
- Is it a good idea to have my fuel injectors flushed?
- Just bought a 91 SE
- AAAAAHHHHHH *mixture of cry/ yell*
- kyb agx
- digital dash
- 17" Tires Sizes
- motor swap
- rough idle
- racing...
- TIe rods or tie rod ends?
- The Mystery Spoiler: Identification
- How do you smoke your tires really well?
- DNAS420 back on the org??
- HELP!!! --- Chilton's CD Manual
- o2 Sensor replacement
- budget ypipe
- Altenator
