- fog light ques
- 3rd gen floormats? Does anyone sell them new?
- This car is hot
- New maxima owner, with light problem
- Couple O2 Questions
- My 94 Maxima is sluggish and shaking at 45 MPH and 1500 RPM
- Intake for a '90
- "tune up" Am I missing anything??
- Learned the hard way
- bleeded air still no heats
- What to do?
- window wont go up
- exhaust flex section
- lost power door locks after disconnecting 3rd brake light?
- help with trunk lid
- '04 engine/tranny..what will it take?
- tach signal wire ve
- simple temperature gauge prob
- it's my bday, any ideas for car
- Radio Question
- Which spark plugs to get?
- Parting out 93' max
- Rust
- Custom "leather" for 3d Gen - home-made ;)
- Potential VE Purchase - Please Help
- Flare in Automatic trans
- New Intake
- VTC parts?
- Size of Axle Locknut
- Anyone had luck with FSTBs from eBay?
- Wiki for 3rd (all) Maxima repair/maintenance/tune/upgrade?
- Let's talk about lights.
- car sounds like a lawnmore
- Tail light question.
- Door Seals?
- Opinions on Brake Lines
- What are your car plans for the summer
- front door speaker mounts?
- For those of you with 97-99 SE wheels..
- Well... I found my brake fluid leak...
- Help me hotwire my car....
- I Changed the Cylinder Head Temp Sensor And......
- Help, VE 194 Gauge Bulbs! (Upgrade)
- Front Seal
- Speedometer stopped working
- Putting VQ engine in 92 SE??
- Stuck in DC? Help!
- help with shaking car
- grounding question
- this works really well...
- engine dimension question
- When extremely hot, Car dies at stop and no performance
- high idle.....rough change of gears
- 2 years of work... some pics
- Please criticize my work......be gentle
- car shutters while driving
- funny thing happened today...
- need expert help, well almost....
- quick vtc question
- article on easy HP
- 92 VE alternator - 2 entirely diff. models???
- Seat Belt Not working
- Sticker Shock...does this seem right?
- Found Classic 3rd Gen Mag Commercial
- i need to replace my pads and rotors
- Cleaning coil packs
- smoke
- Nitrous?
- brake/fuel line rust CHECK IT
- wtf!!!! everything dimming!
- replacing injectors
- E-Brake Tightening
- best muffler for a VG?
- Spark plug freakin' blew out!
- Engine Ideas
- IACV stock position
- Was bored.
- P/S pressure hose and pump???
- fuel line question...
- Sounds like somebody besides me needs a vacation!
- And here's another
- Nice looking VE 5spd on eBay
- a new kind of door lock issue - i think
- I stand corrected
- I need a favor!
- move carpet for power wire
- Is this a sign that my starter is about to fail?
- installing water temp gauge
- How can you find where broken vaccuum lines go?
- Power Steering Hose Replacement
- Coil Packs
- battery light stays on
- Taking out injector
- axel
- anyone who has the blehmco ground kit
- changing cluster from a VG into a VE...
- Need info on 4th gen seat compatible with 3rd gen.
- Replace KS or use Resistor?
- Clutch Replacement
- slight hesitation at first then normal. what to look for?
- Air very low coming from vents....
- Knocking after flex section repair
- Weird sound
- Daytime driving lights or headlight buzzer?
- keypad fix pictures
- Rev Limiter
- Fog lights not working ?
- Help - strut plates loose, can't do alignment
- E36 with lids ... what do you think of this look?
- is this good???
- A/C Not Workin
- silver lining
- Powder Coat Parts
- Engine Bucking, Stalling, Jumping Tach
- bose radio with sony cd player
- tint
- engine misfire
- Dash Panel Lights Out!
- Another AC Question
- Wheel Alignment Problem
- FS: $500 for my 93 SE 5-sp...parts or project
- hot when idleing
- Part Needs???
- its been fun....
- airbag light
- E85 fuel....yes or no?
- E36
- Replace piston rings w/out removing engine??
- Bose CD/Cassette/Radio quits working !!!
- mtbe in drinking water
- e-10 being used in different states
- KYB VS Gabriel
- Some problems..
- really need advice:
- Steering Rack & Pinion
- a/c problems
- new tint pics
- possible blown head gasket
- What do you guys think?
- Pics of MY boring day..
- High Pitch Noise in Rear
- Performance Susp .....
- Detonation sensor?
- Spokane area?
- exhaust noises
- idle woes
- Toyota filter Q
- How Do I know If My Max Had Recall(95V244000) Done?
- Did I Wreck my Tranny?
- Anyone do a JDM Engine swap on 92 SE?
- VG30E Weird (high) idle problem - take two.
- 7000 red line Vg
- fixed keyless entry. for now
- leaking power steering fluid
- Gas w/ ethanol - bad for injectors???
- Air bag replacement
- squeaky brakes
- New car.
- 89 Maxima RIP... worth parting out?
- Help...Need Ideas!
- Intake
- Ol Faithfuul?! Radiator.....
- Window Problem
- bad idling when i turn on a/c
- Problems starting.. sometimes?
- quick simple fog light question for yall
- High Pressure Power Steering Hose
- RELAY BOX - AC Problem Found
- Power Door Lock stops working on 93 GXE
- Pics from my boring day
- Changin Ac belt
- what type of bulbs are in your clr corners??
- Cleaning GXE Rims
- idea for site introduction...thoughts?
- Body parts - where 2 find ...
- Need Lighting Suggestions
- Maybe a new rust Recall victim
- Ractiv muffler sound clip link
- I think my guages might be going or something has anyone heard of this.
- my buddy just bought a 94
- brake sensitivity
- Any pictures of a white 3rd gen with black/graphite powdercoated SE wheels?
- Front Suspension
- Are the 1993-94 Maxima SE Twin Cam faster than...
- new foglights
- what size...
- wiring diagram anyone?
- KN Filter Part Number
- guys, look at this.. custom leathers!
- Any way to open up the stock corner lights?
- How do I remove the rear spoiler?
- true smoked turn signals. PICS *56k Warning*
- Blue smoke...
- I am finally beginning to really like this car!
- AC stops being cold on high
- Cold Air Intake
- Leaking gas tank
- for KIYAKERZ, and all those that have received a photo radar ticket.......
- thinking of selling
- Alternator diagnosis?
- New Ractiv Muffler Pic
- CPS and octane level
- Steering wheel vibes......
- JDM Auto Tranny
- Oil Catch Can for 92 SE w/ VE30DE DOHC engine
- Cruise Control Speed
- 93 SE 5-speed rebuild
- Dreded (sp?) Cruise Control
- Door lock / Car alarm hell?
- What body Kit
- AC Question
- Do I need a new battery or a capacitor?
- Update on my VE5spd!
- transmission fluid...
- will a 4th gen headrest fit in a 3rd gen?
- A/C only blows on High
- 35% tint pics, plz post
- 5spd swap
- replacing engine-VE
- Holy CAI Batman!
- intermittent clock, radio out
- Replacing lower radiator support
- Clogged 'Cabin Air Filter' ??? Cleanup time...
- timing belt
- need part number
- Alignment or Balancing
- Adding Keyless Entry
- photo radar
- 91 GXE Idles Very Rough, Help me diagnose? (Longish...)
- R.I.P. Maxima
- Underwater SE
- rattling only when I go over bumps?
- dash paint?
- Spark plug wires and power steering pressure hose questions.
- wiring question for custom hud project
- problems w/ my indash lcd player help!!!
- Is AC repair hard?
- Hey, let's have a "who can ask the dumbest question?" contest. I'll start.....
- need a link please
- hows this sound for price
- Thinking about tinting corners, how dark?
- On a shopping spree
- Manual Climate Control to Auto Climate Control
- Bumper painting
- spark plug gapping
- Anyone Know Place to Get BodyKit Cheap?
- Effect of AC Compressor on Gas Milage
- A/C problem
- riddle me this! (cooling system)
- Pearl White Paint Repaint?
