PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. U11 bluebiord mods needed
  2. u11 blue bird mods needed
  3. Found this Ebayin'
  4. 18x7.5 limited 800 wheels. and 235 wide tires question..
  5. trunk problems
  6. ECU difference?
  7. Finished installing ST Springs and Struts.
  8. 17" questions
  9. wierd electrical problem
  10. i wanna lower my max
  11. Idle Adjustment
  12. New price for coil on plugs!
  13. smoking corners?
  14. New Mod In The Works: Cattman Catback Exhaust
  15. Non Bose Setup Sucks
  16. ABS question
  17. Power Door Locks Unlocking.
  18. anyone interested in a catback by cattman
  19. New Engine or Crank?
  20. wipers for the headlights??? (pic)
  21. Some VE engine pics, 165k miles of fun.
  22. Power loss in a 91 SE 5 speed
  23. Anyone ever replaced the auto. tranny servo O ring?
  24. Is my transmission hosed?
  25. i will be rebuilding vtc's soon !
  26. Air Condition Vent
  27. maxima headers finally
  28. Need advice from the mechanically savvy and financially sophisticated!
  29. 1991 Maxima SE, thinking about buying, help please.
  30. No Mechanics can figure out whats wrong with my car (Please Read) !!!!!!!
  31. smoke from under hood (pic)
  32. OK here they are...who wants UK (like) clears?
  33. VE Supercharger Possibility
  34. exhaust manifold
  35. Taking out the dings
  36. Loud clunk in rear end, Please HELP!!!
  37. cold air intake
  38. Fidanza
  39. ECU Fail Safe Mode
  40. Brake issues...any idea
  41. Gauges: Red Needles - Blue Numbers...hmmm
  42. Front Lip Redbuild??.......
  43. Some one save this car
  44. Timing Advance + 470K K.S. Resistor. Your results?
  45. Help: Water pump replacement
  46. maxima engine
  47. License Plate Bulbs
  48. calling all experts!!!!
  49. how can i be getting this good of gas mileage???
  50. 94 Maxima gas smell when cold outside
  51. how do i install outer cv boot?
  52. Custom VE Turbo !!!
  53. Hiper Headlights
  54. Bad Startup Sound...
  55. Shaved Doors For Sale
  56. Q: Identifying odd sound
  57. VG30E question
  58. VG30E Engine misfiring bad...really bad!!!.... :(
  59. 90 Maxima Won't go into gear when cold
  60. Looking for a maxima owner...Mr. Rose
  61. fuel problem with the new motor
  62. Control Arm Bushings
  63. '89 SE Foglights
  64. ??????
  65. Paint Job Prices.
  66. thinking about new rack and pinion
  67. Rear brake question..(what is this clip thing)
  68. I Just got a Maxima...FOR FREE!!! :)
  69. Squealing just after startup
  70. buying an 89 maxima. GOOD IDEA?
  71. tranny 90 maxima
  72. Totalled
  73. Clarion Amp Details
  74. Foglight Switch
  75. Need advice on what to do with my ailing 91 Maxima
  76. Tune-Up for 89' 190,000k
  77. Intermittent stalling
  78. bose woes
  79. No wonder my front rotors warped..
  80. The most you've spent on maintenance???
  81. 87 Octane??? YES or NO
  82. Techometer dead on GXE
  83. Synthetic Oil Question?
  84. hood hinges/struts
  85. whats the problem
  86. Oh My Damn!...the Power!!
  87. Problem with digital climate control
  88. Please help diagnose: Startup problem
  89. 20s on a 3rd gen, im getting closer
  90. what is rarity of red SE 5spd?
  91. misterious connetor
  92. Other Body Kit Questions
  93. Body Kits for a 1994 Nissan Maxima
  94. Exhaust Manifold
  95. Gates belts for VE
  96. putting new head unit how to take off the dash surrounding important please read asap
  97. transmission question
  98. Just bought VE engine!
  99. ECU Question
  100. Keyless entry
  101. Rattle in first
  102. Need to know on a auto, shifts and at what mph.
  103. Gt R Terminator??!?
  104. Prolock
  105. cant operate windows from driver side
  106. Turbo Kit 4 3rd gen
  107. Couple of ?'s
  108. Exhaust question
  109. I'm Back....Well not really but kinda.
  110. Intermittent Starting Issues - F@#%!!
  111. Please Help!!!!!
  112. Length of stock muffler
  113. Tail lights from a SE???
  114. Noise when in reverse
  115. i got a question
  116. Rocker arms?
  117. Speed in 5th gear at 3rpm?
  118. who's got bras??
  119. curious about CONSULT
  120. timeing question
  121. IDLE problem
  122. pre-cut window tint for maximas...
  123. which n20 is best?
  124. shifting shaft problem!
  125. Autilury Air Control Valve
  126. original tire size
  127. 300zx calipers
  128. finally found and fixed my problem
  129. Indiglow Gauges!
  130. Button
  131. NGK Spark Plugs
  132. doors won't lock
  133. New Problem...
  134. My max will be going for sale soon
  135. lowering springs
  136. Indications of bad rotor or caliper?
  137. HKS or MSD Ignition Upgrade ?
  138. Clutch Upgrade
  139. Ok, I hope sumbody has theses!!!!!
  140. Shaved my trunk lid (pics)
  141. Spoiler Options??
  142. which engines are compatable
  143. White 92 SE for $2500... Is it a good Deal?
  144. Now What?
  145. car won't start
  146. Max Clear Taillights ??
  147. update on the hurky-jurky (was MAF thread)
  148. do I need splash guard
  149. Clueless, she just shuts off
  150. Grinding and rubbing from front BUT NOT IN REVERSE
  151. No heat
  152. UK fogged corners
  153. less on ATF
  154. Got me a 92 SE 5spd!!!!!!!!
  155. Driver side wheel bearing question, please help.
  156. license plate bulb size for a 93 SE?
  157. steering problems
  158. speedo problem , anyone help ??
  159. Anyone ever do a 5spd to Auto Conversion?
  160. VE injectors in VG??
  161. AC Problems. Fixed. Had to share.
  162. Idle stumble issue
  163. Recommendations for new injector sets for VG?
  164. Car stalled in the middle of a turn
  165. How much does it cost to replace windshield
  166. Diagnostics Port.
  167. Coil Packs
  168. Proud owner of a 92 SE.....
  169. Timing chain cover
  170. Dyno'd on Saturday (10/11)
  171. 4 Banger Max!!
  172. How do I take apart the A/T Switch???
  173. Steering wheel discolouration: how to clean?
  174. body kit
  175. Jacobs Ice Pack Help!
  176. Speedometer Switch Help
  177. the problem that wont go away
  178. Engine/Transmission Swapping!?
  179. air bag steering wheel?
  180. New Max for Me?
  181. 5th Gen and 3rd Gen..... 3rd Gen better?
  182. Anybody need/want 6.5" speaker mounts?
  183. The Max was stolen........
  184. Help on electrical problem
  185. Speed Regulator
  186. Anyone know how to repair rear defrost...??
  187. changing thermostat on VG please help me locate!!
  188. Started the Tranny swap
  189. Where do I connect this cooling hose?
  190. Anyone's maxima choking during acceleration
  191. Accident. Need a Body! where/how/who?
  192. amazing!!!!!!!!!!!!!!!!!
  193. In cabin filter?????
  194. maxima stalls when in gear?, Help?
  195. Re-installing injectors how?
  196. will 19's fit?
  197. Driving problems, please read
  198. fidanza flywheel/valeo clutch update
  199. Opinion
  200. 3G swap guide
  201. New 3G Owner with a Question?
  202. Desperate in Ottawa....93 Max GXE
  203. Aaaaaaaarrrgghhhh !!
  204. just curious!!
  205. power gains?
  206. Manule tranny problem
  207. tranny
  208. Rebirth of a Maxima
  209. speedo
  210. Upper Radiator Hose Leak Question
  211. New to the board and a new maxima owner
  212. Firewall Troubles >> Urgent
  213. who do i go to for tech info?
  214. Need wrench for TB repl in Conn.
  215. Friend with auto tranny problem 88
  216. 1st gear was there, now its gone
  217. Which should I get? 92 Maxima Se or 91 NX2000!!!
  218. Need Injector advise!
  219. Who should replace my water pump?
  220. window prob *new
  221. bye bye max
  222. Gauge rings! anyone? for 3rd gen.
  223. Get a load of this!
  224. does anyone knows what causes this
  225. Somethings not right...
  226. BROKEN Control Arm Bushing
  227. just put in the redline mt-90
  228. rear windsheild loose rattling sound.
  229. Vg30
  230. flowmaster muffler
  231. bosch vs japan brand for distributor cap and rotor
  232. Pics of my engine swap, (thumbnailed) for those who havent seen...
  233. One question about suspension install
  234. a suggestion for a stickie just for the winter months
  235. Temperature gauge again
  236. Next Problem !!! :)
  237. New guy, Alternator talk and Stereo ??'s
  238. 89-94 maxima headers
  239. tranny lifespan
  240. window problem *new
  241. what year tranny will fit my max
  242. 3rd gen vs. 4th gen handling
  243. Cadmium coating on rotors??
  244. Got rear ended yesterday......
  245. GReddy SP2
  246. Strobe lights
  247. Is it me, or is this car a 5-speed?
  248. Car won't start
  249. All Windows Stopped Working
  250. Help hooking up XMRadio without FM Mod or Cassette Adaptor
