PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Started to repair exhaust manifold studs
  2. What Is The Best How To Site For Someone That Wants Do It Yourself Instructions......
  3. Temperature guage no longer working...
  4. Mother Of God!
  5. replacing Condenser
  6. Where's a good place to get Tokicos installed in San Diego?
  7. Getting a maxima Need as much help as possible!!!
  8. aquiring reflective tape like on the 240SX
  9. door lock timer question
  10. how to tcu?
  11. sunroof glass removal
  12. AC compressor
  13. Power antenna replacement
  14. Heater control lever...
  15. maxima ve got clobbered, good body shop in N. Atlanta area? (pics)
  16. Search??!!
  17. Got my Stuff Yesterday
  18. Revs hunting all over the show
  19. G35 Sedan muffler on 89-94 Max!!??
  20. Ring Light around ignition
  21. Levoc Automatic Shift Knob
  22. Ultra S Underdrive Pulley
  23. Squeak at low speeds
  24. Exhaust smell on high speed
  25. final mileage pic (finally)
  26. VG Gas?
  27. 93 Maxima overheating
  28. sentra grill
  29. cutting springs
  30. sound clip and choice of muffler, need deep and throaty sound
  31. what is the cheapest place to order Tokicos and sway bar?
  32. 92 SE Clutch
  33. Um, VG popped PS Line?
  34. how much to get car repainted same color?
  35. 120,000-mile service rec's?
  36. 89se ?
  37. Looking for a good place in the Seattle WA, area for a auto rebuild...............
  38. R-134a retrofit
  39. yet another intrax question
  40. Wheel bearings noise and stereo tape question
  41. Vb Mod
  42. JWT equipped VE dyno request
  43. IMPORTANT suspension question for lowering
  44. new engine
  45. Quick question
  46. intake
  47. New control arms today......
  48. 3rd gen cup holder
  49. Need help on my gauges
  50. Bose Audio Replace Dilehma
  51. Suspension Options
  52. V-IZZY Pics of Crazy4maxima's new VE 5spd
  53. Pix of my headlights w/ fogs and tinted tails....
  54. Basic upgrades
  55. Steering Wheel replacement?
  56. Air flow in the trunk???
  57. Replacing suspension.
  58. Working at a nissan dealership to learn more?
  59. dash & a/c ? gas tank too.
  60. Ya guys might want to check it out
  61. bolt ons?!?! Are you scared?
  62. spark plugs
  63. Quick Question
  64. Best price for Koni struts?
  65. Are all 3rd Gen Struts interchangeable?
  66. Sprint Lowering Coils
  67. Adjusting Idle
  68. What to do about weather stripping.
  69. Failed Vtc Make You Stall Hesitate!!
  70. Antenna issues
  71. Water Pump Install
  72. Anyone know of a good Maxima mechanic in the Seattle, WA area that can help me fix
  73. Engine removal.. is top removal possible
  74. '94 Maxima RPM jumping and stalling
  75. Finally my Door Locks Work!!!!!!
  76. 4th one
  77. power steering
  78. custom trunk kit
  79. some car trouble
  80. Tranny Update and New Question
  81. o2 sensor
  82. Need HELP. Bad vacuum leak.
  83. to chris91se
  84. Noises ????
  85. Axle keeps slipping out when I drive.
  86. Emergency, Anyone With Alot Of Tranny Knowledge?!
  87. fixed something! but I don't know what!
  88. can you ruin one gear?
  89. i need a new motor !
  90. Engine stalls only in the rain...
  91. VE/VG question:
  92. sometimes Idle Speed remains at 1500 and doesn't drop to normal, what can I do?
  93. Smelling gas in the morning.... Help!
  94. 92 max SE with an intermittent stalling problem
  95. Paintscratch.com Is Awsome !!!!!!
  96. Wheels, wheels, wheels
  97. Rb20???
  98. lubricating window regulators
  99. Stereo rattling something in the roof
  100. supercharger kit
  101. Maxima 91 audio active speakers system (New head unit installation)
  102. carpet coming loose
  103. Which OIL filter to use?
  104. cb radios
  105. rate my car http://www.cardomain.com/id/va1adez
  106. i thought the day would never come......
  107. Something else ive noticed that is different on my auto vs my 5sp parts car..
  108. WSP y-pipe fitment
  109. Some pics of one of the many current projects i'm working on...
  110. bad switch: easiest way to get window up?
  111. newer factory mufflers?
  112. to leather or not to leather?
  113. service manual cd?
  114. Gauge Pillar Update!!! --->
  115. Can't search . . . must post boring thread . . .
  116. TPS question
  117. I just changed my bearing and now I hear a grinding.
  118. Cold Air Intake...where Oh Where?
  119. Where to buy the Knock Sensor Sub-Harness Connector?
  120. Question regarding rough ride w/ my GXE
  121. where is the coolant drain plug indicated on the owner's manual ?
  122. rpms fluctuate
  123. the temp gauge
  124. Help a 3rd gen fellow out
  125. steering wheel
  126. mitsubishi intake vs pvc pipe intake
  127. Fuel Pressure
  128. 1992 Maxima SE Stalling
  129. Problems with A/C and heater turning off after a couple of minutes of being on
  130. ECU Maybe?
  131. Q: about timing
  132. 92 SE Parting out
  133. What Is This For
  134. noise with acceleration after suspension change
  135. muffler question ...needed info..
  136. saw a white max, 5th gen. rims in manassas area....
  137. Brake pad questions
  138. JDM engine or rebuilt engine?
  139. 3rd Gens in Lexington Area?
  140. Knock Sensor $135.00 Shipped US
  141. Something loose?
  142. foglights on a gxe
  143. Air/Fuel Gauge
  144. BMW headlights?? flush
  145. My Max is pushing its luck
  146. Vacuum Hose Locations
  147. speedometer doesnt work
  148. How do you change wheel studs?
  149. Picture of Door Lock Timer
  150. What's Up With This 3rd Gen???
  151. 4 questions - please help
  152. http://members.cardomain.com/va1adez
  153. factory or bull
  154. mobiltek vb reclabiration any feed back autos
  155. Wont Start
  156. Spring Compressor
  157. Clamping force (in kg.) of OEM pressure plate?
  158. new muffler question
  159. Rear brake problems
  160. Tranny Swap
  161. whining noise
  162. Fender clips for the oem mudflaps. Where to get?
  163. control arms
  164. Trunk insert
  165. Good place for leather online?
  166. 18x8 ?
  167. PCV valve
  168. New goodies for my car
  169. maxima gxe 1/4 mile
  170. Help Tie rods wont come off
  171. 1994 not starting
  172. Lubrication...
  173. Maxima 89-99 High Flow Racing Intake Kit??????
  174. How do you remove the auto shift knob?
  175. How to remove rear speakers???
  176. Blower motor running all the time
  177. repairing exhaust studs
  178. Keypad and power lock problems....
  179. 92 SE Clutch
  180. ABS Hydraulic Unit
  181. How much is changing the Knock Sensor(Labor+part)?
  182. Front Plates
  183. Limited Slip Diff
  184. cleaning leather
  185. power door locks?
  186. Sprint spring install complete... come see
  187. hello fellow maxiamteers...
  188. Wing West question!!!
  189. quick yes or no
  190. Climate control??
  191. Updated pic
  192. Blacked out lights
  193. Dam Server
  194. Back seat windows
  195. buying a 90SE maxi
  196. Trip to cape may gone bad need help
  197. How do I remove the adhesive strips under the door moldings?
  198. Catalytic Converter question
  199. temp of the sylvania xtravisions
  200. Help: the cassette player can't pull the tape into the player
  201. something wierd when i post
  202. shocks
  203. finally finished the right side door handles (pics)
  204. excessive tranny fluid change?
  205. timing belt and water pump
  206. <sniff> I miss my baby already...
  207. Keyless entry...
  208. why cant i search?
  209. Steering rack bushing?
  210. winow regulator question
  211. A disappoining VTC story
  212. Brake light malfunctioning
  213. engine clatter (horrible)
  214. 300zx wheels
  215. auto tranny cold start stuff
  216. aftermarket muffler with stock y pipe
  217. first chop of an acura rsx
  218. Moda R6 pics
  219. Strut mount bolts
  220. Trans fluid change advice. . .
  221. Timing Belt History
  222. Problem starting the car and putting on neutral only works.
  223. What I've Got Coming... :-)
  224. rear suspension..simple questions
  225. any one know?
  226. Strut question
  227. SE tailights
  228. Got my R6's yesterday!
  229. 5 spd trans problems
  230. My 92 GXE problems
  231. Please Help, exhaust question
  232. What belt size for Unorthordox pulley?
  233. What kind of Engine do I have !
  234. Another Engine Swap Question
  235. which spark plugs
  236. gutting out the catalytic converter...
  237. how to remove, question
  238. 1991 Tranny Question
  239. 300zx caliper
  240. Wheels
  241. Add on CD Changers
  242. gtechpro
  243. ve engine swap
  244. Need some insight!
  245. whats the size (2,2.25,or 3)
  246. Need help... HELP!!!
  247. Camshaft oil seal
  248. 4th and 5th gen wheels fit?
  249. updated site
  250. PopCharger...Remove Box?
