PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Rebuilding rear calipers?
  2. radiator support
  3. valve cover gasket replacement on 89 se
  4. Australian Members???
  5. Diversity Adapter
  6. can someone tell some info on e36 headlights please!!!
  7. about f-ing time!
  8. Rock It Till The Wheels Fall Off
  9. how qts of oil do i put when changing the v6 maxima?
  10. ve under drive pully
  11. Best way to bleed the brake lines
  12. headlight question(sorry)
  13. anyone sell their max lately?
  14. piston rings
  15. First Major Repair->VTC Replacement Brilliance or Insanity (long)
  16. It never ends, one thing after another need help about belts(kinda long)..
  17. Ignition Upgrade
  18. Alarm going off for no reason, HELP!!!
  19. Fuel Pressure Regulator
  20. How do you decipher the trans-axle code?
  21. Camber Kit for Intrax Springs
  22. handling trouble
  23. Crankshaft Bolt
  24. Front Passenger Wheel making noise?
  25. R 134
  26. The rear tailight
  27. Car does not move correctly
  28. I need some help , What is it left for me to check ?
  29. My Car Stopped Firing Help... Help!
  30. bad gearshift lever or tranny?
  31. 91 Maxima Update
  32. Optimizing vs Modifying
  33. buttons
  34. part list for ve 5spd swap
  35. Which tranny cooler ??
  36. rear shocks???
  37. Painting a plastic grill?
  38. 91 or 92 Max not runnin good in rain
  39. OK, so I am seriously considering quitting with Maxima's forever...
  40. Suspension Suggestions
  41. rear tail light fuse blowing
  42. 5spd question
  43. 6 hours C/V joint project
  44. Loose Sunroof
  45. Maf?
  46. Why does the fuse keep blowing out?
  47. what kind of e36 headlights do i need
  48. cleaning pop charger
  49. Seafoam equivelant
  50. Changed the starter
  51. VG auto to 5-speed swap, JWT ECU any good?
  52. Took Some Pics Today...
  53. Help
  54. rear factory speaker hole size
  55. muffler suggestions?
  56. Sunroof Glass Replacement
  57. im new to the forum
  58. Failed Emissions HELP!!
  59. Ebay 5th gen ftsb??
  60. Automatic seatbelt issue
  61. Does the Power Steering Hose come off?
  62. The Best Aluminum Flywheel?
  63. car won't start!!
  64. will ve 5spd axels fit on my vg hubs?
  65. Triple Gauge Pod Question
  66. Got car back, help?
  67. Connected wrong battery terminals.....
  68. coolant leaking
  69. What's The Whole Cu Ft Of Our Car?
  70. Need new POwer steering pump
  71. My day at the junkyard (pics)
  72. Car shakes when breaks are applied ... ?
  73. Had Warpspeed Y pipe finally installed.
  74. speedo not working
  75. worn Wheel Stud ????
  76. VG transmission...
  77. Help with my Bose system!!!
  78. engine burning oil
  79. fuel injector gone bad
  80. anyone ever install a Warpspeed CAI?
  81. Oil Pump??? or Worse
  82. Oil Pump??? or Worse
  83. got worked by a ve today
  84. diffence between 84-88 JDM 300zx and american 300zx engine?
  85. help!!!
  86. just bought a 1992 Maxima SE 5 speed
  87. e36 head light help
  88. Sensor questions
  89. Who has done their timing,,,themselves !
  90. Freeze plugs
  91. Today I made a new headlight wiring harness
  92. Chris92se. Your midpipe is done : )
  93. Track speed troubles....
  94. Who has installed KYB2 GSR's???
  95. Control arm/balljoint play...leaving on 1600mi road trip....GURUS ADVISE PLS!
  96. Parking brake light on/off
  97. Quick Lowering Spring Advice...
  98. DNAS420 has returned!
  99. What next?
  100. what to do with maxima.
  101. need a new radiator...
  102. Torque converter
  103. Cut open a 15208 55Y00 filter...
  104. GXE vs. SE vs. LE
  105. rear brake pad how?
  106. Has anyone done true daul exhaust yet?
  107. audio relays
  108. broken brake line....
  109. Fog Lights
  110. replace or not Bonjo Bolt (brakes)
  111. Pillar/Headliner...Removal and refinish?
  112. Cruise Control
  113. Say.. if anyone wants ported/polished VG heads...
  114. BMW Headlights on a Maxima
  115. VG30E Timing belt...
  116. Tint Pics if ya got em
  117. trunk switch not pop help while theres light =D
  118. Ok to share vacuum line with EGR and power valve?
  119. Dash Removal
  120. VE '92 totalled
  121. Engaging clutch problems
  122. hydraulics
  123. how long should the oem struts last?
  124. How many people here are using the Toyota filter........
  125. POLL wing
  126. POLL wing
  127. Friend just got a VE
  128. Help with new intake filter setup
  129. An invitation to the Cattman MaximaWest04 Meet in Tucson on 15 May
  130. Denso Iridium Spark Plugs
  131. mucho's money into max!!!
  132. newbie questions
  133. Make your own Angel Eyes!!
  134. Regulator went...any way to get window back up?
  135. Fluid leaking in floor board, loss of pressure in clutch?
  136. what u think of my new angel eyes????
  137. What kind of performance clutch do you guys recommend?
  138. axle differances and compatability
  139. another max
  140. Ignition wire options for 92 VE
  141. Antilock Brake Bleeding
  142. Plz help in a hurry!
  143. Where is the starter located?
  144. Bogged down @ <2k rpm
  145. Headlight Problem... Help
  146. I vow to ask about for sale items in the for sale section
  147. Quick q about auto tranny drain plug removing
  148. How much is it to replace my tranny fluid? its for a 5spd
  149. Need your help! Can you vote for my car? It will only take 5 seconds
  150. Poor maxima...
  151. How do I PROPERLY take care of my tranny??
  152. Brake fluid Leaking!
  153. Clutch slipping or tranny problems? ...long
  154. Side Door Moldings.... On or Off?
  155. Found out wats wrong
  156. My new SE!!!
  157. Car not starting, need some help
  158. VE Transmission Q's
  159. Digital AC control conversion??
  160. ground wires
  161. Intrax spring
  162. Cold air Intake
  163. Cams question
  164. Question regarding the 3rd gen drum to disc conversion
  165. pesky bling bling
  166. Odd Hesitation/running rough. Help please.
  167. 18's FO SHO!!!!
  168. GXE custom logo
  169. Car won't start in the rain- help
  170. Odometer problem (update!)
  171. electrical problems...
  172. Check engine light on
  173. O2 sensor LOCATION/pop charger
  174. Trouble with strut install
  175. 91se Dohc
  176. how do I adjust 92 SE DOHC idle speed?
  177. New Rims
  178. wont start !
  179. Big Problem?????
  180. Power Setting on Auto Trans blinking
  181. Foglights and Fuses
  182. Rev Limiter?
  183. Spark plug gap
  184. does a vg30de fit?
  185. Window Auto Down Switch?
  186. SuperMax does 0mph at 8500rpm!
  187. gasoline smell through vents
  188. Help Quick!
  189. Transmission Rebuild Question
  190. Need Help Removing Lower Timing Cover
  191. airbag light flashing after wheel swap. How to reset?
  192. PPL w/ Interior Knowledge
  193. Wheel bearings
  194. Ignitor specs
  195. O2 sensor
  196. Ghetto-Fabulous Molding Glue Removal
  197. How to use your keyless entry...
  198. Intake removal
  199. Y-pipe Heat shields?
  200. Drivers window not working
  201. Sun Roof
  202. Is it just me?
  203. Matt's Mod of the Week
  204. Drivers window auto-roll up feature :D
  205. new project for racing vids
  206. Just put in some LEDs to light the gauges, BUT...
  207. Dropzone Lowering Springs...
  208. Hood louvers
  209. Custom trim for shifter PIC
  210. 92 MAxima noisy
  211. So Mr. Gone. How does you new style CAI work?
  212. Pop Charger vs. Cold Air Intake noise levels
  213. new maxima bumper
  214. GXE badging on a 3rd gen???
  215. What does it mean....
  216. Finally, Another VE CAI!
  217. Anybody With Torque Converter Info?
  218. Newbie needs advice
  219. faulty MAF and O2 sensor
  220. O2 sensor wire length/performance
  221. I'm Super Gay
  222. Z32 VG30DETT in a Maxima !?!?!?!?!
  223. 4th gen = 3rd gen STS
  224. Help: a grinding noise from front when backwards
  225. AutoZone Vs Dealership
  226. What stops us!
  227. Blower
  228. HELP! car won't go into gear...........
  229. Se gauges in a gxe
  230. ABS actuator leak..???
  231. A Few Quick ECU Questions
  232. pics lots of pics oh yeah and an egr problem
  233. 4 wheel disk brakes on GXE?
  234. Operation Ultimate VE 5spd...Budget: +/- $10K
  235. Power antenna wiring!
  236. polyurethane bushings
  237. Does lack of tailpipe/muffler affect sensors?
  238. How much can I get for my 1990 Max?
  239. About to buy parts...Need Answers!!!!!
  240. How many pints of tranny fluid does a Manual VE hold?
  241. strange noise
  242. putting in a youger ve any suggestions
  243. Lower spring
  244. A few questions
  245. 3rd gen Maxima chat
  246. AC Accumulator
  247. E-brake light
  248. Buying a VE
  249. hard shifting into 4th
  250. stuff to look for when buyin used maxima?
