- For those looking for NEW hood struts
- Some pics
- Adding sensor to Factory Alarm 3RD GEN.
- does the front bumper from a SE fit a GXE?
- Some pics and vids of N.E. Max Meet
- Wings west body kit
- electrical problem....not enough power
- engine rumbles, please help
- damn i need new struts housing
- 5spd shifter surround
- Beamer headz, I need help?
- 93 Maxima-Tranny?
- Battery Voltage drop..
- What do the capasitors look like? on the bose amp
- Should I Get a Front Body Piece Or Lower It
- Trying to decide on a short shifter, need some info on them
- busted manifold bolt
- Where to get B-pipe only?
- expansion valve
- I think auto tranny is just about gone.............
- shoulder harness covers invites for mockery?
- advice
- Help need to start my max asap vg auto question
- Why i haven't driven my Maxima in over 4 months.... Lots of Pictures!!!
- Maxima Year Mileage Checks!!
- New Pics
- 95 strut fit 89 se?
- For you that have changed your timing belt.. read this...
- Nitrous Oxide question, hehe
- erebuni kit
- anyone have harmonic balancer 190hp engine?
- cost for kit installation and painting
- Is that... a cloth top?
- bonz here again, for kingcarnage
- Garrett Exhaust
- What is my 94 gxe auto with 74000 worth?
- Some Pics of my Catback! Sound sample may follow soon
- Mother Of God...Part 2
- need help.. removing rear strut cap
- a/c turning off/on at the same time motor's fan ?
- Replacing dash indicator bulbs
- Are these brake lines?
- body kit bumper replacement
- bmw headlights
- Low Fuel Light is on Always
- thinkin about getting a maxima have some questions!
- 1991 Maxima SE (Bose) -- need CD player advice
- Finally "done" with my car
- paint code
- exhaust ?, please help, thanks
- If your gonna do it, then DO IT RIGHT!
- Will 5th gen 17" rims fit if I got Eibachs?
- Springs and struts
- Warpspeed Y-Pipe rules-->
- Looking for the real skinny on intake systems
- Sig Pic
- Unadjustable FSTB?
- Brushed aluminum gauges
- RIms size Question
- test driving a 94 Maxima GXE, what to look for?
- Built a custom CAI system today
- Soon to be new Maxima owner here.
- Group deal for a CLARION VRX 935VD DVD/CD/MP3??
- Horror Story
- Exhaust Question
- WHat color leather is in the 3rd generation
- Y-pipe and cat suggestions
- Hub Bearing Replacement...Help
- 92 Se Strut Bars
- VE and VG hubs
- Power Antenna problems
- no cat?
- Which clear corners do i buy?
- Clicking Noise From Dash
- Photoshop Favor
- My max don't start
- looking for opinions
- Just a few questions
- How Can I get quicker Acceleration
- Pics of my car...
- another headlight conversion other than bmw
- Engine management help
- skyline bodykit GD.... again??
- Silly strut / spring mistake, does it matter?
- Removing Cams, and suggestion needed
- best sounding pop charger stillen or jim wolf.
- I want to learn about car suspention systems
- Brake Shoes questions
- Aftermarket Rim question
- looking for exhaust header
- boring out throttle body
- ECU Diagnostics
- low compression
- CAI intake question
- Woohoo! I'm keeping my baby!
- Coil Pack Replacement For Cheapskates!
- struts
- OEM Carpet & Floormat source - reaonable
- 2.0 of my Car MP3 / GPS setup
- VE Timing (Kinda Long)
- Engine Mount?
- BAD LUCK! -- water pump going
- Weird auto se shift . ?????
- 1990 Strut problems
- Car Will Not Turn Off
- I need help finding cheapest VE new or used.
- Has anyone adjusted timing chains correctly?
- sticky trunk seal
- Exhaust... 2.5" or 3"
- Trouble Codes
- with clutch kit?????
- Pics of Jon610's car
- Struts/springs install...parts question
- Body Kits
- Reverse Lights
- im having trouble matching break light does anyone know size
- ecu reading
- Cefiro parts
- pix of my car
- Auto Tranny Situation......Any suggestions are more then welcome....
- need some help..
- Anybody else ordered Brembo rotors?
- Resetting ABS Circuit
- ebay turbo what do you think
- rough idle
- weird noise
- Need Help under hood!
- BMW Headlight Question
- Bought a 92SE 5-speed with 76k!!
- BMW Headlights
- Tranny (long post)
- suspension like a boat
- need some info just got my 93 max
- RPM's
- I Cant Get This Fukin Factory Air Box Out
- how long sprints settle
- Need Help With Shock Sensor Installation
- Correct tire pressure?
- Paintless Dent Removal
- dual gauge question
- 1989 Intermittently looses power, then comes back
- Best Spring to Use with KONIS?
- Here's a Question From The Archives!
- Next car after 91 GXE- 97 max or 02-03 altima?
- Search Engine
- projector headlights??
- tire rubbing issues w/97-99 5-spokes
- ABS Sensor Question
- Will OBD-II Scanner Work?
- Octance
- Worn control arm bushings...
- Is the Hood Open, or has this been in a wreck?
- Window Regulator questions
- VE vs VG Gauges
- Fuel economy
- My car had a good weekend...
- injector voltage
- Glove box bulb size anyone know?
- some thing smells
- Tranny: aamco rebuild or junkyard jewel
- 9004 & 9007 Headlight Bulbs
- freon
- Euro Gauges
- fuel pressure regulator
- what is dying on my car?
- Speedometer
- any good forums for a '94 sentra????
- Quick important question: 214K miles, how long will it last?
- help!
- Alarm,Keyless Entry, Maybe even Remote Start
- Installed Tokicos today
- Did I make a mistake?
- Spoiler light
- Ahhhhhhh!!!
- Why me?
- e36?
- VE into a VQ
- Breaks
- Rear window going down without hitting the button
- cleaning out throttle plate
- O-rings for A/C system
- Replacing Studs
- pics of VG turbos
- car theft
- dual exhaust
- Looking for answers
- warpspeed y-pipe
- Attn: People with 92 SE and 2000-2003 FSTB
- did anyone ever drop that 300 hp engine for the vg
- tire size
- Bose CD Player
- Can I pull the three bolts off to install a tower brace?
- Quarter panel?
- Anyone with pix of 35% Tint..........Search Down
- cleaning injectors and coils
- Its been a year since my accident.
- vtc strangeness (a brand new kind of it!)
- control panel light out
- May be buying a VE 5-speed, need a little advice
- Changed my belts and...
- Won't start after VTC grounding
- Is my transmission on the way out?
- 94 Check Engine Light
- Max Sighting In Old Saybrook CT
- 90se 5speed ,sounds like a old Volkswagon
- maf sensor
- Leatherseats.com seats are in...
- what happens if you mix injector types?
- ””HELP!! Stalling = trans...
- anyone with y-pipe + cat-back please help
- Headers
- Axles.. Changing them.. after a year
- Backfire
- VE Powered Radio Flyer!!! Pics Inside
- 91 A/T Problem
- Ambient temperature sensor questions
- cleaning cloth interior...
- AAAAAAHHHHGGGGGG Alternator
- noisy lifters
- cutting out...fuel pump???
- Anti freeze oil mix and wont accelerate
- almost had a dyno
- Fuel Injection Problems! Help anyone?!?
- I Have It!!!
- JDM sidemarkers
- whats the percent rating for our brakes
- Trans / TC whine
- max not reving above 4 grand in gear
- i need your 2 cents
- Another damn Knock Sensor question
- Wiring new guages - Help please...
- Control arm bushing replacement
- Map Lights
- Replacing Cassette player with CD/Cassette combo
- Cutting shifter
- 2 questions(radio & speakers) cant use search right now
- Pictures of finished suspension.
- Anyway to give my Max a deeer/louder sound???
- My new front lip pix.......let me know what you guys think........
- AC recharge
- Bmw headlights h7 wiring questions
- Chrome Molding
- I'm trying to install a newer bose amp in my 90
- Change Your Camshaft Position Sensor Today!!!!
- New Guy, Some questions
- VG to VE tranny swap in 89 SE
- Need detailed instructions on installing Tokicos shocks in San Diego
- Stolen Car Alert In Seattle
- tranny question
- st springs
