- Swaybar Q's
- 96 cobra rims, yay or nay ??
- where is the cheapest place to get motor mount??
- Running Rough
- tranny cooler questions?
- WSP Y pipe
- JWT ECU Question
- door handle
- non lsd to lsd
- Knocking at acceleration at ~70km/h
- Y-Pipe Installed
- car won't start
- '90 Drops Cyls & Dies-Restarts Cold
- Back in the Saddle
- mix/match springs? plus bushing question
- vg30dett pistons in ve30de
- should i?
- suspension questions?
- 300zx Calipers
- wiggly axle
- trying to diagnose-what next?
- VG30E compression #'s? not ratio
- Replacing Thermostat and Tranny Problems
- Fuse Problems
- Air Bag
- oops...
- CV Joint Replacement
- HELP :help:
- How many miles can I expect from my tranny
- A leaky Trany
- What is the best way to decide if Rack and pinion needs replacing?
- How do I remove the headlights?
- Rebuilt Speedo Sensor ??
- Just swapped motors..wont start
- Vg30de - Ecu
- question about replace the BOSE HU and speakers..
- Window regulator broke...
- replacing crankshaft pulley
- bogging problem on 90 SE +1 more
- Bad Millage on a 1990
- Is there a way to increase the idle speed?
- noisy noisy
- Bose radio/speaker problems
- I'm back!!!
- coolant leak above pulleys..?
- California people- emissions?
- Valve above egr?
- Tranny Problems and Installing tranny cooler
- VE30DET Dyno Results
- VE engine pull..sorry no search
- Just installed struts and springs... awesome!
- carpet cleaning
- New Excuse For The Window To Stop Working!
- I'm moving on!
- Window problems.....
- Hooking up and Aftermarket Alarm.
- Auto Tranny Stuck in 3rd
- Is there a too big when it commes to tranny coolers?
- Electric Problems
- msd ignition
- New Virus Going Around On IE
- I finally fixed my idle. VG30
- Wanna buy the pimp my ride MaXiMa ??
- interior decorating....lol
- I wanna go faster
- cruise control problem
- paintjob
- mr. clean autodry
- Ve Vg Ve Vg Ve Vg
- Ouch!
- I Heart The Junkyard...
- Help dealer want’s my arm and my leg for this interior piece
- Jack stand placement
- need help with auto transmission
- Bad engine mounts - Y pipe vibration
- There goes the tranny...
- how to install a CAI System for a 1992-1994 Maxima
- Windsheild, Windows, & Wing Question
- Warspeed Y-Pipe
- HELP... Parking Light Issue
- Replacing Struts/Stut mounts
- Aftermarket fog lights
- Removing door molding q's
- Cruise Control Dash Switch MOD?
- Help Need QUICK: Rear suspension
- How to find out my door key pad code
- loss of power pro...any suggestions
- FSM Link?
- VG30DE Timing Belt
- What does this code mean?
- what are the best strut bars to get
- What to change for high performance tune-up
- random shifting problems
- Okay I Goofed (Craig Brace!) any other wire guru
- Exhaust Pipe and Suspension Prob
- brochure for the 1990 Nissan Maxima
- Turbo Charger
- Exhaust questions
- starter gone bad
- Manual tranny noise?
- how low can u go without bouncing?
- Simple
- Anyone Switch Their Auto Stick?
- converting AC
- stiff steering wheel
- Anyone in atlanta want to fix my timing?!
- Seatbelt chime terror
- ATTN :Jeffrey Tran
- Random Skipping Bucking 94
- Bushing Plate question for 1993 Maxima
- VIN number lookup?
- And for the record, my bad
- CC Relay
- Spark Plug Question!
- Today I have learned that....
- Wing and aerodynamics
- thinking about staying with the VG
- question about underdriving
- Tranny finally went - advice?
- The great 3rd gen picture thread
- Headlights
- swapping seats
- Fuel Injector Connectors
- Not your average window question!
- Fstb
- Ignition Coils
- fouled spark plugs?
- Anyone here ever run a "sneaky pete" on their Max?
- Rims
- fixing front end
- fiberglass bodykit
- otto 5th gen strut bar fit my GXE?
- Strut creaking really bad (Internetautomart)
- Abs Unit
- Place Racing CAI question....
- Manifolds
- cf door pillars
- Seriously considering a turbo.
- Tire Rod Question
- Touch Up (Detailed)
- Gas Tank Filler Neck
- Yet another style climate control
- anyone know this guy?
- Does anyone know transmission capacity
- VE 5spd tanny question
- Question about rear brakes on a 92 SE
- Finding vacuum leaks
- Exhaust manifold gasket... DIY?
- stud replacement
- My car idles at 1grand. Is that a bad thing?
- Code scanning
- black Max, trying to cover scrathes
- AAC Valve - Help please
- The plot thickens.....hmmmm
- pison rings
- What Part Do I Need
- What kind of paint for interior piece?
- Brushed Aluminum Dash Kits
- Mechanic Quote Check
- tornado air
- Found This Site
- Stillen K&N Cone and Engine RPM
- Tapping Sound While Turning
- how much paint?
- Replacing the Ball Joint Need Pointers
- RedLine performance shift boot
- Rough idle after warmed up....
- Catback Question
- Color code
- My Maxima Pics Finally!!!
- white plastic piece inbeteen door panel and window
- Window Switch
- My Maxima (Pics)
- preferable e36 bulbs that don't burn....
- cold air intake for 3rd gen maxima
- Getting too much gas??
- Stalling... akward acceleration
- Air Conditioning
- Air Conditioning
- Steering wheels
- broken exhaust manifold bolts
- Electronic Climate Control Circuits
- what is changed when the rebuild a transmission
- Temp gauge
- Damn
- Average Annual Maintenance Costs
- Help needed replacing CV joint boot / 91 SE
- When to Stop Love affair with Max
- Lights
- What dino ATF fluid do my fellow 3rd gen owners use?
- fianlly got my lights, but now i have a problem
- Emmisions..what are my odds??
- Need info on Engine parts
- Potential body decay???
- Buying a 90 SE Auto..advice please.
- Bluebird AWD?
- Question ....
- For the first time ever today....
- Finding the Right Cold Air Intake
- Ignition coil ?
- Host pics. of my car anybody?
- new body kit
- new body kit
- whats better, a/t or m/t
- Need help on new struts and coilovers
- rear speakers not playing
- I need everyone's opinion on this mod except for Matt93SE
- (can you link me to...)
- Have to jiggle my AT shifter to start...anyone know why?
- Door panel snaps
- Suspension spring replacement
- VE headers
- SE chugging problem
- Oh no, I think my cylinder head is cracked.
- Power increases
- Air strut suspension ~ Bell drop
- 94 GXE maintenance opinions
- Battery and Brake dash lights won't go off
- Replacing rear drum shoes
- 3rd Gen Wheel questions for 17s
- update about nismo1989
- Oem Trim Paint ( Pics)
- Quick cigarrette lighter wiring question
- etown 12-13
- Buying a new max
- Seatbelt chime!!! grrr....
- rear arm bushings
- Popular headlight bulbs
- New 5-speed Installed
- Any wood trim pictures
- powder coating rotors
- Hermm, found something interesting...
- time
- How Can I Get the Best Engine Performance on a '93 Maxima GXE?
- Tranny slip in 2nd and 4nd after overhaul
- car RPM moves up and down in acceleration
- questions before i buy
- gauges
- Car shuts down while driving
- Blank, slotted or cross drilled?
- Pics of Mustang wheels on Maxima?
- Will 91 GXE auto tranny fit in 94 GXE auto
- timing belt question
- Ride Quality on 17" Wheels
- how much for 1990 Maxima SE RED
- Blocking off EGR
- Someone help me my car went crazy
- exhaust manifold studs
- Pimpin Electic Blue Max w| Shaved Trunk
- egr valve cleaning
