- Need help on stalling engine.
- Fast turn light
- thinking about buy lowing spring ........
- A civic that I'd rather have than most Maxima's
- rear bumper
- Is it the Alternator?
- No heat
- speaker sizes that fit front door?
- Pics of a maxi with IS300 rims?
- Power loss
- Engine shakes or shuts off when coming to complete stop
- automatic transmission owners step in (need a little help)
- Need Feedback: Upgraded Clutch and Airbag
- Knock sensor replacement
- idle issues, long as usual.
- I put my 18s on today even though I havent painted them yet (pics)
- 1989 Front fender
- Drop Down Resistor For VG Auto
- Speedo 5 mph Off
- shaking in drive at stop AT - Brakes applied
- clutch?
- Are the 94 seats the same as the 93's?
- what color is this...& 5spd fluid change
- Help needed in Minneapolis Area....
- Throw out bearing?
- water in trunk?
- peak rpm
- wanting to buy this max but what could this problem be?
- looking at buying a 89 5speed in the morning
- Windshield washer tank
- Over heating Problems pls Help
- chain like sound on acceleration
- Replacing more parts, need advice...
- Which Steering Wheel to Buy?
- antenna blues
- No power to radio on 91se!!!!
- ebay finding auto upgrade
- Automatic window roll downer thingy
- Help with ABS, doesn't work.
- please help!!! My axle!!
- for anyone with clutch issues
- On Line ASE Repair manual??
- PS Pump Electronic or Regular?
- Electrical Problems
- Is is the alternator?
- Wheels spacers
- voltmeter
- '90 Rear spoiler not lights
- Door latck/lock
- How to program your door keypad.
- Help with Sunshade
- Adding Keyless Entry of SE
- timing too far advanced?
- Matt's Next Project of the Week.... (watch out 56K)
- VG Intake Manifold Modifications...
- Pacesetter headers. . .?
- E-Brake handle
- Eh, sparkplugs
- Just some new pics
- shaved trunk
- tail pipe!!!
- Need '89 Maxima gear ratios
- radar detector hard wire writeup
- Euro Grille and Smoked Corners
- So quiet!!
- sagging pass door
- window broke
- '90 rear tails
- '89 - '90 tranny's
- Varying idle, does yours do this?
- WIll a VE rack replace VG?
- Bumpy ride after installing GR-2s
- Finally foundout what is clicking under dash
- Any one using a stand alone ECU?
- Removal of door panel on a 91
- jdm engine
- is it worth it,....?
- New car system
- Replacing Steering Rack
- Door lock blues..
- tire pressure
- Engine questions
- Air control broken maybe?
- recirculation not working
- '90-'92 Guages
- Auto Tranny Swap
- will 90 FSM work for an 89?
- New Timing Belt Replacement info?
- clear corners not so clear
- ST sway bar bracket
- Replacing CV axle...
- Goodies...
- What u think my cars worth?
- need a new exhaust for my '91 advice?
- finally replaced lower contol arm bushing
- 3rd Gen Injector Questions
- Window tinting
- Inside Fuel Release
- Rott :(
- Grounding kit
- can't fill gas tank all the way up...
- High Amperage altenator
- What have you fixed with org help?
- 93-94 SE Skidpad Numbers?
- Brake and Battery light combo..
- HELP!! With headlight electrical problem!
- Broken Wipers
- Boy am I a Maxima owner
- Axles question
- 300 zx tt swap
- Need a side rear quarter panel glass.
- 300zx wheels and rain
- Lack of power
- Car won't start...
- Finally
- My Car's Got Mugen
- can a worn dist. cap/rotor cause poor low end torque and bad fuel econ?
- CAR GOT TOWED (long)
- head lights out help
- tailight help
- Happy Birthday antonthegrey (and others :))
- Pedals?
- Uneven tire wear
- Where is the thermostat?
- 93 GXE for parts or whole
- 4 wheel disc brakes and no ABS?
- Auto shipping- can anyone help me out?
- Siphon Fuel Tank
- Problems...pls look!!
- Tiiming belt square or round teeth?
- Which manual tranny can I use for a swap?
- Cams
- size of clutch line
- 1993 GXE for sale parts or whole
- dual tip
- aadco anti-sway bar problem
- who has this sticker on their window?
- fuel injectors
- My max and I have parted. Goodbye all.
- dying bell?
- Digital AC conversion
- disable car alarm
- write-up on 5-speed conversion (can't seem to find it)
- Oil leak on a vg
- Front Strut Tower Bar
- i am major stupid, exhaust studs.
- Overcharging
- Y-pipe???
- Timing belt kits?
- coolant leaking on 93 gxe
- OK NEED TECH HELP ... Big Swap ..
- Better Gas Mileage?
- auto gearlock on/off problem
- Where can i buy a timing gun?
- will a .40 off set fit under the wheel wells?
- production year - model year crossovers
- Need Advice... Tranny swap?
- Quick tool question
- 1-2nd gen intake.
- Maxima Troubles
- Question: Clatter sound at 1,000rpm in park
- Fuel injectors and fuel injector cleaner, do they work?
- Fuel Type question
- How well documented is your Max?
- "power" light
- Wheel Bearings
- Hatch-wagon concept
- ve30de underive pulley...where2find?
- VG30 engine questions
- who has the intrax/tokico setup?
- Its a long shot: anyone know where to get/have cefiro grille/steering wheel?
- Random questions/ideas
- Upgrade Fuel Pump
- Those VEer's using the Yota filter. What have you
- Engine code P0172
- Hard to start when cold? (irratic idle too)
- Need thread on how-to install start button feature
- 94 maxmia alarm
- Transmission Question
- bad scent at 60mph, 2900rpm
- 0-60 time for stock ve 5sp
- what type of gas for 91 max
- Engine question for VE30DE
- Oil filter question
- Wierd Auto Tranny issue (again)
- Rear brake question
- Got my max fixed, yay
- why didn't anyone tell me! ve and vg rear brakes arent the same.
- Power steering Squeal
- alternator
- Oh dang. Wheel/suspension noise. Squeaks and groans.
- Top speed limiter? and oil leakage
- Rims
- compression
- 93 GXE Timing Belt
- Will your 2005 Tax Return go towards your Max?
- maxima language
- 91 max ..will not start distributor ?????????
- How do VG Maximas sounds with performance exhausts?
- electric question should i add a fuse?
- Wobbly Rotor...i think
- Steering wheel
- Strange happenings....
- knock sensor question
- Installed my 350Z dead pedal to match my AE pedals
- relay question for radiator fans
- Doors unloks by emself and weird smell in vents
- Tranny leak.........
- Pacesetter Headers Compatible w/ WSP Y-pipe?
- Speed sensor..
- NOLOGY Plug Wires?
- Power Windows
- 5th gen swap in a 3rd gen? What's needed to be done?
- Car won't heat at idle?
- Harsh Shifting please help
- KYB GR2 strut life
- i really messed up my maxima...
- Temperature going crazy....
- Value Clicking Noise
- Suspension drop pictures and advice
- Climate Control Removal...
- Which motor do i have?
- Question about seats
- Finally got the pics
- engine seizes and quits
- Clunking Into drive still
- Underdrive pulleys(where, how much, how?)?
- Cv Joint
- 3rd 4th and 5th gen seats
- help with 5speed
- Car is now always running like it's cold??
- Max Smoking Badly -BLACK
- Tranny Curiosity
- Check out this!
- 3rd gen vs 4th gen
- Keep and mod my VG or go for a VQ35?
- Easy way to shine up your engine
- Frozen Rear Suspension?
- how much
- Performance upgrades
- Speaker modifications
- weird
- considering purchasing a new hu and speakers....
- does any one else get this many miles on a tank?
- Autotragic finally died
- Car not heating up...
- Installing Injectors.
- weird problem with the max
- Door Sills???
- bolt extraction
