PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. inflating tires having to do anything with steering problem?
  2. Any hope....
  3. Crankshaft Pulley bolt torque?
  4. Vq supercharged 3rd gen?
  5. ignition cylinder is dieing....
  6. 4th Gen Seats?
  7. metal portion of powersteering leaking can I replace with rubber??
  8. KYB GR2....Opinons?
  9. my swap parts are here
  10. 4 gen shifter in 3rd gen?????
  11. Help, mystery fluid leak.
  12. Failed Emissoins, just passed!
  13. New Car!!(Pics)
  14. car sputtering bad... sometimes stalls out.
  15. Clicking from shifter- now brake lights don't turn on?
  16. Rev Matching
  17. Installing under dash lights?
  18. Turbo question
  19. Heating Problems/aceleration
  20. Difficulty: 93 ve manual INTO 91 vg auto
  21. Car does not start in rainy weather..
  22. Replacement muffler suggestion- 94 gxe
  23. clunking from drivers front tire area...
  24. 93 Max totalled gently last night
  25. Question about door lock problem
  26. 5spd is whining
  27. installing 4 new brembo rotors need help
  28. How to fix broken lugnut stud
  29. Surging idle problem, need some advice/confirmation
  30. crankshaft pulley removal
  31. HELP alarm trouble!!!!
  32. locks
  33. starting problems
  34. why does exhaust manifold rattle only during acceleration?
  35. exhaust tips
  36. Another check this out...
  37. won't start - afraid timing is off?
  38. Remote starter on GXE?
  39. 5peed gone?
  40. new car possibly???
  41. acc video of my turbo vg tell me what you think
  42. Happy Chanukah! to all
  43. a little shot of my boost gauge
  44. So what did Santa leave at your house?
  45. Figure this one out.
  46. Keyless entry install ! Help!
  47. What if you get a code 55 and your car still doesn't start?
  48. K&N Cone Filters
  49. quick question
  50. inflating tires
  51. Check this out!
  52. Merry christmas 3rd gen group :-)
  53. push starting a stick shift
  54. i might be a 3rd genner soon (hopefully)
  55. best way to clean out k&n cone filter?
  56. Splash guard
  57. Transmission oil...Qty
  58. what are these (HELP!) (pics)
  59. Any suggestions for seat covers?
  60. Hitting a really big puddle could short out the alternator....right?
  61. Radiator fans?????
  62. Crank Sensor, Cam Sensor
  63. Lights Flicker, slight vibration
  64. Conventional Motor Oil to Full Synthetic
  65. coolant reservoir
  66. Stock Fog Light Question
  67. manifold cleaning
  68. flywheel question.
  69. cool e 36 brackets
  70. pcv valve location (VG30E)
  71. Do you put car parts in the dishwasher?
  72. locked out of my max.....kinda
  73. Dash Lights out?
  74. Power Steering Removal
  75. 12/21/2005: Never Forget!
  76. Alarm led hook up to where?
  77. 5 studs broke off my wheel...
  78. VTC repair kits
  79. Car engine sluggish and RPM dropped.
  80. brake fluid (for clutch)
  81. Wiring up my trunk...pics
  82. weird problem help!!!
  83. Electrical Problem.& Power sterring
  84. K&N Air Filter
  85. 5spd swap
  86. stupid question..
  87. Strut assembly
  88. VG tranny to VE swap
  89. !!!! need help, possible max for sale
  90. Toyota V8 Oil Filter
  91. I want a new one now.
  92. Motor Mounts
  93. saying goodbye to maxima fam
  94. Location of Door Locking Relay
  95. 3rd times a charm - working speedometer!
  96. y pipe question
  97. Homemade midpipe pics are up:-)
  98. What the "Electron bat"? And door relay?
  99. I need some fast answers concerning wheel fitment...
  100. somebody hit me wtf
  101. Bored so I took some pix of the dirty maxima
  102. Flat black max
  103. ANything extra to know before changing trans oil for 1st time?
  104. Thermostat change
  105. Light output from E36's
  106. Car sits crooked
  107. VIDEO of my max accelerating after a Y-pipe install...
  108. 9007 headlight bulbs on 3rd gen?
  109. why is my shifter loose.
  110. 3rd. Gen Coil Packs (New) GD
  111. There is another Way of Modifying the ECU Come IN
  112. Intake swap question....
  113. Stick that turns on lights,brights and blinkers...
  114. Matt or other manual tranny experts
  115. Who sells VG UDP?
  116. Oxygen Sensor
  117. Alternator...
  118. Need some help guys
  119. Gasoline odour in the cab...
  120. drive belt pulleys
  121. Finally pulled my blown VE apart today...
  122. VQ35 Swap Ideas
  123. 93->90 better parts?
  124. crappy start.... tps??
  125. Metal Steering Column
  126. How to remove 3rd gen rear seats?
  127. no. 6 goes after warm up
  128. Blue Clock Mod
  129. Steering Problem
  130. How much would it cost the get a brand new 3rd gen?
  131. Oil leak found, now she's ticking....
  132. Passenger side transaxle oil seal
  133. Starting Problem
  134. air conditioning drain
  135. Seatbelt Info
  136. The Power Steering Pump Project
  137. Digital Climate control
  138. SOHC Cold-Air Intake?
  139. Car idle rough
  140. Need wiper links for 92 MAX SE
  141. stuff to get
  142. the holiday spirit
  143. 89 Max not running!!! Help!!!
  144. Power Steering Pump
  145. Q45 caliper+caliper bracket+rotor test fitted
  146. Anyone 'wrap' their Y-pipe?
  147. Broken Crossmember.....has this ever happened to you?
  148. Need some quick advise
  149. Passenger side CV AXLE
  150. 92 SE or Fix mine
  151. Hood Struts mod
  152. what is it?
  153. wanna see something funny ?
  154. another wonderful problem
  155. slightly confused with max today
  156. Anyone
  157. Reverse glow gauges??
  158. THIRD GEN car model...
  159. Help! Daily Driver Messed Up
  160. ShopKey by Snap-on
  161. wow... long time no see!
  162. Ticking sounds
  163. How much is left??????
  164. Anyone have a MT laying around???
  165. Found a replacement auto tranny but...
  166. color code confusion
  167. After market muffler??????
  168. Yarh!!! THATS MINE!
  169. I almost died..well not really but could've (pix inside)
  170. how to tell if i got a bad wheel bearing
  171. Inner wheel wells
  172. Is 4 month old stainless steel muffler supposed to be rusted like that? 56k warning
  173. when does maf max out?
  174. Oil filte doesn't fit... has this ever happened to you?
  175. how to put the rear trans mount bolt (PIC)
  176. Heater Problem
  177. Starting Problems
  178. Stock (OEM) Springs
  179. tail light conversion
  180. some help ( quick quetion)
  181. Simple no-start
  182. questions abt a jdm transmission
  183. Whats the best tint % for a maxima?
  184. gas leak?
  185. 93 wont start
  186. Adding alarm Blinking red light
  187. Wierd turn signal and headlight problem.
  188. Header question
  189. 357 miles on 1 tank of gas
  190. 3rd Gen feat. in Hemmings Sports & Exotic
  191. cars getting worse fuel economy
  192. VG-VE Speed Sensor
  193. Mechanical rapping
  194. Max running like crap!! Please Help!
  195. Jumpy Speedometer?
  196. Cold weather or worse?
  197. the rust recall epic
  198. Headlights
  199. Transmission problem...?
  200. wheres the guy who went 12.5 in a 3rd gen
  201. 92 SE Gauge Cluster on 92 GXE?
  202. addco sway bar... bolts undoing themselves!
  203. Best place to get injectors and my blower is stuck on!
  204. 5x114.3 lug, can i get a hand
  205. Do not accidently post in the 6th GEN section.....
  206. Quick question
  207. dropped tranny??? somone help
  208. More Pics
  209. Jdm Origin
  210. My $50 max
  211. J30 Brake conversion
  212. Need Help: Axle replacement on 94 GXE Auto
  213. Replacing Driver axle seal
  214. took 18s off rockin some 17s
  215. power steering noise....
  216. ignition coils
  217. car running very poorly, please help
  218. Changing out keypad
  219. wiring diagram for swap
  220. Silly computer Q.
  221. Out of sight, out of mind.
  222. natural to smell antifreeze after spilling some in the bay after hose replacement?
  223. weird speedo problems
  224. Vansskaterfreek's axles don't fit thread:-)
  225. Pics of two of the triplets one year later
  226. 'so is smoke SUPPOSED to be billowing out from under the hood? 0_o'
  227. I really really miss my max...
  228. amount of fluids..
  229. Are these sprints spring or what are they?
  230. Rear Window not working?
  231. Third Gen Insurance ...HELP!
  232. Injector dots
  233. Steering sticking - could it be a bearing?
  234. Cat + b pipe
  235. Gas overflow vent hose repair
  236. replacing water pump on ve
  237. High Idle/Surging
  238. Suggestions For A Pillar Gauge Pod
  239. Tough decision
  240. Valet Key
  241. The following does not work; is it related?
  242. Digital Climate control degree change
  243. A/f ratio gauge
  244. nitrous in max
  245. Sweet headlight trick!
  246. what happens when you are being dumb on a public street
  247. Stupid, Stupid Nobb Question......
  248. About to replace my IACV...
  249. Can we use anything off of a J30?
  250. and the swap saga continues......
