PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. Well this might be the end folks
  2. anyone with a junker want to try this?
  3. Weird Hesitation Problem???
  4. Umm...Big Problem!?!?
  5. Brakes making loud moan when stopping
  6. Brake Job
  7. Do you get better mileage with better gas or is just good for the car?
  8. Green vs. Yellow Marking for 93, 94 Injectors
  9. Somthing Wrong
  10. fallen windows glass
  11. Putting a VG into a VE...part 2
  12. Great Day With My Max
  13. Gas
  14. How do you install a tranny cooler in the max?
  15. Heat / AC issue
  16. Sea Foam Question! Help
  17. maxima nightmare...literally
  18. 300ZX calipers
  19. tranny shifting weird
  20. Any Swap Mechanics in or around Southern MA?
  21. PITA oil leak
  22. Help! Lost Key AT locked
  23. lower controle arms
  24. going rate?
  25. SE Stock headlights
  26. changing foglight bulbs help
  27. so i turned my max into a drift machine...
  28. pulling the tranny today
  29. Transmission Rebuild VS Used
  30. .org stickers?
  31. FSTB worth it?
  32. nissan's prices
  33. Decent Price?
  34. road rage
  35. need to paint bumper
  36. Thoes dang yellow lights on the chevy's
  37. Problems started last week
  38. 93 with 84k - $5,950
  39. intakes?
  40. What is the sealing factor in the AC parts?
  41. To all that have done the TB bypass.......
  42. Clutch
  43. any break in period for new clutch?
  44. Two Quick Questions
  45. c foam
  46. orger's in katrina's path...
  47. Odd Hesitation
  48. VGDET heads for a VG30E?
  49. hesitation....help
  50. Exhaust on a budget
  51. Flushing cooling system
  52. starting/power issue
  53. Replaced front wheel bearings-saved $400
  54. help removing permanet bird dropping stains...
  55. PVC valves and cussin'
  56. M.I.A.xima
  57. Quiet "chatter" in 5spd transmission under stress
  58. door hinges
  59. oil sump
  60. How many gallons per gallon?
  61. Question about antenna drain
  62. Stuck on the side of the road HELP!
  63. Injen CAI for 3rd Gen only $5000 !!!
  64. VG30 Timing Belt Replacement
  65. Oil Leak that Opec would hate!
  66. headers???
  67. wsp vs. greddy from the cat back
  68. People That Bought Tokico Struts
  69. WHat Mod To Buy
  70. Should I replace the starter
  71. Need source for radio mounting bracket, etc.
  72. Rear parrell link bushing kit. Worth it?
  73. i need a 1992 fsm
  74. 247.4bhp?
  75. got the timing belt done....
  76. lots of problems lots of money
  77. What do you guys think? (pictures included, 56k welcome)
  78. Cars missing, stumped!
  79. lost power
  80. So I thought I got a steal CONTINUED....
  81. Looking at 3rd gen
  82. How to set VE30DE timing??
  83. problems with slave cylinder after installing new clutch
  84. wipers only work in one speed
  85. Can anyone put up a picture for Speed Sensor?
  86. E36 lights help PLEASE!!!
  87. Best way to remove old Gasket...kinda urgent!
  88. iacv location?
  89. Putting a VG into a VE...a few questions
  90. Fuse and brake light problem
  91. Just replace the o2 sensor and KS?
  92. break grinding
  93. Found Some Rust(pics)
  94. heater hose or core broken?
  95. Tach is possessed!!!
  96. Horn Not working
  97. Brake Question
  98. What a bummer
  99. Question on Steering Linkage
  100. VTC's and oil type
  101. Stiff Brakes!! What do I do??
  102. Motor Oil
  103. ve trans mated to vg, a few problems
  104. What to use for winter wheels
  105. Just thought i would share!!!!
  106. Weird starting problem
  107. Otto Bar.. Me likey likey!!
  108. Looking for someone/shop to fix the broken manifold stud on 93 GXE
  109. weird tread ware on my 91 Max
  110. Wiper Help V.2
  111. need help on removing wax on door moldings and stock spoiler
  112. strut tower deterioration
  113. Might buy a 93 that threw a connecting rod
  114. Soo i have been busy with the grill pictures and others
  115. Fog lamps
  116. Aftermarket gauge users.
  117. who sold their se?
  118. Just got my OTTO bar in,, any advice??
  119. VG intake
  120. Hesitation & surging - then CEL came on
  121. stupid *** sunroof
  122. repair woes
  123. ECU dying?
  124. what's wrong with cardomain?
  125. Hella Supertones installed - See how
  126. Advice on buying 93 SE
  127. Why does this so not look like mine??
  128. All windows quit-resolved!
  129. Need help with Rack and Pinion R & R on my 90 Max
  130. need the FSM
  131. Engine rebuild
  132. tranmission problem
  133. Door Lock Actuators (89 SE)
  134. plug cleaning
  135. My VE(many pics - beware 56k)
  136. If you are scared your heater core will die and leave you stranded, please read -->
  137. weird el. problem. Wiking may be.....
  138. Shifting at high RPM
  139. Water Pump Replacement Instructions??
  140. professional service stress
  141. shaking and high whine
  142. luk clutch
  143. spoiler
  144. HELP! VTC problem!!!
  145. I'm about to give up on Warpspeed
  146. Problem with Wipers
  147. cooling fan problem!!
  148. Parts Source - Manifold Studs?
  149. getting new clutch
  150. Racing Chip
  151. Replaced the injectors, do I have a bigger problem?
  152. Ignition Coil soaked in oil!
  153. very weird problem
  154. Flippin window!
  155. a/c recharge question
  156. All windows quit
  157. Anyone with wiring diagrams?
  158. has anyone else tried this on ve intake
  159. Electrical problem with my new VE
  160. My parts car tried to kill me!!
  161. plz don't say this is a stupid question...but...
  162. My upholstery saga continues ...
  163. So I THOUGHT I got a steal....
  164. Dead MAF... quck question...
  165. Door Locks
  166. Parts Gurus, HELP!!!!
  167. Where to get O2 sensor?
  168. Lighter Flywheel for Auto?
  169. Rainy day weird electric droplets
  170. Rims
  171. Maxima Commercials
  172. underdrive pulley
  173. Air box Vs Cone filter
  174. Cheap suspension mod?
  175. NEW PICS Check out the car
  176. 1st Axle Replacement - Front driver's side
  177. Ahhhhhhhhhh...........A/C!!!
  178. whats it worth?
  179. Some updated pics
  180. HELP- 5 spd tranny problem! shifting out of gear while driving.
  181. Those with HIDs help me out
  182. How much for parting?
  183. Crap again! Now my driver's side window won't go back up
  184. Ignition coils in a certain order?
  185. Electronics, one more try
  186. Need your opinions....SE or GXE Wheels
  187. Must be a record
  188. i LOVE my vg (broken timing belt)...
  189. Mounting 7 in Microvision
  190. Instant RPM rise
  191. Brake pedal for conversion
  192. Took some pics after i used a clay bar...
  193. where to find bushings
  194. HELP! Where to lift VG engine??
  195. Well crap. I can't get the driver's door open.
  196. New Grill, New Pictures
  197. Rotor button
  198. VG on hold, let's talk cams
  199. low fuel warning indicator question
  200. Clunking noises while driving
  201. Got my new 3rd Gen!!
  202. i need your opinions please!!!
  203. Steering Rack Replacement
  204. for those of you with 5spd trans
  205. ITT I search for you :o
  206. Sudden bad gas mileage?
  207. 92SE A/T shift kit
  208. VE30DE Header flanges
  209. Blank factory keys
  210. Axle Replacement
  211. Stock Rim question
  212. Body work
  213. Can you guys help me with this error #32
  214. It's gotta be the switch right???
  215. what are VTCs?
  216. help with addco sway
  217. Car Domain site thought
  218. New clutch ideas
  219. Window switch just broke-help!
  220. Engine won't start
  221. Can I change out the key locks???
  222. Ordered from Warpspeed?????
  223. Lock doesn't go all the way up.
  224. Where can i get a JDM engine?
  225. Check engine + Oil lights lit with removed key
  226. $1,094 = what I paid to fix....
  227. Transmission Problem: Auto slipped out of gear
  228. window problem
  229. Finally the suspension is on! Freshly washed pics.
  230. recent fix
  231. need help!!!
  232. Advice on install and performance tracking...
  233. 92 VE which one is the IACV
  234. What are the wires going to the battey?
  235. another temp gauge prob.-long
  236. Where is the Speed Sensor located?
  237. Clutch time again, need a fianl solutiuon.
  238. The ticking time bomb just went off....
  239. Replace Transmission or Not?
  240. mods, please dont erase.
  241. gas smell
  242. Driving the un-modded car
  243. After alignment problems...
  244. What is the trans code of the VG trans
  245. some advice
  246. The Car stalled when braking too hard
  247. Stubborn Exhaust Manifold Stud...pic
  248. exhaust leak fix, it really works!
  249. broken speedometer
  250. ECU PINs
