PDA
View Full Version : 3rd Generation Maxima (1989-1994)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159
  1. brakes stuck on
  2. So i need a new clutch, need help
  3. Pulsing coming from front left wheel not CLICKING
  4. New dual exhaust
  5. Rear center piece
  6. 94 gxe tranny, oh no!
  7. Indiglo Gauge Wiring Question
  8. installing clear corners...
  9. Comfort/ Power Switch?????
  10. eratic shift when approching overdrive speed
  11. This Piece Of S**t Car!!!
  12. My Car Domain site is now up
  13. Green 194 Bulbs
  14. swappin' engines
  15. Bose cd/cass combo upgrade question?
  16. Early 3rd gen tranny problem's?
  17. Y take down with no search? swap 300 turbo
  18. Regular MPG?
  19. ABS Actuator Assembly (I think
  20. grille tech grill
  21. 89 taillight
  22. Ready to buy 92 SE 5sp, good deal?
  23. Oil filter analysis
  24. Anyone whos dropped their car
  25. Lowering Springs for my Tok's
  26. '89 Max with 333K+
  27. Over 530,00 miles....
  28. 92 Max Trim Question
  29. 4 words
  30. Got my OBX exhaust jacked last night.............
  31. Castrol GTX
  32. Dash lights...
  33. need help!
  34. rims wo/ drop
  35. p/p heads? would these fit? check them out
  36. Manifold
  37. tick tick noise high speed...
  38. exhausts
  39. 1989 Maxima - What should I check out?
  40. Transmission temperature
  41. squealing noise (94gxe)
  42. Turbo swap from 300z?
  43. custom work
  44. jumped the gun
  45. port and polish intake manifold and TB on a VG
  46. Emergency Break and ECU
  47. brake issue!
  48. 17"s or 18"s on a 3rd gen?
  49. Clutch?
  50. disc quality : Raybesto,, Aimco, Mountain
  51. Bye everybody!!
  52. Cruise Control
  53. maxima engine in rwd mustang
  54. who would be interested in corners from UK?
  55. comfort and power switch light
  56. 92 leaking oil
  57. 17s & 18s HELPPPP!
  58. what to do next??
  59. Door Bulbs/ Map Lights/ and Overhead
  60. TV Instructions
  61. A New VE 5SPD Owner, Good Buy Old Reliable
  62. straight pipe vs. catalytic converter
  63. 3rd gen appeal
  64. Matt's Mod of the Week...
  65. My website w/pics...what u think?
  66. Quick boot (Quick CV Boot repair)
  67. car sputtering occasionally....
  68. Comments on Warpspeed Exhaust??
  69. Tokico shocks/Struts with existing Springs
  70. WindShield Wiper Blade Size?
  71. anyone tint their own windows?
  72. '93 radio problem
  73. Warpspeed Y Pipe
  74. injectors
  75. Question about offset for 18" rims
  76. 3 ve 5spds on ebay right now
  77. O2 fuse blows engine dies
  78. my 1990 nissan max needs a face lift help!
  79. Exaust Leak
  80. Cost to Fix CV Joints...
  81. Replacing gauge cluster in '91 SE
  82. my dead leather
  83. limited slip
  84. Is this the diagnostic harness?
  85. Air conditioner
  86. 92 se 5-spd
  87. drain plugs
  88. Figure out this sequence of events
  89. is this ok for a VE auto?
  90. Choking max..same problems as others
  91. Is it oil a good treatment
  92. Shocks and Struts I need em Bad!
  93. exhaust problems need help
  94. How much Pressure???
  95. What is ASC? (93 GXE)
  96. stock height compared to se vs. gxe
  97. VE pistons in a VG?
  98. What susp. setup you running?
  99. Amp rack
  100. Car is freaking out...help please.
  101. Please help, need to know a difference between model taillights
  102. Car got Broken into - Broken Quarter Window
  103. shift lock
  104. Bose Radio Amp Expertise Needed!!! 1991
  105. ordered everything....
  106. coil-overs?
  107. Problem When Turing On Lights
  108. Manifold Studs
  109. air bag inspection 10 years
  110. WARNING: Rusty Seat Belt Mounts
  111. Tempermental Starting Problem
  112. Locked keys in car while running
  113. 3rd gens bought new
  114. Search Disabled, Quick Question
  115. suspension recommendation please...
  116. Please Help An Idiot! Thanks!
  117. suspension question
  118. Request for 194 bulb/LED pics
  119. Location of ECU
  120. planning to replace bose hu and speakers
  121. anyone know how to block the EGR
  122. Brake cables 89 maxima
  123. Manual Transmission Swap Update.......
  124. timer control unit
  125. drum to disk brakes.
  126. Diagonistic Test
  127. Regulator & Motor Questions...
  128. Optima Yellow Top
  129. Alternator Replacement
  130. Rust!
  131. Repetitive Bumping Noise
  132. 16's on a Maxima 3rd Gen
  133. DIN location?
  134. Some Updated Pics of My HID's
  135. The Max is going in for brakes tommorow...
  136. Need some help
  137. Power Locks
  138. Wings West body kit
  139. Keypad!!! I need some help
  140. when it rains my max gets smokey
  141. help me out
  142. Cracked Manifold??
  143. SE swaybar Vs NonSE swaybar
  144. Engine runs different everytime the car is started up?
  145. springs and struts
  146. Center Console - electronic climate control
  147. time to say good bye
  148. door hinges
  149. wont start
  150. My wierd problem -spontaniously gone away?
  151. Overdrive questions
  152. suspension
  153. Ground Effects Needed
  154. gas mileage and other quick Q's
  155. buying a max, 92 se 5spd.
  156. Please Help me with this electrical issue
  157. tranny swap??
  158. those with parts cars
  159. Alarm not dis-engaging
  160. 92 Se...h I D
  161. Body Kit
  162. Rebuild or not to rebuild?
  163. Cup Holders
  164. Anyone ever seen/used this oil filter?
  165. Excedy clutchs compared to OEM
  166. car covers
  167. 92 SE Exhaust Question
  168. Old looking paint...
  169. Do They Make CARGO NETS
  170. Clean throttle body?
  171. keypad operation???
  172. o2 sensor and power
  173. Taking out the Digital Climate Control
  174. Auto - 5speed swap
  175. won't shift out of second?
  176. IS it possible for the ECU to retard the timing?
  177. passenger side possessed!!
  178. fuel system
  179. Do you have Leather, Cloth, or Tweed interior?
  180. manual transversion
  181. 245 will fit an 8" wide rim?
  182. Wings West
  183. ported throttle body
  184. Eyelets
  185. best way to begin
  186. WTB driver window switch..
  187. front subframe brace
  188. weird problem with 92 se
  189. What The He//..... Help Please.........
  190. Quik question on checking distributer..
  191. Might Be Old Just Looking For An Answer
  192. 2k2 muffler
  193. Custom Panels, Tell me what you think?
  194. Catalyic Converter Gone Bad,Why?
  195. Wipers
  196. My injector tested out of spec... now what?
  197. im back with a wierd problem about counting mileage
  198. Indiglo Guages
  199. Speed Sensor
  200. Struts
  201. spark plugs and wires
  202. gas related issues
  203. To Buy A '93 W/ A Bad Tranny?
  204. Overdrive questions that goes along with my dying transmission........I think
  205. lock problem
  206. Would it be ok to changethe timing on almost stock VG?
  207. 30 mile drive and stalling...!!!
  208. Y Pipe
  209. Automatic transmission filter?
  210. My poor baby...
  211. Tires
  212. heat is an issue also..
  213. Power window help needed
  214. Alright this crap has got to stop!!!!!
  215. Center wheel caps (4) needed for '94 GXE.
  216. story
  217. Another Transmission Question!!
  218. Replace Tie Rod "94 GXE
  219. BMW E36 Headlights(Need Help)
  220. The unsolvable problem on the car...
  221. A note on the PCV valve and good engine idle
  222. my max is dead
  223. ABS lights keeps coming on and killing my battery
  224. Aaarrrrgghhh!!!!
  225. Description of VTC Function in FAQs is Lacking
  226. Rubbing compound -alright to use?
  227. removed door trim....now sticky goo, how to remove?
  228. smog check
  229. idle's high
  230. Pics?
  231. Turbo swap - HELP!!!!
  232. What do the coils look like?
  233. Anybody have In-Dash TV plans?
  234. anyone been able to find this....
  235. Question fro the experts
  236. Key broken in the door.. how to get it out? Help
  237. sirius
  238. rims and tv
  239. Pics around oil pan
  240. Idling higher than normal
  241. Speedometer
  242. Tach jumps around, then works, then doesn't
  243. Window Access from Keypad..
  244. does a 92 se have a distributor?
  245. Speedometer (odometer) went out. Help
  246. Transmission Troubel
  247. 92 SE is stalling
  248. A couple of questions
  249. Best wheels & tires?
  250. Low Speed Misfire? 94 GXE SOHC, AUTO
