- brakes
- 5spd Swap Update
- Looking for info - wife bought a 1994 Maxima with out me
- BUYING a Thermostat
- KYB vs. Tokico
- 90 GXE won't start after rain
- need help
- Fuel Injector Cleaner or Not
- Error code 34-Detonation sensor-where is it?
- finnally got my 19s on my 3rd gen
- Bosal Muffler & Cat follow up
- Maxima and 626
- RWD conversion?
- How long does Ebiach & Tokio combo last?
- Chris91SE Missing??
- Well, the UPS guys drop some rims off yesterday, now i have some tire size Qs..
- Rislone
- msd box
- is there a place to buy the stillen body kit cheaper than stillen.com?
- brake rotors ????????
- Those with Subs, where did you run the wire through the firewall to the amp?
- hi new, and many problems... help!!
- Knock sensor gains?
- 92 Project Car - Windsheild Leak Found and Fixed
- I got two problems, both electrical
- 92 Project Car - Update for 2004/07/22 (Dialup beware!)
- a/t harsh shifting
- Radiator Flush?
- Venom 400 Module
- Auto Tranny Issue - Surprise! Surprise!
- Distributor
- Wheel spin
- So I had an idea...
- Is it my window regulator?
- Good site - overview of perf mods for VE30DE
- Preserving life
- rough idle
- timing chain or belt
- Where can I find parts
- Suspention Problem/Question
- Help!!
- Brake bias percentage(proportioning valve)????
- quick when cold, slow when warm
- fuel injector confusion???
- Unorthodox UDP for VG
- had some spacers made
- TEMPERATURE rising on hills
- Crazy AC problem in 91
- Horrid Squeal from the front right wheel area
- O/d
- Looking for a sunshade
- Transmission Problems
- 2 noob questions
- Skyline Project Countdown!!!!
- Muffler question
- What the hell is wrong with my 90 GXE!!!??
- Auto tranny experts post here.........
- 92 Maxima Engine Swap
- problem with my 3rd gen max
- resetting electrical problem
- Need Recs for 89 intake/suspension
- im a noob i know
- free tach voyage
- Silverstars and XD5 pics
- White SE Guages
- Recalls Suck...
- I Saw A Commercial Last Night.........
- rear wheel bearing assembly
- Will a 200sx strut brace fit my ride.
- hesitation/stalling, those who fixed it please post!!!
- Splash Shields... can we run without them?
- e36s -- differences?
- Emergency break handle tightening
- Customizing a subwoofer box
- comparing vg30deTT to ve30de engines
- HELP please, Maxima keeps cutting out...
- Noise in front suspension
- Price I should pay for a 91 se auto with 45,000 miles all org?
- those who got their car painted, how much did it cost you?
- R-33 Tailight question
- CAI How To?
- Oil Pan Gasket
- Loosing power what now???
- need help
- TPS Adjustment
- Where is the PCV? How hard to change plugs?
- Head Gasket
- Interior Swap...
- Leaking oil between engine/trans...
- Ever annoying clicking sound
- Spring QUestion
- Finished removing the side moldings....and washed/detailed today!
- Thread pitch on O2 sensor
- Major Problems....a little long.
- whyyyy
- About BMW E36 Conversion the Projector Lights kind
- Which Brake Pads Do You Prefer??
- help wiring problem
- Wheels smokin!!
- Screeching Noise
- What do you put your's in?
- will 95-01 manual tranny fit on VE motor??
- Suspension Woes
- Painting old tails
- Turbo
- I suddenly have a Traction Control Light
- Grinding noise from rear brakes...
- Will be buying a 91 maxima sport edition sedan in 2 day with 44k miles.
- What is the normal idle speed in "D"?
- changing my brakes on my 91 GXE
- How fast is 4800 rpm in OD?
- need some power
- 4th Gen guy helping out 3rd gen gal
- Shaving Rear Emblem
- Help a new 89 maxima owner
- quick timing question
- Insanity it seems, Maxima-S13...
- Who has done there own head gasket replacement?
- leaving
- Testing Spark Plug Wires
- re: photo of muffler set up on a 91 maxima?
- help with door light and motor mounts
- Thermostat blown...NEED HELP ASAP!!!
- Noobie questions...
- dust guard
- Traded Max for Hardbody, what about engine swap?
- Oil pump leaking, what are my options/costs?
- Shaky steering wheel
- Lower Control Arms
- new maxima owner with some ????
- Best spark plug
- Need help with determining which sensor has failed (security system)
- Pacesetter Headers
- I finally got a VG turbo to mod instead of my VE!!
- How to check fuel pump/injectors?
- No Reverse
- 150k and wanna do maitnace to make her sound BEAUTIFUL
- fog lights
- HELP! Did I buy a bag of problems?
- Is this a transmission problem?
- HEADLIGHTS! (whistle) here boy!
- Brake Pad Problem
- need to confirm an idling problem after porting and polishing my TB........
- Got the new transmission in what next...
- Tuning up the daily driver (Nissan maxima 1990)
- Noob question what kind of maxima do I have?
- Crazy Tachometer...frog in car
- Question--I'm Painting My Bumper
- Trunk Lock Sensor?
- ok, heres the deal...
- changing the pressure p/s hose!
- Engine Mounts
- Clicking when starting
- I'm going soft with age
- What about the TRANNY!
- Stupid slow starting
- few question
- new o2 sensor
- Brake Problem?
- window problems
- In the middle of manifold stud replacement..
- 240sx wheels
- Spedometer and odometer aren't working please help!!
- jacking points
- E36 Headlight Help
- Swapped from AT to MT and car won't start... HELP!
- VG30E to VE30DE
- Suspension Squeak?
- Help my maxima just quit!!!!
- Testing Coil
- A/T hell
- TurboXS RFL BOV
- Help! Hit Curb! What Is Wrong?
- 2" drop on shifter
- NGK.COM for O2 sensor?
- what are better lights?
- 130xxx
- Removing the factory tape unit...
- Misfire problem...help!
- Help my car sounds like its from the jetsons!
- Getting new keys...
- I think I'm missing something(body related)
- Tranny cooler
- Updated site - pics of my new black Max
- Custom grill with BMW headlights - update
- Next Level Performance
- Jet performance chip vs. JWT
- Control Bushing
- Just Put on used body kit
- ve 5-speed drain plug
- lightend flywheel ?
- Supension Max Gas Struts For 89-94 Max's...?
- are the trannys that drive the VE the same found in the VG?
- Well...this might be goodbye...
- Stalling problem?? clogged catalytic?
- Is it possible for timing to jump in a vg?
- door molding question....
- is there a point?
- sticky accelerator
- VQ 3.5 in 3rd gen?
- annoying rattle in my engine
- Performance Upgrades
- new guy with guestions
- My Alignment Readings
- bad mileage w/ new WSP y pipe
- My VE is lucky to be running right now
- Anyone ever replace their condenser?
- Painted Y-pipe and Cat
- AT Transmission replacement
- Whitish Smoke from tail pipe
- Timing Question...
- What should I get for brake pads?
- Cefiro Lights
- Wierd Problem
- timing chain tensioner
- Brake booster difference between ABS and non-ABS cars?
- Intake Bracket for Aftermarket Filter?
- Compression Question
- Lcd Clock
- Driver door hinges
- Fixed: FlexPipe, Alignment, AirCondition
- Looking for Matts Big Brake Kit
- Transmission Weirdness
- Want to plug a 95-99 bose radio into a 3rd gen.max
- how is EGR valve SUPPOSEd to work?
- Best Cap and rotor
- New... Story on my crazy max
- Gauge face
- Matt/Jeffy/other suspension whores :)
- my car is turning into a robot
- Bose speakers with after market headunit
- Code 12 (MAFS) Need help! Matt? Jeff?
- just bought used body kit
- faulty transmissions?
- some autozone clamps
- Nice webiste, all Nissan Maxima TSB's by year and TSB number
- Guys with Gauges, Normal Operating Temp Fog VG?
- power steering pressure hose
- Kind of Muffler?
- VE / VG exhaust poll........
- HP Boosters
- new power steering rack?
- speaker pods
- 112? 115? bolt pattern on a non center cap rim question
- 2004 wheels fit a 92 SE?
- stock fuel pump ?'s
- What do i need for an upgraded fuel system?
- checking a fuel injector
- auto trans questions
- Advanced my timing today
